This document provides a brief overview of Aviatrix Edge Spoke Gateway horizontal scaling.
horizontal scaling.
Edge Spoke Gateway horizontal scaling is supported only with the latest
version of the Aviatrix Controller.
Edge Spoke Gateway horizontal scaling provides you the flexibility to add or
remove gateways to plan for capacity during peak times to ensure high
availability and improve and maintain network stability and performance.Horizontal scaling requires all Edge Spoke Gateways in an
edge site
to be deployed in active-active mode. A maximum of eight Edge Spoke Gateway
instances are supported per site.Edge Spoke Gateways can be scaled horizontally and peered to the Transit Gateway
or Edge Transit Gateways across single or multiple clouds and regions. The Edge
Spoke Gateways connects to the Transit Gateways and Edge Transit Gateways with
active peering connections. Network traffic between the Transit Gateways and
Edge Spoke Gateways or between Edge Transit Gateways and Edge Spoke Gateways is
load balanced and forwarded across all active peering connections by using Equal
Cost Multi Path (ECMP) routing.The following figure shows multiple Edge Spoke Gateways deployed in the same
edge site for horizontal scaling with multiple active-active high availability
connections for multicloud to edge connectivity.The following example shows an Edge configuration in CoPilot for horizontal
scaling with Edge Spoke Gateway instances for the same edge site in
active-active high availability mode.When a high availability mode is not selected, Edge Spoke Gateways deployed in
the same edge site default to active-active mode.The following example shows an Edge configuration in CoPilot for horizontal
scaling with Edge Spoke Gateway instances in active-active mode (no HA) for
the same edge site.For more information about creating HA Edge Gateways, see About
Creating Highly Available Edge Gateways.
Was this page helpful?
⌘I
{"docsConfig":{"theme":"maple","$schema":"https://mintlify.com/docs.json","name":"Aviatrix Documentation","colors":{"primary":"#FA6B1E","light":"#FA6B1E","dark":"#FA6B1E"},"logo":{"light":"https://mintcdn.com/aviatrix-14b37c43/C8-9GwPfjAW7AMr2/images/logo/dark.svg?fit=max\u0026auto=format\u0026n=C8-9GwPfjAW7AMr2\u0026q=85\u0026s=47e3d643dd8f6c4dc80c803241d7dd63","dark":"https://mintcdn.com/aviatrix-14b37c43/C8-9GwPfjAW7AMr2/images/logo/white.svg?fit=max\u0026auto=format\u0026n=C8-9GwPfjAW7AMr2\u0026q=85\u0026s=394b0a8c16154ad1bd3750a31227a770"},"favicon":"https://mintcdn.com/aviatrix-14b37c43/xgvFAWXVm2H2S1EO/images/logo/favicon.ico?fit=max\u0026auto=format\u0026n=xgvFAWXVm2H2S1EO\u0026q=85\u0026s=88aa1f69df1e66dc63d640bb309aebbd","api":{"playground":{"display":"simple"},"examples":{"defaults":"required","languages":["curl","python","go"],"prefill":true}},"footer":{"links":[{"header":"Legal","items":[{"label":"Cookie Consent","href":"https://www.aviatrix.com/privacy-policy"}]}]},"seo":{"metatags":{"robots":"index, follow","charset":"UTF-8","viewport":"width=device-width, initial-scale=1.0","googlebot":"index, follow","google":"notranslate","generator":"Mintlify","theme-color":"#FA6B1E","color-scheme":"light dark","format-detection":"telephone=no","referrer":"origin","language":"en","copyright":"Copyright 2025 Aviatrix Systems","distribution":"global","coverage":"Worldwide","category":"Technology","target":"all","HandheldFriendly":"True","MobileOptimized":"320","apple-mobile-web-app-capable":"yes","apple-mobile-web-app-status-bar-style":"black","apple-mobile-web-app-title":"Aviatrix Documentation","application-name":"Aviatrix Documentation","msapplication-TileColor":"#FA6B1E","og:type":"website","og:site_name":"Aviatrix Documentation","og:locale":"en_US","twitter:card":"summary","twitter:site":"@aviatrix"},"indexing":"all"},"contextual":{"options":["copy","view","assistant","chatgpt","claude","perplexity","grok","aistudio","devin","windsurf","mcp","cursor","vscode","devin-mcp","download-spec"],"display":"header"},"metadata":{"timestamp":false},"styling":{"latex":false},"navigation":{"pages":[]}},"deployment":{"deploymentMetadataValue":{"subdomain":"aviatrix-14b37c43","hasAudioNarration":false,"actualSubdomain":"aviatrix-14b37c43","customDomains":["docs.aviatrix.com"],"gitSource":{"type":"github","owner":"aviatrixdocs","repo":"aviatrix-docs-mdx","deployBranch":"main-prod","contentDirectory":"","isPrivate":true,"mountPath":"","label":""},"feedback":{"thumbs":true,"edits":false,"issues":false},"entitlements":{"AI_CHAT":{"status":"ENABLED"},"WEB_MCP":{"status":"ENABLED"},"NARRATION":{"status":"ENABLED"}},"buildId":"6b07173d6b602dbc5f12cb36","clientVersion":"0.0.4340","searchFilterCounts":[{"language":"default","tag":"Aviatrix Enterprise","count":4349},{"language":"default","tag":"Reference","count":3099},{"language":"default","tag":"API Reference","count":2611},{"language":"default","tag":"Guides","count":977},{"language":"default","tag":"Networking","count":451},{"language":"default","tag":"Connectivity","count":434},{"language":"default","tag":"Security","count":417},{"language":"default","tag":"DCF","count":366},{"language":"default","tag":"Gateways","count":361},{"language":"default","tag":"General","count":347}]},"assistantConfig":{},"basePath":"","hasChatPermissions":true,"hasWebMcpPermissions":true,"toggles":[{"name":"kill-isr","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"custom-rbac-roles","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"agent-mintlify-slack","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"agent-integrations-settings","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"rbac-expansion","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"automations-pr-grouping","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"custom-prefix","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"analytics-v7","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"user-flows-analytics","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"no-publish-flow","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"snapshot-serving-live","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"stripTemperatureMiddleware","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"support-platform-pylon-zendesk","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"snapshot-serving","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"instant-rollback","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"granular-notifications-server","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"granular-notifications","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"automations-fable","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"fixed-ai-action-pricing","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"site-roles","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"automation-resolve-merge-conflict","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"scoped-publishing","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"mintql","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"page-level-analytics","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"editor-version-history-v2","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"billing-page-v2","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"full-page-search","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"workspace-projects","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"fork-pr-previews","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"revalidation-jwt","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"hobby-abuse-scan","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"dashboard-inbox","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"turbopuffer-dual-write","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"approve-review-flow","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"editor-metadata","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"turbopuffer-serve","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"live-agents","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"starter-pricing","enabled":true,"variant":{"name":"treatment","enabled":true,"payload":{"type":"string","value":"treatment"},"feature_enabled":true},"impressionData":false},{"name":"llms-txt-v2","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false},{"name":"wildcard-email-auth","enabled":true,"variant":{"name":"disabled","enabled":false,"feature_enabled":true},"impressionData":false}],"starterQuestions":[],"googleFontsInlined":false},"customCss":[{"filePath":"assets/css/custom.css","content":":has(>.mdx-content>.dcf-capabilities-page){max-width:min(100%, 64rem)!important}.dcf-capabilities-page{width:100%!important;max-width:min(100%, 64rem)!important;min-width:0!important;margin-inline:auto!important;box-sizing:border-box!important}.dcf-capabilities-page pre{max-width:100%!important;white-space:pre-wrap!important;word-break:break-word!important;box-sizing:border-box!important}.dcf-capabilities-page img,.dcf-capabilities-page video,.dcf-capabilities-page svg{max-width:100%!important;height:auto!important}.dcf-capabilities-page [data-table-wrapper=\"true\"]{overflow-x:auto!important;width:100%!important;max-width:100%!important;margin-left:0!important;margin-right:0!important}.dcf-capabilities-page [data-table-wrapper=\"true\"]>div{display:block!important;min-width:0!important;max-width:100%!important;width:100%!important}.dcf-capabilities-page [data-table-wrapper=\"true\"] table{border-collapse:collapse!important;width:100%!important;max-width:100%!important;min-width:0!important;margin:0!important;font-size:0.83333rem!important;border:1px solid #e1e1e1!important;word-wrap:normal!important}.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)){table-layout:fixed!important;font-size:0.72rem!important}.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th:first-child,.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:first-child{width:20%!important;min-width:0!important;overflow-wrap:break-word!important;word-break:normal!important;padding:0.3rem!important}.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th:not(:first-child),.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:not(:first-child){white-space:normal!important;overflow-wrap:break-word!important;word-break:break-word!important;padding:0.2rem 0.1rem!important;text-align:center!important;font-variant-numeric:tabular-nums!important}@container columns-container (max-width: 1024px){.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th:first-child,.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:first-child{width:34%!important}}@container columns-container (max-width: 720px){.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th:first-child,.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:first-child{width:40%!important}}@container columns-container (max-width: 480px){.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th:first-child,.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:first-child{width:46%!important}}@media (max-width: 1024px){.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th:first-child,.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:first-child{width:34%!important}}@media (max-width: 768px){.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th:first-child,.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:first-child{width:38%!important}}@media (max-width: 560px){.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th:first-child,.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:first-child{width:44%!important}}@media (max-width: 400px){.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th:first-child,.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:first-child{width:48%!important}}.dcf-capabilities-page [data-table-wrapper=\"true\"] table:not(:has(tr:first-child>th:nth-child(6))){table-layout:auto!important}.dcf-capabilities-page [data-table-wrapper=\"true\"] table th,.dcf-capabilities-page [data-table-wrapper=\"true\"] table td{box-sizing:border-box!important;min-width:0!important;padding:0.5rem!important;text-align:left!important;vertical-align:top!important;border:1px solid #e1e1e1!important;overflow-wrap:break-word!important;word-break:normal!important;overflow:hidden!important}.dcf-capabilities-page [data-table-wrapper=\"true\"] table thead th{background-color:#e1e1e1!important;border-bottom-width:2.5px!important;font-weight:600!important;color:#201e28!important}.dcf-capabilities-page [data-table-wrapper=\"true\"] table td{color:#201e28!important}.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) thead th:not(:first-child){white-space:nowrap!important}.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:not(:first-child){text-align:center!important;font-variant-numeric:tabular-nums!important}.fn48-table [data-table-wrapper=\"true\"]{overflow-x:auto!important;width:100%!important;max-width:100%!important;margin-left:0!important;margin-right:0!important}.fn48-table [data-table-wrapper=\"true\"]>div{min-width:0!important;max-width:100%!important;overflow-x:auto!important}.fn48-table [data-table-wrapper=\"true\"] table{table-layout:fixed!important;width:100%!important}.fn48-table [data-table-wrapper=\"true\"] td,.fn48-table [data-table-wrapper=\"true\"] th{word-break:break-word!important;overflow-wrap:break-word!important;min-width:0!important}table{border-collapse:collapse!important;border:1px solid #ddd!important;width:100%!important;margin:1rem 0!important}table th,table td{border:1px solid #ddd!important;padding:12px!important;text-align:left!important;vertical-align:top!important}table th{background-color:#f8f9fa!important;font-weight:600!important;color:#333!important}table tbody tr:nth-child(even){background-color:#f9f9f9!important}table tbody tr:hover{background-color:#f0f0f0!important}.dark table{border-color:#374151!important}.dark table th,.dark table td{border-color:#374151!important;color:#e5e7eb!important}.dark table th{background-color:#1f2937!important;color:#f3f4f6!important}.dark table tbody tr:nth-child(even){background-color:rgba(255, 255, 255, 0.03)!important}.dark table tbody tr:hover{background-color:rgba(255, 255, 255, 0.07)!important}.dark table thead th{background-color:#1f2937!important;color:#f3f4f6!important}.dark .dcf-capabilities-page [data-table-wrapper=\"true\"] table thead th{background-color:#1f2937!important;color:#f3f4f6!important}.dark .dcf-capabilities-page [data-table-wrapper=\"true\"] table td{color:#e5e7eb!important}@media (max-width: 768px){table{font-size:14px!important}table th,table td{padding:8px!important}.dcf-capabilities-page [data-table-wrapper=\"true\"] table th,.dcf-capabilities-page [data-table-wrapper=\"true\"] table td{padding:0.4rem 0.35rem!important}.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th:not(:first-child),.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:not(:first-child){padding:0.3rem 0.1rem!important}}@media (max-width: 480px){table{font-size:14px!important}.dcf-capabilities-page [data-table-wrapper=\"true\"] table{font-size:0.75rem!important}.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th:not(:first-child),.dcf-capabilities-page [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:not(:first-child){padding:0.25rem 0.06rem!important;font-size:0.7rem!important}}header.relative>div.text-lg{display:none!important}footer{border-top:1px solid #ece8e1}footer a{text-decoration:none!important;transition:color 0.2s ease, background-color 0.2s ease}footer a:hover{color:#fa6b1e!important}footer a[href*=\"privacy-policy\"]{font-weight:700!important}.cookie-preferences-cta{margin-top:1rem;display:flex;flex-wrap:wrap;gap:0.5rem;align-items:center;padding:0.875rem 1rem;border:1px solid #f0dfd3;border-radius:10px;background:#fff8f3}.cookie-pref-link{display:inline-block;padding:0.45rem 0.75rem;border-radius:999px;border:1px solid #fa6b1e;color:#b44910!important;font-weight:600;text-decoration:none!important}.cookie-pref-link:hover{background:#fa6b1e;color:#ffffff!important}a[data-dropdown-item],a[data-dropdown-item] *{cursor:pointer!important}a[data-dropdown-item] .nav-dropdown-item-text-container,a[data-dropdown-item] .nav-dropdown-item-title{pointer-events:auto!important}.inline-icon{display:inline-block;vertical-align:middle;height:1.2em;width:auto;margin:0 0.2em}html[data-assistant-state=\"open\"]{overflow:hidden!important}html[data-assistant-state=\"open\"] .lg\\:flex>.lg\\:flex-1{overflow-y:auto!important;max-height:100vh!important;max-height:100dvh!important;scrollbar-width:thin!important;scrollbar-color:rgba(0, 0, 0, 0.3) transparent!important}html[data-assistant-state=\"open\"] .lg\\:flex>.lg\\:flex-1::-webkit-scrollbar{width:8px!important}html[data-assistant-state=\"open\"] .lg\\:flex>.lg\\:flex-1::-webkit-scrollbar-track{background:transparent!important}html[data-assistant-state=\"open\"] .lg\\:flex>.lg\\:flex-1::-webkit-scrollbar-thumb{background-color:rgba(0, 0, 0, 0.3)!important;border-radius:4px!important}html[data-assistant-state=\"open\"] .lg\\:flex>.lg\\:flex-1::-webkit-scrollbar-thumb:hover{background-color:rgba(0, 0, 0, 0.5)!important}html.dark[data-assistant-state=\"open\"] .lg\\:flex>.lg\\:flex-1{scrollbar-color:rgba(255, 255, 255, 0.3) transparent!important}html.dark[data-assistant-state=\"open\"] .lg\\:flex>.lg\\:flex-1::-webkit-scrollbar-thumb{background-color:rgba(255, 255, 255, 0.3)!important}#chat-content{overflow-y:scroll!important;scrollbar-width:thin!important;scrollbar-color:rgba(0, 0, 0, 0.3) transparent!important}#chat-content::-webkit-scrollbar{width:8px!important}#chat-content::-webkit-scrollbar-track{background:transparent!important}#chat-content::-webkit-scrollbar-thumb{background-color:rgba(0, 0, 0, 0.3)!important;border-radius:4px!important}#chat-content::-webkit-scrollbar-thumb:hover{background-color:rgba(0, 0, 0, 0.5)!important}.dark #chat-content{scrollbar-color:rgba(255, 255, 255, 0.3) transparent!important}.dark #chat-content::-webkit-scrollbar-thumb{background-color:rgba(255, 255, 255, 0.3)!important}.dark #chat-content::-webkit-scrollbar-thumb:hover{background-color:rgba(255, 255, 255, 0.5)!important}img[src$=\"/threedot.png\"],img[src$=\"/edit-icon.png\"],img[src$=\"/delete-icon.png\"],img[src$=\"/ai-indicator.png\"],img[src$=\"/ai-information-icon.png\"],img[src$=\"/ai-fqdn-information.png\"],img[src$=\"/action-menu-ellipses.png\"],img[src$=\"/icon-accordion-arrow.png\"],img[src$=\"/sub-contrib-azure.png\"],img[src$=\"/platform-administration-edit-icon.png\"],img[src$=\"/ai-fqdn-indicator-text.png\"],img[src$=\"/azure-select-mambers.png\"]{display:inline-block!important;vertical-align:middle!important;height:1.2em!important;width:auto!important;margin:0 0.2em!important}[data-page-href*=\"/docs/cloud/\"] [data-table-wrapper=\"true\"]{overflow-x:visible!important;width:100%!important;max-width:100%!important}[data-page-href*=\"/docs/cloud/\"] [data-table-wrapper=\"true\"]>div{overflow-x:visible!important;min-width:0!important;width:100%!important;max-width:100%!important}[data-page-href*=\"/docs/cloud/\"] [data-table-wrapper=\"true\"] table{width:100%!important;max-width:100%!important;min-width:0!important;table-layout:auto!important}[data-page-href*=\"/docs/cloud/\"] [data-table-wrapper=\"true\"] td,[data-page-href*=\"/docs/cloud/\"] [data-table-wrapper=\"true\"] th{min-width:0!important;word-wrap:break-word!important;overflow-wrap:break-word!important}[data-page-href*=\"/reference/compatibility/eol-eos-policy\"] [data-table-wrapper=\"true\"]{overflow-x:visible!important;width:100%!important;max-width:100%!important}[data-page-href*=\"/reference/compatibility/eol-eos-policy\"] [data-table-wrapper=\"true\"]>div{overflow-x:visible!important;min-width:0!important;width:100%!important;max-width:100%!important}[data-page-href*=\"/reference/compatibility/eol-eos-policy\"] [data-table-wrapper=\"true\"] table{width:100%!important;max-width:100%!important;min-width:0!important;table-layout:fixed!important}[data-page-href*=\"/reference/compatibility/eol-eos-policy\"] [data-table-wrapper=\"true\"] td,[data-page-href*=\"/reference/compatibility/eol-eos-policy\"] [data-table-wrapper=\"true\"] th{min-width:0!important;overflow-wrap:break-word!important;word-break:break-word!important}[data-page-href*=\"/reference/compatibility/eol-eos-policy\"] [data-table-wrapper=\"true\"] th:nth-child(1),[data-page-href*=\"/reference/compatibility/eol-eos-policy\"] [data-table-wrapper=\"true\"] td:nth-child(1){width:16%!important}[data-page-href*=\"/reference/compatibility/eol-eos-policy\"] [data-table-wrapper=\"true\"] th:nth-child(2),[data-page-href*=\"/reference/compatibility/eol-eos-policy\"] [data-table-wrapper=\"true\"] td:nth-child(2){width:24%!important}[data-page-href*=\"/reference/compatibility/eol-eos-policy\"] [data-table-wrapper=\"true\"] th:nth-child(3),[data-page-href*=\"/reference/compatibility/eol-eos-policy\"] [data-table-wrapper=\"true\"] td:nth-child(3),[data-page-href*=\"/reference/compatibility/eol-eos-policy\"] [data-table-wrapper=\"true\"] th:nth-child(4),[data-page-href*=\"/reference/compatibility/eol-eos-policy\"] [data-table-wrapper=\"true\"] td:nth-child(4),[data-page-href*=\"/reference/compatibility/eol-eos-policy\"] [data-table-wrapper=\"true\"] th:nth-child(5),[data-page-href*=\"/reference/compatibility/eol-eos-policy\"] [data-table-wrapper=\"true\"] td:nth-child(5){width:20%!important}[data-page-href*=\"/reference/feature-modes\"] [data-table-wrapper=\"true\"]:has(table tr:first-child>th:nth-child(6)){overflow-x:visible!important;width:100%!important;max-width:100%!important}[data-page-href*=\"/reference/feature-modes\"] [data-table-wrapper=\"true\"]:has(table tr:first-child>th:nth-child(6))>div{overflow-x:visible!important;min-width:0!important;width:100%!important;max-width:100%!important}[data-page-href*=\"/reference/feature-modes\"] [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)){width:100%!important;max-width:100%!important;min-width:0!important;table-layout:fixed!important}[data-page-href*=\"/reference/feature-modes\"] [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td,[data-page-href*=\"/reference/feature-modes\"] [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th{min-width:0!important;overflow-wrap:break-word!important;word-break:break-word!important;padding:0.5rem 0.25rem!important}[data-page-href*=\"/reference/feature-modes\"] [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th:nth-child(1),[data-page-href*=\"/reference/feature-modes\"] [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:nth-child(1){width:22%!important}[data-page-href*=\"/reference/feature-modes\"] [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th:nth-child(2),[data-page-href*=\"/reference/feature-modes\"] [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:nth-child(2){width:13%!important}[data-page-href*=\"/reference/feature-modes\"] [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th:nth-child(3),[data-page-href*=\"/reference/feature-modes\"] [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:nth-child(3){width:21%!important}[data-page-href*=\"/reference/feature-modes\"] [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th:nth-child(4),[data-page-href*=\"/reference/feature-modes\"] [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:nth-child(4){width:16%!important}[data-page-href*=\"/reference/feature-modes\"] [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th:nth-child(5),[data-page-href*=\"/reference/feature-modes\"] [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:nth-child(5){width:13%!important}[data-page-href*=\"/reference/feature-modes\"] [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) th:nth-child(6),[data-page-href*=\"/reference/feature-modes\"] [data-table-wrapper=\"true\"] table:has(tr:first-child>th:nth-child(6)) td:nth-child(6){width:15%!important}.frame:has(img:is(.dark\\:hidden,.dark\\:mint-hidden))>div[class*=\"bg-grid\"],[data-component-part=\"frame\"]:has(img:is(.dark\\:hidden,.dark\\:mint-hidden)) [data-component-part=\"frame-background-pattern\"]{display:none!important}:is(div:has(>.frame img:is(.dark\\:hidden,.dark\\:mint-hidden)),.frame:has(img:is(.dark\\:hidden,.dark\\:mint-hidden)))+:is(div:has(>.frame img:is(.dark\\:hidden,.dark\\:mint-hidden)),.frame:has(img:is(.dark\\:hidden,.dark\\:mint-hidden))),[data-component-part=\"frame-container\"]:has(img:is(.dark\\:hidden,.dark\\:mint-hidden))+[data-component-part=\"frame-container\"]:has(img:is(.dark\\:hidden,.dark\\:mint-hidden)){margin-top:1.5rem!important}[data-avx-print-tab-label]{display:none}@media print{#navbar,#sidebar,#page-context-menu,#pagination,#content-side-layout,#table-of-contents-layout,#footer,[role=\"menu\"]{display:none!important}#content-container{margin-left:0!important;padding-top:0!important}h2,h3,h4{break-after:avoid}img,figure,pre{break-inside:avoid}[data-component-part=\"scroll-area-content\"] .whitespace-pre,[data-component-part=\"scroll-area-content\"] pre,[data-component-part=\"scroll-area-content\"] code{white-space:pre-wrap!important;overflow-wrap:anywhere}[data-component-part=\"scroll-area-content\"] code{width:auto!important}[data-table-wrapper=\"true\"] [class*=\"page-padding\"]{padding-left:0;padding-right:0}#content [role=\"tabpanel\"]{display:block!important}#content [role=\"tablist\"]{display:none!important}[data-avx-print-tab-label]{display:block;margin:1.5rem 0 0.5rem;padding-bottom:0.25rem;border-bottom:1px solid #d1d5db;font-weight:600;break-after:avoid}}"}]}
{"page":{"pagePath":"docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling","slug":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling","pageMetadata":{"title":"Edge Spoke Gateway Horizontal Scaling","description":"This document provides a brief overview of Aviatrix Edge Spoke Gateway horizontal scaling.","keywords":"Controller, controller, edge, gateway, high availability, performance, scaling, spoke, transit","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling"},"description":{"compiledSource":"\"use strict\";\nconst {jsx: _jsx} = arguments[0];\nconst {useMDXComponents: _provideComponents} = arguments[0];\nfunction _createMdxContent(props) {\n const _components = {\n p: \"p\",\n ..._provideComponents(),\n ...props.components\n };\n return _jsx(_components.p, {\n children: \"This document provides a brief overview of Aviatrix Edge Spoke Gateway horizontal scaling.\"\n });\n}\nfunction MDXContent(props = {}) {\n const {wrapper: MDXLayout} = {\n ..._provideComponents(),\n ...props.components\n };\n return MDXLayout ? _jsx(MDXLayout, {\n ...props,\n children: _jsx(_createMdxContent, {\n ...props\n })\n }) : _createMdxContent(props);\n}\nreturn {\n default: MDXContent\n};\n","frontmatter":{},"scope":{}},"pageType":"default","mdx":{"mdxSource":{"compiledSource":"\"use strict\";const{Fragment:_Fragment,jsx:_jsx,jsxs:_jsxs}=arguments[0];const{useMDXComponents:_provideComponents}=arguments[0];function _createMdxContent(props){const _components={a:`a`,em:`em`,p:`p`,..._provideComponents(),...props.components},{Note,OptimizedImage}=_components;if(!Note)_missingMdxReference(`Note`,true);if(!OptimizedImage)_missingMdxReference(`OptimizedImage`,true);return _jsxs(_Fragment,{children:[_jsx(`a`,{id:`edge-spoke-gateway-scaling`}),`\n`,_jsx(_components.p,{children:`This document provides a brief overview of Aviatrix Edge Spoke Gateway\nhorizontal scaling.`}),`\n`,_jsx(Note,{children:_jsx(_components.p,{children:`Edge Spoke Gateway horizontal scaling is supported only with the latest\nversion of the Aviatrix Controller.`})}),`\n`,_jsx(_components.p,{children:`Edge Spoke Gateway horizontal scaling provides you the flexibility to add or\nremove gateways to plan for capacity during peak times to ensure high\navailability and improve and maintain network stability and performance.`}),`\n`,_jsxs(_components.p,{children:[`Horizontal scaling requires all Edge Spoke Gateways in an\n`,_jsx(_components.a,{href:`https://legacy.docs.aviatrix.com/documentation/latest/network/edge-spoke-settings.html`,children:`edge site`}),`\nto be deployed in `,_jsx(_components.em,{children:`active-active`}),` mode. A maximum of eight Edge Spoke Gateway\ninstances are supported per site.`]}),`\n`,_jsx(_components.p,{children:`Edge Spoke Gateways can be scaled horizontally and peered to the Transit Gateway\nor Edge Transit Gateways across single or multiple clouds and regions. The Edge\nSpoke Gateways connects to the Transit Gateways and Edge Transit Gateways with\nactive peering connections. Network traffic between the Transit Gateways and\nEdge Spoke Gateways or between Edge Transit Gateways and Edge Spoke Gateways is\nload balanced and forwarded across all active peering connections by using Equal\nCost Multi Path (ECMP) routing.`}),`\n`,_jsx(_components.p,{children:`The following figure shows multiple Edge Spoke Gateways deployed in the same\nedge site for horizontal scaling with multiple active-active high availability\nconnections for multicloud to edge connectivity.`}),`\n`,_jsx(OptimizedImage,{src:`https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-horizontal-scale.png?fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=d28496a6a9c4b3af0d1349cf2987d1ba`,alt:`Diagram showing Edge Spoke Gateway horizontal scaling with multicloud to edge connectivity`,\"data-og-width\":`882`,width:`882`,\"data-og-height\":`578`,height:`578`,\"data-path\":`images/concepts-architectures/architecture/connectivity/edge-horizontal-scale.png`,\"data-optimize\":`true`,\"data-opv\":`3`,srcset:`https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-horizontal-scale.png?w=280\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=0b61b996887a301a2503d1f9f82f1993 280w, https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-horizontal-scale.png?w=560\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=72d29b7cc4e0ca1a4dd6784e8a18c804 560w, https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-horizontal-scale.png?w=840\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=b454e4af8ffcf05e9ebcd59f9e5a2cfc 840w, https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-horizontal-scale.png?w=1100\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=99f06623136e14af265353c8960443ea 1100w, https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-horizontal-scale.png?w=1650\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=d9d29fb5f8b812ffa5d8e8adf462b9d8 1650w, https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-horizontal-scale.png?w=2500\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=39d022e592174f7405c6437ed100f6b0 2500w`}),`\n`,_jsxs(_components.p,{children:[`The following example shows an Edge configuration in CoPilot for horizontal\nscaling with Edge Spoke Gateway instances for the same edge site in\n`,_jsx(_components.em,{children:`active-active high availability mode`}),`.