- State of the gateway as reported by the cloud provider.
- Connectivity between Controller and gateway over HTTPS (TCP port 443).
- Status of critical services running on the gateway.
- The gateway and the Controller could not communicate with each other over HTTPS (443).
- The Gateway instance (VM) is not in running state.
- Critical services are down on the gateway.
- Examine the security policy of the Aviatrix Controller instance and make sure TCP port 443 is opened to traffic originating from gateway public IP address.
- Examine the security policy of the gateway and make sure that TCP port 443 is opened to traffic originating from controller public IP address. This rule is inserted by the Aviatrix Controller during gateway creation. Please restore it if was removed for some reason.
- Make sure network ACLs or other firewall rules are not configured to block traffic between controller and gateway over TCP port 443.
