You must have port 443 open to the IP address of the Aviatrix Controller. For the required port access for Edge Gateway deployment, refer to Aviatrix Edge Gateway Ports and Protocols. |
Click + Edge Gateway, then provide the following information.
Select edge_admin.
ZTP File Type
Select the ZTP file type.
For VMware ESXi, select iso.
For KVM, select iso or cloud-init.
Configuring the WAN Interface
| For IP and DNS settings, enter using the applicable format. For example, if the Edge Gateway’s WAN IP is 10.1.1.151, enter 10.1.1.151/24 or what your netmask is. |
| Parameter | Description |
IP Assignment |
The default is Static for static IP assignment. DHCP for dynamic IP address assignment is not supported. |
Interface Labels |
(optional) A name to identify the WAN interface. |
Interface CIDR |
The CIDR for the WAN interface. |
Default Gateway IP |
Public IP |
(optional) The Public IP address of the WAN interface. |
Configuring the LAN Interface
IP Assignment |
VRRP |
If you have Virtual Router Redundancy Protocol (VRRP) configured for the LAN router redundancy, set this switch to On. |
Interface CIDR |
The CIDR for the LAN interface. |
VRRP Gateway IP |
The Virtual IP (VIP) address, when VRRP is enabled. |
(optional) The Default Gateway IP for the LAN interface. |
Interface Labels |
(optional) A name to identify the LAN interface. |
VLAN Interface
| You cannot edit the VLAN ID after the Edge Gateway is created. To edit the VLAN sub-interface attributes, it is highly recommended to delete and recreate the VLAN sub-interface configuration. |
Interface CIDR |
The native VLAN interface IP address. This is the interface where the untagged packets are sent. |
VRRP Gateway IP |
The Virtual IP for the VRRP Gateway, when VRRP is enabled. |
The Default Gateway IP address for the native VLAN interface. |
Interface Labels |
(optional) A name to identify this native VLAN interface. |
VLAN Sub-Interfaces |
VLAN ID |
The VLAN ID. VLAN ID must be a number between 2 and 4092. |
VLAN Interface CIDR |
The VLAN sub-interface IP address. |
VRRP Gateway IP |
The Default Gateway IP address for this VLAN sub-interface. |
Sub-Interface Tag |
(optional) A name to identify this VLAN sub-interface. |
IP Assignment |
Select DHCP or Static, depending on your environment. This setting cannot be changed after the gateway is created. |
Private Network |
If the Management interface connection to the Aviatrix Controller is over a private network, set this switch to On. Leave the setting to Off, if the connection is over the public internet. |
Parameter |
Description |
Egress CIDR (Optional) |
The CIDR range for the egress flow for the Management interface. |
The ISO file expires after 24 hours. You cannot download it again and will have to repeat the above steps. You must mount the ISO file to an Edge VM to complete the Edge Gateway registration within 24 hours. See Deploying the Edge Gateway Virtual Machine Instance. |
