This page explains how to perform single-version Controller and Gateway upgrade using either CoPilot (recommended) or Controller UI. Choose a tab below. For multiple-version Controller and Gateway upgrade, see Upgrade your Controller and Gateways to the Latest Aviatrix Supported Images (AWS and Azure Only).
If your Controller version is 7.0 or earlier, use Controller UI for the Controller and Gateway upgrade. See the Controller UI tab.
This page instructs you on how to perform single-version Controller and Gateway upgrade via the CoPilot UI.
Before Upgrade
Before upgrading your Controller and Gateways, it is highly recommended to check the Upgrade Overview.
  • You must upgrade the Controller first, ensuring it is at the desired release version.
  • Once the Controller upgrade is completed successfully, you proceed to upgrade the Gateways.
Review the Pre-upgrade Tasks
Check and perform all the pre-upgrade tasks. See details in Pre-upgrade Tasks for Controller and Gateways.
Check the Upgrade Checklist
Perform all the items listed in the upgrade checklist. See details in Upgrade Checklist of the Controller and Gateway Upgrade.The following table outlines the steps involved in upgrading the Controller and Gateways when upgrading between different versions.
Perform the following steps to upgrade your Controller to a desired version:
  1. Log into your CoPilot.
  2. Go to Administration > Maintenance > Controller Upgrade.
  3. Select the Target Version to which you want to upgrade. By default, it will upgrade to the latest version of the current release. Alternatively, you can specify a specific release version.
  4. Click Run Readiness Check and resolve any Failed (Blocker) issues before you continue. See Readiness Check for the Aviatrix Controller Upgrade.
  5. Follow the on-screen prompts to start the Controller upgrade process.
Upgrade your Gateways
Perform the following steps to upgrade your Gateways to a desired version:
  2. Go to Administration > Maintenance > Gateway Upgrade.
  3. Create or select an upgrade group and choose the gateways you want to upgrade. However, please note that the system will upgrade the Controller first and then the gateways.
    1. Click Run Readiness Check to check for potential issues.
    2. (Optional) If any issues are reported, address and fix them accordingly.
    3. Click Prepare For Upgrade to upgrade the selected gateways.
  4. Alternatively, go to Cloud Fabric > Gateways > Gateway Management and click Software Upgrade.
    1. Select the gateways you want to upgrade.
    2. Click Actions > Upgrade Software.
  5. Wait for the upgrade process to complete and verify that you receive a successful upgrade message.
If you wish to organize gateways into groups and upgrade them in batches, see Upgrade Gateways in Groups.
Verify your Upgrade Status
After performing an upgrade, it is important to verify your upgrade status.
