Since Controller Version 6.8, DCF has been supported in AWS, AWS GovCloud,
Azure, Azure Government, and GCP.
Ranges
Supported Features
This table is the source of truth for DCF feature availability and release stage (Preview/GA) per Controller version. Other pages, such asFeature Classification , may reference the same features; if a stage or version ever disagrees with this table, this table takes precedence.The following are supported on AWS, Azure and GCP unless otherwise noted.- PV = feature is in Preview
- GA = feature is Generally Available
- If a cell is blank the feature was not supported in that release.
Additional Capabilities
- Overlapping IPs have been supported since Controller Version 7.0. Distributed Cloud Firewall (DCF) understands any defined SNAT/DNAT rules and updates the address for each gateway, enforcing the DCF rules.
- DCF auto-prunes all rules and pushes only related rules to specific gateways.
- SmartGroups dynamically change the resources inside the groups by tracking EC2 changes (AWS, Azure, GCP).
Shared VPC instance tags are not supported in GCP-based SmartGroups.
- Log Export to Splunk HTTP Event Collector
