- In Aviatrix CoPilot, go to Cloud Fabric > Gateways > Settings tab.
- In Rollback on Gateway Creation Error, set the toggle to Off.
Gateways
Disabling Rollback on Gateway Creation Error
When an error occurs during a gateway creation, Aviatrix automatically rolls back all of the resources that was created during the gateway deployment process (elastic IP, storage volume, security groups, and so on) and terminates the gateway instance.
gateway instance. However, you may want to keep the gateway instance for
debugging purposes even when an error occurs during the gateway creation.
To disable rollback on gateway creation error, you need to disable this
automatic rollback feature.