`]}),`\n`,_jsx(OptimizedImage,{src:`https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-ha.png?fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=af0ac788efd6b946f39aa091d111f5d2`,alt:`Edge configuration in CoPilot showing horizontal scaling with Edge Spoke Gateway instances in active-active high availability mode`,\"data-og-width\":`3454`,width:`3454`,\"data-og-height\":`1832`,height:`1832`,\"data-path\":`images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-ha.png`,\"data-optimize\":`true`,\"data-opv\":`3`,srcset:`https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-ha.png?w=280\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=0290df36e8fa8706ba64b91b5a607923 280w, https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-ha.png?w=560\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=39301e3d8b87c898f8d983822acf5224 560w, https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-ha.png?w=840\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=e7670469b213c1600e2ce0a290b2fb08 840w, https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-ha.png?w=1100\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=d8d0ea6733df96e2ffa16e70de00f534 1100w, https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-ha.png?w=1650\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=ff3bb00d29f1a3fa61191cde9b2bf33b 1650w, https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-ha.png?w=2500\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=76b476e005144edff500d5b108c4cfc7 2500w`}),`\n`,_jsx(_components.p,{children:`When a high availability mode is not selected, Edge Spoke Gateways deployed in\nthe same edge site default to active-active mode.`}),`\n`,_jsxs(_components.p,{children:[`The following example shows an Edge configuration in CoPilot for horizontal\nscaling with Edge Spoke Gateway instances in `,_jsx(_components.em,{children:`active-active`}),` mode (no HA) for\nthe same edge site.`]}),`\n`,_jsx(OptimizedImage,{src:`https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-no-ha.png?fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=85d9c37681f06579236a31e98fadbfa4`,alt:`Edge configuration in CoPilot showing horizontal scaling with Edge Spoke Gateway instances in active-active mode without HA`,\"data-og-width\":`3450`,width:`3450`,\"data-og-height\":`1802`,height:`1802`,\"data-path\":`images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-no-ha.png`,\"data-optimize\":`true`,\"data-opv\":`3`,srcset:`https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-no-ha.png?w=280\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=e23f2974bd1263102ede46236975b606 280w, https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-no-ha.png?w=560\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=3f573b01aa83fcb94d3e91b53438d836 560w, https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-no-ha.png?w=840\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=109f2aba91d270688f3591a0ae1b74e0 840w, https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-no-ha.png?w=1100\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=8e0907ab50793eb431cf617f98abe350 1100w, https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-no-ha.png?w=1650\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=cc6c6c0cb0b2ffbb18c6160fcc07ce25 1650w, https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-no-ha.png?w=2500\u0026fit=max\u0026auto=format\u0026n=8iF92JcVck-Y3RaJ\u0026q=85\u0026s=97b272ae604cc62719572c6faf2896de 2500w`}),`\n`,_jsxs(_components.p,{children:[`For more information about creating HA Edge Gateways, see `,_jsx(_components.a,{href:`/docs/enterprise/`+`10.0`+`/concepts-architectures/architecture/connectivity/edge-spoke-ha`,children:`About\nCreating Highly Available Edge Gateways`}),`.`]})]})}function MDXContent(props={}){const{wrapper:MDXLayout}={..._provideComponents(),...props.components};return MDXLayout?_jsx(MDXLayout,{...props,children:_jsx(_createMdxContent,{...props})}):_createMdxContent(props)}return{default:MDXContent};function _missingMdxReference(id,component){throw new Error(`Expected `+(component?`component`:`object`)+\" `\"+id+\"` to be defined: you likely forgot to import, pass, or provide it.\")}","frontmatter":{},"scope":{"config":{},"pageMetadata":{"title":"Edge Spoke Gateway Horizontal Scaling","description":"This document provides a brief overview of Aviatrix Edge Spoke Gateway horizontal scaling.","keywords":"Controller, controller, edge, gateway, high availability, performance, scaling, spoke, transit","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling"}}},"mdxSourceWithNoJs":null,"noJsSplices":[[8891,8981,""]]},"mdxExtracts":{"tableOfContents":[],"codeExamples":{}},"jsLinks":["/_mintlify/custom/aviatrix-14b37c43/78e137009cf9c01a/assets/js/custom-scripts.js"],"subdomain":"aviatrix-14b37c43","siteName":"Aviatrix Documentation","title":"Edge Spoke Gateway Horizontal Scaling - Aviatrix Documentation","contextualStarterQuestions":[],"navMaps":{"firstHrefInVersion":{"10.1":{"href":"/docs/enterprise/10.1/concepts-architectures/architecture/connectivity/edge-spoke-scaling","matchLevel":1},"10.0":{"href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling","matchLevel":0},"9.0":{"href":"/docs/enterprise/9.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling","matchLevel":1},"8.2":{"href":"/docs/enterprise/8.2/concepts-architectures/architecture/connectivity/edge-spoke-scaling","matchLevel":1},"8.1":{"href":"/docs/cloud/getting-started","matchLevel":5},"8.0":{"href":"/docs/cloud/getting-started","matchLevel":5},"7.2":{"href":"/docs/cloud/getting-started","matchLevel":5},"7.1":{"href":"/docs/cloud/getting-started","matchLevel":5}},"firstHrefInLanguage":{}},"lastModified":"2026-07-28T16:02:10.700Z","originalFileLocation":"docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling.mdx"},"headHtml":"\u003cscript data-mint-head>(function(){var d=document.documentElement,p=null;if(!p){try{p=localStorage.getItem(\"isDarkMode\")}catch(e){}if(p==='true')p='dark';else if(p==='false')p='light';if(p!=='light'\u0026\u0026p!=='dark'\u0026\u0026p!=='system')p=\"system\"}var r=p==='system'?(matchMedia(\"(prefers-color-scheme: dark)\").matches?'dark':'light'):p;d.classList.remove(r==='dark'?'light':'dark');d.classList.add(r);d.setAttribute(\"data-theme-preference\",p)})();\u003c/script>\u003cmeta data-mint-head name=\"description\" content=\"This document provides a brief overview of Aviatrix Edge Spoke Gateway horizontal scaling.\">\u003cmeta data-mint-head name=\"application-name\" content=\"Aviatrix Documentation\">\u003cmeta data-mint-head name=\"generator\" content=\"Mintlify\">\u003cmeta data-mint-head name=\"robots\" content=\"index, follow\">\u003clink data-mint-head rel=\"icon\" type=\"image/png\" sizes=\"192x192\" href=\"/mintlify-assets/_mintlify/favicons/aviatrix-14b37c43/_YRInNkqIeHlausz/_generated/favicon/android-chrome-192x192.png\" media=\"(prefers-color-scheme: light)\">\u003clink data-mint-head rel=\"apple-touch-icon\" type=\"image/png\" sizes=\"180x180\" href=\"/mintlify-assets/_mintlify/favicons/aviatrix-14b37c43/_YRInNkqIeHlausz/_generated/favicon/apple-touch-icon.png\">\u003clink data-mint-head rel=\"icon\" type=\"image/png\" sizes=\"16x16\" href=\"/mintlify-assets/_mintlify/favicons/aviatrix-14b37c43/_YRInNkqIeHlausz/_generated/favicon/favicon-16x16.png\" media=\"(prefers-color-scheme: light)\">\u003clink data-mint-head rel=\"icon\" type=\"image/png\" sizes=\"32x32\" href=\"/mintlify-assets/_mintlify/favicons/aviatrix-14b37c43/_YRInNkqIeHlausz/_generated/favicon/favicon-32x32.png\" media=\"(prefers-color-scheme: light)\">\u003clink data-mint-head rel=\"shortcut icon\" type=\"image/x-icon\" href=\"/mintlify-assets/_mintlify/favicons/aviatrix-14b37c43/_YRInNkqIeHlausz/_generated/favicon/favicon.ico\" media=\"(prefers-color-scheme: light)\">\u003clink data-mint-head rel=\"icon\" type=\"image/png\" sizes=\"192x192\" href=\"/mintlify-assets/_mintlify/favicons/aviatrix-14b37c43/_YRInNkqIeHlausz/_generated/favicon-dark/android-chrome-192x192.png\" media=\"(prefers-color-scheme: dark)\">\u003clink data-mint-head rel=\"icon\" type=\"image/png\" sizes=\"16x16\" href=\"/mintlify-assets/_mintlify/favicons/aviatrix-14b37c43/_YRInNkqIeHlausz/_generated/favicon-dark/favicon-16x16.png\" media=\"(prefers-color-scheme: dark)\">\u003clink data-mint-head rel=\"icon\" type=\"image/png\" sizes=\"32x32\" href=\"/mintlify-assets/_mintlify/favicons/aviatrix-14b37c43/_YRInNkqIeHlausz/_generated/favicon-dark/favicon-32x32.png\" media=\"(prefers-color-scheme: dark)\">\u003clink data-mint-head rel=\"shortcut icon\" type=\"image/x-icon\" href=\"/mintlify-assets/_mintlify/favicons/aviatrix-14b37c43/_YRInNkqIeHlausz/_generated/favicon-dark/favicon.ico\" media=\"(prefers-color-scheme: dark)\">\u003cmeta data-mint-head property=\"og:title\" content=\"Edge Spoke Gateway Horizontal Scaling - Aviatrix Documentation\">\u003cmeta data-mint-head property=\"og:description\" content=\"This document provides a brief overview of Aviatrix Edge Spoke Gateway horizontal scaling.\">\u003cmeta data-mint-head property=\"og:site_name\" content=\"Aviatrix Documentation\">\u003cmeta data-mint-head property=\"og:url\" content=\"https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling\">\u003cmeta data-mint-head property=\"og:type\" content=\"website\">\u003cmeta data-mint-head property=\"og:image\" content=\"https://aviatrix-14b37c43.mintlify.site/_mintlify/api/og/v2?division=Connectivity\u0026amp;title=Edge+Spoke+Gateway+Horizontal+Scaling\u0026amp;description=This+document+provides+a+brief+overview+of+Aviatrix+Edge+Spoke+Gateway+horizontal+scaling.\u0026amp;theme=4ba23ffc57c0b83df9b7f35d\u0026amp;signature=fda80dc653c4decf10a418c2f35d7202125dde2c2d7df858ee19f8c878452292\">\u003cmeta data-mint-head property=\"og:image:width\" content=\"1200\">\u003cmeta data-mint-head property=\"og:image:height\" content=\"630\">\u003cmeta data-mint-head name=\"twitter:card\" content=\"summary_large_image\">\u003cmeta data-mint-head name=\"twitter:title\" content=\"Edge Spoke Gateway Horizontal Scaling - Aviatrix Documentation\">\u003cmeta data-mint-head name=\"twitter:description\" content=\"This document provides a brief overview of Aviatrix Edge Spoke Gateway horizontal scaling.\">\u003cmeta data-mint-head name=\"twitter:image\" content=\"https://aviatrix-14b37c43.mintlify.site/_mintlify/api/og/v2?division=Connectivity\u0026amp;title=Edge+Spoke+Gateway+Horizontal+Scaling\u0026amp;description=This+document+provides+a+brief+overview+of+Aviatrix+Edge+Spoke+Gateway+horizontal+scaling.\u0026amp;theme=4ba23ffc57c0b83df9b7f35d\u0026amp;signature=fda80dc653c4decf10a418c2f35d7202125dde2c2d7df858ee19f8c878452292\">\u003cmeta data-mint-head name=\"twitter:image:width\" content=\"1200\">\u003cmeta data-mint-head name=\"twitter:image:height\" content=\"630\">\u003cmeta data-mint-head name=\"msapplication-config\" content=\"/mintlify-assets/_mintlify/favicons/aviatrix-14b37c43/_YRInNkqIeHlausz/_generated/favicon/browserconfig.xml\">\u003cmeta data-mint-head name=\"apple-mobile-web-app-title\" content=\"Aviatrix Documentation\">\u003cmeta data-mint-head name=\"msapplication-TileColor\" content=\"#FA6B1E\">\u003cmeta data-mint-head name=\"og:locale\" content=\"en_US\">\u003cmeta data-mint-head name=\"charset\" content=\"UTF-8\">\u003cmeta data-mint-head name=\"viewport\" content=\"width=device-width, initial-scale=1.0\">\u003cmeta data-mint-head name=\"googlebot\" content=\"index, follow\">\u003cmeta data-mint-head name=\"google\" content=\"notranslate\">\u003cmeta data-mint-head name=\"generator\" content=\"Mintlify\">\u003cmeta data-mint-head name=\"theme-color\" content=\"#FA6B1E\">\u003cmeta data-mint-head name=\"color-scheme\" content=\"light dark\">\u003cmeta data-mint-head name=\"format-detection\" content=\"telephone=no\">\u003cmeta data-mint-head name=\"referrer\" content=\"origin\">\u003cmeta data-mint-head name=\"language\" content=\"en\">\u003cmeta data-mint-head name=\"copyright\" content=\"Copyright 2025 Aviatrix Systems\">\u003cmeta data-mint-head name=\"distribution\" content=\"global\">\u003cmeta data-mint-head name=\"coverage\" content=\"Worldwide\">\u003cmeta data-mint-head name=\"category\" content=\"Technology\">\u003cmeta data-mint-head name=\"target\" content=\"all\">\u003cmeta data-mint-head name=\"HandheldFriendly\" content=\"True\">\u003cmeta data-mint-head name=\"MobileOptimized\" content=\"320\">\u003cmeta data-mint-head name=\"apple-mobile-web-app-capable\" content=\"yes\">\u003cmeta data-mint-head name=\"apple-mobile-web-app-status-bar-style\" content=\"black\">\u003cmeta data-mint-head name=\"application-name\" content=\"Aviatrix Documentation\">\u003clink data-mint-head rel=\"canonical\" href=\"https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling\">\u003clink data-mint-head rel=\"alternate\" type=\"application/xml\" href=\"/sitemap.xml\">\u003clink data-mint-head rel=\"alternate\" type=\"text/markdown\" href=\"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling.md\">\u003cscript data-mint-head type=\"application/ld+json\">{\"@context\":\"https://schema.org\",\"@graph\":[{\"@type\":\"Organization\",\"@id\":\"https://docs.aviatrix.com/#organization\",\"name\":\"Aviatrix Documentation\",\"url\":\"https://docs.aviatrix.com\",\"logo\":{\"@type\":\"ImageObject\",\"url\":\"https://mintcdn.com/aviatrix-14b37c43/C8-9GwPfjAW7AMr2/images/logo/dark.svg?fit=max\u0026auto=format\u0026n=C8-9GwPfjAW7AMr2\u0026q=85\u0026s=47e3d643dd8f6c4dc80c803241d7dd63\"}},{\"@type\":\"WebSite\",\"@id\":\"https://docs.aviatrix.com#website\",\"name\":\"Aviatrix Documentation\",\"url\":\"https://docs.aviatrix.com\",\"publisher\":{\"@id\":\"https://docs.aviatrix.com/#organization\"}},{\"@type\":\"WebPage\",\"@id\":\"https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling#webpage\",\"url\":\"https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling\",\"name\":\"Edge Spoke Gateway Horizontal Scaling\",\"description\":\"This document provides a brief overview of Aviatrix Edge Spoke Gateway horizontal scaling.\",\"dateModified\":\"2026-07-28T16:02:10.700Z\",\"isPartOf\":{\"@id\":\"https://docs.aviatrix.com#website\"},\"breadcrumb\":{\"@id\":\"https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling#breadcrumb\"}},{\"@type\":\"BreadcrumbList\",\"@id\":\"https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling#breadcrumb\",\"itemListElement\":[{\"@type\":\"ListItem\",\"position\":1,\"name\":\"Concepts \u0026 Architecture\",\"item\":\"https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/CNSF\"},{\"@type\":\"ListItem\",\"position\":2,\"name\":\"Architecture\",\"item\":\"https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/platform-overview\"},{\"@type\":\"ListItem\",\"position\":3,\"name\":\"Connectivity\",\"item\":\"https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-ha\"},{\"@type\":\"ListItem\",\"position\":4,\"name\":\"Edge Spoke Gateway Horizontal Scaling\",\"item\":\"https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling\"}]},{\"@type\":[\"Article\",\"TechArticle\"],\"@id\":\"https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling#article\",\"headline\":\"Edge Spoke Gateway Horizontal Scaling\",\"name\":\"Edge Spoke Gateway Horizontal Scaling\",\"description\":\"This document provides a brief overview of Aviatrix Edge Spoke Gateway horizontal scaling.\",\"url\":\"https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling\",\"mainEntityOfPage\":{\"@id\":\"https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling#webpage\"},\"dateModified\":\"2026-07-28T16:02:10.700Z\",\"publisher\":{\"@id\":\"https://docs.aviatrix.com/#organization\"},\"isPartOf\":{\"@id\":\"https://docs.aviatrix.com#website\"}}]}\u003c/script>\u003cscript data-mint-head type=\"application/ld+json\">{\"@context\":\"https://schema.org\",\"@type\":\"WebSite\",\"name\":\"Aviatrix Documentation\",\"publisher\":{\"@type\":\"Organization\",\"name\":\"Aviatrix Documentation\"},\"provider\":{\"@type\":\"Organization\",\"name\":\"Mintlify\",\"url\":\"https://mintlify.com\"}}\u003c/script>","agentPointerHref":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling.md","siteName":"Aviatrix Documentation","nav":{"global":null,"dropdowns":[{"dropdown":"Aviatrix Enterprise","icon":"building","versions":[{"version":"10.1","pages":[{"title":"10.1","href":"/docs/enterprise/10.1/concepts-architectures/architecture/connectivity/edge-spoke-scaling"}]},{"version":"10.0","groups":[{"group":"Concepts \u0026 Architecture","icon":"lightbulb","pages":[{"title":"CNSF","href":"/docs/enterprise/10.0/concepts-architectures/CNSF"},{"group":"Solutions","pages":[{"title":"Stop Data Exfiltration Through Default-Deny Egress Control","sidebarTitle":"Egress Security","href":"/docs/enterprise/10.0/solutions/stop-data-exfiltration/egress-security"},{"title":"Contain Lateral Movement Through Identity-Based Segmentation","sidebarTitle":"East-West Segmentation","href":"/docs/enterprise/10.0/solutions/contain-lateral-movement/east-west-containment"},{"group":"Security for AI","pages":[{"title":"AI Agent Workload Containment","sidebarTitle":"AI Agent Containment","href":"/docs/enterprise/10.0/solutions/security-for-ai/ai-agent-workload-security"},{"title":"MCP Server Security Through Containment Architecture","sidebarTitle":"MCP Egress Containment","href":"/docs/enterprise/10.0/solutions/security-for-ai/mcp-server-egress-security"}]},{"title":"Secure Kubernetes Workloads Through Identity-Based Egress Policy","sidebarTitle":"Kubernetes Workload Security","href":"/docs/enterprise/10.0/solutions/secure-kubernetes-workloads/kubernetes-workload-security"},{"title":"Secure Third-Party Connections Through Least-Privilege Perimeter Policy","sidebarTitle":"Third-Party Perimeter","href":"/docs/enterprise/10.0/solutions/third-party-perimeter/third-party-perimeter-security"},{"title":"Automate Security Operations Through Policy as Code","sidebarTitle":"Security Automation","href":"/docs/enterprise/10.0/solutions/security-automation/security-operations-automation"},{"group":"AI Agent Integrations","pages":[{"title":"Aviatrix MCP for Enterprise Fabrics","sidebarTitle":"MCP for Enterprise Fabrics","href":"/docs/enterprise/10.0/solutions/ai-agent-integrations/mcp-for-enterprise-fabrics"},{"title":"Aviatrix MCP for Docs","sidebarTitle":"MCP for Docs","href":"/docs/enterprise/10.0/solutions/ai-agent-integrations/mcp-for-docs"},{"title":"Suggested Use Cases for the Aviatrix Enterprise MCP Server","href":"/docs/enterprise/10.0/solutions/ai-agent-integrations/mcp-suggested-use-cases"}]}]},{"group":"Components","pages":[{"group":"Control Plane","pages":[{"title":"CoPilot Overview","href":"/docs/enterprise/10.0/concepts-architectures/components/controlplane/copilot-overview"},{"title":"CoPilot Features","href":"/docs/enterprise/10.0/concepts-architectures/components/controlplane/copilot-features"},{"title":"Controller Overview","href":"/docs/enterprise/10.0/concepts-architectures/components/controlplane/controller-overview"}]},{"group":"Edge","pages":[{"title":"Edge Platform","href":"/docs/enterprise/10.0/concepts-architectures/components/edge-gateways/edge-aep"},{"title":"Hybrid Cloud Edge","href":"/docs/enterprise/10.0/concepts-architectures/components/edge-gateways/edge-overview"},{"title":"Edge Spoke Gateway","href":"/docs/enterprise/10.0/concepts-architectures/components/edge-gateways/edge-spoke-overview"},{"title":"Edge Spoke Gateway Use Cases","href":"/docs/enterprise/10.0/concepts-architectures/components/edge-gateways/edge-spoke-usecases"},{"title":"Edge Transit Gateway","href":"/docs/enterprise/10.0/concepts-architectures/components/edge-gateways/edge-transit-overview"}]},{"group":"Connectivity","pages":[{"title":"ActiveMesh","href":"/docs/enterprise/10.0/concepts-architectures/components/connectivity/activemesh-about"},{"title":"ActiveMesh 4.0","href":"/docs/enterprise/10.0/concepts-architectures/components/connectivity/activemesh-4.0"},{"title":"ActiveMesh Design Notes","href":"/docs/enterprise/10.0/concepts-architectures/components/connectivity/activemesh-design-notes"},{"title":"IPv6 Overview","href":"/docs/enterprise/10.0/concepts-architectures/components/connectivity/ipv6-overview"},{"title":"Native Peering","href":"/docs/enterprise/10.0/concepts-architectures/components/native-peering-about"},{"title":"Site2Cloud","href":"/docs/enterprise/10.0/concepts-architectures/components/connectivity/s2c-overview"}]},{"group":"Security","pages":[{"title":"About High Performance Encryption","sidebarTitle":"High Performance Encryption","href":"/docs/enterprise/10.0/concepts-architectures/components/security/hpe-about"},{"title":"High Performance Encryption for GCP","href":"/docs/enterprise/10.0/concepts-architectures/components/security/hpe-for-gcp"},{"title":"Transit Network Segmentation","href":"/docs/enterprise/10.0/concepts-architectures/components/security/transit-segmentation-faq"}]},{"group":"Distributed Cloud Firewall","pages":[{"title":"Distributed Cloud Firewall Overview","sidebarTitle":"Overview","href":"/docs/enterprise/10.0/concepts-architectures/components/dcf/dcf-overview"},{"title":"Distributed Cloud Firewall Rulesets","sidebarTitle":"Rulesets","href":"/docs/enterprise/10.0/concepts-architectures/components/dcf/dcf-rulesets-about"},{"title":"Enforcing Zero Trust with Distributed Cloud Firewall and the Default Action Rule","href":"/docs/enterprise/10.0/concepts-architectures/components/dcf/dcf-zero-trust"},{"title":"Kubernetes Firewall","href":"/docs/enterprise/10.0/concepts-architectures/components/dcf/kubernetes-overview"},{"title":"Security Group Orchestration for Distributed Cloud Firewall","sidebarTitle":"Security Group Orchestration","href":"/docs/enterprise/10.0/concepts-architectures/components/dcf/security-group-orchestration"},{"title":"SmartGroup Use Cases","href":"/docs/enterprise/10.0/concepts-architectures/components/dcf/smartgroup-use-cases"},{"title":"Managing SmartGroups","href":"/docs/enterprise/10.0/concepts-architectures/components/dcf/smartgroups-about"},{"title":"Managing WebGroups","href":"/docs/enterprise/10.0/concepts-architectures/components/dcf/webgroups-about"},{"title":"About DNS Hostname SmartGroups","sidebarTitle":"DNS Hostname SmartGroups","href":"/docs/enterprise/10.0/concepts-architectures/components/dcf/hostname-smartgroups-about"}]},{"group":"AWS Transit Gateway","pages":[{"title":"AWS Transit Gateway Orchestrator","sidebarTitle":"Orchestrator","href":"/docs/enterprise/10.0/concepts-architectures/components/tgw/tgw-landing-page"},{"title":"AWS Transit Gateway Orchestrator FAQ","sidebarTitle":"Orchestrator FAQ","href":"/docs/enterprise/10.0/concepts-architectures/components/tgw/tgw-orchestrator-faq"}]},{"group":"UserVPN","pages":[{"title":"UserVPN Overview","sidebarTitle":"Overview","href":"/docs/enterprise/10.0/concepts-architectures/components/uservpn/user-vpn-feature-description"}]},{"group":"Egress","pages":[{"title":"Egress Security Score Protection","href":"/docs/enterprise/10.0/concepts-architectures/components/egress/egress-overview"}]}]},{"group":"Architecture","pages":[{"title":"Aviatrix Platform Overview","href":"/docs/enterprise/10.0/concepts-architectures/platform-overview"},{"group":"Connectivity","pages":[{"title":"Edge Spoke Gateway High Availability","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-ha"},{"title":"Local Internet Breakout at Network Edge","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-local-internet-breakout"},{"title":"Customized SNAT and DNAT on Edge","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-snat-dnat"},{"title":"Transit Peering Over Public Network with Edge Spoke Gateway","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-transit-peering"},{"title":"Transitive Routing with Edge Spoke Gateway","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-transitive-routing"},{"title":"Extending VLAN Segmentation to the Cloud","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-vlan-segmentation"},{"title":"Aviatrix in the China Regions","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/aviatrix-china-overview"},{"title":"Bidirectional Forwarding Detection for BGP","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/bgp-bfd"},{"title":"BGP Communities","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/bgp-communities"},{"title":"Edge Spoke Gateway Design Patterns","description":"This document describes these common design patterns for deploying Aviatrix Edge Spoke Gateway.","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-design-patterns"},{"title":"Edge Spoke Gateway Horizontal Scaling","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling"},{"title":"Edge Transit Gateway Design Patterns","description":"Edge Transit Gateway allows you to build high performance encrypted connections across Equinix and Megaport fabric to cloud environments. You can also deploy Edge Spoke Gateways in on-premises for high performance encrypted connections to Edge Transit Gateway in Equinix and Megaport.","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-transit-design-patterns"},{"title":"Edge Transit Gateway External Connection","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-transit-s2c-overview"},{"title":"Enabling GCP Global VPC Routing","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/gcp-global-vpc"},{"title":"Multicloud Transit Network Design Patterns","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/multi-cloud-design-patterns"},{"title":"Aviatrix Multicloud Transit Architecture for Azure","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/nextgen-transit-azure"},{"title":"Azure Transit Network Design Patterns","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/planning-azure"},{"title":"Overview of Transit Gateway to External Devices","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/transit-externaldevice-usecase"},{"title":"Aviatrix Multicloud Transit Network FAQ","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/transit-network-faq"},{"title":"TGW Design Patterns","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/tgw-design-patterns"},{"title":"Aviatrix UserVPN Design for Multi-Accounts and Multi-VPC/VNets","href":"/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/user-vpn-designs"}]},{"group":"Security","pages":[{"title":"FireNet Design Patterns","href":"/docs/enterprise/10.0/concepts-architectures/architecture/security/firenet-design-patterns"},{"title":"FireNet Ingress Traffic Inspection","href":"/docs/enterprise/10.0/concepts-architectures/architecture/security/planning-firenet-ingress"}]},{"group":"Sizing","pages":[{"title":"Auto Right-Sizing","href":"/docs/enterprise/10.0/concepts-architectures/architecture/sizing/auto-right-sizing-about"}]}]},{"group":"Validated Designs","hidden":true,"pages":[{"title":"Validated Designs ✅","href":"/docs/enterprise/10.0/concepts-architectures/validated-designs/index"}]}]},{"group":"Guides","icon":"book-open","pages":[{"group":"Getting Started","pages":[{"title":"AWS Getting Started Guide","href":"/docs/enterprise/10.0/guides/controlplane/getting-started-guide-aws"},{"title":"Azure Getting Started Guide","href":"/docs/enterprise/10.0/guides/controlplane/getting-started-guide-azure"},{"title":"Deploy Aviatrix Controller through CSP Consoles","href":"/docs/enterprise/10.0/guides/controlplane/manual-launch-controller-csp"}]},{"group":"Connectivity","pages":[{"group":"Edge","pages":[{"title":"Installing Edge OS and Onboarding Dell Hardware","href":"/docs/enterprise/10.0/guides/connectivity/edge/edge-device-onboarding"},{"title":"Edge Gateway Image Upgrade and Post-Upgrade Tasks","href":"/docs/enterprise/10.0/guides/connectivity/edge/edge-gateway-upgrade"},{"title":"Edge Gateway Multi-Peer BGP over LAN Connection","href":"/docs/enterprise/10.0/guides/connectivity/edge/edge-multipeer-bgpolan"},{"title":"Setting up Accounts for Edge Platforms","href":"/docs/enterprise/10.0/guides/connectivity/edge/edge-platform-account"},{"title":"Using a Proxy Profile on the Edge Device","href":"/docs/enterprise/10.0/guides/connectivity/edge/edge-proxy-profile"},{"title":"Creating the Default RBAC Access Account for Edge","href":"/docs/enterprise/10.0/guides/connectivity/edge/edge-rbac-account"},{"title":"Edge Transit Gateway External Connection Workflow","href":"/docs/enterprise/10.0/guides/connectivity/edge/edge-s2c-workflow"},{"title":"Create Edge Spoke Gateway Attachments","href":"/docs/enterprise/10.0/guides/connectivity/edge/edge-spoke-attachments"},{"title":"Deploy an Edge Spoke Gateway on Equinix Network Edge","href":"/docs/enterprise/10.0/guides/connectivity/edge/edge-spoke-workflow-equinix"},{"title":"Deploy an Edge Spoke Gateway on Megaport Virtual Edge","href":"/docs/enterprise/10.0/guides/connectivity/edge/edge-spoke-workflow-megaport"},{"title":"Deploy an Edge Spoke Gateway on Aviatrix Edge Platform","href":"/docs/enterprise/10.0/guides/connectivity/edge/edge-spoke-workflow-onpremise"},{"title":"Edge Spoke Gateway Deployment Workflow on Self-Managed VMware ESXi and KVM","href":"/docs/enterprise/10.0/guides/connectivity/edge/edge-spoke-workflow-selfmanaged"},{"title":"Create Edge Transit Gateway Attachments","href":"/docs/enterprise/10.0/guides/connectivity/edge/edge-transit-attachments"},{"title":"Deploy an Edge Transit Gateway on Equinix Network Edge","href":"/docs/enterprise/10.0/guides/connectivity/edge/edge-transit-workflow-equinix"},{"title":"Deploy an Edge Transit Gateway on Megaport Virtual Edge","href":"/docs/enterprise/10.0/guides/connectivity/edge/edge-transit-workflow-megaport"},{"title":"Deploy an Edge Transit Gateway on the Aviatrix Edge Platform","href":"/docs/enterprise/10.0/guides/connectivity/edge/edge-transit-workflow-onpremise"},{"title":"Troubleshooting Edge Gateway Connectivity","href":"/docs/enterprise/10.0/guides/connectivity/edge/edge-troubleshooting"}]},{"group":"Gateways","pages":[{"title":"Edge Gateway Attachments","href":"/docs/enterprise/10.0/guides/connectivity/gateways/edge-gateway-attachments"},{"title":"Edge Gateway External Connection","href":"/docs/enterprise/10.0/guides/connectivity/gateways/edge-s2c"},{"title":"External Connection Settings","href":"/docs/enterprise/10.0/guides/connectivity/gateways/external-connection-settings"},{"title":"Transit Gateway CSP Related Settings","href":"/docs/enterprise/10.0/guides/connectivity/gateways/transit-gateway-csp-settings"}]},{"group":"Kubernetes","pages":[{"title":"Securing and Scaling Kubernetes - AWS EKS","href":"/docs/enterprise/10.0/guides/connectivity/kubernetes/secure-eks-design"}]},{"group":"NAT","pages":[{"title":"Tuning for Sub-10 Seconds Failover Time in Overlapping Networks","href":"/docs/enterprise/10.0/guides/connectivity/nat/s2c-overlapping-cidrs-with-fast-convergence"}]},{"group":"Peering","pages":[{"title":"Creating AWS VPC Peering Connection","href":"/docs/enterprise/10.0/guides/connectivity/peering/aws-vpc-peering"},{"title":"Creating Azure VNet Peering Connection","href":"/docs/enterprise/10.0/guides/connectivity/peering/azure-vnet-peering"},{"title":"Multi-Region Multicloud Transit Gateway Peering Workflow","href":"/docs/enterprise/10.0/guides/connectivity/peering/transit-gateway-peering-workflow"},{"title":"Transit Gateway Peering Over Private Network Workflow","href":"/docs/enterprise/10.0/guides/connectivity/peering/transit-peering-over-private-network-hpe"},{"title":"Transit