Aviatrix Gateway Diagnostics
You can run diagnostics for any Aviatrix gateway instance running in your multicloud network.
You can access Gateway Diagnostics from these areas of the CoPilot UI:
Diagnostic Tools page
Select the Gateway Diagnostics tab at:
CoPilot > Diagnostics > Diagnostic Tools > Controller Diagnostics.
Topology page
In the topology map, select a gateway node, locate the Tools menu in the Properties pane, and select Gateway Diagnostics from the list:
CoPilot > Cloud Fabric > Topology > Overview
Cloud Routes page
Select the Gateway Routes tab, locate the table row of the gateway, and click the Gateway Diagnostics icon.
CoPilot > Diagnostics > Cloud Routes > Gateway Routes
Gateways page
For the CoPilot > Cloud Fabric > Gateways page from any gateway view (Transit, Spoke, or Specialty), locate the table row of the gateway, and click the Gateway Diagnostics icon.
On the Gateway Diagnostics page, select a Gateway Instance.
Select a tool from the Gateway Diagnostics list.
Click Run.
| Gateway Diagnostics | Description |
Ping |
Runs pings directly from the gateway to outside the Aviatrix-managed network or to any resource inside the network. |
Packet Capture |
Capture packets on any gateway. Filter on host and port number and specify the capture time. Search and filter by time, source address, destination address, source port, destination port, protocol, flags, length, and info. Select the interface on the physical or virtual interface you want to capture on. Click Start to start the capture, click Stop to stop the capture, then click Download to download the pcap file. The pcap file can be viewed by Wireshark. |
Traceroute |
Run trace route. |
Tracepath |
Discover the MTU on the path if the router supports it. |
Connectivity |
Test the connectivity of the gateway to a specified host running on a specified TCP or UDP port. |
Active Sessions |
View sessions that are active on the selected gateway. You can filter active sessions by search criteria. For example, a search on a specific port to see if the gateway has an action session on that port. |
Interface Stats |
View interface statistics about the gateway. The number of interfaces or tunnels associated with the gateway is displayed. Click on the name of an interface or tunnel to see its statistical information. |
Services |
Check the status of gateway services and restart services. |
Diagnostics |
Run a comprehensive diagnostics report that you can download and analyze. |
Tracelog |
Upload a gateway’s tracelog directly to Aviatrix Support. The controller and gateway tracelog is uploaded and the support team notified. |
