# Example Configuration for Check Point VM in AWS
> In this document, we provide an example to set up the Check Point Security Gateway instance for you to validate that packets are indeed sent to the Check Point Security Gateway for VPC-to-VPC and from VPC to internet traffic inspection.
inspection.
> [!NOTE]
> Both "Firewall" and "Security Gateway" will be used interchangeably in this
> document. Both refer to the Check Point Security Gateway product.
## Prerequisites for Check Point in AWS Firewall
Before you start setting up your Check Point Security Gateway with AWS example
to verify that packets are sent to the gateway for traffic inspection, make sure
you meet the basic requirements:
* Basic Check Point Architecture understanding
* Check Point CloudGuard IaaS product is subscribed to in the AWS Marketplace
The following Check Point AMIs and software versions are supported.
| Supported AMI Name | Software Version |
| CloudGuard IaaS Next-Gen Firewall with Threat Prevention & SandBlast BYOL | R80.40, R80.30 |
| CloudGuard IaaS Next-Gen Firewall with Thread Prevention | R80.40, R80.30 |
| CloudGuard IaaS All-In-One R80.40 | R80.40 |
The basic Check Point architecture is shown below:
![cp\_arch\_reference](https://mintcdn.com/aviatrix-14b37c43/-mwrdwN2SbwuEu52/images/reference/security/firenet/cp-arch-reference.png?fit=max\&auto=format\&n=-mwrdwN2SbwuEu52\&q=85\&s=23155b4b598a3381f0019f9214aab358)
In this document, we provide an example to set up the Check Point Firewall
Firewall for VPC-to-VPC and from VPC to internet traffic inspection.
> [!NOTE]
> You must first&#x20;
> [create a Transit FireNet in AWS](https://docs.aviatrix.com/docs/enterprise/10.1/guides/security/firenet/firenet-workflow)
> , and&#x20;
> [deploy a Check Point firewall](https://docs.aviatrix.com/docs/enterprise/10.1/guides/security/firenet/firenet-workflow)&#x20;
> in that Transit FireNet.
After you launch a Check Point firewall instance, the Security > FireNet >
Firewall tab displays the public IP address of the firewall's management/egress
interface. You click this to access the firewall UI.
## Launching Check Point Firewall from Aviatrix CoPilot (AWS)
> [!NOTE]
> , and&#x20;
You can use the Security Gateway information in this example for your reference.
Adjust it depending on your requirements.
| Example setting | Example value |
| Firewall Image | Check Point CloudGuard IaaS All-In-One R80.40 |
| Firewall Image Version | R80.40-294.581 |
| Firewall Instance Size | m5.large |
| Egress Interface Subnet | Select the subnet whose name contains "FW-ingress-egress." |
| Key Pair Name (Optional) | The .pem file name for SSH access to the firewall instance. |
| Attach | Check |
Make note of the SIC (Secure Inter-communication) Key; it is required to add the
Security Gateway inside the Security Manager.
The Check Point Firewall instance has two interfaces as described below.
Additionally, firewall instance eth1 is on the same subnet as FireNet Gateway
eth2 interface.
| Check Point VM instance interfaces | Description | Inbound Security Group Rule |
| eth0 (on subnet -Public-FW-ingress-egress-AZ-a) | Egress or Untrusted interface | Allow ALL |
| eth1 (on subnet -dmz-firewall) | LAN or Trusted interface | Allow ALL (Do not change) |
Below are the steps for initial setup.
## Setting up Check Point Gateway (Firewall) SSH login Using Password
For Metered AMI, open a terminal and run the following command.
After you download the access key (.pem file), change the file permission
to 600. It usually takes 5-10 minutes for the Check Point Gateway to be ready.
ssh -i <private_key.pem> admin@<public-ip_address>
set expert-password
Enter new expert password:
Enter new expert password (again):
gw-358e82> expert
Enter expert password:
Warning! All configurations should be done through clish
You are in expert mode now.
[Expert@gw-358e82:0]# sed -i 's/PasswordAuthentication no/PasswordAuthentication yes/' /etc/ssh/sshd_config
[Expert@gw-358e82:0]# sed -i 's/PermitRootLogin forced-commands-only/PermitRootLogin yes/' /etc/ssh/sshd_config
[Expert@gw-358e82:0]# service sshd reload
Reloading sshd:                                            [  OK  ]
[Expert@gw-358e82:0]# exit
Terminate the SSH session.
## Logging in to the Check Point Firewall Gaia Portal
After the firewall launch is completed in Aviatrix CoPilot, go to Security >
FireNet > Firewall and click on the firewall link in the Management UI column.
This step applies to AWS and Azure.
![v2\_cp\_login\_UI](https://mintcdn.com/aviatrix-14b37c43/-mwrdwN2SbwuEu52/images/reference/security/firenet/cp-login-ui-aws.png?fit=max\&auto=format\&n=-mwrdwN2SbwuEu52\&q=85\&s=d22758230426965cd3b0562e6e83be99)
The URL takes you to the Check Point Firewall Gaia Portal you just launched.
