All figures are the median encrypted throughput measured by Aviatrix across
test runs. Large Payload uses full-size packets, the figure vendor
datasheets commonly quote. IMIX is a blend of packet sizes that better
reflects production traffic, so size for IMIX. Figures marked * are burst
performance when operating within burst credits; see About Burst
Performance. Figures marked †used a different
test methodology than the rest of this page, and figures marked ‡ were
corroborated with an additional AES-256 test run; see the notes beside the
figures where they appear. Treat these numbers as planning guidance, not a
guarantee.
Quick Sizing
IMIX throughput per Aviatrix standard size, by gateway role. For Spoke Gateways with Distributed Cloud Firewall, see Performance with Distributed Cloud Firewall. Use this table to find a starting size, then check the detailed tables below.- AWS
- Azure
Choosing a Gateway Size
- Spoke Gateways serve the workloads of a single VPC/VNet. Small is the most commonly deployed production Spoke Gateway size across Aviatrix deployments.
- Transit Gateways are the hub of the fabric and terminate many spokes, so they need more headroom. Medium is the most common Transit Gateway size on AWS, and Small on Azure.
- The same instance type can map to different standard sizes by role. For example, on AWS a c6in.large is a Small Transit Gateway but a Large Spoke Gateway. The tables below show the size for each role.
- X Small sizes are for dev/test, not production.
Transit Gateway Performance
Measured end to end through a Spoke-Transit-Spoke path.- AWS
- Azure
Spoke Gateway Performance
Measured Spoke Gateway to Spoke Gateway.- AWS
- Azure
Aviatrix inspects traffic on the gateway itself; there is no separate firewall appliance to size, license, or hairpin traffic through. The following figures are for a Spoke Gateway performing NAT on egress traffic, with traffic exiting directly from the spoke (no transit in the path). NAT Only is the same gateway with no Distributed Cloud Firewall policy applied. Each cell shows Large Payload / IMIX throughput in Gbps.AWS
Azure
L7 inspection is packet-size sensitive: large-payload throughput stays close to
NAT-only numbers, while IMIX traffic pays a higher per-packet inspection cost.
Size egress gateways for your IMIX number, or scale out.
Distributed Cloud Firewall is supported on burstable sizes down to Standard_B1ms
for L4-only policy, Standard_B2s with external groups, and Standard_B2ms with
IDS or IPS enabled. See
Minimum Spoke Gateway Sizing
for the full matrix.
FireNet
When you insert a third-party firewall through Transit FireNet, end-to-end throughput is limited by the lower of the firewall appliance’s inspection rate and the Transit Gateway’s forwarding rate. Size the Transit Gateway one standard size larger than the size whose throughput matches your target, and consult your firewall vendor’s cloud datasheet for the appliance-side limit. The following figures are for the Aviatrix side of the path (Spoke-Transit FireNet-Spoke, end to end).- AWS
- Azure
About Burst Performance
Figures marked * are burst performance when operating within burst credits. Two kinds of AWS instance burst:- t3 instances earn CPU credits while traffic is light and spend them during bursts.
- c6in.large, c6in.xlarge, and c6in.2xlarge earn AWS network burst credits the same way. IMIX traffic on these sizes stays below the baseline and is not affected. c6in.4xlarge and larger sustained full throughput for the entire test.
How these numbers were measured
Aviatrix measured these figures on Controller versions 8.0 through 9.0 using
AES-128 encryption with HPE enabled (except where marked Non-HPE, and except
the Standard_D2s_v5 Spoke Gateway Large Payload figure, which also included
an AES-256 test run; see the ‡ footnote where it appears), with
CyPerf-generated traffic in a single region. Each figure is the median
throughput across repeated test runs. Burst durations are the longest burst
observed at full line rate starting with full credits; actual duration depends
on the credit balance when a burst begins.