Gateway Peering over Public Network Workflow","href":"/docs/enterprise/10.0/guides/connectivity/peering/transit-peering-over-public-network-hpe"}]},{"group":"Routing","pages":[{"title":"BGP Route Approval","href":"/docs/enterprise/10.0/guides/connectivity/routing/bgp-route-approval"},{"title":"GCP Spoke Single IP SNAT and Tagless Default Routes (Regional VPC)","href":"/docs/enterprise/10.0/guides/connectivity/routing/gcp-spoke-single-ip-snat-regional-vpc"},{"title":"Transit Gateway BGP Over LAN in AWS Workflow","href":"/docs/enterprise/10.0/guides/connectivity/routing/transit-externaldevice-aws-bgpolan"},{"title":"Transit Gateway Multi-Peer BGP Over LAN with Azure Route Server Workflow","href":"/docs/enterprise/10.0/guides/connectivity/routing/transit-externaldevice-azure-bgpolan-ars"},{"title":"Transit Gateway BGP Over LAN in Azure Workflow","href":"/docs/enterprise/10.0/guides/connectivity/routing/transit-externaldevice-azure-bgpolan"},{"title":"Transit Gateway Multi-Peer BGP Over LAN in GCP Workflow","href":"/docs/enterprise/10.0/guides/connectivity/routing/transit-externaldevice-gcp-multipeer-bgpolan"}]},{"group":"Transit","pages":[{"title":"Single-Region Multicloud Transit Network Workflow","href":"/docs/enterprise/10.0/guides/connectivity/transit/transitvpc-workflow"},{"title":"Explicit Azure Route Table Selection for Single IP SNAT","href":"/docs/enterprise/10.0/guides/connectivity/transit/azure-route-table-selection-snat"}]},{"group":"TGW","pages":[{"title":"Overview of AWS Transit Gateway Orchestrator Features","href":"/docs/enterprise/10.0/guides/connectivity/tgw/tgw-overview"},{"title":"AWS Transit Gateway Route Limit Test Validation","href":"/docs/enterprise/10.0/guides/connectivity/tgw/tgw-route-limit"},{"title":"Migrating a CSR Transit to AWS Transit Gateway (TGW)","href":"/docs/enterprise/10.0/guides/connectivity/tgw/tgw-csr-migrate"},{"title":"Migrating a DIY TGW to Aviatrix Managed TGW Deployment","href":"/docs/enterprise/10.0/guides/connectivity/tgw/tgw-migrate-aviatrix-tgw"}]},{"group":"VPN","pages":[{"title":"Site2Cloud Solution for Encryption over Direct Connect/ExpressRoute","href":"/docs/enterprise/10.0/guides/connectivity/vpn/aws-azure-encryption"},{"title":"Using Aviatrix Site2Cloud Tunnels to Access VPC Endpoints in Different Regions","href":"/docs/enterprise/10.0/guides/connectivity/vpn/aws-site2cloud-tunnels"},{"title":"Accessing a Virtual IP Address Instance via Aviatrix Transit Network","href":"/docs/enterprise/10.0/guides/connectivity/vpn/firewall-onprem-virtualip"},{"title":"Networks with Overlapping CIDRs Scenarios","href":"/docs/enterprise/10.0/guides/connectivity/vpn/overlapping-network-connectivity-solutions"},{"title":"Configuring Overlapping Networks with Network Mapped IPsec","href":"/docs/enterprise/10.0/guides/connectivity/vpn/overlapping-networks-mapped-ipsec"},{"title":"Proxy-ID for Routed IPSec Connections","href":"/docs/enterprise/10.0/guides/connectivity/vpn/proxy-id-routed-ipsec-connections"},{"title":"Aviatrix Gateway to Aviatrix Gateway","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-aviatrixgw-to-aviatrixgw"},{"title":"Aviatrix Gateway to AWS Virtual Private Gateway (VGW)","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-aviatrixgw-to-aws-vgw"},{"title":"Aviatrix Gateway to Azure VPN Gateway","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-aviatrixgw-to-azure-vpn"},{"title":"Aviatrix Gateway to Check Point(R77.30)","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-aviatrixgw-to-checkpoint-r77"},{"title":"Aviatrix Gateway to Check Point (R80.10)","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-aviatrixgw-to-checkpoint-r80"},{"title":"Aviatrix Gateway to Cisco ASA","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-aviatrixgw-to-cisco-asa"},{"title":"Aviatrix Gateway to Cisco Ios Router","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-aviatrixgw-to-cisco-ios-router"},{"title":"Aviatrix Gateway to FortiGate","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-aviatrixgw-to-fortigate"},{"title":"Aviatrix Gateway to Juniper SRX","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-aviatrixgw-to-juniper-srx"},{"title":"Aviatrix Integration with Microsoft's SSE Solution","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-aviatrixgw-to-microsoft-entra"},{"title":"Aviatrix Gateway to Oracle Drg","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-aviatrixgw-to-oracle-drg"},{"title":"Aviatrix Gateway to Palo Alto Firewall","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-aviatrixgw-to-paloalto-firewall"},{"title":"Aviatrix Gateway to Sonicwall","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-aviatrixgw-to-sonicwall"},{"title":"Site2Cloud Certificate-Based Authentication","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-cacert"},{"title":"Connect Networks With Overlapping CIDRs","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-cidrs-overlap-connect"},{"title":"Site2Cloud External Connection Workflow","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-configuration-workflow"},{"title":"Connect Overlapping VPC/VNet to On-prem","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-connect-overlap-vpc"},{"title":"Site2Cloud With Customized SNAT","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-customized-snat"},{"title":"Site2Cloud with NAT to fix Overlapping VPC Subnets","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-nat-overlapping"},{"title":"Site2Cloud to a Public IP Address","href":"/docs/enterprise/10.0/guides/connectivity/vpn/s2c-public-ip"},{"title":"Building Site to Site IPsec VPN Connection","href":"/docs/enterprise/10.0/guides/connectivity/vpn/site-to-site-vpn"},{"title":"Using Customized SNAT and DNAT on Spoke Gateway","href":"/docs/enterprise/10.0/guides/connectivity/vpn/spoke-gateway-snat-dnat"},{"title":"Troubleshooting Transit Gateway Connections","href":"/docs/enterprise/10.0/guides/connectivity/vpn/tgw-activemesh-troubleshoot"},{"title":"Transit Gateway GRE Tunneling in AWS Workflow","href":"/docs/enterprise/10.0/guides/connectivity/vpn/transit-externaldevice-aws-gre-tunneling"},{"title":"Transit Gateway Integration with AWS VGW Workflow","href":"/docs/enterprise/10.0/guides/connectivity/vpn/transit-externaldevice-aws-vgw"},{"title":"Transit Gateway Integration with Azure VNG Workflow","href":"/docs/enterprise/10.0/guides/connectivity/vpn/transit-externaldevice-azure-vng"},{"title":"BGP-Enabled Spoke Gateway to External Devices","href":"/docs/enterprise/10.0/guides/connectivity/vpn/transit-externaldevice-bgpspoke"},{"title":"Transit Gateway to Cisco ASA Over the Internet Workflow","href":"/docs/enterprise/10.0/guides/connectivity/vpn/transit-externaldevice-ciscoasa"},{"title":"Transit Gateway to Cisco Router over the Internet Workflow","href":"/docs/enterprise/10.0/guides/connectivity/vpn/transit-externaldevice-ciscorouter"},{"title":"Transit Gateway to FortiGate Over the Internet Workflow","href":"/docs/enterprise/10.0/guides/connectivity/vpn/transit-externaldevice-fortigate"},{"title":"Transit Gateway to JuniperSRX over the Internet Workflow","href":"/docs/enterprise/10.0/guides/connectivity/vpn/transit-externaldevice-junipersrx"},{"title":"Transit Gateway to Palo Alto VM-Series Workflow","href":"/docs/enterprise/10.0/guides/connectivity/vpn/transit-externaldevice-paloalto"},{"title":"Transit Gateway to External Devices Workflow","href":"/docs/enterprise/10.0/guides/connectivity/vpn/transit-externaldevice-workflow"},{"title":"Troubleshooting IPsec VPN Connection with IKEv2","href":"/docs/enterprise/10.0/guides/connectivity/vpn/troubleshooting-ipsec-vpn-ikev2"}]}]},{"group":"Control Plane","pages":[{"title":"CoPilot Deployment Methods","href":"/docs/enterprise/10.0/guides/controlplane/deployment-methods"},{"title":"Planning Your Controller Deployment","href":"/docs/enterprise/10.0/guides/controlplane/planning-deployment"},{"title":"Aviatrix Licensing","href":"/docs/enterprise/10.0/guides/controlplane/aviatrix-licensing"},{"group":"Controller Deployment","pages":[{"title":"Planning Your Controller Deployment","href":"/docs/enterprise/10.0/guides/controlplane/controller-planning-deployment"},{"title":"Planning AWS Deployment","href":"/docs/enterprise/10.0/guides/controlplane/planning-aws-deployment"},{"title":"Subscribing Gateway and Firewall Offers to Private Azure Marketplace for Aviatrix Deployments","href":"/docs/enterprise/10.0/guides/controlplane/azure-powershell-deploy"},{"title":"Controller High Availability in AWS","href":"/docs/enterprise/10.0/guides/controlplane/controller-ha-aws"},{"title":"Configuring an AWS Load Balancer with SSL in Front of Aviatrix Controller","href":"/docs/enterprise/10.0/guides/controlplane/aws-ssl-lb"}]},{"group":"CoPilot Deployment","pages":[{"title":"Planning Your CoPilot Deployment","href":"/docs/enterprise/10.0/guides/controlplane/copilot-planning-deployment"},{"title":"CoPilot Simple Deployment","href":"/docs/enterprise/10.0/guides/controlplane/simple-deployment"},{"title":"Deploying Your CoPilot","href":"/docs/enterprise/10.0/guides/controlplane/copilot-deployment"},{"title":"Deploy CoPilot from Your Controller UI (AWS Only)","href":"/docs/enterprise/10.0/guides/controlplane/deploy-copilot-controller"},{"title":"Deploy CoPilot from the Marketplace","href":"/docs/enterprise/10.0/guides/controlplane/deploy-copilot-marketplace"},{"title":"Deploy CoPilot Using Terraform","href":"/docs/enterprise/10.0/guides/controlplane/deploy-copilot-terraform"},{"title":"Verify the CoPilot Deployment and the Connectivity with Controller","href":"/docs/enterprise/10.0/guides/controlplane/copilot-deployment-verification"},{"title":"Deleting a CoPilot Instance","href":"/docs/enterprise/10.0/guides/controlplane/delete-copilot"}]},{"group":"Initial Setup","pages":[{"title":"Initial Setup of CoPilot","href":"/docs/enterprise/10.0/guides/controlplane/initial-setup"},{"title":"Logging in to CoPilot","href":"/docs/enterprise/10.0/guides/controlplane/ui-login"},{"title":"Onboard Your AWS Access Account in Controller","href":"/docs/enterprise/10.0/guides/controlplane/onboard-account-controller-aws"},{"title":"Post-Deployment Tasks for the Controller","href":"/docs/enterprise/10.0/guides/controlplane/post-deploy-controller"}]},{"group":"Settings and Configuration","pages":[{"title":"CoPilot Settings You Can Enable in Controller","href":"/docs/enterprise/10.0/guides/controlplane/copilot-controller-settings"},{"title":"Migrating CoPilot Data","href":"/docs/enterprise/10.0/guides/controlplane/copilot-migrate"},{"title":"Controller Certificate Management","href":"/docs/enterprise/10.0/guides/controlplane/controller-certificate-management"},{"title":"CoPilot Disk (Volume) Management","href":"/docs/enterprise/10.0/guides/controlplane/disk-management"},{"title":"CA Certificate Rotation of Internal Service","href":"/docs/enterprise/10.0/guides/controlplane/internal-service-ca-rotation"},{"title":"Configure CoPilot for the Aviatrix Platform","href":"/docs/enterprise/10.0/guides/controlplane/platform-integration-points"},{"title":"Re-Encrypt Existing Controller and CoPilot Volumes Using a Custom Key","href":"/docs/enterprise/10.0/guides/controlplane/reencrypt-custom-key"}]},{"group":"Migration","pages":[{"title":"Migrate CoPilot to Appliance V3 (AWS)","href":"/docs/enterprise/10.0/guides/controlplane/migrate-to-appliance-v3"},{"title":"Troubleshoot the CoPilot Migration","href":"/docs/enterprise/10.0/guides/controlplane/migrate-to-appliance-v3-troubleshoot"}]}]},{"group":"Gateways","pages":[{"title":"High Availability Gateways","href":"/docs/enterprise/10.0/guides/gateways/gateway-ha-about"}]},{"group":"Maintenance","pages":[{"title":"Back Up and Restore Your Controller","href":"/docs/enterprise/10.0/guides/maintenance/controller-backup-restore"},{"title":"Overview of the Aviatrix Controller and Gateways Upgrade","href":"/docs/enterprise/10.0/guides/maintenance/upgrade-overview"},{"title":"Upgrade OpenVPN Users","href":"/docs/enterprise/10.0/guides/maintenance/controller-gateway-openvpn-user-upgrade"},{"title":"Upgrade HA Gateways in An ActiveMesh Topology","href":"/docs/enterprise/10.0/guides/maintenance/controller-hagateway-activemesh-topolog"},{"title":"Unattended Upgrades","href":"/docs/enterprise/10.0/guides/maintenance/unattended-upgrade"},{"title":"Upgrade Checklist of the Controller and Gateway Upgrade","href":"/docs/enterprise/10.0/guides/maintenance/controller-upgrade-checklist"},{"title":"Pre-Upgrade Tasks for Controller and Gateways","href":"/docs/enterprise/10.0/guides/maintenance/controller-upgrade-planning"},{"title":"Readiness Check for the Aviatrix Controller Upgrade","href":"/docs/enterprise/10.0/guides/maintenance/controller-upgrade-readiness-check"},{"title":"Procedures for Upgrading Aviatrix Controller and Gateways","href":"/docs/enterprise/10.0/guides/maintenance/controller-upgrade-workflow"},{"title":"Single-Version Upgrade for Controller and Gateways","href":"/docs/enterprise/10.0/guides/maintenance/controller-gateway-upgrade-steps"},{"title":"Upgrade Your Controller and Gateways","href":"/docs/enterprise/10.0/guides/maintenance/controller-gateway-upgrade-controller"},{"title":"Upgrade Gateways in Groups","href":"/docs/enterprise/10.0/guides/maintenance/gateway-upgrade-groups"},{"title":"Upgrading Your Gateway Image","href":"/docs/enterprise/10.0/guides/maintenance/gateway-image-upgrade"},{"title":"Gateway Drain and Undrain During Image Upgrade and Maintenance","href":"/docs/enterprise/10.0/guides/maintenance/gateway-drain-undrain-upgrades"},{"title":"Upgrade Your Aviatrix Controller Image Overview","href":"/docs/enterprise/10.0/guides/maintenance/upgrade-controller-image-overview"},{"title":"Upgrade your Controller and Gateways to the Latest Aviatrix Supported Images (AWS and Azure Only)","href":"/docs/enterprise/10.0/guides/maintenance/controller-gateway-upgrade-latest-image"},{"title":"Upgrade Your Controller to the Latest Aviatrix Supported Images (AWS and Azure Only)","href":"/docs/enterprise/10.0/guides/maintenance/controller-upgrade-latest-image"},{"title":"Upgrade Gateways for the Latest Aviatrix Supported Images (AWS and Azure Only)","href":"/docs/enterprise/10.0/guides/maintenance/gateway-upgrade-latest-image"},{"title":"Troubleshooting Controller and Gateway Upgrades","href":"/docs/enterprise/10.0/guides/maintenance/controller-gateway-upgrade-troubleshooting"},{"title":"Verify Your Upgrade Status","href":"/docs/enterprise/10.0/guides/maintenance/controller-gateway-upgrade-verify"},{"title":"Controller Migration","href":"/docs/enterprise/10.0/guides/maintenance/controller-migration"},{"title":"Upgrading Gateway Image","href":"/docs/enterprise/10.0/guides/maintenance/gateway-image-migration"},{"title":"Installing Software and Security Patches","href":"/docs/enterprise/10.0/guides/maintenance/copilot-installing-patches"}]},{"group":"Monitoring","pages":[{"title":"Controller and Gateway Logging","href":"/docs/enterprise/10.0/guides/monitoring/aviatrix-logging"},{"title":"AWS CloudWatch Integration","href":"/docs/enterprise/10.0/guides/monitoring/logging-integration-cloudwatch"},{"title":"External Monitoring with the Metrics and Status APIs","href":"/docs/enterprise/10.0/guides/monitoring/metrics-api-enable"},{"title":"Monitoring Business Unit Costs with CostIQ","href":"/docs/enterprise/10.0/guides/monitoring/network-costs"},{"title":"Viewing Recent Changes Made to Your Network","href":"/docs/enterprise/10.0/guides/monitoring/topology-replay"},{"title":"Gaining Visibility into Your Network Topology","href":"/docs/enterprise/10.0/guides/monitoring/topology-visibility"},{"title":"Monitoring Traffic Flows","href":"/docs/enterprise/10.0/guides/monitoring/traffic-flows"},{"title":"Notifications (Alerts) About Network Events","href":"/docs/enterprise/10.0/guides/monitoring/user-alerts-network"}]},{"group":"Platform Administration","pages":[{"title":"Setting Up Azure Account Credentials","href":"/docs/enterprise/10.0/guides/platform-administration/account-azure"},{"title":"Admin Users and Duo Sign in","href":"/docs/enterprise/10.0/guides/platform-administration/admin-users-duo"},{"title":"Setting up Alibaba Cloud Account Credentials","href":"/docs/enterprise/10.0/guides/platform-administration/aviatrix-account-alibaba"},{"title":"Managing Access Accounts","href":"/docs/enterprise/10.0/guides/platform-administration/aviatrix-account"},{"title":"Connecting a Cloud Account","href":"/docs/enterprise/10.0/guides/platform-administration/cloud-account-create"},{"title":"DNS Server Configurations for the Aviatrix Controller","href":"/docs/enterprise/10.0/guides/platform-administration/copilot-dns-controller"},{"title":"CoPilot SAML Authentication","href":"/docs/enterprise/10.0/guides/platform-administration/copilot-saml-authentication"},{"title":"Use Azure IAM Custom Role","href":"/docs/enterprise/10.0/guides/platform-administration/custom-role-azure"},{"title":"DNS Server Configuration for Aviatrix Services","href":"/docs/enterprise/10.0/guides/platform-administration/dns-server-general"},{"title":"GCP Account Onboarding","href":"/docs/enterprise/10.0/guides/platform-administration/gcp-account-onboarding"},{"title":"IP Whitelist AWS Azure","href":"/docs/enterprise/10.0/guides/platform-administration/ip-whitelist-aws-azure"},{"title":"Admin Users and Duo Sign in","href":"/docs/enterprise/10.0/guides/platform-administration/objective-duo"},{"title":"Role-Based Access Control (RBAC) or User Access Overview","href":"/docs/enterprise/10.0/guides/platform-administration/rbac-faq"},{"title":"Set Up SAML Login for CoPilot","href":"/docs/enterprise/10.0/guides/platform-administration/saml-login-setup"}]},{"group":"Security","pages":[{"group":"DCF","pages":[{"title":"Creating Groups for Distributed Cloud Firewall","href":"/docs/enterprise/10.0/guides/security/dcf/dcf-create-groups"},{"title":"Disabling the Distributed Cloud Firewall Feature","href":"/docs/enterprise/10.0/guides/security/dcf/dcf-disable-feature"},{"title":"Distributed Cloud Firewall Setup and Default Action Rule","href":"/docs/enterprise/10.0/guides/security/dcf/dcf-enable-feature"},{"title":"About Distributed Cloud Firewall Settings","href":"/docs/enterprise/10.0/guides/security/dcf/dcf-settings"},{"title":"Extending Distributed Cloud Firewall to your Network Edge","href":"/docs/enterprise/10.0/guides/security/dcf/edge-dcf"},{"title":"Migrating from Legacy Egress to Distributed Cloud Firewall","href":"/docs/enterprise/10.0/guides/security/dcf/egress-migration"},{"title":"Onboarding Kubernetes Clusters","href":"/docs/enterprise/10.0/guides/security/dcf/kubernetes-onboard"},{"title":"Onboard EKS Clusters","href":"/docs/enterprise/10.0/guides/security/dcf/kubernetes-onboard-eks"},{"title":"Onboard AKS Clusters","href":"/docs/enterprise/10.0/guides/security/dcf/kubernetes-onboard-aks"},{"title":"Onboard GKE Clusters","href":"/docs/enterprise/10.0/guides/security/dcf/kubernetes-onboard-gke"},{"title":"Onboard Self-Managed or Custom Kubernetes Clusters","href":"/docs/enterprise/10.0/guides/security/dcf/kubernetes-onboard-custom"},{"title":"Onboarding Private Kubernetes Clusters","href":"/docs/enterprise/10.0/guides/security/dcf/private-kubernetes-cluster-onboard"},{"title":"Discovery of Kubernetes Resources","href":"/docs/enterprise/10.0/guides/security/dcf/kubernetes-resource-discovery"},{"title":"Distributed Cloud Firewall for Kubernetes","href":"/docs/enterprise/10.0/guides/security/dcf/dcf-kubernetes"},{"title":"Distributed Cloud Firewall Logging","href":"/docs/enterprise/10.0/guides/security/dcf/dcf-logging"},{"title":"OCI Support for Distributed Cloud Firewall","href":"/docs/enterprise/10.0/guides/security/dcf/dcf-oci"},{"title":"Distributed Cloud Firewall for Serverless Resources (Early Access)","href":"/docs/enterprise/10.0/guides/security/dcf/dcf-serverless-resources"},{"title":"Intrusion Prevention System (IPS)","href":"/docs/enterprise/10.0/guides/security/dcf/ips"},{"title":"MultiWriter Policy via Terraform","href":"/docs/enterprise/10.0/guides/security/dcf/multiwriter-policy-terraform"},{"title":"Policy Audit Enhancement for Distributed Cloud Firewall","href":"/docs/enterprise/10.0/guides/security/dcf/policy-audit"},{"title":"Centralized Security Hub VPC (Early Access)","href":"/docs/enterprise/10.0/guides/security/dcf/centralized-security-hub-vpc"}]},{"group":"Egress","pages":[{"title":"Implementing Egress in an Aviatrix-Managed Network","href":"/docs/enterprise/10.0/guides/security/egress/egress-introduction"},{"title":"Managing Egress Security for VPC/VNets","href":"/docs/enterprise/10.0/guides/security/egress/egress-vpc-vnets-tab"},{"title":"Protecting Egress Traffic with the Egress Protection Workflow","href":"/docs/enterprise/10.0/guides/security/egress/egress-protect-vpc-vnets"},{"title":"Enabling Local Egress","href":"/docs/enterprise/10.0/guides/security/egress/egress-enabling-local"},{"title":"Monitoring Egress Traffic","href":"/docs/enterprise/10.0/guides/security/egress/egress-monitor-vpc-vnets"},{"title":"Unprotecting and Monitoring a VPC/VNet","href":"/docs/enterprise/10.0/guides/security/egress/egress-unprotect-monitor"},{"title":"Aviatrix Cloud Firewall Secure Egress Implementation Guide","href":"/docs/enterprise/10.0/guides/security/egress/aviatrix-cloud-firewall-implementation"},{"title":"Egress FQDN Filtering (Legacy)","href":"/docs/enterprise/10.0/guides/security/egress/egress-legacy-overview"},{"title":"Configure MCP Server Egress Containment with Obot on EKS","sidebarTitle":"MCP Containment: Obot (EKS)","href":"/docs/enterprise/10.0/guides/security/egress/mcp-egress-containment-obot-aws"},{"title":"Configure MCP Server Egress Containment with Obot on AKS","sidebarTitle":"MCP Containment: Obot (AKS)","href":"/docs/enterprise/10.0/guides/security/egress/mcp-egress-containment-obot-azure"},{"title":"Configure MCP Server Egress Containment for Self-Hosted MCP Servers","sidebarTitle":"MCP Containment: Self-Hosted","href":"/docs/enterprise/10.0/guides/security/egress/mcp-egress-containment-self-hosted"},{"title":"Secure AWS Bedrock AgentCore Agent Workloads","sidebarTitle":"Agent Containment: AWS Bedrock","href":"/docs/enterprise/10.0/guides/security/egress/ai-agent-containment-aws-bedrock"},{"title":"Secure Microsoft Foundry Agents with Enterprise Transit","sidebarTitle":"Microsoft Foundry: With Transit","href":"/docs/enterprise/10.0/guides/security/egress/ai-agent-containment-azure-foundry-transit"},{"title":"Secure Microsoft Foundry Agents with a Standalone Gateway","sidebarTitle":"Microsoft Foundry: Standalone","href":"/docs/enterprise/10.0/guides/security/egress/ai-agent-containment-azure-foundry-standalone"},{"title":"Secure Self-Hosted AI Agent Workloads on Kubernetes","sidebarTitle":"Agent Containment: Self-Hosted","href":"/docs/enterprise/10.0/guides/security/egress/ai-agent-containment-self-hosted"}]},{"group":"East-West","pages":[{"title":"East-West Traffic Inspection Overview","href":"/docs/enterprise/10.0/guides/security/east-west/east-west-overview"},{"title":"Transparent DCF Protection with AWS Transit Gateway","href":"/docs/enterprise/10.0/guides/security/east-west/transparent-dcf-protection-aws-tgw"}]},{"group":"Firenet","pages":[{"title":"Configuring Transit FireNet","href":"/docs/enterprise/10.0/guides/security/firenet/transit-firenet-overview"},{"title":"Managing Firewalls in Transit FireNet","href":"/docs/enterprise/10.0/guides/security/firenet/firewall-overview"},{"title":"Transit FireNet Workflow for AWS","href":"/docs/enterprise/10.0/guides/security/firenet/transit-firenet-workflow-aws"},{"title":"Transit FireNet Workflow for AWS TGW","href":"/docs/enterprise/10.0/guides/security/firenet/transit-firenet-workflow-aws-tgw"},{"title":"Transit FireNet Workflow for Azure","href":"/docs/enterprise/10.0/guides/security/firenet/transit-firenet-workflow-azure"},{"title":"Transit FireNet Workflow for GCP","href":"/docs/enterprise/10.0/guides/security/firenet/transit-firenet-workflow-gcp"},{"title":"Transit FireNet Workflow for OCI","href":"/docs/enterprise/10.0/guides/security/firenet/transit-firenet-workflow-oci"},{"title":"Transit FireNet Workflow for Egress","href":"/docs/enterprise/10.0/guides/security/firenet/transit-firenet-workflow-egress"},{"title":"Attaching a Spoke to a Transit FireNet","href":"/docs/enterprise/10.0/guides/security/firenet/transit-firenet-attach-spoke"},{"title":"Subscribing to a Firewall Instance (AWS)","href":"/docs/enterprise/10.0/guides/security/firenet/firewall-subscribe-aws"},{"title":"Deploying a Firewall","href":"/docs/enterprise/10.0/guides/security/firenet/firewall-launch-attach"},{"title":"Disassociating or Deleting Firewall Association","href":"/docs/enterprise/10.0/guides/security/firenet/firewall-delete-disassociate"},{"title":"Checking the Health of Your Firewall","href":"/docs/enterprise/10.0/guides/security/firenet/firenet-health"},{"title":"Transit FireNet Vendor Integration","href":"/docs/enterprise/10.0/guides/security/firenet/firenet-vendor-integration"},{"title":"Transit FireNet Diagnostics","href":"/docs/enterprise/10.0/guides/security/firenet/transit-firenet-diagnostics"},{"title":"Managing VM-Series by Panorama","href":"/docs/enterprise/10.0/guides/security/firenet/firewall-panorama-configure"},{"title":"Migrating from Individual VM to Panorama","href":"/docs/enterprise/10.0/guides/security/firenet/firewall-panorama-migrate"},{"title":"Deploying Check Point CloudGuard","href":"/docs/enterprise/10.0/guides/security/firenet/config-checkpoint"},{"title":"AWS Ingress Firewall Setup Solution","href":"/docs/enterprise/10.0/guides/security/firenet/ingress-firewall-example"},{"title":"Azure Ingress Firewall Setup Solution","href":"/docs/enterprise/10.0/guides/security/firenet/azure-ingress-firewall-example"},{"title":"Ingress Protection via Aviatrix Transit FireNet with Palo Alto in GCP","href":"/docs/enterprise/10.0/guides/security/firenet/paloalto-ingress-gcp"},{"title":"Restrictive Firewall Management Security Groups for Azure","href":"/docs/enterprise/10.0/guides/security/firenet/restrictive-firewall-management-security-groups"}]},{"title":"Detecting Network Anomalies using Network Behavior Analytics","href":"/docs/enterprise/10.0/guides/security/network-anomalies"},{"title":"Network Segmentation","href":"/docs/enterprise/10.0/guides/security/network-segmentation-secured"},{"title":"Platform Security Hardening Guidelines","href":"/docs/enterprise/10.0/guides/security/security-hardening-guidelines"},{"title":"General Guidelines for Migrating from Legacy ThreatIQ and Geoblocking to Distributed Cloud Firewall","href":"/docs/enterprise/10.0/guides/security/threatiq-geo-dcf-migration-guidelines"}]},{"group":"Troubleshooting","pages":[{"title":"CoPilot Support and Troubleshooting","href":"/docs/enterprise/10.0/guides/troubleshooting/copilot-support"},{"title":"Troubleshooting Routing Issues in Your Aviatrix-Managed Network","href":"/docs/enterprise/10.0/guides/troubleshooting/diagnose-cloud-routes"},{"title":"Interpreting Gateway Diagnostic Results","href":"/docs/enterprise/10.0/guides/troubleshooting/troubleshoot-diagnostic-result"}]},{"group":"UserVPN","pages":[{"title":"Migrating to Azure VPN Load Balancer Standard SKU","href":"/docs/enterprise/10.0/guides/uservpn/migrate-lb-sku"},{"title":"Deploying Aviatrix UserVPN with AWS TGW","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-aws-tgw"},{"title":"CA Certificate Rotation of UserVPN","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-ca-rotation"},{"title":"Download the Aviatrix VPN Client","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-client-download"},{"title":"Aviatrix VPN Client User Guide","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-client-user-guide"},{"title":"Aviatrix VPN User Authentication with Duo IdP","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-duo-authentication"},{"title":"Creating a UserVPN Default Gateway","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-gateway-default-vpn-create"},{"title":"Editing VPN Gateways","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-gateway-edit"},{"title":"Deleting a VPN Gateway","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-gateway-delete"},{"title":"Creating a Geo VPN Gateway","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-gateway-geo-vpn-create"},{"title":"UserVPN Gateway Guide","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-gateway-guide"},{"title":"Aviatrix LDAP-Based Authentication","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-ldap-authenticaton"},{"title":"Aviatrix VPN User Authentication with an Okta API Token","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-okta-authentication"},{"title":"Aviatrix SAML Authentication on Microsoft Entra ID IdP","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-saml-authentication-entra-id"},{"title":"Aviatrix SAML Authentication on Microsoft Entra Id IdP","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-saml-authentication-entra-id1"},{"title":"Aviatrix SAML Authentication on Okta IdP","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-saml-authentication-okta"},{"title":"Aviatrix SAML Authentication on OneLogin IdP","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-saml-authentication-onelogin"},{"title":"Aviatrix SAML-Based Authentication","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-saml-authentication"},{"title":"Setting Up Okta SAML with Profile Attribute","href":"/docs/enterprise/10.0/guides/uservpn/user-vpn-saml-okta-set-profile-attribute"}]}]},{"group":"Reference","icon":"book","pages":[{"group":"CoPilot UI","pages":[{"title":"Dashboard","href":"/docs/enterprise/10.0/reference/ui/dashboard/index"},{"group":"Cloud Fabric","pages":[{"title":"Topology","href":"/docs/enterprise/10.0/reference/ui/cloud-fabric/topology"},{"title":"Gateways","href":"/docs/enterprise/10.0/reference/ui/cloud-fabric/gateways"},{"title":"Hybrid Cloud","href":"/docs/enterprise/10.0/reference/ui/cloud-fabric/hybrid-cloud"},{"title":"Scaling","href":"/docs/enterprise/10.0/reference/ui/cloud-fabric/scaling"},{"title":"UserVPN","href":"/docs/enterprise/10.0/reference/ui/cloud-fabric/uservpn"}]},{"group":"Networking","pages":[{"title":"Network Segmentation","href":"/docs/enterprise/10.0/reference/ui/networking/network-segmentation"},{"title":"Connectivity","href":"/docs/enterprise/10.0/reference/ui/networking/connectivity"}]},{"group":"Security","pages":[{"title":"Distributed Cloud Firewall","href":"/docs/enterprise/10.0/reference/ui/security/distributed-cloud-firewall"},{"title":"Egress","href":"/docs/enterprise/10.0/reference/ui/security/egress"},{"title":"FireNet","href":"/docs/enterprise/10.0/reference/ui/security/firenet"},{"title":"Anomaly Detection","href":"/docs/enterprise/10.0/reference/ui/security/anomaly-detection"}]},{"title":"Groups","href":"/docs/enterprise/10.0/reference/ui/groups/index"},{"group":"Cloud Resources","pages":[{"title":"Cloud Account","href":"/docs/enterprise/10.0/reference/ui/cloud-resources/cloud-account"},{"title":"Cloud Workloads","href":"/docs/enterprise/10.0/reference/ui/cloud-resources/cloud-workloads"},{"title":"Cloud