Deploying Aviatrix Secure Edge on Equinix Network Edge
This document provides instructions for deploying Aviatrix Secure Edge on Equinix Network Edge.
For an overview of Aviatrix Secure Edge, see Overview of Aviatrix Secure Edge.
The following diagram shows an example of network connectivity for Aviatrix Secure Edge Gateway to Transit Gateway in AWS. This topology shows Aviatrix Secure Edge connection to an upstream WAN router which is used to terminate CSP underlay private connections.
The topology below shows Aviatrix Secure Edge used to terminate CSP underlay private connections (which does not require upstream WAN router).
Aviatrix Secure Edge requires Aviatrix Controller 7.1 and Aviatrix Secure Edge Image 7.1 to support BGP underlay connectivity to CSP. |
To deploy Aviatrix Secure Edge on Equinix Network Edge, follow these steps.
Creating Aviatrix Edge Gateway Cloud-Init ZTP File
The Edge Gateway cloud-init ZTP file is used to provision the Aviatrix Edge Gateway virtual device in Equinix Fabric.
To create the Edge Gateway cloud-init ZTP file, follow these steps.
In CoPilot, navigate to Cloud Fabric > Edge > Edge Gateways tab.
Click + Edge Gateway.
Provide the following information to set up your Edge Gateway.
Setting
Enter a name for the Edge Gateway.
Click on this dropdown menu and select the platform where you want to deploy the Edge Gateway. You can create and edit platforms in CoPilot under Cloud Fabric > Edge > Platforms tab.
Enter a site ID to identify the edge location.
ZTP File Type
This is set to cloud-init.
High Availability is disabled by default in this release and not supported. Deploying Edge Gateways with different site names is supported but not more than 1 in each site.
Configure the Edge Gateway WAN Interface
Provide the following information for the Edge Gateway WAN interface.
Setting | Description |
Edge Gateway Interface |
This is set to eth0. Adding multiple WAN interfaces is applicable when Edge Gateway is used for BGP underlay to CSP. Add an interface per CSP underlay (such as Express Route or BGP). When Edge Gateway is not terminating CSP underlay, use one interface per Edge Gateway to connect to upstream router. |
IP Assignment |
Select Static to assign a static IP address for this WAN interface. DHCP for dynamic IP address assignment is not supported. |
Interface Tag |
Enter a name to identify this WAN interface. |
BGP |
To enable BGP on the Edge Gateway, click this switch to On. |
Interface CIDR |
Enter the CIDR for the WAN interface. |
Default Gateway IP |
Enter the Default gateway IP address for this WAN interface. |
Local ASN |
The ASN of the Edge Gateway. |
Remote ASN |
The ASN of the CSP side peering connection such as private VIF on VGW (AWS) and VNG ASN (Azure). |
Local Tunnel IP |
The IP address of the Edge Gateway. This is the local peering PTP IP for BGP. |
Remote Tunnel IP |
The IP address of the CSP VNG or VGW peering PTP IP. (GCP and Oracle are also supported). |
Password |
(Optional) Required for connection to AWS. |
To change or update the Edge Gateway WAN connectivity to Transit Gateway, you will need to first detach the Edge-to-Transit gateway attachment, if there is an attachment. |
Configure the Edge Gateway LAN Interface
Provide the following information for the Edge Gateway LAN interface.
Setting |
Description |
This is set to eth1. |
IP Assignment |
Select Static to assign a static IP address for this LAN interface. This interface is used for LAN side BGP connection. DHCP for dynamic IP address assignment is not supported. |
Interface Tag |
Enter a name to identify this LAN interface. |
BGP |
Click this switch to turn BGP mode On or Off. |
Interface CIDR |
Enter the CIDR for the LAN interface. |
(Optional) Enter the Default gateway IP address for this LAN interface. |
Configure the Edge Gateway Management Interface
In Equinix Network Edge deployment, the Management interface of the Edge Gateway is assigned the IP address that is allocated by Equinix. The ZTP file that is generated by CoPilot includes the parameters needed for Edge Gateway to get the IP addresses from Equinix. The ZTP file will include these settings {"mgmt_ip": "$PUBLIC_ADDRESS_WITH_MASK", "mgmt_default_gateway": "$PUBLIC_GATEWAY"} If the ZTP file does not include the settings for “mgmt_ip” and “mgmt_default_gateway” with the values as indicated above, please modify the downloaded ZTP file to include these values. |
Below is an example configuration of ZTP file with Aviatrix Edge Gateway setup with BGP underlay to CSPs in Equinix.
