# Creating the Default RBAC Access Account for Edge
> You have the option to create a default RBAC group and assign users to this group with permissions to create, delete, and manage Aviatrix Edge Gateways.
## Creating the Default RBAC Access Account for Edge
To create an RBAC group with permissions to create, delete, and manage Edge
gateways, follow these steps.
1. In Aviatrix CoPilot, go to **Administration** > **User Access** >
   **Permission Group**.
2. Click **+ Permission Group**.
3. In the **Name** field, enter a name for this Permission group.
4. From the **Users** dropdown list, select the users to add to this Permission
   group.
5. From the **Access Accounts** dropdown list, select the Edge Platform account
   this group should be able to access.
6. Click **CoPilot Visibility** tab.
7. Under **Cloud Fabric > Hybrid Cloud**, select the permissions for the users
   in this Permission group.
8. Click **Save**.
   ![Edge RBAC Configuration](https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-rbac.png?fit=max\&auto=format\&n=DtLW-mqMRi95qZN9\&q=85\&s=1c1f3281b1e3323f1ea1cd1c0f7665d6)
You can now create or assign a user account with the newly created RBAC group.
9. Go to **Administration** > **User Access** > **Users** tab.
10. Click **+ User**.
11. Enter the user credentials, then from the **Permissions Groups** dropdown
    list, select the RBAC Permission group.
