Transit Gateway to Cisco Router over the Internet Workflow
In CoPilot navigate to Cloud Fabric > Gateways > Transit Gateways.
Create a Transit gateway that will connect to the Cisco Router.
To connect the Transit VPC gateway to the Cisco Router, go to Networking > Connectivity > External Connections (S2C) and follow these instructions.
Ensure that your Cisco Router is configured based on the information in the downloaded file. The following is a sample configuration based on the Site2Cloud configuration above.
| The tunnel IP addresses are configured accordingly with the configuration file downloaded above. |
After configuring the Cisco Router, in CoPilot navigate to Diagnostics > Cloud Routes > External Connections to confirm that the tunnel status has changed from Down to Up.
Navigate to Diagnostics > Cloud Routes > BGP Info to check the BGP routes.