Networks","href":"/docs/enterprise/10.0/reference/ui/cloud-resources/cloud-networks"}]},{"group":"Monitor","pages":[{"title":"FlowIQ","href":"/docs/enterprise/10.0/reference/ui/monitor/flowiq"},{"title":"Performance","href":"/docs/enterprise/10.0/reference/ui/monitor/performance"},{"title":"Traffic \u0026 Latencies","href":"/docs/enterprise/10.0/reference/ui/monitor/traffic-latencies"},{"title":"Notifications","href":"/docs/enterprise/10.0/reference/ui/monitor/notifications"}]},{"group":"Diagnostics","pages":[{"title":"AppIQ","href":"/docs/enterprise/10.0/reference/ui/diagnostics/appiq"},{"title":"Diagnostic tools","href":"/docs/enterprise/10.0/reference/ui/diagnostics/diagnostic-tools"},{"title":"Cloud Routes","href":"/docs/enterprise/10.0/reference/ui/diagnostics/cloud-routes"}]},{"group":"Administration","pages":[{"title":"User Access","href":"/docs/enterprise/10.0/reference/ui/administration/user-access"},{"title":"Reports","href":"/docs/enterprise/10.0/reference/ui/administration/reports"},{"title":"Audit","href":"/docs/enterprise/10.0/reference/ui/administration/audit"},{"title":"Maintenance","href":"/docs/enterprise/10.0/reference/ui/administration/maintenance"},{"title":"Billing","href":"/docs/enterprise/10.0/reference/ui/administration/billing"}]},{"group":"Settings","pages":[{"title":"Configuration","href":"/docs/enterprise/10.0/reference/ui/settings/configuration"},{"title":"Resources","href":"/docs/enterprise/10.0/reference/ui/settings/resources"},{"title":"Support","href":"/docs/enterprise/10.0/reference/ui/settings/support"}]}]},{"group":"General","pages":[{"title":"Multicloud Rosetta Stone","href":"/docs/enterprise/10.0/reference/general/cloud-rosetta-stone"},{"title":"Aviatrix Glossary","href":"/docs/enterprise/10.0/reference/general/aviatrix-glossary"},{"title":"General Glossary","href":"/docs/enterprise/10.0/reference/general/general-glossary"},{"title":"How to Read Diagrams","href":"/docs/enterprise/10.0/reference/general/how-to-read-diagrams"},{"title":"Error Messages","href":"/docs/enterprise/10.0/reference/general/error-messages"},{"title":"Federal Information Processing Standard (FIPS) 140-2 Module","href":"/docs/enterprise/10.0/reference/general/fips-140-2"},{"title":"Federal Information Processing Standard (FIPS) 140-3","href":"/docs/enterprise/10.0/reference/general/fips-140-3"},{"title":"AWS IAM Roles and Policies","href":"/docs/enterprise/10.0/reference/general/iam-role"},{"title":"Account with Access Key for AWS China Accounts","href":"/docs/enterprise/10.0/reference/general/access-key"},{"title":"Required External Access for Aviatrix Products","href":"/docs/enterprise/10.0/reference/general/required-external-access"},{"title":"Managing the Relationship Between Feeds and ExternalGroups","href":"/docs/enterprise/10.0/reference/externalgroup-about"}]},{"group":"Best Practices","pages":[{"title":"Network Resiliency Best Practices Guide","href":"/docs/enterprise/10.0/reference/best-practices/network-resiliency-best-practice"},{"title":"Secure VPCs Best Practices Guide","href":"/docs/enterprise/10.0/reference/best-practices/secure-vpcs-best-practice"}]},{"group":"Control Plane","pages":[{"title":"Aviatrix CoPilot FAQs","href":"/docs/enterprise/10.0/reference/controlplane/copilot-faq"},{"title":"CoPilot Access Control","href":"/docs/enterprise/10.0/reference/controlplane/copilot-access-control"},{"title":"Controller to CoPilot Terminology and Navigation Guide","href":"/docs/enterprise/10.0/reference/controlplane/controller-to-copilot-mapping"},{"title":"CoPilot IP Access List Management","href":"/docs/enterprise/10.0/reference/controlplane/copilot-ip-access-management"},{"title":"CoPilot Requirements","href":"/docs/enterprise/10.0/reference/controlplane/copilot-platform-requirements"},{"title":"CoPilot Security Group Management","href":"/docs/enterprise/10.0/reference/controlplane/copilot-security-group-management"},{"title":"CoPilot User Account Administration","href":"/docs/enterprise/10.0/reference/controlplane/copilot-user-account-administration"},{"title":"FIPS 140-2 Module","href":"/docs/enterprise/10.0/reference/controlplane/security-controller-fips"},{"title":"Aviatrix Service Time Synchronization Policy","href":"/docs/enterprise/10.0/reference/controlplane/time-sync-policy"},{"title":"CoPilot Tuning and Performance","href":"/docs/enterprise/10.0/reference/controlplane/tuning-performance"}]},{"group":"Gateways","pages":[{"title":"Gateway Performance and Sizing","href":"/docs/enterprise/10.0/reference/gateways/gateway-sizing"},{"title":"Gateway States","href":"/docs/enterprise/10.0/reference/gateways/gateway-state"},{"title":"Gateway Keepalive","href":"/docs/enterprise/10.0/reference/gateways/gateway-keepalive"},{"title":"Disabling Rollback on Gateway Creation Error","href":"/docs/enterprise/10.0/reference/gateways/gateway-keep-on-error"},{"title":"Performance Improvement with Gateway Scaling","href":"/docs/enterprise/10.0/reference/gateways/gateway-scaling"},{"title":"Support for IPv6 on Aviatrix Gateways","href":"/docs/enterprise/10.0/reference/gateways/gateway-ipv6-enable"},{"title":"DNS Server Configuration for Aviatrix Gateways","href":"/docs/enterprise/10.0/reference/gateways/transit-spoke-dns"},{"title":"High Performance Encryption Performance Benchmarks","href":"/docs/enterprise/10.0/reference/gateways/hpe-perf-benchmark"},{"group":"Edge","pages":[{"title":"Supported Edge Hardware for the Aviatrix Edge Platform","href":"/docs/enterprise/10.0/reference/gateways/edge/edge-hardware-specs"},{"title":"Edge Gateway Virtual Machine Requirements","href":"/docs/enterprise/10.0/reference/gateways/edge/edge-vm-requirements"},{"title":"Dell Poweredge Bios Configuration","href":"/docs/enterprise/10.0/reference/gateways/edge/edge-device-bios-config"},{"title":"Prerequisites for Edge Spoke Gateway Deployment on Aviatrix Edge Platform","href":"/docs/enterprise/10.0/reference/gateways/edge/edge-spoke-planning-aep"},{"title":"Prerequisites for Edge Spoke Gateway Deployment on Equinix Network Edge","href":"/docs/enterprise/10.0/reference/gateways/edge/edge-spoke-planning-equinix"},{"title":"Prerequisites for Edge Spoke Gateway Deployment on Megaport Virtual Edge","href":"/docs/enterprise/10.0/reference/gateways/edge/edge-spoke-planning-megaport"},{"title":"Prerequisites for Edge Spoke Deployment on VMware ESXi and KVM","href":"/docs/enterprise/10.0/reference/gateways/edge/edge-spoke-planning-selfmanaged"},{"title":"Prerequisites for Edge Transit Gateway Deployment on the Aviatrix Edge Platform","href":"/docs/enterprise/10.0/reference/gateways/edge/edge-transit-planning-aep"},{"title":"Prerequisites for Edge Transit Gateway Deployment on Equinix Network Edge","href":"/docs/enterprise/10.0/reference/gateways/edge/edge-transit-planning-equinix"},{"title":"Prerequisites for Edge Transit Gateway Deployment on Megaport Virtual Edge","href":"/docs/enterprise/10.0/reference/gateways/edge/edge-transit-planning-megaport"},{"title":"Prerequisites for Edge Spoke and Edge Transit Deployment on Edge Platforms","href":"/docs/enterprise/10.0/reference/gateways/edge/edge-spoke-transit-planning"},{"title":"Edge Spoke Gateway Interfaces","href":"/docs/enterprise/10.0/reference/gateways/edge/edge-spoke-interfaces"}]},{"group":"Auto Right-Sizing","pages":[{"title":"Selecting Auto Right-Sizing Settings","href":"/docs/enterprise/10.0/reference/gateways/auto-right-sizing/auto-right-sizing-settings"},{"title":"Auto Right-Sizing Metrics and Optimization","href":"/docs/enterprise/10.0/reference/gateways/auto-right-sizing/ars-metrics"},{"title":"Auto Right-Sizing Maintenance Window","href":"/docs/enterprise/10.0/reference/gateways/auto-right-sizing/auto-right-sizing-maintenance"},{"title":"Mapping Aviatrix Standard Gateway Sizes to VM Instance Sizes","href":"/docs/enterprise/10.0/reference/gateways/auto-right-sizing/auto-right-sizing-standard-sizes"}]}]},{"group":"Connectivity","pages":[{"title":"External BGP Connection Notification Settings","href":"/docs/enterprise/10.0/reference/connectivity/external-connections-bgp-settings"}]},{"group":"Monitoring","pages":[{"title":"Aviatrix Log Formats","href":"/docs/enterprise/10.0/reference/monitoring/aviatrix-log-format"},{"title":"Billing Item Descriptions","href":"/docs/enterprise/10.0/reference/monitoring/billing-item-descriptions"},{"title":"Metrics Monitored for Aviatrix Resources","href":"/docs/enterprise/10.0/reference/monitoring/metrics-monitor"}]},{"group":"Security","pages":[{"group":"Egress","pages":[{"title":"Egress Security Score","href":"/docs/enterprise/10.0/reference/egress-filtering/egress-security-score"},{"title":"How is Egress Security Score Calculated","href":"/docs/enterprise/10.0/reference/security/egress/egress-security-score-calculated"}]},{"group":"FireNet","pages":[{"title":"Supported Firewall Versions","href":"/docs/enterprise/10.0/reference/security/firenet/firewalls-supported-versions"},{"title":"Firewall Interface Specifications","href":"/docs/enterprise/10.0/reference/security/firenet/firewall-interfaces"},{"title":"Load Balancing Traffic Between Different Firewalls","href":"/docs/enterprise/10.0/reference/security/firenet/firenet-load-balance"},{"title":"Transit FireNet Security Groups","href":"/docs/enterprise/10.0/reference/security/firenet/firenet-security-groups"},{"title":"Aviatrix FireNet / AWS Transit Gateway Native Deployment Comparison","href":"/docs/enterprise/10.0/reference/security/firenet/firenet-deployment-tgw"},{"title":"Example Configuration for FortiGate VM in GCP","href":"/docs/enterprise/10.0/reference/security/firenet/config-fortigate-gcp"},{"title":"Example Configuration for Check Point VM in AWS","href":"/docs/enterprise/10.0/reference/security/firenet/firewall-check-point-aws"},{"title":"Example Configuration for Check Point VM in Azure","href":"/docs/enterprise/10.0/reference/security/firenet/firewall-check-point-azure"},{"title":"Example Configuration for Palo Alto VM-Series in AWS","href":"/docs/enterprise/10.0/reference/security/firenet/firewall-paloalto-configure-aws"},{"title":"Example Configuration for Palo Alto VM-Series in Azure","href":"/docs/enterprise/10.0/reference/security/firenet/firewall-paloalto-configure-azure"},{"title":"Example Configuration for FortiGate VM in AWS","href":"/docs/enterprise/10.0/reference/security/firenet/fortigate-example-intro-aws"},{"title":"Example Configuration for FortiGate VM in Azure","href":"/docs/enterprise/10.0/reference/security/firenet/fortigate-example-intro-azure"},{"title":"Example Configuration for Palo Alto Network VM-Series in GCP","href":"/docs/enterprise/10.0/reference/security/firenet/paloalto-vmseries-gcp"},{"title":"Example Configuration for Palo Alto Network VM-Series in OCI","href":"/docs/enterprise/10.0/reference/security/firenet/paloalto-vmseries-oci"}]},{"group":"DCF","pages":[{"title":"Distributed Cloud Firewall Supported Capabilities","href":"/docs/enterprise/10.0/reference/dcf/dcf-capabilities"},{"title":"Configuring Distributed Cloud Firewall","href":"/docs/enterprise/10.0/reference/dcf/dcf-configuring"},{"title":"Public Subnet Filtering and Distributed Cloud Firewall","href":"/docs/enterprise/10.0/reference/dcf/dcf-psf"},{"title":"External Connection (Site2Cloud) and Distributed Cloud Firewall","href":"/docs/enterprise/10.0/reference/dcf/dcf-s2c"},{"title":"Distributed Cloud Firewall and Transit Egress","href":"/docs/enterprise/10.0/reference/dcf/dcf-transit-egress"},{"title":"Kubernetes Onboarding Prerequisites","href":"/docs/enterprise/10.0/reference/dcf/kubernetes-prerequisites"},{"title":"Disable SNAT for Kubernetes Workloads","href":"/docs/enterprise/10.0/reference/dcf/kubernetes-snat"},{"title":"Kubernetes CRD Reference","href":"/docs/enterprise/10.0/reference/dcf/kubernetes-crd-reference"}]}]},{"group":"Terraform","pages":[{"title":"Terraform Modules","href":"/docs/enterprise/10.0/reference/terraform/modules"},{"title":"Terraform Provider","url":"https://registry.terraform.io/providers/AviatrixSystems/aviatrix/latest/docs","href":"/docs/enterprise/10.0/reference/terraform/provider"}]},{"group":"API Reference","pages":[{"title":"Overview","href":"/docs/enterprise/10.0/reference/api/overview"},{"title":"API Changelog","href":"/docs/enterprise/10.0/reference/api/changelog"},{"group":"Access \u0026 Identity","pages":[{"group":"Account Management","pages":[{"title":"List Account Users","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_account_users","href":"/reference/api/10.0/account-management/get-v2apilist_account_users"},{"title":"List Accounts","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_accounts","href":"/reference/api/10.0/account-management/get-v2apilist_accounts"},{"title":"Add Account User","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_account_user","href":"/reference/api/10.0/account-management/post-v2apiadd_account_user"},{"title":"Add Admin Email","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_admin_email_addr","href":"/reference/api/10.0/account-management/post-v2apiadd_admin_email_addr"},{"title":"Delete Account Profile","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_account_profile","href":"/reference/api/10.0/account-management/post-v2apidelete_account_profile"},{"title":"Delete Account User","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_account_user","href":"/reference/api/10.0/account-management/post-v2apidelete_account_user"},{"title":"Edit Account Alias","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_account_alias","href":"/reference/api/10.0/account-management/post-v2apiedit_account_alias"},{"title":"Edit Account Profile","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_account_profile","href":"/reference/api/10.0/account-management/post-v2apiedit_account_profile"},{"title":"Edit Account User","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_account_user","href":"/reference/api/10.0/account-management/post-v2apiedit_account_user"}]},{"group":"Authentication","pages":[{"title":"Admin login status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_admin_login_status","href":"/reference/api/10.0/authentication/get-v2apiget_admin_login_status"},{"title":"Duo API server status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_duo_api_server_status","href":"/reference/api/10.0/authentication/get-v2apiget_duo_api_server_status"},{"title":"Duo login status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_duo_login_status","href":"/reference/api/10.0/authentication/get-v2apiget_duo_login_status"},{"title":"LDAP login status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_ldap_login_status","href":"/reference/api/10.0/authentication/get-v2apiget_ldap_login_status"},{"title":"List controller SAML login","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_controller_saml_login","href":"/reference/api/10.0/authentication/get-v2apilist_controller_saml_login"},{"title":"Disable local login","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_local_login","href":"/reference/api/10.0/authentication/post-v2apidisable_local_login"},{"title":"Forget Controller Password","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/forgot_password","href":"/reference/api/10.0/authentication/post-v2apiforgot_password"},{"title":"Initial Setup","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/initial_setup","href":"/reference/api/10.0/authentication/post-v2apiinitial_setup"},{"title":"Login","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/login","href":"/reference/api/10.0/authentication/post-v2apilogin"},{"title":"Setup Account Profile","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/setup_account_profile","href":"/reference/api/10.0/authentication/post-v2apisetup_account_profile"},{"title":"Setup Customer ID","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/setup_customer_id","href":"/reference/api/10.0/authentication/post-v2apisetup_customer_id"},{"title":"Show LDAP conf","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_ldap_conf","href":"/reference/api/10.0/authentication/post-v2apishow_ldap_conf"},{"title":"Test LDAP bind","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/test_ldap_bind","href":"/reference/api/10.0/authentication/post-v2apitest_ldap_bind"},{"title":"Test LDAP configuration","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/test_ldap_configuration","href":"/reference/api/10.0/authentication/post-v2apitest_ldap_configuration"}]},{"group":"RBAC \u0026 Permissions","pages":[{"title":"List access account details in rbac group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_access_account_details_in_rbac_group","href":"/reference/api/10.0/rbac/get-v2apilist_access_account_details_in_rbac_group"},{"title":"List access accounts addable to rbac group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_access_accounts_addable_to_rbac_group","href":"/reference/api/10.0/rbac/get-v2apilist_access_accounts_addable_to_rbac_group"},{"title":"List Access Accounts in RBAC Group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_access_accounts_in_rbac_group","href":"/reference/api/10.0/rbac/get-v2apilist_access_accounts_in_rbac_group"},{"title":"List permission group details","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_permission_group_details","href":"/reference/api/10.0/rbac/get-v2apilist_permission_group_details"},{"title":"List Permission Groups","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_permission_groups","href":"/reference/api/10.0/rbac/get-v2apilist_permission_groups"},{"title":"List RBAC Group Permissions","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_rbac_group_permissions","href":"/reference/api/10.0/rbac/get-v2apilist_rbac_group_permissions"},{"title":"List Users in RBAC Group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_users_in_rbac_group","href":"/reference/api/10.0/rbac/get-v2apilist_users_in_rbac_group"},{"title":"Add Access Accounts to RBAC Group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_access_accounts_to_rbac_group","href":"/reference/api/10.0/rbac/post-v2apiadd_access_accounts_to_rbac_group"},{"title":"Add Permission Group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_permission_group","href":"/reference/api/10.0/rbac/post-v2apiadd_permission_group"},{"title":"Add Permissions to RBAC Group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_permissions_to_rbac_group","href":"/reference/api/10.0/rbac/post-v2apiadd_permissions_to_rbac_group"},{"title":"Add Users to RBAC Group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_users_to_rbac_group","href":"/reference/api/10.0/rbac/post-v2apiadd_users_to_rbac_group"},{"title":"Delete Access Accounts from RBAC Group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_access_accounts_from_rbac_group","href":"/reference/api/10.0/rbac/post-v2apidelete_access_accounts_from_rbac_group"},{"title":"Delete Permission Group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_permission_group","href":"/reference/api/10.0/rbac/post-v2apidelete_permission_group"},{"title":"Delete Permissions from RBAC Group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_permissions_from_rbac_group","href":"/reference/api/10.0/rbac/post-v2apidelete_permissions_from_rbac_group"},{"title":"Delete Users from RBAC Group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_users_from_rbac_group","href":"/reference/api/10.0/rbac/post-v2apidelete_users_from_rbac_group"}]},{"group":"SAML","pages":[{"title":"SAML endpoint information","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_saml_endpoint_information","href":"/reference/api/10.0/saml/get-v2apiget_saml_endpoint_information"},{"title":"Create SAML endpoint","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/create_saml_endpoint","href":"/reference/api/10.0/saml/post-v2apicreate_saml_endpoint"},{"title":"Delete SAML endpoint","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_saml_endpoint","href":"/reference/api/10.0/saml/post-v2apidelete_saml_endpoint"},{"title":"Edit SAML endpoint","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_saml_endpoint","href":"/reference/api/10.0/saml/post-v2apiedit_saml_endpoint"}]}]},{"group":"Certificates","pages":[{"title":"Delete certificate authority","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json delete /v2.5/api/certificate-authorities/{uid}","href":"/reference/api/10.0/certificates/delete-certificate-authority"},{"title":"Unprepare a prepared Certificate Authority","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json delete /v2.5/api/pkis/{service}/certificate-authorities/{uid}","href":"/reference/api/10.0/certificates/unprepare-a-prepared-certificate-authority"},{"title":"List all certificate authorities","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/certificate-authorities","href":"/reference/api/10.0/certificates/list-all-certificate-authorities"},{"title":"Certificate authority by ID","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/certificate-authorities/{uid}","href":"/reference/api/10.0/certificates/get-certificate-authority-by-id"},{"title":"Show the service PKI status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/pkis/{service}","href":"/reference/api/10.0/certificates/show-the-service-pki-status"},{"title":"List all Certificate Authorities associated with the service","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/pkis/{service}/certificate-authorities","href":"/reference/api/10.0/certificates/list-all-certificate-authorities-associated-with-the-service"},{"title":"A specific Certificate Authority by ID","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/pkis/{service}/certificate-authorities/{uid}","href":"/reference/api/10.0/certificates/get-a-specific-certificate-authority-by-id"},{"title":"HTTPS certs status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_https_certs_status","href":"/reference/api/10.0/certificates/get-v2apiget_https_certs_status"},{"title":"List cert domain","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_cert_domain","href":"/reference/api/10.0/certificates/get-v2apilist_cert_domain"},{"title":"Update certificate authority display name","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json patch /v2.5/api/certificate-authorities/{uid}","href":"/reference/api/10.0/certificates/update-certificate-authority-display-name"},{"title":"Activate a prepared Certificate Authority","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json patch /v2.5/api/pkis/{service}/certificate-authorities/{uid}","href":"/reference/api/10.0/certificates/activate-a-prepared-certificate-authority"},{"title":"Create a certificate authority","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2.5/api/certificate-authorities","href":"/reference/api/10.0/certificates/create-a-certificate-authority"},{"title":"Prepare a new Certificate Authority for the service","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2.5/api/pkis/{service}/certificate-authorities","href":"/reference/api/10.0/certificates/prepare-a-new-certificate-authority-for-the-service"},{"title":"Prune all deactivated Certificate Authorities of the service","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2.5/api/pkis/{service}/certificate-authorities:prune","href":"/reference/api/10.0/certificates/prune-all-deactivated-certificate-authorities-of-the-service"},{"title":"Disable imported certificate","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_imported_certificate","href":"/reference/api/10.0/certificates/post-v2apidisable_imported_certificate"},{"title":"Download avx CA cert","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/download_avx_ca_cert","href":"/reference/api/10.0/certificates/post-v2apidownload_avx_ca_cert"},{"title":"Import new HTTPS certs","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/import_new_https_certs","href":"/reference/api/10.0/certificates/post-v2apiimport_new_https_certs"}]},{"group":"Controller","pages":[{"title":"Controller Allowlist","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/controller/allow-list","href":"/reference/api/10.0/controller/get-v25apicontrollerallow-list"},{"title":"Controller metadata","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/get-controller-metadata","href":"/reference/api/10.0/controller/get-v25apiget-controller-metadata"},{"title":"Pipeline details for the controller","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/otel/controller/pipeline","href":"/reference/api/10.0/controller/get-pipeline-details-for-the-controller"},{"title":"Aviatrix controller commandlog","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_aviatrix_controller_commandlog","href":"/reference/api/10.0/controller/get-v2apiget_aviatrix_controller_commandlog"},{"title":"Compatible image version","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_compatible_image_version","href":"/reference/api/10.0/controller/get-v2apiget_compatible_image_version"},{"title":"Controller remote SSH status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_controller_remote_ssh_status","href":"/reference/api/10.0/controller/get-v2apiget_controller_remote_ssh_status"},{"title":"Controller security group management status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_controller_security_group_management_status","href":"/reference/api/10.0/controller/get-v2apiget_controller_security_group_management_status"},{"title":"Controller VPC DNS server status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_controller_vpc_dns_server_status","href":"/reference/api/10.0/controller/get-v2apiget_controller_vpc_dns_server_status"},{"title":"Copilot association status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_copilot_association_status","href":"/reference/api/10.0/controller/get-v2apiget_copilot_association_status"},{"title":"Copilot deployment status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_copilot_deployment_status","href":"/reference/api/10.0/controller/get-v2apiget_copilot_deployment_status"},{"title":"Copilot security group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_copilot_sg","href":"/reference/api/10.0/controller/get-v2apiget_copilot_sg"},{"title":"Instance by id","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_instance_by_id","href":"/reference/api/10.0/controller/get-v2apiget_instance_by_id"},{"title":"Keep alive speed","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_keep_alive_speed","href":"/reference/api/10.0/controller/get-v2apiget_keep_alive_speed"},{"title":"Cloud network info","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/cloud_network_info","href":"/reference/api/10.0/controller/post-v2apicloud_network_info"},{"title":"Disable controller security group management","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_controller_security_group_management","href":"/reference/api/10.0/controller/post-v2apidisable_controller_security_group_management"},{"title":"Disable controller VPC DNS server","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_controller_vpc_dns_server","href":"/reference/api/10.0/controller/post-v2apidisable_controller_vpc_dns_server"},{"title":"Disable CoPilot association","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_copilot_association","href":"/reference/api/10.0/controller/post-v2apidisable_copilot_association"},{"title":"Disable CoPilot security group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_copilot_sg","href":"/reference/api/10.0/controller/post-v2apidisable_copilot_sg"},{"title":"Enable controller security group management","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_controller_security_group_management","href":"/reference/api/10.0/controller/post-v2apienable_controller_security_group_management"},{"title":"Enable CoPilot association","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_copilot_association","href":"/reference/api/10.0/controller/post-v2apienable_copilot_association"},{"title":"Set keep alive speed","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/set_keep_alive_speed","href":"/reference/api/10.0/controller/post-v2apiset_keep_alive_speed"},{"title":"Update Controller Allowlist","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/controller/allow-list","href":"/reference/api/10.0/controller/put-v25apicontrollerallow-list"},{"title":"Update pipeline configuration for the controller","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/otel/controller/pipeline","href":"/reference/api/10.0/controller/update-pipeline-configuration-for-the-controller"}]},{"group":"DCF","pages":[{"group":"SmartGroups","pages":[{"title":"List SmartGroups","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/app-domains","href":"/reference/api/10.0/app-domains/get-v25apiapp-domains"},{"title":"SmartGroup Configuration","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/app-domains/config","href":"/reference/api/10.0/app-domains/get-v25apiapp-domainsconfig"},{"title":"SmartGroup by Name","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/app-domains/name/{ad_name}","href":"/reference/api/10.0/app-domains/get-v25apiapp-domainsname"},{"title":"Poll SmartGroup Status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/app-domains/poll-resources","href":"/reference/api/10.0/app-domains/get-v25apiapp-domainspoll-resources"},{"title":"Create SmartGroup","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2.5/api/app-domains","href":"/reference/api/10.0/app-domains/post-v25apiapp-domains"},{"title":"Update SmartGroup Configuration","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/app-domains/config","href":"/reference/api/10.0/app-domains/put-v25apiapp-domainsconfig"}]},{"group":"IPS","pages":[{"title":"IPS profile Delete","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json delete /v2.5/api/dcf/ips-profiles/{profile_uuid}","href":"/reference/api/10.0/ips/delete-v25apidcfips-profiles"},{"title":"IPS rule feed Delete","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json delete /v2.5/api/dcf/ips-rule-feeds/{feed_uuid}","href":"/reference/api/10.0/ips/delete-v25apidcfips-rule-feeds"},{"title":"IPS profile","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/dcf/ips-profiles/{profile_uuid}","href":"/reference/api/10.0/ips/get-v25apidcfips-profiles"},{"title":"IPS profile","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/dcf/ips-profiles/{profile_uuid}","href":"/reference/api/10.0/ips/get-v25apidcfips-profiles"},{"title":"IPS rule feed","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/dcf/ips-rule-feeds/{feed_uuid}","href":"/reference/api/10.0/ips/get-v25apidcfips-rule-feeds"},{"title":"IPS rule feed","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/dcf/ips-rule-feeds/{feed_uuid}","href":"/reference/api/10.0/ips/get-v25apidcfips-rule-feeds"},{"title":"IPS profiles create","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2.5/api/dcf/ips-profiles","href":"/reference/api/10.0/ips/post-v25apidcfips-profiles"},{"title":"IPS rule feeds upload","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2.5/api/dcf/ips-rule-feeds","href":"/reference/api/10.0/ips/post-v25apidcfips-rule-feeds"},{"title":"IPS