What This Is
Aviatrix hosts an MCP server atdocs.aviatrix.com/mcp that exposes the
Aviatrix Documentation knowledge base to any MCP-compatible AI agent. Connect
your agent once, and it can search product documentation, generate
configuration, and answer product questions directly inside your current
workflow, without opening a browser tab.
MCP (Model Context Protocol) is a Linux Foundation open standard for AI agent
tool access. Once you configure the server endpoint in your MCP client, the
agent discovers and invokes available tools automatically.
When to Use MCP vs. the Docs Website
If you are exploring a new feature or learning how a concept fits together, the
docs website remains the better tool. If you are mid-task and need a fast,
specific answer, connect your agent to the MCP server instead.
Available Tool
The server exposes one tool:
Ask your agent a question in natural language. The agent calls
search_aviatrix_documentation on your behalf and incorporates the results into
its response.
Connect Your Agent
1
Choose your MCP client
The Aviatrix MCP for Docs server works with any MCP-compatible client,
including Claude Code, Claude Desktop, and Cursor.
2
Add the remote server endpoint
Configure your client to connect to
https://docs.aviatrix.com/mcp using
the MCP Streamable HTTP transport. In Claude Code, run:Connect to the remote hosted endpoint directly. Local MCP server
packages for this integration are not supported.
3
Restart or refresh your client
Restart your MCP client, or refresh the connectors list, so the new
server is picked up.
4
Ask a question
Ask your agent a product question, for example “What are the Distributed
Cloud Firewall group limits?” The agent searches Aviatrix documentation
and responds with a cited answer.
Example Questions
- “Is the Onboard All Route Tables feature documented?”
- “What are the latest Controller and CoPilot versions?”
- “How do I configure Transit Egress?”
- “Show me the API reference for version 8.2.”
