Creating the ZTP Cloud-Init and Deploying Primary Edge Gateway (Megaport)
The Edge Gateway cloud-init ZTP file is used to provision the Aviatrix Edge Gateway virtual machine and create the Edge Gateway in Megaport Virtual Edge (MVE).
To create the primary Edge Gateway, follow these steps.
Step 1: Gateway Configuration
  1. In CoPilot, go to Cloud Fabric > Hybrid Cloud > Edge Gateways tab.
  2. Click Spoke Gateways, then click +Spoke Gateway and provide the following information.
    Identifies the edge location.
    See Edge site.
    ZTP File Type
    This is set to cloud-init.
    See Edge Spoke Gateway High Availability.
  3. Click Next to configure the edge gateway interfaces.
Step 2: Interface Configurations
By default, an Edge Spoke Gateway has three interfaces: one WAN interface, one LAN interface, and one Management interface. You can configure multiple WAN interfaces on the Edge Gateway, as needed. You will need these configuration information to configure the interfaces.
Configuring the WAN Interface
You can configure multiple WAN interfaces on the Edge Gateway. Megaport MVE supports a maximum of 5 interfaces. Aviatrix Edge Gateway requires at least 3 interfaces (WAN, LAN, and MGMT), additional two interfaces can be WAN interfaces.
  1. Click + WAN Interface, then provide the following information.
    Interface
    Adding multiple WAN interfaces is applicable when the Edge Gateway is set up for BGP underlay to cloud service provider (CSP).
    Edge Gateway WAN support for BGP underlay to CSP is supported for AWS, Azure, and GCP.
    Interface Primary CIDR
  2. If BGP is turned On, provide the following information:
    Password (optional)
    The MD5 authentication key.
  3. If BGP is turned On, in Gateway Configuration, enter the Local AS Number of the Edge Gateway.
  4. To add another WAN interface, click + WAN again and provide the required information.
Configuring the LAN Interface
To configure the Edge Gateway LAN interface, click + LAN Interface, then provide the following information.
Interface
  1. Click MGMT, then click + MGMT interface.
  2. Leave the default settings and click Save.
    Leave the Private Network setting to Off. In the Megaport fabric, the MGMT interface of the Edge Gateway is assigned the Public IP address that is allocated by Megaport.
  3. To create the ZTP cloud-init image file, click Done.
    Next, log in to Megaport and deploy the Edge Gateway VM instance and attach the cloud-init image file to complete the Edge Gateway creation and authentication with the Aviatrix Controller.
    The cloud-init image file expires after 24 hours. You cannot download it again and will have to repeat the above steps to recreate the file. You must launch an Edge MVE on the Megaport platform and deploy the Edge Gateway within the 24 hours.
Step 3: Deploy the Edge Gateway in Megaport Virtual Edge
