Supported Edge Hardware for the Aviatrix Edge Platform
Dell Hardware Technical Specifications
Dell PowerEdge R450 Server for Edge Transit or Edge Spoke Gateway
R450 is End-of-Sale (EOS) after the 7.2 release.
For Aviatrix Controller and Gateway version 8.0 and later, use the Dell PowerEdge R470 for Edge Transit Gateway and Edge Spoke Gateway. See Supported Edge Hardware for the Aviatrix Edge Platform for more details.
Although R450 is End-of-Sale, it continues to be supported in 7.2 and earlier releases. For new orders, use R470 only.
The Dell PowerEdge R450 for Edge Transit Gateway uses two Ethernet controllers.
Component
Requirement
Front Storage
Chassis with up to 8x2.5" Drives
Backplane
SAS/SATA Backplane
Trusted Platform Module
Trusted Platform Module 2.0 V3
Chassis Configuration
2.5" Chassis with up to 8 Hard Drives (ChipsetSATA) 1 CPU
Processor
Intel® Xeon® Gold 5318Y 2.1G, 24C/48T, 11.2GT/s, 36M Cache, Turbo, HT (165W) DDR4-2933
Additional Processor
No Additional Processor
Processor Thermal Configuration
Heatsink for 1 CPU configuration (CPU less or equal 165W)
Memory Configuration Type
Performance Optimized
Memory DIMM Type and Speed
3200MT/s RDIMMs
Memory Capacity
32GB RDIMM, 3200MT/s, Dual Rank, 16Gb BASE x8
RAID Configuration
C20, No RAID with Embedded SATA for SATA HDDs or SATA SSDs (Mixed Drive Types Allowed)
Hard Drives
480GB SSD SATA Read Intensive 6Gbps 512 2.5in Hot-plug AG Drive, 1 DWPD
BIOS and Advanced System Configuration Settings
Power Saving Dell Active Power Controller
Advanced System Configurations
No-OS Partition Removed
Fans
Standard Fan x5
Power Supply
Dual, (1+1) Fully Redundant, Hot-Plug Power Supply, 800W MM (100-240Vac)
Power Cords
(2) NEMA 5-15P to C13 Wall Plug, 125 Volt, 15 AMP, 10 Feet (3m), Power Cord, North America
PCIe Riser
Riser Config 0, 1xOCP 3.0(x16)+ 1x16LP
Motherboard
PowerEdge R450 Motherboard with Broadcom 5720 Dual Port 1Gb On-Board LOM
OCP 3.0 Network Adapters
Intel E810-XXV Dual Port 10/25GbE SFP28, OCP NIC 3.0
Additional Network Cards
Intel E810-XXV Dual Port 10/25GbE SFP28 Adapter, PCIe Low Profile
Bezel
No Bezel for x8 Chassis
Optics & Cables for Network Cards
Select either 25G or 10G. Each server needs four SFPs.
  • (4) SFP28 SR Optic, 25GbE, 85C, for all SFP28 ports
    This selection includes four 25G SFPs.
  • (4) SFP+ SR Optic, 10GbE, for all SFP+ ports except high temp validation warning cards
    This selection includes four 10G SFPs.
Operating System
No Operating System
OS Media Kits
No Media Required
Embedded Systems Management
iDRAC9, Enterprise 15G
Quick Sync
No Quick Sync
Password
iDRAC,Factory Generated Password
IDRAC Service Module
iDRAC Service Module (ISM), NOT Installed
Group Manager
iDRAC Group Manager, Disabled
Rack Rails
ReadyRails A11 drop-in/stab-in Slide Combo Rails Without Cable Management Arm
Internal Optical Drive
No Internal Optical Drive
System Documentation
No Systems Documentation, No OpenManage DVD Kit
Shipping
PowerEdge R450 Shipping
Shipping Material
PowerEdge R450 x8 Short Drive Shipping Material
Regulatory
PowerEdge 1U CCC and BIS Marking, No CE Marking on Chassis
Services: Hardware Support
Basic Next Business Day 36 Months, 36 Month(s)
Services: Extended Service
NO WARRANTY UPGRADE SELECTED, 36 Month(s)
Please contact your Aviatrix Sales and Account representative for more information or to place an order.
