Creating the ZTP Cloud-Init for the Primary Edge Spoke Gateway (Equinix)
The Edge Gateway cloud-init ZTP file is used to provision the Edge Gateway virtual machine and create the Edge Gateway in Equinix Fabric.
To create the primary Edge Spoke Gateway, follow these steps.
Step 1: Gateway Configuration
  1. In CoPilot, go to Cloud Fabric > Hybrid Cloud > Edge Gateways tab.
  2. Click Spoke Gateways, then click + Spoke Gateway and provide the following information.
    Identifies the edge location.
    See Edge site.
    ZTP File Type
    This is set to cloud-init.
    See Edge Spoke Gateway High Availability.
  3. Click Next to configure the edge gateway interfaces.
By default, an Edge Spoke Gateway has three interfaces: one WAN interface, one LAN interface, and one Management interface. You can configure multiple WAN interfaces on the Edge Gateway, as needed. You will need these configuration information to configure the interfaces.
Configuring the WAN Interface
You can configure multiple WAN interfaces on the Edge Gateway. While up to 8 WAN interfaces is supported, Aviatrix recommends a maximum of 4 WAN interfaces per Edge Gateway.
  1. Click + WAN Interface, then provide the following information.
    Interface
    Adding multiple WAN interfaces is applicable when the Edge Gateway is set up for BGP underlay to cloud service provider (CSP).
    Edge Gateway WAN support for BGP underlay to CSP is supported for AWS, Azure, and GCP.
    Interface Primary CIDR
  2. If BGP is turned On, provide the following information:
    Password (optional)
    The MD5 authentication key.
  3. If BGP is turned On, in Gateway Configuration, enter the Local AS Number of the Edge Gateway.
  4. To add another WAN interface, click + WAN again and provide the required information.
Configuring the LAN Interface
To configure the Edge Gateway LAN interface, click + LAN Interface, then provide the following information.
Interface
  1. Click MGMT, then click + MGMT Interface.
  2. Leave the default settings and click Save.
    Leave the Private Network setting to Off. In the Equinix Platform, the Management interface of the Edge Gateway is assigned the public IP address that is allocated by Equinix.
  3. To create the ZTP cloud-init image file, click Done.
    CoPilot downloads the ZTP cloud-init file to your downloads folder.
    Next, log in to your Equinix Portal and deploy the Edge Gateway VM instance and attach the cloud-init image file to complete the Edge Gateway creation and authentication with the Aviatrix Controller.
    The cloud-init file is valid for 24 hours after you create it, so you must launch an Edge VM and deploy the Edge Gateway on the Equinix platform within that time. You will not be able to download the file again and will have to repeat the steps to recreate a new cloud-init file.
Step 3: Deploy the Edge Gateway in Equinix Network Edge
