When enabled, the Controller checks if the gateway can reach the configured
VPC/VNet DNS server; otherwise, it returns an error.
For Transit networks requiring private DNS server, ensure the DNS server
remains reachable regardless of the network tunnel status.
Configure DNS Server for an Aviatrix Gateway
By default, Aviatrix gateways use the built-in Aviatrix Default DNS Server for their own hostname resolutions. However, Aviatrix also provides the option to use the Cloud VPC/VNet private DNS Server. To configure the DNS server for an Aviatrix gateway:- In Aviatrix CoPilot, go to Cloud Fabric > Gateways, click Transit Gateways, Spoke Gateways, or Specialty Gateways tab.
- In the table, locate and click the gateway name.
- Go to the gateway’s Settings page.
- Expand the General section and locate Gateway Management DNS Server. By default, the Aviatrix gateway uses the Aviatrix Default DNS Server. You can choose Cloud VPC/VNet DNS Server to force the Aviatrix gateway to use a private DNS server.