profile update","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/dcf/ips-profiles/{profile_uuid}","href":"/reference/api/10.0/ips/put-v25apidcfips-profiles"},{"title":"IPS rule feed update","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/dcf/ips-rule-feeds/{feed_uuid}","href":"/reference/api/10.0/ips/put-v25apidcfips-rule-feeds"}]},{"group":"MITM","pages":[{"title":"Delete a specific DCF TLS profile by UUID","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json delete /v2.5/api/dcf/tls-profile/{profile_uuid}","href":"/reference/api/10.0/mitm/delete-a-specific-dcf-tls-profile-by-uuid"},{"title":"Delete a CA trust bundle","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json delete /v2.5/api/dcf/trustbundle/{bundle_uuid}","href":"/reference/api/10.0/mitm/delete-a-ca-trust-bundle"},{"title":"MITM Delete CA","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json delete /v2.5/api/mitm/ca","href":"/reference/api/10.0/mitm/delete-v25apimitmca"},{"title":"MITM Delete CA bundle","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json delete /v2.5/api/mitm/trusted-ca-bundle","href":"/reference/api/10.0/mitm/delete-v25apimitmtrusted-ca-bundle"},{"title":"All DCF TLS profiles","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/dcf/tls-profile","href":"/reference/api/10.0/mitm/get-all-dcf-tls-profiles"},{"title":"A specific DCF TLS profile by UUID","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/dcf/tls-profile/{profile_uuid}","href":"/reference/api/10.0/mitm/get-a-specific-dcf-tls-profile-by-uuid"},{"title":"List all CA trust bundles","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/dcf/trustbundle","href":"/reference/api/10.0/mitm/list-all-ca-trust-bundles"},{"title":"DCF trustbundle by name","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/dcf/trustbundle/name/{display_name}","href":"/reference/api/10.0/mitm/get-v25apidcftrustbundlename"},{"title":"DCF trustbundle","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/dcf/trustbundle/{bundle_uuid}","href":"/reference/api/10.0/mitm/get-v25apidcftrustbundle"},{"title":"MITM Get CA","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/mitm/ca","href":"/reference/api/10.0/mitm/get-v25apimitmca"},{"title":"MITM Get CA 2","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/mitm/ca-2","href":"/reference/api/10.0/mitm/get-v25apimitmca-2"},{"title":"MITM Get verification level","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/mitm/origin-cert-verify","href":"/reference/api/10.0/mitm/get-v25apimitmorigin-cert-verify"},{"title":"MITM Get verification level 2","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/mitm/origin-cert-verify-2","href":"/reference/api/10.0/mitm/get-v25apimitmorigin-cert-verify-2"},{"title":"MITM Get CA bundle","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/mitm/trusted-ca-bundle","href":"/reference/api/10.0/mitm/get-v25apimitmtrusted-ca-bundle"},{"title":"Create a new DCF TLS profile","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2.5/api/dcf/tls-profile","href":"/reference/api/10.0/mitm/create-a-new-dcf-tls-profile"},{"title":"Upload a CA trust bundle","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2.5/api/dcf/trustbundle","href":"/reference/api/10.0/mitm/upload-a-ca-trust-bundle"},{"title":"MITM Create CA","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2.5/api/mitm/ca","href":"/reference/api/10.0/mitm/post-v25apimitmca"},{"title":"Update a specific DCF TLS profile by UUID","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/dcf/tls-profile/{profile_uuid}","href":"/reference/api/10.0/mitm/update-a-specific-dcf-tls-profile-by-uuid"},{"title":"Update a CA trust bundle","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/dcf/trustbundle/{bundle_uuid}","href":"/reference/api/10.0/mitm/update-a-ca-trust-bundle"},{"title":"MITM Update CA","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/mitm/ca","href":"/reference/api/10.0/mitm/put-v25apimitmca"},{"title":"MITM Update verification level","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/mitm/origin-cert-verify","href":"/reference/api/10.0/mitm/put-v25apimitmorigin-cert-verify"},{"title":"MITM Update CA bundle","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/mitm/trusted-ca-bundle","href":"/reference/api/10.0/mitm/put-v25apimitmtrusted-ca-bundle"}]},{"group":"Policies","pages":[{"title":"Delete Intra-VPC","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json delete /v2.5/api/microseg/intra-vpc","href":"/reference/api/10.0/policies/delete-v25apimicrosegintra-vpc"},{"title":"Delete Policy","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json delete /v2.5/api/microseg/policy-list","href":"/reference/api/10.0/policies/delete-v25apimicrosegpolicy-list"},{"title":"Delete Policy 3","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json delete /v2.5/api/microseg/policy-list3/{policy_uuid}","href":"/reference/api/10.0/policies/delete-v25apimicrosegpolicy-list3"},{"title":"Delete a Single Stat","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json delete /v2.5/api/microseg/stats/{policy_uuid}","href":"/reference/api/10.0/policies/delete-v25apimicrosegstats"},{"title":"Delete a Single Stat","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json delete /v2.5/api/microseg/stats/{policy_uuid}","href":"/reference/api/10.0/policies/delete-v25apimicrosegstats"},{"title":"Default ips profile","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/dcf/default-ips-profile","href":"/reference/api/10.0/policies/get-v25apidcfdefault-ips-profile"},{"title":"VPCs using a specific DCF IPS profile","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/dcf/ips-profile-vpc/vpcs/{profile_uuid}","href":"/reference/api/10.0/policies/get-vpcs-using-a-specific-dcf-ips-profile"},{"title":"DCF IPS profiles for a VPC","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/dcf/ips-profile-vpc/{vpc_id}","href":"/reference/api/10.0/policies/get-dcf-ips-profiles-for-a-vpc"},{"title":"A specific DCF Log profile by name","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/dcf/log-profile","href":"/reference/api/10.0/policies/get-a-specific-dcf-log-profile-by-name"},{"title":"List Attachment Points","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/microseg/attachment-points","href":"/reference/api/10.0/policies/get-v25apimicrosegattachment-points"},{"title":"Get Default Action Policy","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/microseg/default-action-policy","href":"/reference/api/10.0/policies/get-v25apimicrosegdefault-action-policy"},{"title":"Deploy policy retrieve","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/microseg/deploy-policy","href":"/reference/api/10.0/policies/get-v25apimicrosegdeploy-policy"},{"title":"List Intra-VPC","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/microseg/intra-vpc","href":"/reference/api/10.0/policies/get-v25apimicrosegintra-vpc"},{"title":"Intra-VPC Orchestration Status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/microseg/intra-vpc/orchestration-status","href":"/reference/api/10.0/policies/get-v25apimicrosegintra-vpcorchestration-status"},{"title":"Policy List","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/microseg/policy-list","href":"/reference/api/10.0/policies/get-v25apimicrosegpolicy-list"},{"title":"Policy List 2","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/microseg/policy-list2","href":"/reference/api/10.0/policies/get-v25apimicrosegpolicy-list2"},{"title":"List Policy 3 Configurations","deprecated":null,"version":null,"openapi":"/openapi/8.2/aviatrix-api.json get /v2.5/api/microseg/policy-list3","href":"/api-reference/policies/get-v25apimicrosegpolicy-list3-list"},{"title":"Get Policy 3 by UUID","deprecated":null,"version":null,"openapi":"/openapi/8.2/aviatrix-api.json get /v2.5/api/microseg/policy-list3/{policy_uuid}","href":"/api-reference/policies/get-v25apimicrosegpolicy-list3-by-uuid"},{"title":"Stats","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/microseg/stats","href":"/reference/api/10.0/policies/get-v25apimicrosegstats"},{"title":"Attachment Points Cleanup","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2.5/api/microseg/attachment-points/cleanup-orphans","href":"/reference/api/10.0/policies/post-v25apimicrosegattachment-pointscleanup-orphans"},{"title":"Deploy policy create","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2.5/api/microseg/deploy-policy","href":"/reference/api/10.0/policies/post-v25apimicrosegdeploy-policy"},{"title":"Create Policy 3","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2.5/api/microseg/policy-list3","href":"/reference/api/10.0/policies/post-v25apimicrosegpolicy-list3"},{"title":"Update access policy","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/update_access_policy","href":"/reference/api/10.0/policies/post-v2apiupdate_access_policy"},{"title":"Default ips profile set","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/dcf/default-ips-profile","href":"/reference/api/10.0/policies/put-v25apidcfdefault-ips-profile"},{"title":"Set DCF IPS profiles for a VPC","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/dcf/ips-profile-vpc/{vpc_id}","href":"/reference/api/10.0/policies/set-dcf-ips-profiles-for-a-vpc"},{"title":"Edit Default Action Policy","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/microseg/default-action-policy","href":"/reference/api/10.0/policies/put-v25apimicrosegdefault-action-policy"},{"title":"Create/Update Intra-VPC","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/microseg/intra-vpc","href":"/reference/api/10.0/policies/put-v25apimicrosegintra-vpc"},{"title":"Create Policy","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/microseg/policy-list","href":"/reference/api/10.0/policies/put-v25apimicrosegpolicy-list"},{"title":"Create Policy 2","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/microseg/policy-list2","href":"/reference/api/10.0/policies/put-v25apimicrosegpolicy-list2"},{"title":"Update Policy 3","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/microseg/policy-list3/{policy_uuid}","href":"/reference/api/10.0/policies/put-v25apimicrosegpolicy-list3"}]}]},{"group":"FireNet","pages":[{"title":"Firewall LAN CIDR","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_firewall_lan_cidr","href":"/reference/api/10.0/firenet/get-v2apiget_firewall_lan_cidr"},{"title":"List FireNet","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_firenet","href":"/reference/api/10.0/firenet/get-v2apilist_firenet"},{"title":"List firewall manager vendor","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_firewall_manager_vendor","href":"/reference/api/10.0/firenet/get-v2apilist_firewall_manager_vendor"},{"title":"List firewall vendor","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_firewall_vendor","href":"/reference/api/10.0/firenet/get-v2apilist_firewall_vendor"},{"title":"List primary FireNet","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_primary_firenet","href":"/reference/api/10.0/firenet/get-v2apilist_primary_firenet"},{"title":"List secondary FireNet","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_secondary_firenet","href":"/reference/api/10.0/firenet/get-v2apilist_secondary_firenet"},{"title":"List transit FireNet","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_transit_firenet","href":"/reference/api/10.0/firenet/get-v2apilist_transit_firenet"},{"title":"List transit FireNet spoke policies","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_transit_firenet_spoke_policies","href":"/reference/api/10.0/firenet/get-v2apilist_transit_firenet_spoke_policies"},{"title":"List transit FireNet spokes","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_transit_firenet_spokes","href":"/reference/api/10.0/firenet/get-v2apilist_transit_firenet_spokes"},{"title":"Add firewall instance","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_firewall_instance","href":"/reference/api/10.0/firenet/post-v2apiadd_firewall_instance"},{"title":"Add spoke to transit FireNet inspection","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_spoke_to_transit_firenet_inspection","href":"/reference/api/10.0/firenet/post-v2apiadd_spoke_to_transit_firenet_inspection"},{"title":"Associate firewall with FireNet","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/associate_firewall_with_firenet","href":"/reference/api/10.0/firenet/post-v2apiassociate_firewall_with_firenet"},{"title":"Attach centralized FireNet","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/attach_centralized_firenet","href":"/reference/api/10.0/firenet/post-v2apiattach_centralized_firenet"},{"title":"Attach firewall to FireNet","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/attach_firewall_to_firenet","href":"/reference/api/10.0/firenet/post-v2apiattach_firewall_to_firenet"},{"title":"Connect FireNet with TGW","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/connect_firenet_with_tgw","href":"/reference/api/10.0/firenet/post-v2apiconnect_firenet_with_tgw"},{"title":"Delete FireNet firewall instance","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_firenet_firewall_instance","href":"/reference/api/10.0/firenet/post-v2apidelete_firenet_firewall_instance"},{"title":"Delete spoke from transit FireNet inspection","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_spoke_from_transit_firenet_inspection","href":"/reference/api/10.0/firenet/post-v2apidelete_spoke_from_transit_firenet_inspection"},{"title":"Detach centralized FireNet","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/detach_centralized_firenet","href":"/reference/api/10.0/firenet/post-v2apidetach_centralized_firenet"},{"title":"Detach firewall from FireNet","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/detach_firewall_from_firenet","href":"/reference/api/10.0/firenet/post-v2apidetach_firewall_from_firenet"},{"title":"Disable FireNet TGW segmentation for egress","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_firenet_tgw_segmentation_for_egress","href":"/reference/api/10.0/firenet/post-v2apidisable_firenet_tgw_segmentation_for_egress"},{"title":"Disable gateway FireNet interfaces","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_gateway_firenet_interfaces","href":"/reference/api/10.0/firenet/post-v2apidisable_gateway_firenet_interfaces"},{"title":"Disable gateway for transit FireNet","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_gateway_for_transit_firenet","href":"/reference/api/10.0/firenet/post-v2apidisable_gateway_for_transit_firenet"},{"title":"Disable native AWS gwlb FireNet","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_native_aws_gwlb_firenet","href":"/reference/api/10.0/firenet/post-v2apidisable_native_aws_gwlb_firenet"},{"title":"Disable transit FireNet on egress transit gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_transit_firenet_on_egress_transit_gateway","href":"/reference/api/10.0/firenet/post-v2apidisable_transit_firenet_on_egress_transit_gateway"},{"title":"Disassociate firewall with FireNet","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disassociate_firewall_with_firenet","href":"/reference/api/10.0/firenet/post-v2apidisassociate_firewall_with_firenet"},{"title":"Disconnect FireNet with TGW","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disconnect_firenet_with_tgw","href":"/reference/api/10.0/firenet/post-v2apidisconnect_firenet_with_tgw"},{"title":"Edit FireNet","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_firenet","href":"/reference/api/10.0/firenet/post-v2apiedit_firenet"},{"title":"Edit FireNet egress static CIDR","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_firenet_egress_static_cidr","href":"/reference/api/10.0/firenet/post-v2apiedit_firenet_egress_static_cidr"},{"title":"Edit FireNet excluded CIDR","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_firenet_excluded_cidr","href":"/reference/api/10.0/firenet/post-v2apiedit_firenet_excluded_cidr"},{"title":"Edit FireNet firewall vendor info","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_firenet_firewall_vendor_info","href":"/reference/api/10.0/firenet/post-v2apiedit_firenet_firewall_vendor_info"},{"title":"Edit transit FireNet management access","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_transit_firenet_management_access","href":"/reference/api/10.0/firenet/post-v2apiedit_transit_firenet_management_access"},{"title":"Enable FireNet TGW segmentation for egress","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_firenet_tgw_segmentation_for_egress","href":"/reference/api/10.0/firenet/post-v2apienable_firenet_tgw_segmentation_for_egress"},{"title":"Enable gateway FireNet interfaces","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_gateway_firenet_interfaces","href":"/reference/api/10.0/firenet/post-v2apienable_gateway_firenet_interfaces"},{"title":"Enable gateway for transit FireNet","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_gateway_for_transit_firenet","href":"/reference/api/10.0/firenet/post-v2apienable_gateway_for_transit_firenet"},{"title":"Enable native AWS gwlb FireNet","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_native_aws_gwlb_firenet","href":"/reference/api/10.0/firenet/post-v2apienable_native_aws_gwlb_firenet"},{"title":"Enable transit FireNet on egress transit gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_transit_firenet_on_egress_transit_gateway","href":"/reference/api/10.0/firenet/post-v2apienable_transit_firenet_on_egress_transit_gateway"},{"title":"Show FireNet detail","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_firenet_detail","href":"/reference/api/10.0/firenet/post-v2apishow_firenet_detail"},{"title":"Show FireNet firewall vendor config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_firenet_firewall_vendor_config","href":"/reference/api/10.0/firenet/post-v2apishow_firenet_firewall_vendor_config"},{"title":"Update firewall attachment access from onprem","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/update_firewall_attachment_access_from_onprem","href":"/reference/api/10.0/firenet/post-v2apiupdate_firewall_attachment_access_from_onprem"}]},{"group":"FQDN","pages":[{"title":"FQDN cache global status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_fqdn_cache_global_status","href":"/reference/api/10.0/fqdn/get-v2apiget_fqdn_cache_global_status"},{"title":"FQDN discovery result","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_fqdn_discovery_result","href":"/reference/api/10.0/fqdn/get-v2apiget_fqdn_discovery_result"},{"title":"FQDN discovery result file","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_fqdn_discovery_result_file","href":"/reference/api/10.0/fqdn/get-v2apiget_fqdn_discovery_result_file"},{"title":"FQDN exact match status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_fqdn_exact_match_status","href":"/reference/api/10.0/fqdn/get-v2apiget_fqdn_exact_match_status"},{"title":"FQDN exception rule status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_fqdn_exception_rule_status","href":"/reference/api/10.0/fqdn/get-v2apiget_fqdn_exception_rule_status"},{"title":"FQDN private network filtering status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_fqdn_private_network_filtering_status","href":"/reference/api/10.0/fqdn/get-v2apiget_fqdn_private_network_filtering_status"},{"title":"FQDN stat status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_fqdn_stat_status","href":"/reference/api/10.0/fqdn/get-v2apiget_fqdn_stat_status"},{"title":"FQDN stats","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_fqdn_stats","href":"/reference/api/10.0/fqdn/get-v2apiget_fqdn_stats"},{"title":"List FQDN filter tag attached gateways","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_fqdn_filter_tag_attached_gws","href":"/reference/api/10.0/fqdn/get-v2apilist_fqdn_filter_tag_attached_gws"},{"title":"List FQDN filter tag domain names","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_fqdn_filter_tag_domain_names","href":"/reference/api/10.0/fqdn/get-v2apilist_fqdn_filter_tag_domain_names"},{"title":"List FQDN filter tag source ip filters","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_fqdn_filter_tag_source_ip_filters","href":"/reference/api/10.0/fqdn/get-v2apilist_fqdn_filter_tag_source_ip_filters"},{"title":"List FQDN filter tags","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_fqdn_filter_tags","href":"/reference/api/10.0/fqdn/get-v2apilist_fqdn_filter_tags"},{"title":"List FQDN gateways","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_fqdn_gateways","href":"/reference/api/10.0/fqdn/get-v2apilist_fqdn_gateways"},{"title":"List FQDN pass through CIDRs","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_fqdn_pass_through_cidrs","href":"/reference/api/10.0/fqdn/get-v2apilist_fqdn_pass_through_cidrs"},{"title":"List gateways not attached to a FQDN tag","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_gateways_not_attached_to_a_fqdn_tag","href":"/reference/api/10.0/fqdn/get-v2apilist_gateways_not_attached_to_a_fqdn_tag"},{"title":"List supported protocols for FQDN","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_supported_protocols_for_fqdn","href":"/reference/api/10.0/fqdn/get-v2apilist_supported_protocols_for_fqdn"},{"title":"Add FQDN policies to tag","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_fqdn_policies_to_tag","href":"/reference/api/10.0/fqdn/post-v2apiadd_fqdn_policies_to_tag"},{"title":"Attach FQDN filter tag to gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/attach_fqdn_filter_tag_to_gw","href":"/reference/api/10.0/fqdn/post-v2apiattach_fqdn_filter_tag_to_gw"},{"title":"Del FQDN filter tag","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/del_fqdn_filter_tag","href":"/reference/api/10.0/fqdn/post-v2apidel_fqdn_filter_tag"},{"title":"Delete FQDN policies to tag","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_fqdn_policies_to_tag","href":"/reference/api/10.0/fqdn/post-v2apidelete_fqdn_policies_to_tag"},{"title":"Detach FQDN filter tag from gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/detach_fqdn_filter_tag_from_gw","href":"/reference/api/10.0/fqdn/post-v2apidetach_fqdn_filter_tag_from_gw"},{"title":"Disable FQDN cache global","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_fqdn_cache_global","href":"/reference/api/10.0/fqdn/post-v2apidisable_fqdn_cache_global"},{"title":"Disable FQDN exact match","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_fqdn_exact_match","href":"/reference/api/10.0/fqdn/post-v2apidisable_fqdn_exact_match"},{"title":"Disable FQDN exception rule","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_fqdn_exception_rule","href":"/reference/api/10.0/fqdn/post-v2apidisable_fqdn_exception_rule"},{"title":"Disable FQDN on custom networks","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_fqdn_on_custom_networks","href":"/reference/api/10.0/fqdn/post-v2apidisable_fqdn_on_custom_networks"},{"title":"Disable FQDN on private networks","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_fqdn_on_private_networks","href":"/reference/api/10.0/fqdn/post-v2apidisable_fqdn_on_private_networks"},{"title":"Download FQDN log","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/download_fqdn_log","href":"/reference/api/10.0/fqdn/post-v2apidownload_fqdn_log"},{"title":"Enable FQDN cache global","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_fqdn_cache_global","href":"/reference/api/10.0/fqdn/post-v2apienable_fqdn_cache_global"},{"title":"Enable FQDN exact match","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_fqdn_exact_match","href":"/reference/api/10.0/fqdn/post-v2apienable_fqdn_exact_match"},{"title":"Enable FQDN exception rule","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_fqdn_exception_rule","href":"/reference/api/10.0/fqdn/post-v2apienable_fqdn_exception_rule"},{"title":"Enable FQDN on private networks","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_fqdn_on_private_networks","href":"/reference/api/10.0/fqdn/post-v2apienable_fqdn_on_private_networks"},{"title":"Set FQDN filter tag color","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/set_fqdn_filter_tag_color","href":"/reference/api/10.0/fqdn/post-v2apiset_fqdn_filter_tag_color"},{"title":"Set FQDN filter tag domain names","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/set_fqdn_filter_tag_domain_names","href":"/reference/api/10.0/fqdn/post-v2apiset_fqdn_filter_tag_domain_names"},{"title":"Set FQDN filter tag state","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/set_fqdn_filter_tag_state","href":"/reference/api/10.0/fqdn/post-v2apiset_fqdn_filter_tag_state"},{"title":"Update FQDN filter tag source ip filters","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/update_fqdn_filter_tag_source_ip_filters","href":"/reference/api/10.0/fqdn/post-v2apiupdate_fqdn_filter_tag_source_ip_filters"},{"title":"Update FQDN pass through CIDRs","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/update_fqdn_pass_through_cidrs","href":"/reference/api/10.0/fqdn/post-v2apiupdate_fqdn_pass_through_cidrs"}]},{"group":"Gateways","pages":[{"title":"Disable gateway insertion for specified VPC","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json delete /v2.5/api/gateway-insertion/vpc","href":"/reference/api/10.0/gateways/disable-gateway-insertion-for-specified-vpc"},{"title":"Gateway insertion enablement status for specified VPC","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/gateway-insertion/vpc","href":"/reference/api/10.0/gateways/get-gateway-insertion-enablement-status-for-one-or-more-vpcs"},{"title":"Pipeline details for gateways","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/otel/gateway/pipeline","href":"/reference/api/10.0/gateways/get-pipeline-details-for-gateways"},{"title":"Gateway group details","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_gateway_group_details","href":"/reference/api/10.0/gateways/get-v2apiget_gateway_group_details"},{"title":"Gateway info","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_gateway_info","href":"/reference/api/10.0/gateways/get-v2apiget_gateway_info"},{"title":"Gateway rollback on error status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_gateway_rollback_on_error_status","href":"/reference/api/10.0/gateways/get-v2apiget_gateway_rollback_on_error_status"},{"title":"Gateway service status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_gateway_service_status","href":"/reference/api/10.0/gateways/get-v2apiget_gateway_service_status"},{"title":"Gro GSO status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_gro_gso_status","href":"/reference/api/10.0/gateways/get-v2apiget_gro_gso_status"},{"title":"Jumbo frame status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_jumbo_frame_status","href":"/reference/api/10.0/gateways/get-v2apiget_jumbo_frame_status"},{"title":"Private oob state","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_private_oob_state","href":"/reference/api/10.0/gateways/get-v2apiget_private_oob_state"},{"title":"Private s3 gateway details","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_private_s3_gateway_details","href":"/reference/api/10.0/gateways/get-v2apiget_private_s3_gateway_details"},{"title":"Public subnet filtering gateway details","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_public_subnet_filtering_gateway_details","href":"/reference/api/10.0/gateways/get-v2apiget_public_subnet_filtering_gateway_details"},{"title":"Scheduled gateway operation status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_scheduled_gateway_operation_status","href":"/reference/api/10.0/gateways/get-v2apiget_scheduled_gateway_operation_status"},{"title":"Skip public route table update status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_skip_public_route_table_update_status","href":"/reference/api/10.0/gateways/get-v2apiget_skip_public_route_table_update_status"},{"title":"Tunnel latency","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_tunnel_latency","href":"/reference/api/10.0/gateways/get-v2apiget_tunnel_latency"},{"title":"List arm native spokes","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_arm_native_spokes","href":"/reference/api/10.0/gateways/get-v2apilist_arm_native_spokes"},{"title":"List attached spoke gateways","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_attached_spoke_gateways","href":"/reference/api/10.0/gateways/get-v2apilist_attached_spoke_gateways"},{"title":"List aviatrix spoke advanced config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_aviatrix_spoke_advanced_config","href":"/reference/api/10.0/gateways/get-v2apilist_aviatrix_spoke_advanced_config"},{"title":"List Edge CSP gateways","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_edge_csp_gateways","href":"/reference/api/10.0/gateways/get-v2apilist_edge_csp_gateways"},{"title":"List Edge gateway attributes","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_edge_gateway_attributes","href":"/reference/api/10.0/gateways/get-v2apilist_edge_gateway_attributes"},{"title":"List Edge Gateways by Site ID","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_edge_gateway_by_site_id","href":"/reference/api/10.0/gateways/get-v2apilist_edge_gateway_by_site_id"},{"title":"List gateway groups","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_gateway_groups","href":"/reference/api/10.0/gateways/get-v2apilist_gateway_groups"},{"title":"List gateway interfaces","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_gateway_interfaces","href":"/reference/api/10.0/gateways/get-v2apilist_gateway_interfaces"},{"title":"List gateway security policy rules","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_gateway_security_policy_rules","href":"/reference/api/10.0/gateways/get-v2apilist_gateway_security_policy_rules"},{"title":"List gateway services","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_gateway_services","href":"/reference/api/10.0/gateways/get-v2apilist_gateway_services"},{"title":"List gateway upgrade status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_gateway_upgrade_status","href":"/reference/api/10.0/gateways/get-v2apilist_gateway_upgrade_status"},{"title":"List gateways","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_gateways","href":"/reference/api/10.0/gateways/get-v2apilist_gateways"},{"title":"List gateways details","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_gateways_details","href":"/reference/api/10.0/gateways/get-v2apilist_gateways_details"},{"title":"List primary and HA spoke gateways","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_primary_and_ha_spoke_gateways","href":"/reference/api/10.0/gateways/get-v2apilist_primary_and_ha_spoke_gateways"},{"title":"List spoke gateway display fields","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_spoke_gateway_display_fields","href":"/reference/api/10.0/gateways/get-v2apilist_spoke_gateway_display_fields"},{"title":"List spoke gateway loadbalancer","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_spoke_gateway_loadbalancer","href":"/reference/api/10.0/gateways/get-v2apilist_spoke_gateway_loadbalancer"},{"title":"List spoke