Creating the ZTP Cloud-Init for the Secondary Edge Gateway (Equinix)
Step 1: Gateway Configuration
Click Spoke Gateways
In Edit Edge Gateway, from the High Availability dropdown menu, select Active-Active or Active-Standby mode.
Click Next to configure the edge gateway interfaces.
In Interface Configuration, configure the WAN, LAN, and Management interfaces of the secondary (HA) Edge Gateway.
Configuring the WAN Interface
To configure the WAN interface, click + WAN Interface, then provide the following information.
Field |
Description |
Interface |
Add an interface per CSP underlay (such as Direct Connect or Express Route). When Edge Gateway is not terminating CSP underlay, use one interface per Edge Gateway to connect to upstream router. |
Interface Labels |
Name to identify the WAN interface. |
BGP |
Enables BGP underlay connection to cloud service provider (CSP) on the WAN interface. Set BGP toggle On to set up BGP connection to cloud routers such as VGW, VNG, and Google cloud router.
Interface Primary CIDR |
The CIDR for the WAN interface. DHCP for dynamic IP address assignment is not supported. Interface CIDR must be in the format interface_ip/netmask (for example, 192.18.20.1/24).
If you need to create a BGP underlay connection to cloud service provider (CSP) with a link-local IP address, you must enter the link-local IP address in the Link-local Underlay CIDR setting of the WAN interface. |
Default Gateway IP |
The Default Gateway IP address for the WAN interface. For CSP underlay, this is the remote side IP address of the BGP session on CSP VNG or VGW. If Link-Local Underlay CIDR is configured, the Default Gateway IP should be in the same subnet as the Link-Local Underlay CIDR, otherwise, it should be in the same subnet as the WAN Interface CIDR. |
Public IP |
Field |
Description |
Remote ASN |
The AS Number of the CSP side peering connection such as private VIF on VGW (AWS) and VNG ASN (Azure). |
Local LAN IP |
The IP address of the Edge Gateway. This is the local peering PTP IP for BGP. |
Remote LAN IP |
The IP address of the CSP VNG or VGW peering PTP IP. (GCP is not supported). |
Password (optional) |
The MD5 authentication key. |
Configuring the LAN Interface
To configure the LAN interface, click LAN, then provide the following information.
Field |
Description |
Interface |
Interface Labels |
Name to identify the LAN interface. |
Interface CIDR |
The CIDR for the LAN interface. DHCP for dynamic IP address assignment is not supported. |
Click MGMT, then click + MGMT Interface.
Leave the Private Network setting to Off. In the Equinix Platform, the Management interface of the Edge Gateway is assigned the public IP address that is allocated by Equinix.
To create the ZTP cloud-init image file, click Done.
CoPilot downloads the ZTP cloud-init file to your downloads folder.
Next, log in to your Equinix Portal and deploy the Edge Gateway VM instance and attach the cloud-init image file to complete the Edge Gateway creation and authentication with the Aviatrix Controller.
The cloud-init file is valid for 24 hours after you create it, so you must launch an Edge VM and deploy the Edge Gateway on the Equinix platform within that time. You will not be able to download the file again and will have to repeat the steps to recreate a new cloud-init file.
