| Speed | Gateway sends keepalive | Down detection |
| Fast | every 2 seconds | every 7 seconds |
| Medium | every 12 seconds | every 1 minute |
| Slow | every 1 minute | every 5 minutes |
Changing Gateway Keepalive Setting
To change the keepalive speed:- In Aviatrix CoPilot, go to Settings > Configuration > General tab.
- In the General tab, expand the Advanced section.
- Under Advanced section, in Gateway to Controller Communication, from the Keep-Alive Speed dropdown menu, select the speed.
- Click Save.