gateway subnets","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_spoke_gateway_subnets","href":"/reference/api/10.0/gateways/get-v2apilist_spoke_gateway_subnets"},{"title":"List spoke gateways","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_spoke_gws","href":"/reference/api/10.0/gateways/get-v2apilist_spoke_gws"},{"title":"List spoke learned CIDRs","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_spoke_learned_cidrs","href":"/reference/api/10.0/gateways/get-v2apilist_spoke_learned_cidrs"},{"title":"Add public subnet filtering gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_public_subnet_filtering_gateway","href":"/reference/api/10.0/gateways/post-v2apiadd_public_subnet_filtering_gateway"},{"title":"Create Edge Gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/create_edge_gateway","href":"/reference/api/10.0/gateways/post-v2apicreate_edge_gateway"},{"title":"Create mct gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/create_mct_gateway","href":"/reference/api/10.0/gateways/post-v2apicreate_mct_gateway"},{"title":"Create Multicloud HA Gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/create_multicloud_ha_gateway","href":"/reference/api/10.0/gateways/post-v2apicreate_multicloud_ha_gateway"},{"title":"Create Multicloud Primary Gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/create_multicloud_primary_gateway","href":"/reference/api/10.0/gateways/post-v2apicreate_multicloud_primary_gateway"},{"title":"Create peering HA gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/create_peering_ha_gateway","href":"/reference/api/10.0/gateways/post-v2apicreate_peering_ha_gateway"},{"title":"Delete Edge Gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_edge_gateway","href":"/reference/api/10.0/gateways/post-v2apidelete_edge_gateway"},{"title":"Delete Multicloud Gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_multicloud_gateway","href":"/reference/api/10.0/gateways/post-v2apidelete_multicloud_gateway"},{"title":"Delete public subnet filtering gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_public_subnet_filtering_gateway","href":"/reference/api/10.0/gateways/post-v2apidelete_public_subnet_filtering_gateway"},{"title":"Disable GRO GSO","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_gro_gso","href":"/reference/api/10.0/gateways/post-v2apidisable_gro_gso"},{"title":"Disable IPv6","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_ipv6","href":"/reference/api/10.0/gateways/post-v2apidisable_ipv6"},{"title":"Disable jumbo frame","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_jumbo_frame","href":"/reference/api/10.0/gateways/post-v2apidisable_jumbo_frame"},{"title":"Disable private oob","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_private_oob","href":"/reference/api/10.0/gateways/post-v2apidisable_private_oob"},{"title":"Disable single AZ HA","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_single_az_ha","href":"/reference/api/10.0/gateways/post-v2apidisable_single_az_ha"},{"title":"Discover Edge Gateway WAN IP","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/discovery_edge_gateway_wan_ip","href":"/reference/api/10.0/gateways/post-v2apidiscovery_edge_gateway_wan_ip"},{"title":"Edit gateway advertised CIDR","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_gateway_advertised_cidr","href":"/reference/api/10.0/gateways/post-v2apiedit_gateway_advertised_cidr"},{"title":"Edit gateway custom routes","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_gateway_custom_routes","href":"/reference/api/10.0/gateways/post-v2apiedit_gateway_custom_routes"},{"title":"Edit gateway filter routes","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_gateway_filter_routes","href":"/reference/api/10.0/gateways/post-v2apiedit_gateway_filter_routes"},{"title":"Edit gateway config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_gw_config","href":"/reference/api/10.0/gateways/post-v2apiedit_gw_config"},{"title":"Enable GRO GSO","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_gro_gso","href":"/reference/api/10.0/gateways/post-v2apienable_gro_gso"},{"title":"Enable HA for public subnet filtering gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_ha_for_public_subnet_filtering_gateway","href":"/reference/api/10.0/gateways/post-v2apienable_ha_for_public_subnet_filtering_gateway"},{"title":"Enable IPv6","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_ipv6","href":"/reference/api/10.0/gateways/post-v2apienable_ipv6"},{"title":"Enable jumbo frame","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_jumbo_frame","href":"/reference/api/10.0/gateways/post-v2apienable_jumbo_frame"},{"title":"Enable single AZ HA","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_single_az_ha","href":"/reference/api/10.0/gateways/post-v2apienable_single_az_ha"},{"title":"Encrypt gateway volume","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/encrypt_gateway_volume","href":"/reference/api/10.0/gateways/post-v2apiencrypt_gateway_volume"},{"title":"Set designated gateway additional CIDR list","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/set_designated_gateway_additional_cidr_list","href":"/reference/api/10.0/gateways/post-v2apiset_designated_gateway_additional_cidr_list"},{"title":"Update Edge Gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/update_edge_gateway","href":"/reference/api/10.0/gateways/post-v2apiupdate_edge_gateway"},{"title":"Enable gateway insertion for specified VPC and routing tables","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/gateway-insertion/vpc","href":"/reference/api/10.0/gateways/enable-gateway-insertion-for-specified-vpc-and-routing-tables"},{"title":"Update pipeline configuration for gateways","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/otel/gateway/pipeline","href":"/reference/api/10.0/gateways/update-pipeline-configuration-for-gateways"}]},{"group":"General","pages":[{"title":"Delete a Cluster Configuration","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json delete /v2.5/api/k8s/clusters/{uid}","href":"/reference/api/10.0/general/delete-a-single-clusterconfig-by-id"},{"title":"All Cluster Statuses","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/k8s/cluster_statuses","href":"/reference/api/10.0/general/get-all-clusterstatuses"},{"title":"Cluster Status by ID","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/k8s/cluster_statuses/{cluster_id}","href":"/reference/api/10.0/general/get-a-single-clusterstatus-by-cluster-id"},{"title":"All Cluster Configurations","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/k8s/clusters","href":"/reference/api/10.0/general/get-all-clusterconfigs"},{"title":"Cluster Configuration by ID","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/k8s/clusters/{uid}","href":"/reference/api/10.0/general/get-a-single-clusterconfig-by-id"},{"title":"The list of available log files.","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/logs/api","href":"/reference/api/10.0/general/get-the-list-of-available-log-files"},{"title":"The content of a specific log file.","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/logs/api/{fname}","href":"/reference/api/10.0/general/get-the-content-of-a-specific-log-file"},{"title":"Metrics Get instance stats","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/metrics/instance-stats","href":"/reference/api/10.0/general/get-v25apimetricsinstance-stats"},{"title":"Hostname resolver addresses List","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/microseg/hostname-resolver/addresses","href":"/reference/api/10.0/general/get-v25apimicroseghostname-resolveraddresses"},{"title":"Cloudn backup config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_cloudn_backup_config","href":"/reference/api/10.0/general/get-v2apiget_cloudn_backup_config"},{"title":"Email notification config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_email_notification_config","href":"/reference/api/10.0/general/get-v2apiget_email_notification_config"},{"title":"Pending approved CIDRs","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_pending_approved_cidrs","href":"/reference/api/10.0/general/get-v2apiget_pending_approved_cidrs"},{"title":"Profile base policy","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_profile_base_policy","href":"/reference/api/10.0/general/get-v2apiget_profile_base_policy"},{"title":"Rate limit emails","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_rate_limit_emails","href":"/reference/api/10.0/general/get-v2apiget_rate_limit_emails"},{"title":"Session timeout","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_session_timeout","href":"/reference/api/10.0/general/get-v2apiget_session_timeout"},{"title":"Status change event email","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_status_change_event_email","href":"/reference/api/10.0/general/get-v2apiget_status_change_event_email"},{"title":"List arm account resource groups","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_arm_account_resource_groups","href":"/reference/api/10.0/general/get-v2apilist_arm_account_resource_groups"},{"title":"List attachment route table details","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_attachment_route_table_details","href":"/reference/api/10.0/general/get-v2apilist_attachment_route_table_details"},{"title":"List bell notifications","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_bell_notifications","href":"/reference/api/10.0/general/get-v2apilist_bell_notifications"},{"title":"List MultiCloud domain attachments","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_multi_cloud_domain_attachments","href":"/reference/api/10.0/general/get-v2apilist_multi_cloud_domain_attachments"},{"title":"List notify email addresses","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_notif_email_addr","href":"/reference/api/10.0/general/get-v2apilist_notif_email_addr"},{"title":"List policy members","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_policy_members","href":"/reference/api/10.0/general/get-v2apilist_policy_members"},{"title":"List profile policies","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_profile_policies","href":"/reference/api/10.0/general/get-v2apilist_profile_policies"},{"title":"List resource counts","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_resource_counts","href":"/reference/api/10.0/general/get-v2apilist_resource_counts"},{"title":"List tunnel info","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_tunnel_info","href":"/reference/api/10.0/general/get-v2apilist_tunnel_info"},{"title":"List tunnels latencies","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_tunnels_latencies","href":"/reference/api/10.0/general/get-v2apilist_tunnels_latencies"},{"title":"List unused subnet CIDRs","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_unused_subnet_cidrs","href":"/reference/api/10.0/general/get-v2apilist_unused_subnet_cidrs"},{"title":"List user profile names","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_user_profile_names","href":"/reference/api/10.0/general/get-v2apilist_user_profile_names"},{"title":"List version info","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_version_info","href":"/reference/api/10.0/general/get-v2apilist_version_info"},{"title":"List VGW connections","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_vgw_connections","href":"/reference/api/10.0/general/get-v2apilist_vgw_connections"},{"title":"Create a Cluster Configuration","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2.5/api/k8s/clusters","href":"/reference/api/10.0/general/create-a-clusterconfig"},{"title":"Add policy tag","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_policy_tag","href":"/reference/api/10.0/general/post-v2apiadd_policy_tag"},{"title":"Add profile member","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_profile_member","href":"/reference/api/10.0/general/post-v2apiadd_profile_member"},{"title":"Add user profile","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_user_profile","href":"/reference/api/10.0/general/post-v2apiadd_user_profile"},{"title":"Apply proxy config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/apply_proxy_config","href":"/reference/api/10.0/general/post-v2apiapply_proxy_config"},{"title":"Connect container","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/connect_container","href":"/reference/api/10.0/general/post-v2apiconnect_container"},{"title":"Del policy tag","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/del_policy_tag","href":"/reference/api/10.0/general/post-v2apidel_policy_tag"},{"title":"Del profile member","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/del_profile_member","href":"/reference/api/10.0/general/post-v2apidel_profile_member"},{"title":"Del user profile","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/del_user_profile","href":"/reference/api/10.0/general/post-v2apidel_user_profile"},{"title":"Delete container","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_container","href":"/reference/api/10.0/general/post-v2apidelete_container"},{"title":"Delete proxy config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_proxy_config","href":"/reference/api/10.0/general/post-v2apidelete_proxy_config"},{"title":"Disable active standby","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_active_standby","href":"/reference/api/10.0/general/post-v2apidisable_active_standby"},{"title":"Disable cloudn backup config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_cloudn_backup_config","href":"/reference/api/10.0/general/post-v2apidisable_cloudn_backup_config"},{"title":"Disable learned CIDRs approval","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_learned_cidrs_approval","href":"/reference/api/10.0/general/post-v2apidisable_learned_cidrs_approval"},{"title":"Disable skip public route table update","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_skip_public_route_table_update","href":"/reference/api/10.0/general/post-v2apidisable_skip_public_route_table_update"},{"title":"Disable spoke onprem route propagation","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_spoke_onprem_route_propagation","href":"/reference/api/10.0/general/post-v2apidisable_spoke_onprem_route_propagation"},{"title":"Disable spoke preserve AS path","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_spoke_preserve_as_path","href":"/reference/api/10.0/general/post-v2apidisable_spoke_preserve_as_path"},{"title":"Edit aviatrix spoke advanced config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_aviatrix_spoke_advanced_config","href":"/reference/api/10.0/general/post-v2apiedit_aviatrix_spoke_advanced_config"},{"title":"Edit public subnet filtering enforced route table list","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_public_subnet_filtering_enforced_route_table_list","href":"/reference/api/10.0/general/post-v2apiedit_public_subnet_filtering_enforced_route_table_list"},{"title":"Edit spoke connection AS path prepend","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_spoke_connection_as_path_prepend","href":"/reference/api/10.0/general/post-v2apiedit_spoke_connection_as_path_prepend"},{"title":"Edit spoke local AS number","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_spoke_local_as_number","href":"/reference/api/10.0/general/post-v2apiedit_spoke_local_as_number"},{"title":"Enable active standby","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_active_standby","href":"/reference/api/10.0/general/post-v2apienable_active_standby"},{"title":"Enable cloudn backup config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_cloudn_backup_config","href":"/reference/api/10.0/general/post-v2apienable_cloudn_backup_config"},{"title":"Enable learned CIDRs approval","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_learned_cidrs_approval","href":"/reference/api/10.0/general/post-v2apienable_learned_cidrs_approval"},{"title":"Enable skip public route table update","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_skip_public_route_table_update","href":"/reference/api/10.0/general/post-v2apienable_skip_public_route_table_update"},{"title":"Enable spoke onprem route propagation","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_spoke_onprem_route_propagation","href":"/reference/api/10.0/general/post-v2apienable_spoke_onprem_route_propagation"},{"title":"Enable spoke preserve AS path","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_spoke_preserve_as_path","href":"/reference/api/10.0/general/post-v2apienable_spoke_preserve_as_path"},{"title":"Modify detection time","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/modify_detection_time","href":"/reference/api/10.0/general/post-v2apimodify_detection_time"},{"title":"Modify split tunnel","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/modify_split_tunnel","href":"/reference/api/10.0/general/post-v2apimodify_split_tunnel"},{"title":"Peer diag test","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/peer_diag_test","href":"/reference/api/10.0/general/post-v2apipeer_diag_test"},{"title":"Set rate limit emails","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/set_rate_limit_emails","href":"/reference/api/10.0/general/post-v2apiset_rate_limit_emails"},{"title":"Set RX queue size","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/set_rx_queue_size","href":"/reference/api/10.0/general/post-v2apiset_rx_queue_size"},{"title":"Show customer domain","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_customer_domain","href":"/reference/api/10.0/general/post-v2apishow_customer_domain"},{"title":"Show proxy config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_proxy_config","href":"/reference/api/10.0/general/post-v2apishow_proxy_config"},{"title":"Show spoke learned CIDRs approval info","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_spoke_learned_cidrs_approval_info","href":"/reference/api/10.0/general/post-v2apishow_spoke_learned_cidrs_approval_info"},{"title":"Show tunnel status change detection time","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_tunnel_status_change_detection_time","href":"/reference/api/10.0/general/post-v2apishow_tunnel_status_change_detection_time"},{"title":"Test CIDR overlap","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/test_cidr_overlap","href":"/reference/api/10.0/general/post-v2apitest_cidr_overlap"},{"title":"Test connectivity in diag","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/test_connectivity_in_diag","href":"/reference/api/10.0/general/post-v2apitest_connectivity_in_diag"},{"title":"Test proxy connectivity","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/test_proxy_connectivity","href":"/reference/api/10.0/general/post-v2apitest_proxy_connectivity"},{"title":"Tracepath diagnostics","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/tracepath_diagnostics","href":"/reference/api/10.0/general/post-v2apitracepath_diagnostics"},{"title":"Traceroute diagnostics","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/traceroute_diagnostics","href":"/reference/api/10.0/general/post-v2apitraceroute_diagnostics"},{"title":"Update customized route advertisement","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/update_customized_route_advertisement","href":"/reference/api/10.0/general/post-v2apiupdate_customized_route_advertisement"},{"title":"Update policy members","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/update_policy_members","href":"/reference/api/10.0/general/post-v2apiupdate_policy_members"},{"title":"Update profile policy","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/update_profile_policy","href":"/reference/api/10.0/general/post-v2apiupdate_profile_policy"},{"title":"Update a Cluster Configuration","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/k8s/clusters/{uid}","href":"/reference/api/10.0/general/update-a-single-clusterconfig"},{"title":"Hostname resolver addresses set","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/microseg/hostname-resolver/addresses","href":"/reference/api/10.0/general/put-v25apimicroseghostname-resolveraddresses"}]},{"group":"Networking","pages":[{"group":"BGP","pages":[{"title":"BGP CIDR overlapping alert email status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_bgp_cidr_overlapping_alert_email_status","href":"/reference/api/10.0/bgp/get-v2apiget_bgp_cidr_overlapping_alert_email_status"},{"title":"BGP route limitation alert email status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_bgp_route_limitation_alert_email_status","href":"/reference/api/10.0/bgp/get-v2apiget_bgp_route_limitation_alert_email_status"},{"title":"List BGP diag commands","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_bgp_diag_commands","href":"/reference/api/10.0/bgp/get-v2apilist_bgp_diag_commands"},{"title":"List BGP gateways","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_bgp_gws","href":"/reference/api/10.0/bgp/get-v2apilist_bgp_gws"},{"title":"List BGP only gateways","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_bgp_only_gws","href":"/reference/api/10.0/bgp/get-v2apilist_bgp_only_gws"},{"title":"List BGP Site2cloud connections","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_bgp_site2cloud_connections","href":"/reference/api/10.0/bgp/get-v2apilist_bgp_site2cloud_connections"},{"title":"List BGP spoke gateways","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_bgp_spoke_gws","href":"/reference/api/10.0/bgp/get-v2apilist_bgp_spoke_gws"},{"title":"Change BGP hold time","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/change_bgp_hold_time","href":"/reference/api/10.0/bgp/post-v2apichange_bgp_hold_time"},{"title":"Change BGP neighbor status polling time","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/change_bgp_neighbor_status_polling_time","href":"/reference/api/10.0/bgp/post-v2apichange_bgp_neighbor_status_polling_time"},{"title":"Change BGP polling time","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/change_bgp_polling_time","href":"/reference/api/10.0/bgp/post-v2apichange_bgp_polling_time"},{"title":"Disable auto cloud BGP community","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_auto_cloud_bgp_community","href":"/reference/api/10.0/bgp/post-v2apidisable_auto_cloud_bgp_community"},{"title":"Disable BGP communities global","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_bgp_communities_global","href":"/reference/api/10.0/bgp/post-v2apidisable_bgp_communities_global"},{"title":"Disable BGP connection CIDR approval","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_bgp_connection_cidr_approval","href":"/reference/api/10.0/bgp/post-v2apidisable_bgp_connection_cidr_approval"},{"title":"Disable BGP ecmp","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_bgp_ecmp","href":"/reference/api/10.0/bgp/post-v2apidisable_bgp_ecmp"},{"title":"Disable BGP gateway CIDR approval","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_bgp_gateway_cidr_approval","href":"/reference/api/10.0/bgp/post-v2apidisable_bgp_gateway_cidr_approval"},{"title":"Disable BGP med to SDN metric global","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_bgp_med_to_sdn_metric_global","href":"/reference/api/10.0/bgp/post-v2apidisable_bgp_med_to_sdn_metric_global"},{"title":"Disable connection BGP multihop","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_connection_bgp_multihop","href":"/reference/api/10.0/bgp/post-v2apidisable_connection_bgp_multihop"},{"title":"Edit connection BGP bfd","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_connection_bgp_bfd","href":"/reference/api/10.0/bgp/post-v2apiedit_connection_bgp_bfd"},{"title":"Edit connection BGP send communities","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_connection_bgp_send_communities","href":"/reference/api/10.0/bgp/post-v2apiedit_connection_bgp_send_communities"},{"title":"Edit spoke connection BGP manual advertise CIDRs","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_spoke_connection_bgp_manual_advertise_cidrs","href":"/reference/api/10.0/bgp/post-v2apiedit_spoke_connection_bgp_manual_advertise_cidrs"},{"title":"Edit transit connection BGP manual advertise CIDRs","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_transit_connection_bgp_manual_advertise_cidrs","href":"/reference/api/10.0/bgp/post-v2apiedit_transit_connection_bgp_manual_advertise_cidrs"},{"title":"Enable auto cloud BGP community","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_auto_cloud_bgp_community","href":"/reference/api/10.0/bgp/post-v2apienable_auto_cloud_bgp_community"},{"title":"Enable BGP communities global","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_bgp_communities_global","href":"/reference/api/10.0/bgp/post-v2apienable_bgp_communities_global"},{"title":"Enable BGP connection CIDR approval","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_bgp_connection_cidr_approval","href":"/reference/api/10.0/bgp/post-v2apienable_bgp_connection_cidr_approval"},{"title":"Enable BGP gateway CIDR approval","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_bgp_gateway_cidr_approval","href":"/reference/api/10.0/bgp/post-v2apienable_bgp_gateway_cidr_approval"},{"title":"Enable BGP med to SDN metric global","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_bgp_med_to_sdn_metric_global","href":"/reference/api/10.0/bgp/post-v2apienable_bgp_med_to_sdn_metric_global"},{"title":"Set BGP connection approved CIDR rules","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/set_bgp_connection_approved_cidr_rules","href":"/reference/api/10.0/bgp/post-v2apiset_bgp_connection_approved_cidr_rules"},{"title":"Set BGP gateway approved CIDR rules","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/set_bgp_gateway_approved_cidr_rules","href":"/reference/api/10.0/bgp/post-v2apiset_bgp_gateway_approved_cidr_rules"},{"title":"Set BGP gateway CIDR approval mode","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/set_bgp_gateway_cidr_approval_mode","href":"/reference/api/10.0/bgp/post-v2apiset_bgp_gateway_cidr_approval_mode"},{"title":"Set BGP max as limit","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/set_bgp_max_as_limit","href":"/reference/api/10.0/bgp/post-v2apiset_bgp_max_as_limit"},{"title":"Set gateway accept BGP communities override","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/set_gateway_accept_bgp_communities_override","href":"/reference/api/10.0/bgp/post-v2apiset_gateway_accept_bgp_communities_override"},{"title":"Set gateway send BGP communities override","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/set_gateway_send_bgp_communities_override","href":"/reference/api/10.0/bgp/post-v2apiset_gateway_send_bgp_communities_override"},{"title":"Show auto cloud BGP community","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_auto_cloud_bgp_community","href":"/reference/api/10.0/bgp/post-v2apishow_auto_cloud_bgp_community"},{"title":"Show BGP advertised networks","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_bgp_advertised_networks","href":"/reference/api/10.0/bgp/post-v2apishow_bgp_advertised_networks"},{"title":"Show BGP auto refresh","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_bgp_auto_refresh","href":"/reference/api/10.0/bgp/post-v2apishow_bgp_auto_refresh"},{"title":"Show BGP communities gateway overrides","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_bgp_communities_gateway_overrides","href":"/reference/api/10.0/bgp/post-v2apishow_bgp_communities_gateway_overrides"},{"title":"Show BGP communities global","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_bgp_communities_global","href":"/reference/api/10.0/bgp/post-v2apishow_bgp_communities_global"},{"title":"Show BGP gateway CIDR approval info","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_bgp_gateway_cidr_approval_info","href":"/reference/api/10.0/bgp/post-v2apishow_bgp_gateway_cidr_approval_info"},{"title":"Show BGP learned routes","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_bgp_learned_routes","href":"/reference/api/10.0/bgp/post-v2apishow_bgp_learned_routes"},{"title":"Show BGP max as limit","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_bgp_max_as_limit","href":"/reference/api/10.0/bgp/post-v2apishow_bgp_max_as_limit"},{"title":"Show BGP med to SDN metric gateway override","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_bgp_med_to_sdn_metric_gateway_override","href":"/reference/api/10.0/bgp/post-v2apishow_bgp_med_to_sdn_metric_gateway_override"},{"title":"Show BGP med to SDN metric global","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_bgp_med_to_sdn_metric_global","href":"/reference/api/10.0/bgp/post-v2apishow_bgp_med_to_sdn_metric_global"},{"title":"Update BGP connection md5 signature","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/update_bgp_connection_md5_signature","href":"/reference/api/10.0/bgp/post-v2apiupdate_bgp_connection_md5_signature"}]},{"group":"NAT","pages":[{"title":"NAT Delete gateway mapped List","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json delete /v2.5/api/nat/mapped-list/{gw_name}","href":"/reference/api/10.0/nat/delete-v25apinatmapped-list"},{"title":"NAT Get entry","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/nat/entries/{gw_name}","href":"/reference/api/10.0/nat/get-v25apinatentries"},{"title":"NAT Get entry","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/nat/entries/{gw_name}","href":"/reference/api/10.0/nat/get-v25apinatentries"},{"title":"NAT Get gateway mapped List","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/nat/mapped-list/{gw_name}","href":"/reference/api/10.0/nat/get-v25apinatmapped-list"},{"title":"DNAT supported interfaces","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_dnat_supported_interfaces","href":"/reference/api/10.0/nat/get-v2apiget_dnat_supported_interfaces"},{"title":"DNAT supported protocols","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_dnat_supported_protocols","href":"/reference/api/10.0/nat/get-v2apiget_dnat_supported_protocols"},{"title":"Gateway DNAT config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_gateway_dnat_config","href":"/reference/api/10.0/nat/get-v2apiget_gateway_dnat_config"},{"title":"Gateway SNAT config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_gateway_snat_config","href":"/reference/api/10.0/nat/get-v2apiget_gateway_snat_config"},{"title":"Gateway DNAT config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_gw_dnat_config","href":"/reference/api/10.0/nat/get-v2apiget_gw_dnat_config"},{"title":"List DNAT supported interfaces","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_dnat_supported_interfaces","href":"/reference/api/10.0/nat/get-v2apilist_dnat_supported_interfaces"},{"title":"List DNAT supported protocols","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_dnat_supported_protocols","href":"/reference/api/10.0/nat/get-v2apilist_dnat_supported_protocols"},{"title":"List SNAT supported interfaces","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_snat_supported_interfaces","href":"/reference/api/10.0/nat/get-v2apilist_snat_supported_interfaces"},{"title":"List