Creating a Scheduled Scaling Policy
You can create a scheduled scaling policy to add a gateway instance during a scheduled time period, and remove it when the scheduled time period ends. The gateway instance is created in the first available empty subnet. Gateways can only be removed if they were previously added using gateway scaling.
VPCs/VNets cannot have both automatic and scheduled scaling applied. Scheduled scaling occurs in the local time zone in which the browser is deployed. For example, if the scheduled scaling event is set to begin at 9 am, it begins at 9 am according to the local browser time zone. |
On the Cloud Fabric > Scaling > Policies tab, click +Policy. The Create New Scaling Policy dialog displays.
Select the Scheduled Scaling option.
Enter a name for the policy that clearly describes what the policy will do.
In the Scheduled VPC/VNets field, select the VPCs/VNets on which to apply the policy.
You can type a string in this field to display the matching VPCs/VNets. You can then click Select All to select the matching VPCs/VNets.
Select Scheduled Scaling.
Under Scaling Schedule, select a time to begin scaling out, and a time to begin scaling in.
Select the days when this scheduled scaling will be performed.
In the Send Notifications To field, select the email address/webhook which should receive the notification when the scaling begins and ends.
If this field is left blank you will not receive alerts.
