Since Controller Version 6.8, DCF has been supported in AWS, AWS GovCloud, Azure, Azure Government, and GCP.
Ranges
Supported Features
The following are supported on AWS, Azure and GCP unless otherwise noted.
Additional Capabilities
  • Overlapping IPs have been supported since Controller Version 7.0. Distributed Cloud Firewall (DCF) understands any defined SNAT/DNAT rules and updates the address for each gateway, enforcing the DCF rules.
  • DCF auto-prunes all rules and pushes only related rules to specific gateways.
  • SmartGroups dynamically change the resources inside the groups by tracking EC2 changes (AWS, Azure, GCP).
Shared VPC instance tags are not supported in GCP-based SmartGroups.
  • Log Export to Splunk HTTP Event Collector