SNAT supported protocols","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_snat_supported_protocols","href":"/reference/api/10.0/nat/get-v2apilist_snat_supported_protocols"},{"title":"Disable SNAT","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_snat","href":"/reference/api/10.0/nat/post-v2apidisable_snat"},{"title":"Edit gateway customized SNAT config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_gw_customized_snat_config","href":"/reference/api/10.0/nat/post-v2apiedit_gw_customized_snat_config"},{"title":"Enable SNAT","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_snat","href":"/reference/api/10.0/nat/post-v2apienable_snat"},{"title":"NAT Update gateway mapped List","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/nat/mapped-list/{gw_name}","href":"/reference/api/10.0/nat/put-v25apinatmapped-list"}]},{"title":"The tagging settings","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/globalvpc/tagging_settings","href":"/reference/api/10.0/networking/get-the-tagging-settings"},{"title":"IPsec peering policy for gateway group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2.5/api/ipsec-peering-policy/{gwgroup_name}","href":"/reference/api/10.0/networking/get-ipsec-peering-policy-for-gateway-group"},{"title":"Custom VPC by name","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_custom_vpc_by_name","href":"/reference/api/10.0/networking/get-v2apiget_custom_vpc_by_name"},{"title":"IPsec Peering Policy (Global)","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_ipsec_peering_policy_global","href":"/reference/api/10.0/networking/get-v2apiget_ipsec_peering_policy_global"},{"title":"Spoke gateway subnet group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_spoke_gateway_subnet_group","href":"/reference/api/10.0/networking/get-v2apiget_spoke_gateway_subnet_group"},{"title":"List arm peer vnet pairs","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_arm_peer_vnet_pairs","href":"/reference/api/10.0/networking/get-v2apilist_arm_peer_vnet_pairs"},{"title":"List attached VPC names to route domain","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_attached_vpc_names_to_route_domain","href":"/reference/api/10.0/networking/get-v2apilist_attached_vpc_names_to_route_domain"},{"title":"List AWS peerings","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_aws_peerings","href":"/reference/api/10.0/networking/get-v2apilist_aws_peerings"},{"title":"List connected route domains","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_connected_route_domains","href":"/reference/api/10.0/networking/get-v2apilist_connected_route_domains"},{"title":"List custom VPCs","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_custom_vpcs","href":"/reference/api/10.0/networking/get-v2apilist_custom_vpcs"},{"title":"List oci VPC availability domains","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_oci_vpc_availability_domains","href":"/reference/api/10.0/networking/get-v2apilist_oci_vpc_availability_domains"},{"title":"List oci VPC fault domains","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_oci_vpc_fault_domains","href":"/reference/api/10.0/networking/get-v2apilist_oci_vpc_fault_domains"},{"title":"List peer VPC pairs","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_peer_vpc_pairs","href":"/reference/api/10.0/networking/get-v2apilist_peer_vpc_pairs"},{"title":"List resource tags","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_resource_tags","href":"/reference/api/10.0/networking/get-v2apilist_resource_tags"},{"title":"List route domain names","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_route_domain_names","href":"/reference/api/10.0/networking/get-v2apilist_route_domain_names"},{"title":"List spoke gateway subnet groups","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_spoke_gateway_subnet_groups","href":"/reference/api/10.0/networking/get-v2apilist_spoke_gateway_subnet_groups"},{"title":"List vnets with VNG","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_vnets_with_vng","href":"/reference/api/10.0/networking/get-v2apilist_vnets_with_vng"},{"title":"List VPC all subnets","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_vpc_all_subnets","href":"/reference/api/10.0/networking/get-v2apilist_vpc_all_subnets"},{"title":"List VPC by name","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_vpc_by_name","href":"/reference/api/10.0/networking/get-v2apilist_vpc_by_name"},{"title":"List VPC ids with name tag","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_vpc_ids_with_name_tag","href":"/reference/api/10.0/networking/get-v2apilist_vpc_ids_with_name_tag"},{"title":"List VPC loadbalancer names","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_vpc_lb_names","href":"/reference/api/10.0/networking/get-v2apilist_vpc_lb_names"},{"title":"List VPC route tables","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_vpc_route_tables","href":"/reference/api/10.0/networking/get-v2apilist_vpc_route_tables"},{"title":"List vpcs","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_vpcs","href":"/reference/api/10.0/networking/get-v2apilist_vpcs"},{"title":"List vpcs association","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_vpcs_association","href":"/reference/api/10.0/networking/get-v2apilist_vpcs_association"},{"title":"List vpcs summary","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_vpcs_summary","href":"/reference/api/10.0/networking/get-v2apilist_vpcs_summary"},{"title":"Add a new instance to the exclude list","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2.5/api/globalvpc/exclude_list","href":"/reference/api/10.0/networking/add-a-new-instance-to-the-exclude-list"},{"title":"Set IPsec peering policy for gateway group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2.5/api/ipsec-peering-policy/{gwgroup_name}","href":"/reference/api/10.0/networking/set-ipsec-peering-policy-for-gateway-group"},{"title":"Add connection between route domains","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_connection_between_route_domains","href":"/reference/api/10.0/networking/post-v2apiadd_connection_between_route_domains"},{"title":"Add resource tags","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_resource_tags","href":"/reference/api/10.0/networking/post-v2apiadd_resource_tags"},{"title":"Add route domain","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_route_domain","href":"/reference/api/10.0/networking/post-v2apiadd_route_domain"},{"title":"Add spoke gateway subnet group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_spoke_gateway_subnet_group","href":"/reference/api/10.0/networking/post-v2apiadd_spoke_gateway_subnet_group"},{"title":"ARM peer vnet pair","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/arm_peer_vnet_pair","href":"/reference/api/10.0/networking/post-v2apiarm_peer_vnet_pair"},{"title":"ARM unpeer vnet pair","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/arm_unpeer_vnet_pair","href":"/reference/api/10.0/networking/post-v2apiarm_unpeer_vnet_pair"},{"title":"Create custom VPC","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/create_custom_vpc","href":"/reference/api/10.0/networking/post-v2apicreate_custom_vpc"},{"title":"Delete connection between route domains","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_connection_between_route_domains","href":"/reference/api/10.0/networking/post-v2apidelete_connection_between_route_domains"},{"title":"Delete custom VPC","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_custom_vpc","href":"/reference/api/10.0/networking/post-v2apidelete_custom_vpc"},{"title":"Delete resource tag","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_resource_tag","href":"/reference/api/10.0/networking/post-v2apidelete_resource_tag"},{"title":"Delete route domain","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_route_domain","href":"/reference/api/10.0/networking/post-v2apidelete_route_domain"},{"title":"Delete spoke gateway subnet group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_spoke_gateway_subnet_group","href":"/reference/api/10.0/networking/post-v2apidelete_spoke_gateway_subnet_group"},{"title":"Disable global VPC","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_global_vpc","href":"/reference/api/10.0/networking/post-v2apidisable_global_vpc"},{"title":"Disable private VPC default route","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_private_vpc_default_route","href":"/reference/api/10.0/networking/post-v2apidisable_private_vpc_default_route"},{"title":"Disable VPC DNS server","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_vpc_dns_server","href":"/reference/api/10.0/networking/post-v2apidisable_vpc_dns_server"},{"title":"Edit private route tables","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_private_route_tables","href":"/reference/api/10.0/networking/post-v2apiedit_private_route_tables"},{"title":"Enable global VPC","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_global_vpc","href":"/reference/api/10.0/networking/post-v2apienable_global_vpc"},{"title":"Enable VPC DNS server","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_vpc_dns_server","href":"/reference/api/10.0/networking/post-v2apienable_vpc_dns_server"},{"title":"Peer VPC pair","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/peer_vpc_pair","href":"/reference/api/10.0/networking/post-v2apipeer_vpc_pair"},{"title":"Set VPC base policy","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/set_vpc_base_policy","href":"/reference/api/10.0/networking/post-v2apiset_vpc_base_policy"},{"title":"Unpeer VPC pair","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/unpeer_vpc_pair","href":"/reference/api/10.0/networking/post-v2apiunpeer_vpc_pair"},{"title":"Update resource tags","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/update_resource_tags","href":"/reference/api/10.0/networking/post-v2apiupdate_resource_tags"},{"title":"Update spoke gateway subnet group","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/update_spoke_gateway_subnet_group","href":"/reference/api/10.0/networking/post-v2apiupdate_spoke_gateway_subnet_group"},{"title":"View route domain details","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/view_route_domain_details","href":"/reference/api/10.0/networking/post-v2apiview_route_domain_details"},{"title":"VPC access policy","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/vpc_access_policy","href":"/reference/api/10.0/networking/post-v2apivpc_access_policy"},{"title":"Update tagging setting","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json put /v2.5/api/globalvpc/tagging_settings","href":"/reference/api/10.0/networking/update-tagging-setting"}]},{"group":"Observability","pages":[{"group":"Logging","pages":[{"title":"Cloudwatch agent status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_cloudwatch_agent_status","href":"/reference/api/10.0/logging/get-v2apiget_cloudwatch_agent_status"},{"title":"Datadog agent logging status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_datadog_agent_logging_status","href":"/reference/api/10.0/logging/get-v2apiget_datadog_agent_logging_status"},{"title":"Netflow agent","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_netflow_agent","href":"/reference/api/10.0/logging/get-v2apiget_netflow_agent"},{"title":"Disable cloudwatch agent","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_cloudwatch_agent","href":"/reference/api/10.0/logging/post-v2apidisable_cloudwatch_agent"},{"title":"Disable Datadog agent logging","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_datadog_agent_logging","href":"/reference/api/10.0/logging/post-v2apidisable_datadog_agent_logging"},{"title":"Disable netflow agent","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_netflow_agent","href":"/reference/api/10.0/logging/post-v2apidisable_netflow_agent"},{"title":"Disable remote syslog logging","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_remote_syslog_logging","href":"/reference/api/10.0/logging/post-v2apidisable_remote_syslog_logging"},{"title":"Download gateway packet capture file","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/download_gateway_packet_capture_file","href":"/reference/api/10.0/logging/post-v2apidownload_gateway_packet_capture_file"},{"title":"Download gateway syslog","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/download_gateway_syslog","href":"/reference/api/10.0/logging/post-v2apidownload_gateway_syslog"},{"title":"Enable cloudwatch agent","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_cloudwatch_agent","href":"/reference/api/10.0/logging/post-v2apienable_cloudwatch_agent"},{"title":"Enable Datadog agent logging","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_datadog_agent_logging","href":"/reference/api/10.0/logging/post-v2apienable_datadog_agent_logging"},{"title":"Enable netflow agent","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_netflow_agent","href":"/reference/api/10.0/logging/post-v2apienable_netflow_agent"},{"title":"Enable remote syslog logging","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_remote_syslog_logging","href":"/reference/api/10.0/logging/post-v2apienable_remote_syslog_logging"},{"title":"Gateway packet capture log","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/gateway_packet_capture_log","href":"/reference/api/10.0/logging/post-v2apigateway_packet_capture_log"},{"title":"Start gateway packet capture","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/start_gateway_packet_capture","href":"/reference/api/10.0/logging/post-v2apistart_gateway_packet_capture"},{"title":"Stop gateway packet capture","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/stop_gateway_packet_capture","href":"/reference/api/10.0/logging/post-v2apistop_gateway_packet_capture"}]},{"group":"Monitoring \u0026 Diagnostics","pages":[{"title":"Account audit records","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_account_audit_records","href":"/reference/api/10.0/monitoring/get-v2apiget_account_audit_records"},{"title":"Bell alert config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_bell_alert_config","href":"/reference/api/10.0/monitoring/get-v2apiget_bell_alert_config"},{"title":"Controller audit log","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_controller_audit_log","href":"/reference/api/10.0/monitoring/get-v2apiget_controller_audit_log"},{"title":"Controller audit log file","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_controller_audit_log_file","href":"/reference/api/10.0/monitoring/get-v2apiget_controller_audit_log_file"},{"title":"Edge CSP device metrics","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_edge_csp_device_metrics","href":"/reference/api/10.0/monitoring/get-v2apiget_edge_csp_device_metrics"},{"title":"Exception email notification status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_exception_email_notification_status","href":"/reference/api/10.0/monitoring/get-v2apiget_exception_email_notification_status"},{"title":"Gateway periodic ping status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_gateway_periodic_ping_status","href":"/reference/api/10.0/monitoring/get-v2apiget_gateway_periodic_ping_status"},{"title":"Gateway stats","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_gateway_stats","href":"/reference/api/10.0/monitoring/get-v2apiget_gateway_stats"},{"title":"List AWS Guard Duty","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_aws_guard_duty","href":"/reference/api/10.0/monitoring/get-v2apilist_aws_guard_duty"},{"title":"Active standby connection switchover","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/active_standby_connection_switchover","href":"/reference/api/10.0/monitoring/post-v2apiactive_standby_connection_switchover"},{"title":"Disable AWS Guard Duty","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_aws_guard_duty","href":"/reference/api/10.0/monitoring/post-v2apidisable_aws_guard_duty"},{"title":"Disable exception email notification","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_exception_email_notification","href":"/reference/api/10.0/monitoring/post-v2apidisable_exception_email_notification"},{"title":"Disable gateway periodic ping","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_gateway_periodic_ping","href":"/reference/api/10.0/monitoring/post-v2apidisable_gateway_periodic_ping"},{"title":"Disable monitor gateway subnets","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_monitor_gateway_subnets","href":"/reference/api/10.0/monitoring/post-v2apidisable_monitor_gateway_subnets"},{"title":"Disable public subnet filtering Guard Duty enforced mode","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_public_subnet_filtering_guard_duty_enforced_mode","href":"/reference/api/10.0/monitoring/post-v2apidisable_public_subnet_filtering_guard_duty_enforced_mode"},{"title":"Do ping on activemesh","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/do_ping_on_activemesh","href":"/reference/api/10.0/monitoring/post-v2apido_ping_on_activemesh"},{"title":"Enable AWS Guard Duty","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_aws_guard_duty","href":"/reference/api/10.0/monitoring/post-v2apienable_aws_guard_duty"},{"title":"Enable gateway periodic ping","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_gateway_periodic_ping","href":"/reference/api/10.0/monitoring/post-v2apienable_gateway_periodic_ping"},{"title":"Enable monitor gateway subnets","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_monitor_gateway_subnets","href":"/reference/api/10.0/monitoring/post-v2apienable_monitor_gateway_subnets"},{"title":"Enable public subnet filtering Guard Duty enforced mode","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_public_subnet_filtering_guard_duty_enforced_mode","href":"/reference/api/10.0/monitoring/post-v2apienable_public_subnet_filtering_guard_duty_enforced_mode"},{"title":"Ping diagnostics","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/ping_diagnostics","href":"/reference/api/10.0/monitoring/post-v2apiping_diagnostics"},{"title":"Update AWS Guard Duty excluded ips","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/update_aws_guard_duty_excluded_ips","href":"/reference/api/10.0/monitoring/post-v2apiupdate_aws_guard_duty_excluded_ips"},{"title":"Update AWS Guard Duty poll interval","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/update_aws_guard_duty_poll_interval","href":"/reference/api/10.0/monitoring/post-v2apiupdate_aws_guard_duty_poll_interval"}]}]},{"group":"Site-to-Cloud","pages":[{"title":"Auto advertise Site2cloud CIDRs List","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_auto_advertise_s2c_cidrs_list","href":"/reference/api/10.0/site-to-cloud/get-v2apiget_auto_advertise_s2c_cidrs_list"},{"title":"Auto advertise Site2cloud CIDRs status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_auto_advertise_s2c_cidrs_status","href":"/reference/api/10.0/site-to-cloud/get-v2apiget_auto_advertise_s2c_cidrs_status"},{"title":"Site2cloud CA cert List","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_s2c_ca_cert_list","href":"/reference/api/10.0/site-to-cloud/get-v2apiget_s2c_ca_cert_list"},{"title":"Site2cloud CA cert List by name","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_s2c_ca_cert_list_by_name","href":"/reference/api/10.0/site-to-cloud/get-v2apiget_s2c_ca_cert_list_by_name"},{"title":"Site2cloud CA cert names","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_s2c_ca_cert_names","href":"/reference/api/10.0/site-to-cloud/get-v2apiget_s2c_ca_cert_names"},{"title":"Site2cloud name List by cert tag name","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_s2c_name_list_by_cert_tag_name","href":"/reference/api/10.0/site-to-cloud/get-v2apiget_s2c_name_list_by_cert_tag_name"},{"title":"Site2cloud connection detail","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_site2cloud_conn_detail","href":"/reference/api/10.0/site-to-cloud/get-v2apiget_site2cloud_conn_detail"},{"title":"List Site2cloud conn","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_site2cloud_conn","href":"/reference/api/10.0/site-to-cloud/get-v2apilist_site2cloud_conn"},{"title":"List Site2cloud connection algorithms","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_site2cloud_connection_algorithms","href":"/reference/api/10.0/site-to-cloud/get-v2apilist_site2cloud_connection_algorithms"},{"title":"Add Site2cloud CA cert","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_s2c_ca_cert","href":"/reference/api/10.0/site-to-cloud/post-v2apiadd_s2c_ca_cert"},{"title":"Connect transit gateway to external device","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/connect_transit_gw_to_external_device","href":"/reference/api/10.0/site-to-cloud/post-v2apiconnect_transit_gw_to_external_device"},{"title":"Connect transit gateway to vgw","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/connect_transit_gw_to_vgw","href":"/reference/api/10.0/site-to-cloud/post-v2apiconnect_transit_gw_to_vgw"},{"title":"Delete Site2cloud CA cert","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_s2c_ca_cert","href":"/reference/api/10.0/site-to-cloud/post-v2apidelete_s2c_ca_cert"},{"title":"Delete Site2cloud connection","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_site2cloud_connection","href":"/reference/api/10.0/site-to-cloud/post-v2apidelete_site2cloud_connection"},{"title":"Disable auto advertise Site2cloud CIDRs","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_auto_advertise_s2c_cidrs","href":"/reference/api/10.0/site-to-cloud/post-v2apidisable_auto_advertise_s2c_cidrs"},{"title":"Disable DPD config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_dpd_config","href":"/reference/api/10.0/site-to-cloud/post-v2apidisable_dpd_config"},{"title":"Disable Site2cloud RX balancing","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_s2c_rx_balancing","href":"/reference/api/10.0/site-to-cloud/post-v2apidisable_s2c_rx_balancing"},{"title":"Disable Site2cloud active active HA","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_site2cloud_active_active_ha","href":"/reference/api/10.0/site-to-cloud/post-v2apidisable_site2cloud_active_active_ha"},{"title":"Disable Site2cloud event triggered HA","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_site2cloud_event_triggered_ha","href":"/reference/api/10.0/site-to-cloud/post-v2apidisable_site2cloud_event_triggered_ha"},{"title":"Disable spoke mapped Site2cloud forwarding","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_spoke_mapped_site2cloud_forwarding","href":"/reference/api/10.0/site-to-cloud/post-v2apidisable_spoke_mapped_site2cloud_forwarding"},{"title":"Disconnect transit gateway from vgw","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disconnect_transit_gw_from_vgw","href":"/reference/api/10.0/site-to-cloud/post-v2apidisconnect_transit_gw_from_vgw"},{"title":"Edit Site2cloud conn","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_site2cloud_conn","href":"/reference/api/10.0/site-to-cloud/post-v2apiedit_site2cloud_conn"},{"title":"Enable auto advertise Site2cloud CIDRs","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_auto_advertise_s2c_cidrs","href":"/reference/api/10.0/site-to-cloud/post-v2apienable_auto_advertise_s2c_cidrs"},{"title":"Enable DPD config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_dpd_config","href":"/reference/api/10.0/site-to-cloud/post-v2apienable_dpd_config"},{"title":"Enable Site2cloud RX balancing","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_s2c_rx_balancing","href":"/reference/api/10.0/site-to-cloud/post-v2apienable_s2c_rx_balancing"},{"title":"Enable Site2cloud active active HA","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_site2cloud_active_active_ha","href":"/reference/api/10.0/site-to-cloud/post-v2apienable_site2cloud_active_active_ha"},{"title":"Enable Site2cloud event triggered HA","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_site2cloud_event_triggered_ha","href":"/reference/api/10.0/site-to-cloud/post-v2apienable_site2cloud_event_triggered_ha"},{"title":"Enable spoke mapped Site2cloud forwarding","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_spoke_mapped_site2cloud_forwarding","href":"/reference/api/10.0/site-to-cloud/post-v2apienable_spoke_mapped_site2cloud_forwarding"}]},{"group":"AWS TGW","pages":[{"title":"TGW 3D view data","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_tgw_3d_view_data","href":"/reference/api/10.0/tgw/get-v2apiget_tgw_3d_view_data"},{"title":"TGW attachment details","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_tgw_attachment_details","href":"/reference/api/10.0/tgw/get-v2apiget_tgw_attachment_details"},{"title":"TGW connect by connection name","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_tgw_connect_by_connection_name","href":"/reference/api/10.0/tgw/get-v2apiget_tgw_connect_by_connection_name"},{"title":"TGW connect peer by connect peer name","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_tgw_connect_peer_by_connect_peer_name","href":"/reference/api/10.0/tgw/get-v2apiget_tgw_connect_peer_by_connect_peer_name"},{"title":"TGW directconnect allowed prefix","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_tgw_directconnect_allowed_prefix","href":"/reference/api/10.0/tgw/get-v2apiget_tgw_directconnect_allowed_prefix"},{"title":"TGW nightly automatic audit status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_tgw_nightly_automatic_audit_status","href":"/reference/api/10.0/tgw/get-v2apiget_tgw_nightly_automatic_audit_status"},{"title":"List all TGW attachments","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_all_tgw_attachments","href":"/reference/api/10.0/tgw/get-v2apilist_all_tgw_attachments"},{"title":"List all TGW security domains","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_all_tgw_security_domains","href":"/reference/api/10.0/tgw/get-v2apilist_all_tgw_security_domains"},{"title":"List all TGWs details","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_all_tgws_details","href":"/reference/api/10.0/tgw/get-v2apilist_all_tgws_details"},{"title":"List AWS TGW","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_aws_tgw","href":"/reference/api/10.0/tgw/get-v2apilist_aws_tgw"},{"title":"List AWS TGW domain connection policies","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_aws_tgw_domain_connection_policies","href":"/reference/api/10.0/tgw/get-v2apilist_aws_tgw_domain_connection_policies"},{"title":"List peered TGW names","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_peered_tgw_names","href":"/reference/api/10.0/tgw/get-v2apilist_peered_tgw_names"},{"title":"List TGW connect id with VPC name","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_tgw_connect_id_with_vpc_name","href":"/reference/api/10.0/tgw/get-v2apilist_tgw_connect_id_with_vpc_name"},{"title":"List TGW connect peer ids with name tag","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_tgw_connect_peer_ids_with_name_tag","href":"/reference/api/10.0/tgw/get-v2apilist_tgw_connect_peer_ids_with_name_tag"},{"title":"List TGW details","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_tgw_details","href":"/reference/api/10.0/tgw/get-v2apilist_tgw_details"},{"title":"List TGW directconnect gateways","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_tgw_directconnect_gateways","href":"/reference/api/10.0/tgw/get-v2apilist_tgw_directconnect_gateways"},{"title":"List TGW names","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_tgw_names","href":"/reference/api/10.0/tgw/get-v2apilist_tgw_names"},{"title":"List TGW security domain details","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_tgw_security_domain_details","href":"/reference/api/10.0/tgw/get-v2apilist_tgw_security_domain_details"},{"title":"List TGW security domains to switch to","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_tgw_security_domains_to_switch_to","href":"/reference/api/10.0/tgw/get-v2apilist_tgw_security_domains_to_switch_to"},{"title":"List TGW with cloud type","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_tgw_with_cloud_type","href":"/reference/api/10.0/tgw/get-v2apilist_tgw_with_cloud_type"},{"title":"Add AWS TGW","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_aws_tgw","href":"/reference/api/10.0/tgw/post-v2apiadd_aws_tgw"},{"title":"Add TGW peering","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_tgw_peering","href":"/reference/api/10.0/tgw/post-v2apiadd_tgw_peering"},{"title":"Attach direct connect to TGW","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/attach_direct_connect_to_tgw","href":"/reference/api/10.0/tgw/post-v2apiattach_direct_connect_to_tgw"},{"title":"Attach TGW connect to TGW","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/attach_tgw_connect_to_tgw","href":"/reference/api/10.0/tgw/post-v2apiattach_tgw_connect_to_tgw"},{"title":"Attach VNG to transit gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/attach_vng_to_transit_gateway","href":"/reference/api/10.0/tgw/post-v2apiattach_vng_to_transit_gateway"},{"title":"Attach VPC to TGW","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/attach_vpc_to_tgw","href":"/reference/api/10.0/tgw/post-v2apiattach_vpc_to_tgw"},{"title":"Create TGW connect peer","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/create_tgw_connect_peer","href":"/reference/api/10.0/tgw/post-v2apicreate_tgw_connect_peer"},{"title":"Delete AWS TGW","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_aws_tgw","href":"/reference/api/10.0/tgw/post-v2apidelete_aws_tgw"},{"title":"Delete TGW connect peer","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_tgw_connect_peer","href":"/reference/api/10.0/tgw/post-v2apidelete_tgw_connect_peer"},{"title":"Delete TGW peering","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_tgw_peering","href":"/reference/api/10.0/tgw/post-v2apidelete_tgw_peering"},{"title":"Detach directconnect from TGW","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/detach_directconnect_from_tgw","href":"/reference/api/10.0/tgw/post-v2apidetach_directconnect_from_tgw"},{"title":"Detach TGW connect from TGW","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/detach_tgw_connect_from_tgw","href":"/reference/api/10.0/tgw/post-v2apidetach_tgw_connect_from_tgw"},{"title":"Detach VPC from TGW","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/detach_vpc_from_tgw","href":"/reference/api/10.0/tgw/post-v2apidetach_vpc_from_tgw"},{"title":"Disable TGW intra domain inspection","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_tgw_intra_domain_inspection","href":"/reference/api/10.0/tgw/post-v2apidisable_tgw_intra_domain_inspection"},{"title":"Disable transit gateway interface to AWS TGW","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_transit_gateway_interface_to_aws_tgw","href":"/reference/api/10.0/tgw/post-v2apidisable_transit_gateway_interface_to_aws_tgw"},{"title":"Disable transit summarize CIDR to TGW","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_transit_summarize_cidr_to_tgw","href":"/reference/api/10.0/tgw/post-v2apidisable_transit_summarize_cidr_to_tgw"},{"title":"Edit