# Disabling Rollback on Gateway Creation Error
> When an error occurs during a gateway creation, Aviatrix automatically rolls back all of the resources that was created during the gateway deployment process (elastic IP, storage volume, security groups, and so on) and terminates the gateway instance.
gateway instance. However, you may want to keep the gateway instance for
debugging purposes even when an error occurs during the gateway creation.
To disable rollback on gateway creation error, you need to disable this
automatic rollback feature.
1. In Aviatrix CoPilot, go to **Cloud Fabric > Gateways > Settings** tab.
2. In **Rollback on Gateway Creation Error**, set the toggle to **Off**.
When you disable the automatic rollback feature, CoPilot will keep the gateway
instance even after the failed deployment and continue to list the gateway
instance in the gateways table. If you no longer require to keep the gateway for
debugging purposes, you can delete the gateway instance in CoPilot UI and
CoPilot will automatically delete all of the resources associated with the
gateway instance.
[About Gateway Keepalive](https://docs.aviatrix.com/docs/enterprise/8.2/reference/gateways/gateway-keepalive.md)
[DNS Server Configuration for Aviatrix Gateways](https://docs.aviatrix.com/docs/enterprise/8.2/reference/gateways/transit-spoke-dns.md)
