Platform requirements
Confirm the following before onboarding any cluster:- The Distributed Cloud Firewall feature is enabled.
- Discovery of Kubernetes Resources is enabled under Groups > Settings.
- The Kubernetes API server is reachable from the Aviatrix Controller. The most common case is a public API endpoint with the Controller’s IP allowlisted; private clusters require a private network path. See Onboarding Private Kubernetes Clusters .
- SNAT is disabled on worker nodes. See Disable SNAT for Kubernetes Workloads for EKS / AKS / GKE instructions.
- The cluster uses flat networking (the default for EKS, AKS, and GKE). Overlay networks are supported but only for Service-typed SmartGroups used as the destination of DCF rules. See Services, Load Balancing, and Networking for background.
Cloud account discovery permissions
The Aviatrix Controller’s cloud account must include the permissions below for the relevant provider so the controller can discover clusters in the cloud account.- AWS (EKS)
- Azure (AKS)
- Google Cloud (GKE)
eks:ListClusterseks:DescribeClusterelasticloadbalancing:DescribeLoadBalancers(already present in the base set)elasticloadbalancing:DescribeTags(already present in the base set)
Kubernetes RBAC
The Aviatrix Controller authenticates to your cluster’s Kubernetes API and reads namespaces, services, pods, nodes, and endpoint slices. Permissions are granted by a single ClusterRole,avx-controller, installed by the
Aviatrix k8s-firewall helm chart.
Aviatrix recommends installing the helm chart on every onboarded cluster. It is
the canonical packaging of the Aviatrix CRDs and the avx-controller
ClusterRole and ClusterRoleBinding, and it stays aligned with the controller
version. If Helm is not available in your environment, you can render the same
objects with
helm template k8s-firewall k8s-firewall/k8s-firewall | kubectl apply -f - and
apply them yourself.
What the ClusterRole grants
The helm chart installs this ClusterRole regardless of whether you use CRD-based
DCF policy — there is no separate discovery-only manifest. If you cannot use the
helm chart (for example, a custom self-managed cluster without helm), see the
equivalent manifest on the
Onboard Self-Managed or Custom Clusters
page.
CRD-based policy requires the
k8s_dcf_policies feature flag to be enabled by
Aviatrix. See
Distributed Cloud Firewall for Kubernetes
Kubeconfig requirements
When onboarding via the kubeconfig path (an alternative to CSP credentials, supported on every provider), the kubeconfig must:- Use inline credential data —
certificate-authority-data,token, orclient-certificate-data(base64-encoded). The Controller does not read files from the local filesystem. - Use static credentials.
execplugins (such asaws eks get-tokenor AAD auth) are not supported. - Contain a single cluster, user, and context.
- Be sufficient to read namespaces, services, pods, nodes, and endpointslices.
For CRD-based DCF policy, also read/write
networking.aviatrix.com/*.
Limitations
- Automatic onboarding via the Kubernetes Clusters tab supports only publicly available clusters. Private clusters are onboarded after establishing connectivity. See Onboarding Private Kubernetes Clusters .
- A cluster that does not meet the prerequisites above appears greyed out in the SmartGroup creation dialog.
Next Steps
- Onboard EKS Clusters
- Onboard AKS Clusters
- Onboard GKE Clusters
- Onboard Self-Managed or Custom Clusters