AWS TGW inspection mode","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_aws_tgw_inspection_mode","href":"/reference/api/10.0/tgw/post-v2apiedit_aws_tgw_inspection_mode"},{"title":"Edit TGW spoke VPC customized routes","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_tgw_spoke_vpc_customized_routes","href":"/reference/api/10.0/tgw/post-v2apiedit_tgw_spoke_vpc_customized_routes"},{"title":"Enable TGW intra domain inspection","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_tgw_intra_domain_inspection","href":"/reference/api/10.0/tgw/post-v2apienable_tgw_intra_domain_inspection"},{"title":"Enable transit gateway interface to AWS TGW","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_transit_gateway_interface_to_aws_tgw","href":"/reference/api/10.0/tgw/post-v2apienable_transit_gateway_interface_to_aws_tgw"},{"title":"Enable transit summarize CIDR to TGW","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_transit_summarize_cidr_to_tgw","href":"/reference/api/10.0/tgw/post-v2apienable_transit_summarize_cidr_to_tgw"},{"title":"Update TGW CIDRs","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/update_tgw_cidrs","href":"/reference/api/10.0/tgw/post-v2apiupdate_tgw_cidrs"},{"title":"Update TGW directconnect allowed prefix","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/update_tgw_directconnect_allowed_prefix","href":"/reference/api/10.0/tgw/post-v2apiupdate_tgw_directconnect_allowed_prefix"}]},{"group":"Transit","pages":[{"title":"Inter transit gateway peering details","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_inter_transit_gateway_peering_details","href":"/reference/api/10.0/transit/get-v2apiget_inter_transit_gateway_peering_details"},{"title":"Transit or spoke gateway best routes","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_transit_or_spoke_gateway_best_routes","href":"/reference/api/10.0/transit/get-v2apiget_transit_or_spoke_gateway_best_routes"},{"title":"Transit or spoke gateway details","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_transit_or_spoke_gateway_details","href":"/reference/api/10.0/transit/get-v2apiget_transit_or_spoke_gateway_details"},{"title":"List aviatrix transit advanced config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_aviatrix_transit_advanced_config","href":"/reference/api/10.0/transit/get-v2apilist_aviatrix_transit_advanced_config"},{"title":"List aviatrix transit gateways","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_aviatrix_transit_gateways","href":"/reference/api/10.0/transit/get-v2apilist_aviatrix_transit_gateways"},{"title":"List inter transit gateway peering","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_inter_transit_gateway_peering","href":"/reference/api/10.0/transit/get-v2apilist_inter_transit_gateway_peering"},{"title":"List MultiCloud security domain connection policy","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_multi_cloud_security_domain_connection_policy","href":"/reference/api/10.0/transit/get-v2apilist_multi_cloud_security_domain_connection_policy"},{"title":"List MultiCloud security domain names","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_multi_cloud_security_domain_names","href":"/reference/api/10.0/transit/get-v2apilist_multi_cloud_security_domain_names"},{"title":"List MultiCloud security domains","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_multi_cloud_security_domains","href":"/reference/api/10.0/transit/get-v2apilist_multi_cloud_security_domains"},{"title":"List transit gateways for MultiCloud domains","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_transit_gateways_for_multi_cloud_domains","href":"/reference/api/10.0/transit/get-v2apilist_transit_gateways_for_multi_cloud_domains"},{"title":"List transit learned CIDRs","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_transit_learned_cidrs","href":"/reference/api/10.0/transit/get-v2apilist_transit_learned_cidrs"},{"title":"Add MultiCloud security domain","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_multi_cloud_security_domain","href":"/reference/api/10.0/transit/post-v2apiadd_multi_cloud_security_domain"},{"title":"Associate attachment to MultiCloud security domain","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/associate_attachment_to_multi_cloud_security_domain","href":"/reference/api/10.0/transit/post-v2apiassociate_attachment_to_multi_cloud_security_domain"},{"title":"Attach ARM Native Spoke to Transit","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/attach_arm_native_spoke_to_transit","href":"/reference/api/10.0/transit/post-v2apiattach_arm_native_spoke_to_transit"},{"title":"Attach Spoke to Transit Gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/attach_spoke_to_transit_gw","href":"/reference/api/10.0/transit/post-v2apiattach_spoke_to_transit_gw"},{"title":"Connect MultiCloud security domains","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/connect_multi_cloud_security_domains","href":"/reference/api/10.0/transit/post-v2apiconnect_multi_cloud_security_domains"},{"title":"Delete inter transit gateway peering","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_inter_transit_gateway_peering","href":"/reference/api/10.0/transit/post-v2apidelete_inter_transit_gateway_peering"},{"title":"Delete MultiCloud security domain","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_multi_cloud_security_domain","href":"/reference/api/10.0/transit/post-v2apidelete_multi_cloud_security_domain"},{"title":"Detach ARM Native Spoke from Transit","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/detach_arm_native_spoke_to_transit","href":"/reference/api/10.0/transit/post-v2apidetach_arm_native_spoke_to_transit"},{"title":"Detach Spoke from Transit Gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/detach_spoke_from_transit_gw","href":"/reference/api/10.0/transit/post-v2apidetach_spoke_from_transit_gw"},{"title":"Disable advertise transit CIDR","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_advertise_transit_cidr","href":"/reference/api/10.0/transit/post-v2apidisable_advertise_transit_cidr"},{"title":"Disable connected transit on gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_connected_transit_on_gateway","href":"/reference/api/10.0/transit/post-v2apidisable_connected_transit_on_gateway"},{"title":"Disable Edge transitive routing","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_edge_transitive_routing","href":"/reference/api/10.0/transit/post-v2apidisable_edge_transitive_routing"},{"title":"Disable multitier transit","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_multitier_transit","href":"/reference/api/10.0/transit/post-v2apidisable_multitier_transit"},{"title":"Disable transit gateway for MultiCloud security domain","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_transit_gateway_for_multi_cloud_security_domain","href":"/reference/api/10.0/transit/post-v2apidisable_transit_gateway_for_multi_cloud_security_domain"},{"title":"Disable transit preserve AS path","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_transit_preserve_as_path","href":"/reference/api/10.0/transit/post-v2apidisable_transit_preserve_as_path"},{"title":"Disassociate attachment from MultiCloud security domain","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disassociate_attachment_from_multi_cloud_security_domain","href":"/reference/api/10.0/transit/post-v2apidisassociate_attachment_from_multi_cloud_security_domain"},{"title":"Disconnect MultiCloud security domains","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disconnect_multi_cloud_security_domains","href":"/reference/api/10.0/transit/post-v2apidisconnect_multi_cloud_security_domains"},{"title":"Disconnect transit gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disconnect_transit_gw","href":"/reference/api/10.0/transit/post-v2apidisconnect_transit_gw"},{"title":"Edit aviatrix transit advanced config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_aviatrix_transit_advanced_config","href":"/reference/api/10.0/transit/post-v2apiedit_aviatrix_transit_advanced_config"},{"title":"Edit inter transit gateway peering","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_inter_transit_gateway_peering","href":"/reference/api/10.0/transit/post-v2apiedit_inter_transit_gateway_peering"},{"title":"Edit transit connection AS path prepend","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_transit_connection_as_path_prepend","href":"/reference/api/10.0/transit/post-v2apiedit_transit_connection_as_path_prepend"},{"title":"Edit transit gateway customized VPC route","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_transit_gateway_customized_vpc_route","href":"/reference/api/10.0/transit/post-v2apiedit_transit_gateway_customized_vpc_route"},{"title":"Edit transit local AS number","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_transit_local_as_number","href":"/reference/api/10.0/transit/post-v2apiedit_transit_local_as_number"},{"title":"Enable advertise transit CIDR","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_advertise_transit_cidr","href":"/reference/api/10.0/transit/post-v2apienable_advertise_transit_cidr"},{"title":"Enable connected transit on gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_connected_transit_on_gateway","href":"/reference/api/10.0/transit/post-v2apienable_connected_transit_on_gateway"},{"title":"Enable Edge transitive routing","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_edge_transitive_routing","href":"/reference/api/10.0/transit/post-v2apienable_edge_transitive_routing"},{"title":"Enable multitier transit","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_multitier_transit","href":"/reference/api/10.0/transit/post-v2apienable_multitier_transit"},{"title":"Enable transit gateway for MultiCloud security domain","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_transit_gateway_for_multi_cloud_security_domain","href":"/reference/api/10.0/transit/post-v2apienable_transit_gateway_for_multi_cloud_security_domain"},{"title":"Enable transit preserve AS path","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_transit_preserve_as_path","href":"/reference/api/10.0/transit/post-v2apienable_transit_preserve_as_path"},{"title":"Show inter transit gateway peering parameters","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_inter_transit_gateway_peering_parameters","href":"/reference/api/10.0/transit/post-v2apishow_inter_transit_gateway_peering_parameters"},{"title":"Show MultiCloud transit peering details","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_multi_cloud_transit_peering_details","href":"/reference/api/10.0/transit/post-v2apishow_multi_cloud_transit_peering_details"},{"title":"Show MultiCloud transit connection config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_multicloud_transit_connection_config","href":"/reference/api/10.0/transit/post-v2apishow_multicloud_transit_connection_config"},{"title":"Show MultiCloud transit connection log","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_multicloud_transit_connection_log","href":"/reference/api/10.0/transit/post-v2apishow_multicloud_transit_connection_log"},{"title":"Show MultiCloud transit connection security association","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_multicloud_transit_connection_security_association","href":"/reference/api/10.0/transit/post-v2apishow_multicloud_transit_connection_security_association"},{"title":"Show MultiCloud transit connection security policy","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_multicloud_transit_connection_security_policy","href":"/reference/api/10.0/transit/post-v2apishow_multicloud_transit_connection_security_policy"},{"title":"Show MultiCloud transit connection service","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_multicloud_transit_connection_service","href":"/reference/api/10.0/transit/post-v2apishow_multicloud_transit_connection_service"},{"title":"Show transit learned CIDRs approval info","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_transit_learned_cidrs_approval_info","href":"/reference/api/10.0/transit/post-v2apishow_transit_learned_cidrs_approval_info"},{"title":"Show transit route cache","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_transit_route_cache","href":"/reference/api/10.0/transit/post-v2apishow_transit_route_cache"}]},{"group":"UserVPN","pages":[{"title":"Allow downloading VPN client status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_allow_downloading_vpn_client_status","href":"/reference/api/10.0/vpn/get-v2apiget_allow_downloading_vpn_client_status"},{"title":"Attached TGW VPN config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_attached_tgw_vpn_config","href":"/reference/api/10.0/vpn/get-v2apiget_attached_tgw_vpn_config"},{"title":"Geo VPN info","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_geo_vpn_info","href":"/reference/api/10.0/vpn/get-v2apiget_geo_vpn_info"},{"title":"VPN gateway authentication","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_vpn_gateway_authentication","href":"/reference/api/10.0/vpn/get-v2apiget_vpn_gateway_authentication"},{"title":"VPN gateway config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_vpn_gateway_config","href":"/reference/api/10.0/vpn/get-v2apiget_vpn_gateway_config"},{"title":"VPN system use notification status","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_vpn_system_use_notification_status","href":"/reference/api/10.0/vpn/get-v2apiget_vpn_system_use_notification_status"},{"title":"VPN user by name","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/get_vpn_user_by_name","href":"/reference/api/10.0/vpn/get-v2apiget_vpn_user_by_name"},{"title":"List live VPN users","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_live_vpn_users","href":"/reference/api/10.0/vpn/get-v2apilist_live_vpn_users"},{"title":"List live VPN users detail","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_live_vpn_users_detail","href":"/reference/api/10.0/vpn/get-v2apilist_live_vpn_users_detail"},{"title":"List VPN user XLR","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_vpn_user_xlr","href":"/reference/api/10.0/vpn/get-v2apilist_vpn_user_xlr"},{"title":"List VPN users","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_vpn_users","href":"/reference/api/10.0/vpn/get-v2apilist_vpn_users"},{"title":"List VPN users attached to profile","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_vpn_users_attached_to_profile","href":"/reference/api/10.0/vpn/get-v2apilist_vpn_users_attached_to_profile"},{"title":"List VPN users not attached to profile","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json get /v2/api/list_vpn_users_not_attached_to_profile","href":"/reference/api/10.0/vpn/get-v2apilist_vpn_users_not_attached_to_profile"},{"title":"Add elb to geo VPN","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_elb_to_geo_vpn","href":"/reference/api/10.0/vpn/post-v2apiadd_elb_to_geo_vpn"},{"title":"Add VPN user","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/add_vpn_user","href":"/reference/api/10.0/vpn/post-v2apiadd_vpn_user"},{"title":"Attach Edge VPN to TGW","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/attach_edge_vpn_to_tgw","href":"/reference/api/10.0/vpn/post-v2apiattach_edge_vpn_to_tgw"},{"title":"Delete elb from geo VPN","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_elb_from_geo_vpn","href":"/reference/api/10.0/vpn/post-v2apidelete_elb_from_geo_vpn"},{"title":"Delete VPN user","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/delete_vpn_user","href":"/reference/api/10.0/vpn/post-v2apidelete_vpn_user"},{"title":"Detach VPN from TGW","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/detach_vpn_from_tgw","href":"/reference/api/10.0/vpn/post-v2apidetach_vpn_from_tgw"},{"title":"Disable geo VPN","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_geo_vpn","href":"/reference/api/10.0/vpn/post-v2apidisable_geo_vpn"},{"title":"Disable nat on VPN gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_nat_on_vpn_gateway","href":"/reference/api/10.0/vpn/post-v2apidisable_nat_on_vpn_gateway"},{"title":"Disable VPN client download","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/disable_vpn_client_download","href":"/reference/api/10.0/vpn/post-v2apidisable_vpn_client_download"},{"title":"Edit VPN config","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_vpn_config","href":"/reference/api/10.0/vpn/post-v2apiedit_vpn_config"},{"title":"Edit VPN gateway virtual address range","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/edit_vpn_gateway_virtual_address_range","href":"/reference/api/10.0/vpn/post-v2apiedit_vpn_gateway_virtual_address_range"},{"title":"Enable nat on VPN gateway","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_nat_on_vpn_gateway","href":"/reference/api/10.0/vpn/post-v2apienable_nat_on_vpn_gateway"},{"title":"Enable VPN client download","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/enable_vpn_client_download","href":"/reference/api/10.0/vpn/post-v2apienable_vpn_client_download"},{"title":"Set VPN gateway authentication","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/set_vpn_gateway_authentication","href":"/reference/api/10.0/vpn/post-v2apiset_vpn_gateway_authentication"},{"title":"Set VPN max connection","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/set_vpn_max_connection","href":"/reference/api/10.0/vpn/post-v2apiset_vpn_max_connection"},{"title":"Show VPN duplicate conn","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/show_vpn_duplicate_conn","href":"/reference/api/10.0/vpn/post-v2apishow_vpn_duplicate_conn"},{"title":"Update VPN user XLR","deprecated":null,"version":null,"openapi":"/openapi/10.0/aviatrix-api.json post /v2/api/update_vpn_user_xlr","href":"/reference/api/10.0/vpn/post-v2apiupdate_vpn_user_xlr"}]}]},{"group":"Feature Modes","pages":[{"title":"Aviatrix Feature Modes","href":"/docs/enterprise/10.0/reference/feature-modes/index"}]},{"group":"Compatibility","pages":[{"title":"Aviatrix Feature Availability by Controller Version","href":"/docs/enterprise/10.0/reference/compatibility/feature-availability"},{"title":"Aviatrix Support: End-of-Life and End-of-Support Policy","href":"/docs/enterprise/10.0/reference/compatibility/eol-eos-policy"}]},{"group":"UserVPN","pages":[{"title":"Aviatrix UserVPN FAQ","href":"/docs/enterprise/10.0/reference/uservpn/user-vpn-faq"}]},{"group":"Release Notices","pages":[{"title":"Field Notices","href":"/docs/enterprise/10.0/reference/release-notices/field-notices/index"},{"title":"PSIRT Advisories","href":"/docs/enterprise/10.0/reference/release-notices/psirt-advisories/index"},{"title":"Security Patches","href":"/docs/enterprise/10.0/reference/release-notices/security-patches/index"},{"group":"Release Notes","pages":[{"title":"Aviatrix Controller and Gateway Software Release Notes","href":"/docs/enterprise/10.0/reference/release-notices/release-notes/controller/index"},{"title":"Aviatrix Controller and Gateway Image Release Notes","href":"/docs/enterprise/10.0/reference/release-notices/release-notes/controller-images/index"},{"title":"Aviatrix CoPilot Release Notes","href":"/docs/enterprise/10.0/reference/release-notices/release-notes/copilot/index"},{"title":"Aviatrix CoPilot Image Release Notes","href":"/docs/enterprise/10.0/reference/release-notices/release-notes/copilot-images/index"},{"title":"VPN Client Release Notes","href":"/docs/enterprise/10.0/reference/release-notices/release-notes/vpn-client/index"}]},{"group":"What's New","pages":[{"title":"What's New in the Aviatrix Platform?","href":"/docs/enterprise/10.0/reference/release-notices/what-is-new/what-is-new"},{"title":"What's New in the Aviatrix Controller","href":"/docs/enterprise/10.0/reference/release-notices/what-is-new/what-is-new-controller"},{"title":"What's New in CoPilot?","href":"/docs/enterprise/10.0/reference/release-notices/what-is-new/what-is-new-copilot"}]}]}]}]},{"version":"9.0","pages":[{"title":"9.0","href":"/docs/enterprise/9.0/concepts-architectures/architecture/connectivity/edge-spoke-scaling"}]},{"version":"8.2","pages":[{"title":"8.2","href":"/docs/enterprise/8.2/concepts-architectures/architecture/connectivity/edge-spoke-scaling"}]},{"version":"8.1","href":"https://legacy.docs.aviatrix.com/documentation/v8.1/index.html"},{"version":"8.0","href":"https://legacy.docs.aviatrix.com/documentation/v8.0/index.html"},{"version":"7.2","href":"https://legacy.docs.aviatrix.com/documentation/v7.2/index.html"},{"version":"7.1","href":"https://legacy.docs.aviatrix.com/documentation/v7.1/index.html"}]},{"dropdown":"Aviatrix Cloud","icon":"cloud","groups":[{"group":"Getting Started","icon":"rocket","pages":[{"title":"Overview","href":"/docs/cloud/getting-started"},{"group":"AWS Getting Started for Aviatrix Cloud Network Security PaaS","pages":[{"title":"Overview","href":"/docs/cloud/getting-started/aws/aws-getting-started"},{"title":"Upgrade a Free Trial to a Term Subscription on AWS","href":"/docs/cloud/getting-started/aws/aws-upgrade-subscription"}]},{"group":"Azure Secure NAT Gateway Getting Started","pages":[{"title":"Overview","href":"/docs/cloud/getting-started/azure/azure-getting-started"},{"title":"Upgrade a Developer Evaluation Trial to a Paid Plan on Azure","href":"/docs/cloud/getting-started/azure/azure-upgrade-subscription"}]}]},{"group":"Security","icon":"shield","pages":[{"title":"Overview","href":"/docs/cloud/security/index"},{"group":"Protect Your Traffic with Egress Security","pages":[{"title":"Overview","href":"/docs/cloud/security/egress-nat/about-egress-security"},{"title":"Egress Traffic Analysis","href":"/docs/cloud/security/egress-nat/egress-traffic-analysis"},{"title":"Egress Traffic Protection","href":"/docs/cloud/security/egress-nat/egress-traffic-protection"},{"title":"Egress Security Overview","href":"/docs/cloud/security/egress-nat/egress-security-overview"},{"title":"Egress Security Score","href":"/docs/cloud/security/egress-nat/egress-security-score"},{"title":"Aviatrix AI FQDN Analyzer","href":"/docs/cloud/security/egress-nat/ai-fqdn-analyzer"},{"title":"Monitor VPC/VNets","href":"/docs/cloud/security/egress-nat/egress-monitor-vpc-vnets"},{"title":"Protect VPC/VNets","href":"/docs/cloud/security/egress-nat/egress-protect-vpc-vnets"},{"title":"Disable Egress on VPCs/VNets","href":"/docs/cloud/security/egress-nat/egress-disabling-vpc-vnets"}]},{"group":"Protect Your Traffic with Distributed Cloud Firewall","pages":[{"title":"Overview","href":"/docs/cloud/security/dcf/about-dcf-security"},{"title":"Create Distributed Cloud Firewall Egress Rules","href":"/docs/cloud/security/dcf/dcf-create-rules"},{"title":"View Distributed Cloud Firewall Rule Details","href":"/docs/cloud/security/dcf/dcf-rule-details"},{"title":"Distributed Cloud Firewall Monitoring","href":"/docs/cloud/security/dcf/dcf-monitor"},{"title":"Configuring TLS Inspection with Aviatrix PaaS","href":"/docs/cloud/security/dcf/tls-decryption-configure"},{"title":"About Decryption CA Certificates and Trust Bundles","href":"/docs/cloud/security/dcf/decryption-ca-certificate"}]},{"group":"Gain AI Workload Visibility with AgentGuard","pages":[{"title":"Overview","href":"/docs/cloud/security/agentguard/agentguard-overview"},{"title":"Architecture","href":"/docs/cloud/security/agentguard/agentguard-architecture"},{"title":"AI Traffic Flow Analytics","href":"/docs/cloud/security/agentguard/agentguard-traffic-analytics"},{"title":"AI Workload Discovery","href":"/docs/cloud/security/agentguard/agentguard-workload-discovery"},{"group":"Get Started with AgentGuard","pages":[{"title":"Set Up AgentGuard","href":"/docs/cloud/security/agentguard/getting-started/agentguard-setup"},{"title":"Get Basic Visibility Without a Gateway","href":"/docs/cloud/security/agentguard/getting-started/agentguard-without-gateway"},{"title":"Get Deep Visibility and Enforcement With a Gateway","href":"/docs/cloud/security/agentguard/getting-started/agentguard-with-gateway"}]},{"title":"AgentGuard Release Phases","href":"/docs/cloud/security/agentguard/agentguard-release-phases"}]}]},{"group":"Monitoring","icon":"chart-line","pages":[{"title":"Overview","href":"/docs/cloud/monitoring/index"},{"group":"Dashboard Overview","pages":[{"title":"Overview","href":"/docs/cloud/monitoring/dashboard-overview"},{"title":"Dashboard Page Reference","href":"/docs/cloud/monitoring/dashboard-page-reference"}]},{"group":"Observe Your Network Topology","pages":[{"title":"Overview","href":"/docs/cloud/monitoring/topology-observe"},{"title":"Working with Topology","href":"/docs/cloud/monitoring/topology-working-with"},{"title":"Create a Topology View","href":"/docs/cloud/monitoring/topology-view-create"},{"title":"Filter Topology by Cloud Tags","href":"/docs/cloud/monitoring/topology-filter-example-csptags"},{"title":"Topology Property Reference","href":"/docs/cloud/monitoring/topology-property-reference"}]}]},{"group":"Resource Groups","icon":"layer-group","pages":[{"title":"Overview","href":"/docs/cloud/resource-groups/index"},{"group":"Manage SmartGroups","pages":[{"title":"Overview","href":"/docs/cloud/resource-groups/smartgroup/smartgroups-about"},{"title":"Create a SmartGroup","href":"/docs/cloud/resource-groups/smartgroup/smartgroups-create"},{"title":"Create a Kubernetes SmartGroup","href":"/docs/cloud/resource-groups/smartgroup/smartgroup-kubernetes"},{"title":"Edit a Group","href":"/docs/cloud/resource-groups/general/groups-edit"},{"title":"Delete a Group","href":"/docs/cloud/resource-groups/general/groups-delete"},{"title":"Clone SmartGroups","href":"/docs/cloud/resource-groups/smartgroup/smartgroup-cloning"},{"title":"SmartGroups Reference","href":"/docs/cloud/resource-groups/smartgroup/smartgroups-reference"},{"title":"About DNS Hostname SmartGroups","href":"/docs/cloud/resource-groups/smartgroup/hostname-smartgroups-about"}]},{"group":"Manage WebGroups","pages":[{"title":"Overview","href":"/docs/cloud/resource-groups/webgroups/webgroups-about"},{"title":"Create a WebGroup","href":"/docs/cloud/resource-groups/webgroups/webgroups-create"},{"title":"Edit a WebGroup","href":"/docs/cloud/resource-groups/webgroups/webgroups-edit"},{"title":"Delete a WebGroup","href":"/docs/cloud/resource-groups/webgroups/webgroups-delete"}]},{"group":"Manage ExternalGroups","pages":[{"title":"Overview","href":"/docs/cloud/resource-groups/externalgroup/externalgroup-about"},{"title":"Create an ExternalGroup","href":"/docs/cloud/resource-groups/externalgroup/externalgroup-create"}]}]},{"group":"Best Practices","icon":"star","pages":[{"title":"Overview","href":"/docs/cloud/best-practices/index"},{"title":"Aviatrix Cloud Firewall Secure Egress Implementation Guide for PaaS","href":"/docs/cloud/best-practices/aviatrix-cloud-firewall-paas"}]},{"group":"Platform Administration","icon":"gears","pages":[{"title":"Overview","href":"/docs/cloud/platform-administration/index"},{"group":"Aviatrix PaaS Overview","pages":[{"title":"Overview","href":"/docs/cloud/platform-administration/overview/paas-description"},{"title":"Aviatrix PaaS Subscriptions","href":"/docs/cloud/platform-administration/overview/subscription-plan-options"},{"title":"Email Sign-In to Aviatrix PaaS","href":"/docs/cloud/getting-started/aviatrix-paas-sign-in"},{"title":"Toolbar Icons","href":"/docs/cloud/platform-administration/overview/toolbar"}]},{"group":"Automating with Terraform","pages":[{"title":"Overview","href":"/docs/cloud/platform-administration/terraform/terraform-overview"},{"title":"Configure the Aviatrix Cloud Terraform Provider","href":"/docs/cloud/platform-administration/terraform/terraform-getting-started"},{"title":"Onboard Cloud Accounts to Aviatrix Cloud with Terraform","href":"/docs/cloud/platform-administration/terraform/terraform-cloud-account"},{"title":"Manage Networks with the Aviatrix Cloud Terraform Provider","href":"/docs/cloud/platform-administration/terraform/terraform-manage-networks"}]},{"group":"Onboarding Resources","pages":[{"title":"Overview","href":"/docs/cloud/platform-administration/onboard-offboard/resources-onboarding"},{"group":"Onboard Your Microsoft Azure Cloud Account","pages":[{"title":"Overview","href":"/docs/cloud/platform-administration/onboard-offboard/azure-cloud-account-onboard"},{"title":"Gather Information for Azure Onboarding","href":"/docs/cloud/platform-administration/onboard-offboard/azure-onboard-info"}]},{"group":"Onboard Your AWS Cloud Account","pages":[{"title":"Onboard Your AWS Cloud Account","href":"/docs/cloud/platform-administration/onboard-offboard/aws-cloud-account-onboard"},{"title":"Privileges Assigned to the Aviatrix IAM Policy","href":"/docs/cloud/platform-administration/onboard-offboard/aws-onboard-iam-privileges"}]},{"title":"Upgrade Cloud Account Permissions","href":"/docs/cloud/platform-administration/onboard-offboard/upgrade-account-permissions"},{"title":"Onboard VPCs or VNets","href":"/docs/cloud/platform-administration/onboard-offboard/vpc-vnet-onboard"},{"title":"Offboard VPCs or VNets","href":"/docs/cloud/platform-administration/onboard-offboard/vpc-vnet-offboard"},{"title":"Offboard Cloud Accounts","href":"/docs/cloud/platform-administration/onboard-offboard/cloud-account-offboard"}]},{"group":"Managing Cloud Resources","pages":[{"title":"Overview","href":"/docs/cloud/platform-administration/manage/platform-manage"},{"title":"View Cloud Assets","href":"/docs/cloud/platform-administration/manage/cloud-assets-viewing"},{"title":"Add Users","href":"/docs/cloud/platform-administration/manage/user-add"},{"title":"User Access to Aviatrix PaaS","href":"/docs/cloud/platform-administration/manage/user-access"},{"group":"SSO with OIDC in Aviatrix PaaS","pages":[{"title":"Overview","href":"/docs/cloud/platform-administration/manage/sso-with-paas"},{"title":"Disable Single Sign-On (SSO)","href":"/docs/cloud/platform-administration/manage/sso-disable"}]},{"group":"Gateway Logging","pages":[{"title":"Overview","href":"/docs/cloud/platform-administration/manage/logging-gateways"},{"title":"Aviatrix Log Formats","href":"/docs/cloud/platform-administration/manage/log-formats"}]},{"title":"Maintenance Windows","href":"/docs/cloud/platform-administration/manage/settings-maintenance-window"}]},{"group":"Aviatrix Kubernetes Firewall","pages":[{"title":"Overview","href":"/docs/cloud/platform-administration/kubernetes/kubernetes-overview"},{"title":"Kubernetes Prerequisites and Permissions","href":"/docs/cloud/platform-administration/kubernetes/kubernetes-prerequisites"},{"title":"Onboard Kubernetes Clusters","href":"/docs/cloud/platform-administration/kubernetes/kubernetes-onboard"},{"title":"View Kubernetes Cluster Details","href":"/docs/cloud/platform-administration/kubernetes/kubernetes-clusters-viewing"},{"title":"Offboard a Kubernetes Cluster","href":"/docs/cloud/platform-administration/kubernetes/kubernetes-offboard"}]}]}]}]},"basePath":"","title":"Edge Spoke Gateway Horizontal Scaling - Aviatrix Documentation","deploymentId":"dpl_EtLmMeZHkKGqAjV1DiX4ZXCriDj3","buildId":"dpl_EtLmMeZHkKGqAjV1DiX4ZXCriDj3","dynamics":["a74be98ba7"],"chunks":["zoom-image-lightbox-BA_UUN68.js","lightbox-handle-r17bVUz3.js"]}
