Edge Gateway Virtual Machine Requirements
This document provides the Edge Gateway virtual maching (VM) configurations that are supported and network access requirements.
Virtual Machine CPU and Memory Configurations
This table provides the CPU and memory specifications of the virtual machine instance supported for Aviatrix Edge Gateway deployment.
| Deployment Type | Hardware Profile | Storage Requirements | Note |
Small |
2 vCPU - 4GB |
64 GB |
<1Gbps Throughput |
Medium |
4 vCPU - 8GB |
64 GB |
<5Gbps throughput |
Large |
8 vCPU - 16GB |
64 GB |
~10Gbps throughput |
X-Large |
16 vCPU - 32GB |
64 GB |
We recommend that you do not change the Edge VM resource allocation after deploying it. Aviatrix support may not be able to assist with any issue that occurs on a system with customized resource allocation. |
Over subscription of host resources can lead to a reduction of performance and your instance could become unstable. We recommend that you follow the guidelines and the best practices for your host hypervisor.
Aviatrix Edge Gateway Ports and Protocols
The Aviatrix Edge Gateway requires outbound access to communicate with the Aviatrix Controller. You must allow access on the specified ports on your firewall.
