Creating the ZTP Cloud-Init and Deploying the Secondary Edge Gateway (Megaport)
To create a highly available (HA) Edge Gateway, follow these steps.
Step 1: Gateway Configuration
Click Spoke Gateways
In Edit Edge Gateway, from the High Availability dropdown menu, select Active-Active or Active-Standby mode.
Click Next to configure the edge gateway interfaces.
In Interface Configuration section, configure the WAN, LAN, and Management interfaces of the secondary (HA) Edge Gateway.
Configuring the WAN Interface
You can configure multiple WAN interfaces on the Edge Gateway. Megaport MVE supports a maximum of 5 interfaces. Aviatrix Edge Gateway requires at least 3 interfaces (WAN, MGMT and LAN), additional two interfaces can be WAN interfaces.
This is set to eth0.
WAN support for BGP underlay to CSP is supported for AWS and Azure. Interface CIDR
The ASN of the Edge Gateway.
Password (optional)
The MD5 authentication key.
Configuring the LAN Interface
This is set to eth1.
Leave the Private Network setting to Off. In the Megaport Fabric, the MGMT interface of the Edge Gateway is assigned the Public IP address that is allocated by Megaport.
The cloud-init image file expires after 24 hours. You cannot download it again and will have to repeat the above steps to recreate the file. You must launch an Edge MVE on the Megaport platform and deploy the Edge Gateway within the 24 hours.