WAN, LAN, and MGMT configuration example:
The cloud-init file is valid for 24 hours after you create it, so you must launch an Edge VM on Equinix platform within that timeframe, as you cannot download it again and will have to recreate the cloud-init file.
Launching Aviatrix Edge Gateway in Equinix Network Edge
To launch the Aviatrix Edge Gateway in Equinix Network Edge, see Create an Aviatrix Edge in the Equinix documentation. Demo video: Step-by-Step Guide to Deploy Aviatrix Secure Edge on Equinix Network Edge on Vimeo.
You will need to create an Access Control List Template to allow CoPilot access to the Aviatrix Edge virtual device. |
Once the Aviatrix Edge virtual device is created and provisioned, an email is sent to the notification email you provided informing that the Aviatrix Edge virtual device is provisioned.
Creating the Access Control List Template for CoPilot
The Access Control List Template defines the inbound rules for the Aviatrix Edge Gateway virtual device to allow specific inbound traffic. Aviatrix Controller and CoPilot needs to communicate with the Aviatrix Edge Gateway. Inbound traffic from the Controller and CoPilot must be allowed on the Edge Gateway virtual device.
Controller’s IP address will be automatically allowed based on the cloud-init. |
To define the inbound rules for CoPilot, in the CreateNew Access Control List Management Template page, provide the following information.
In the Basic Details section, enter a name for the Access Control List template and a description.
In the Inbound Rules section, enter the following information:
For IP Address Subnet, enter the CoPilot public or private IP address.
For Protocol, select IP from the drop-down.
For Description (Optional), enter a description for this rule.
Click Add Rule.
To create the Access Control List template, click Create Template.
The Management Egress IP address of the Aviatrix Edge Gateway virtual device must be updated from the Aviatrix CoPilot so that the Security Group is updated with the correct Egress IP address.
Locate the public IP assigned by Equinix during Aviatrix Edge virtual device creation.
From Equinix Fabric Portal, go to Network Edge > Virtual Device Inventory > Details and locate the public IP address of the device.
Select the Edge Gateway.
Click MGMT interface and update the Egress CIDR with the public IP from the Equinix Fabric Portal as shown below.
Connecting Edge Interfaces
Use the Advanced section to set the advanced gateway settings that apply.
If the Edge WAN connection to the Transit Gateway is over a private network, set this toggle to On. Leave it Off if the connection is over the public internet.
Ensure that Jumbo Frame is enabled on the Edge Gateway before you attach the Edge Gateway to the Transit Gateway. High Performance Encryption
Ensure that the Transit Gateway is created with High Performance Encryption enabled before you attach the Edge Gateway. Max Performance
Max Performance is set to On when High Performance Encryption is enabled for both the Transit and Edge Gateway.
In Number of Tunnels, enter the number of HPE tunnels to create. The number of tunnels depends on the Edge Gateway instance size:
small: 4 tunnels
medium: 8 tunnels
large and x-large: up to 50 tunnels
To attach the Edge Gateway to another Transit Gateway:
Click + Transit Gateway Attachment again.
From the Transit Gateway drop-down menu, select another Transit Gateway.
Provide the required information.
Click + External Connection.
Setting Description Name
Enter a unique name to identify the connection to the LAN router.
Connect Local Gateway To
Select the Edge Gateway you created.
Enter the BGP AS number the Edge Gateway will use to exchange routes with the LAN router.
Enter the BGP AS number configured on the LAN router.
Settings Description Remote Gateway Instance IP
Enter the LAN router IP address for BGP peering.
