NetFlow Agent must be enabled in CoPilot to use FlowIQ. You can enable or edit the NetFlow Agent from Settings > Configuration > Logging Services > NetFlow Agent.
Advantages of FlowIQ
You can use CoPilot’s FlowIQ feature to determine if a gateway is actually compromised, or if a compromised system is attempting a connection. Sometimes when you use an Aviatrix DNS resolution feature (Egress FQDN, Single IP SNAT, User SSL VPN) you might see a message that an Aviatrix gateway is compromised, when it is the endpoint itself that is compromised. Use FlowIQ to view the source of the traffic that generated an alert.Interacting with the Flows
FlowIQ provides various views for visualizing traffic records. The views respond to filters that are selected. The filters that you set are carried across all of the views.FlowIQ Overview Page
In the FlowIQ overview page, CoPilot provides an overview of all the traffic that has traversed across your Aviatrix transit network over the last hour, day, week, month, or over a custom timeframe. The traffic information is broken down into various categories displayed in pie charts. By default, the pie charts show details for all traffic. You can filter the information to show only the traffic you are interested in analyzing. When you click any pie-chart slice, CoPilot automatically creates a filter that narrows down the information displayed across all pie charts. Each time you select another slice, CoPilot adds another rule to your filter group. After you analyze traffic data based on one or more filters (you can create up to ten filters), clear the filter(s) so that CoPilot returns to showing data for all traffic.FlowIQ Trends Page
In the FlowIQ trends page, CoPilot shows an overview of traffic as it moves over time for traffic based on:- A specified destination port.
- A specified source address.
- A specified destination address.
- Total bandwidth based on direction of traffic, ingress or egress.
