Transit Gateway to FortiGate over the Internet Workflow
| This is not a common scenario. You would only set up this type of connection if you want to connect an Aviatrix Transit gateway to a firewall that is outside your Cloud service provider (for example, in a branch office or warehouse). |
In CoPilot, navigate to Cloud Fabric > Gateways > Transit Gateways.
Create a Transit gateway that will connect to your FortiGate firewall.
To connect the transit VPC gateway to FortiGate, navigate to Networking > Connectivity > External Connections (S2C).
Click +External Connection.
In the Add External Connection dialog, configure the following: Field Value Connect Public Cloud to External Device > BGP over IPsec Local Gateway Select the Transit gateway you created in step 2 above Local ASN The BGP AS number the Transit gateway will use to exchange routes with the external device. Remote ASN Enter the BGP AS number the external device will use to exchange routes with the Transit Gateway. Remote Gateway IP This is the FortiGate WAN IP.
| Ensure that the Local/Remote ASN and the Remote Gateway IP are correct before saving. |
The following is a sample configuration based on the Site2Cloud configuration above.
Configuring the Fortinet FortiGate Firewall
Login into FortiGate and configure it as follows: -
Navigate to VPN > IPsec Tunnels.
Click +Create New, and select IPsec Tunnel.
In the VPN Creation Wizard, select the Custom template type.
Populate the fields according to your preferences.
Click Next.
New VPN Tunnel Tab
Complete the Network fields on the New VPN Tunnel tab as follows:
Network section of New VPN Tunnel tab
| Field | Expected Value |
| IP Version | IPv4 |
| Remote Gateway | Static IP Address |
| IP Address | Public IP address of Aviatrix Gateway |
| Interface | Select the external port/interface |
| Local Gateway | Disabled |
| Mode Config | Unchecked |
| NAT Traversal | Recommended: Enable |
| Keepalive Frequency | Any value |
| Dead Peer Detection | On Demand |
Authentication section of New VPN Tunnel tab
| Method | Pre-Shared Key |
| Pre-shared Key | In the Pre-shared Key field, enter the value from the Pre-Shared Key row in the downloaded configuration file. |
| IKE Version | 1 |
| IKE Mode | Main (ID protection) |
Phase 1 Proposal section of New VPN Tunnel tab
| Encryption | In the Encryption field, enter the value from the Encryption Algorithm row in the downloaded configuration file. |
| Authentication | In the Authentication field, enter the value from the Authentication Algorithm row in the downloaded configuration file. |
| Diffie-Hellman Group | Select the appropriate value as per the Perfect Forward Secrecy row in the downloaded configuration file. |
| Key Lifetime (seconds) | 28800 |
XAUTH section of New VPN Tunnel tab
| Type | Disabled |
Phase 2 Selectors > New Phase 2 section of New VPN Tunnel tab
| Name | Any string value |
| Comments | Any string value |
| Local Address | 0.0.0.0/0 |
| Remote Address | 0.0.0.0/0 |
Advanced section of New VPN Tunnel tab
Click +Advanced to complete the fields listed below.
| Obtain the following values from the downloaded configuration file. |
Click OK.
Navigate to Network > Interfaces.
Click on the Tunnel created above (e.g. aviatrix-gatew) and assign the IP address from the downloaded configuration file.
Click OK.
Configure IPv4 Policy
Navigate to Policy & Objects > IPv4 DoS Policy.
Create two new IPv4 policies: -
Outbound traffic
Inbound traffic
| The reference to port2 in the screenshots should be replaced with your own interface name that represents the internal facing interface. |
| Be sure to select ACCEPT for Action and select ALL for Service. |
IPSec Monitor
In the Fortigate UI, navigate to Dashboard > Network and click the IPsec widget.
Select the Aviatrix tunnel, and click Bring Up.
You can then check the tunnel status in CoPilot under Diagnostics > Cloud Routes.
In the FortiGate UI, navigate to Network > BGP.
Configure the Local BGP Options as below: -
RouterID : Tunnel IP address taken from the configuration file downloaded at step3
Neighbors: Remote tunnel IP address and ASN
Networks: All the networks needs to be advertised via BGP (here 10.0.3.0 is the local network of FortiGate)
In CoPilot, go to Diagnostics > Cloud Routes > BGP Info to verify the BGP Routes.
