How do I connect to an external device?
There are three options to connect a Transit Gateway to an on-prem network. Choose one option that meets your network requirements.
AWS VGW (This is the default setting)
External Device (over Direct Connect or over Internet)
Azure VNG
Currently, only one connection is supported on a specific Transit Gateway/VPC, regardless of which of the three options above is chosen.
Transit Gateway Connect Type | Performance | HA | Route Limit | Deployment notes |
AWS VGW |
1.25Gbps |
Active/Active |
100 |
VGW should be detached. Use the instruction here to build encryption between VGW and on-prem router. |
External Device |
Up to 10Gbps |
Active/Standby |
Unlimited |
VGW should be attached. Aviatrix Transit Gateway establishes BGP + IPSEC with on-prem router. |
Azure VNG |
10Gbps |
Active/Active |
Unlimited |
VNG should be attached. |
To connect AWS VGW, see Multicloud Transit Integration with AWS VGW Workflow.
To connect to Azure VNG, see Multicloud Transit Integration with Azure VNG Workflow.
To connect to an external device, see Multicloud Transit to External Devices Workflow.
