Multicloud Transit BGP over LAN in Azure Workflow
Introduction
Transit BGP to LAN allows Aviatrix Transit Gateways to communicate with a pair of instances in different VNets in Azure without running any tunneling protocol such as IPsec or GRE. One use case is to interoperate with third-party virtual appliances such as SD-WAN cloud instances that do not have the capability to support BGP over any tunneling protocols.
For example, integrating with SD-WAN gateways can be deployed as below where an Aviatrix Multicloud Transit Gateway connects to a third-party cloud instance in different VNets in Azure.
This document describes step-by-step instructions on how to build an Aviatrix Transit Gateway to External Device using BGP over LAN in Azure:
For other BGP over LAN workflows, please see:
For more information about Multicloud Transit Network and External Device, please see:
ActiveMesh 2.0 is required. To migrate to ActiveMesh 2.0, see Migrating from Classic Aviatrix Encrypted Transit Network to Aviatrix ActiveMesh Transit Network.
This solution is available in AWS and Azure. To configure this solution for AWS, see Multicloud Transit BGP over LAN in AWS Workflow. Please adjust the topology depending on your requirements.
LAN interfaces for Aviatrix Transit Primary and third-party cloud instance must be in the different VNets.
One BGP over LAN connection per gateway is supported.
A BGP session establishes between a third-party cloud instance and Aviatrix Transit Gateway via each LAN interface in different VNets.
Data plane traffic also runs between a third-party cloud instance and Aviatrix Transit Gateway via each LAN interface without a tunnel protocol such as IPsec and GRE.
This feature is available for 6.3 and later. Upgrade Aviatrix Controller to at least version 6.3.
In this example, you are going to deploy the below VNets in Azure:
Transit VNets (i.e. 10.1.0.0/16 and 10.2.0.0/16) by creating a VNet with the VPC Function Aviatrix FireNet VNet option enabled.
Spoke VNets (i.e. 192.168.11.0/24 and 192.168.21.0/24) by creating a VNet as per the previous step or manually deploying it in each cloud portal. You can use your existing cloud network.
Third-party cloud instance supports high throughput.
Deploying Aviatrix Multicloud Transit Solution
Refer to Global Transit Network Workflow Instructions for the below steps. Please adjust the topology depending on your requirements.
Deploy Aviatrix Multicloud Transit Gateway and HA with High Performance Encryption Mode enabled in Transit VNet.
Select the BGP Over LAN checkbox to enable that function. |
See Performance Benchmarks for more information about Gateway size and benchmark performance.
Deploy Spoke Gateway and HA to launch Aviatrix Spoke gateway and enable HA with High Performance Encryption enabled in Spoke VNet.
(Optional) You can attach Azure Spoke VNet via native peering if you prefer not to encrypt the traffic between the Transit VNet and the Spoke VNet.
In this example, this approach is selected to benchmark: Performance Benchmarks.
Launch Third-Party Cloud Instances
Deploy third-party cloud instances in a separate Transit VNet.
Create a third-party cloud instance and put the MGMT interface in the public gateway subnet.
Create a new public WAN subnet and a dedicated routing table for the WAN interface if needed.
Create a new private LAN subnet and a dedicated routing table for the LAN interface.
Make sure the IP forwarding function on third-party cloud instance interfaces is enabled.
An Aviatrix Transit Gateway and third-party cloud instance CANNOT be deployed in the same Transit VNet. |
Building BGP over LAN
Creating Azure VNet Peering Between Aviatrix Transit VNet and Third-Party Cloud Instance Transit VNet
In CoPilot, navigate to Networking > Connectivity > Native Peering.
Click +Native Peering.
In the Create Native Peering dialog, select Azure Cloud.
Select the VNet where the Aviatrix Transit gateway is located as Peer1.
Select the VNet where the third-party cloud instance is located as Peer2.
You can also select the route tables for each VNet by sliding Select Route Tables to On.
Configuring BGP over LAN on Aviatrix Transit Gateway
In CoPilot, navigate to Networking > Connectivity > External Connections (S2C).
Click +External Connection.
In the Add External Connection dialog, select Connect Public Cloud to External Device.
Select BGP over LAN from the drop-down.
Enter the following information in the fields provided.
Setting Value Name
Unique name to identify the external device connection.
Select the Transit VPC ID where the Transit gateway was launched (BGP over LAN must have been enabled for this Transit gateway).
The local BGP AS number (for on-site equipment) the Spoke gateway will use to exchange routes with the external device.
Enter the BGP AS number of the cloud location the external device will use to exchange routes with the Transit Gateway.
BGP ActiveMesh
Enable full mesh BGP connections to the external devices.
Learned CIDR Approval
Set to On by default if selected for the Local Gateway. Otherwise, it is set to Off.
The private IP of the LAN interface of the third-party cloud primary instance.
Aviatrix detects the Local LAN IP automatically.
To generate BGP session over LAN, click Save.
(Optional) Downloading the BGP over LAN configuration sample from Aviatrix Controller
On the External Connections (S2C) tab, click the vertical ellipsis
and then select Download Configuration.
In the Download Configuration dialog, select the following:
Vendor: select the device you are using (any device that is capable of running IPsec and BGP).
Platform: select the applicable platform for the chosen device.
Software: automatically selected based on the Vendor/Platform you select.
Click Download.
Configuring BGP over LAN on Third-Party Cloud Instance
Log in to the Azure portal.
Create a user-defined routing table with default route (0.0.0.0/0) pointing nexthop to the Aviatrix Primary Transit LAN IP for the subnet where the third-party cloud primary instance LAN interface is located.
Create a user-defined routing table with default route (0.0.0.0/0) pointing nexthop to the Aviatrix HA Transit LAN IP for the subnet where third-party cloud HA instance’s LAN interface is located, for HA deployment.
(Optional) Open the downloaded BGP over LAN configuration file.
Log in to the third-party cloud instance.
Program route to send traffic to the Aviatrix Transit LAN IP through the third-party cloud instance LAN interface.
Configure the related BGP and LAN information in the third-party cloud instance.
Check if the function 'eBGP multi-hop' is enabled, if the BGP session is not established.
Repeat these steps for HA deployment.
You must create a default route 0.0.0.0/0 in the third-party cloud instance LAN route table to point to the Aviatrix Transit LAN IP over VNET peering in Azure. |
Verifying LAN and Transit Status
LAN status: Navigate to Diagnostics > Cloud Routes > External Connections. The Status and Tunnel Status columns indicate if the tunnel is Up or Down.
Transit gateway status: Navigate to Diagnostics > Cloud Routes > Gateway Routes. The Gateway Status and Tunnel Status columns indicate if the gateway and tunnel are Up or Down.
Ready to Go
At this point, run connectivity and performance test to ensure everything is working correctly.