Launching Check Point firewall instances from Aviatrix CoPilot automatically
initiates its onboarding process.
For initial Check Point login information, go to Credentials for Check Point
Initial Login. You must be registered to access the Aviatrix Customer Support
website. If you are not already registered, you can sign-up at
[https://support.aviatrix.com](https://support.aviatrix.com).
## Initializing and Logging in to the Check Point Firewall via Gaia Portal
When you log in for the first time you see the Check Point First Time
Configuration Wizard screen as shown below.
![400](https://mintcdn.com/aviatrix-14b37c43/HMh-g4DI2V-ei5Vm/images/reference/security/firenet/checkpoint-gaia-wizard-one.png?fit=max\&auto=format\&n=HMh-g4DI2V-ei5Vm\&q=85\&s=6be5ef77d82a255db82f52f890cfd638)
Click **Next** in each dialog and then click **Finish**.
![400](https://mintcdn.com/aviatrix-14b37c43/HMh-g4DI2V-ei5Vm/images/reference/security/firenet/checkpoint-gaia-wizard-two.png?fit=max\&auto=format\&n=HMh-g4DI2V-ei5Vm\&q=85\&s=122949bd0eebbff8aa11012be24cf2d7)
![400](https://mintcdn.com/aviatrix-14b37c43/HMh-g4DI2V-ei5Vm/images/reference/security/firenet/checkpoint-gaia-wizard-twelve.png?fit=max\&auto=format\&n=HMh-g4DI2V-ei5Vm\&q=85\&s=e7a33ff0c1612c1172860a73084955b7)
Since Aviatrix CoPilot automatically configures the Check Point interfaces and
RFC1918 static routes which are required for the FireNet feature, initialize
wizard configurations are no longer required. However, you must complete the
wizard steps to initialize the firewall properly.
After the initialization is completed, you see the Check Point Firewall Gaia
Portal Overview page.
![v2\_CheckPoint\_Gaia\_Portal\_Overview](https://mintcdn.com/aviatrix-14b37c43/HMh-g4DI2V-ei5Vm/images/reference/security/firenet/checkpoint-gaia-wizard-overview.png?fit=max\&auto=format\&n=HMh-g4DI2V-ei5Vm\&q=85\&s=d53d8661345d5fb8f1f2a6dd0cc98a6b)
Navigate to Network Management > Network Interfaces to review eth0 (WAN) and
eth1 (LAN) configuration as shown below.
![cp\_firewall\_interfaces\_aws](https://mintcdn.com/aviatrix-14b37c43/-mwrdwN2SbwuEu52/images/reference/security/firenet/firewall-interfaces-aws.png?fit=max\&auto=format\&n=-mwrdwN2SbwuEu52\&q=85\&s=72b667b0bbaae1cbdccafb3d594f941d)
Review static routes RFC 1918 which is configured on LAN port, the purpose of
those static route is to send the packets back to the Gateway (GW).
Routes can also be reviewed by clicking **Monitoring** on the page Network
Management > IPv4 Static Routes.
![cp\_firewall\_routes\_monitoring\_aws](https://mintcdn.com/aviatrix-14b37c43/-mwrdwN2SbwuEu52/images/reference/security/firenet/firewall-routes-monitoring-aws.png?fit=max\&auto=format\&n=-mwrdwN2SbwuEu52\&q=85\&s=7fb09300f24cc570b7e426df5d8c5fe8)
## Vendor Integration
Click [here](https://docs.aviatrix.com/docs/enterprise/10.1/guides/security/firenet/firenet-vendor-integration.md) for information
on vendor integration.
## Downloading and Installing the SmartConsole
The Check Point Single Gateway 'All-In-One' image is used in this example and
does not require Check Point Security Manager. All other Gateway images require
Check Point Security Manager. If you are not using the 'All-In-One' image, skip
this step and follow the Deploying and Installing the SmartConsole steps.
The SmartConsole must be downloaded on a Windows-based computer.
Log in to the Check Point Gateway and download the SmartConsole on a
Option 1: click **Download Now!** with the message "Manage Software Blades using
SmartConsole" on the Overview page as shown below.
![v2\_CheckPoint\_Gaia\_Portal\_SmartConsole\_DL](https://mintcdn.com/aviatrix-14b37c43/HMh-g4DI2V-ei5Vm/images/reference/security/firenet/checkpoint-gaia-smartconsole.png?fit=max\&auto=format\&n=HMh-g4DI2V-ei5Vm\&q=85\&s=d3c4183b09b4babc0cd1d039fd32d378)
Option 2: download it by using this link:
[R80.40](https://supportcenter.checkpoint.com/supportcenter/portal?eventSubmit_doGoviewsolutiondetails=\&solutionid=sk119612).
### Installing and Logging into the SmartConsole
The Check Point SmartConsole is a Windows-based application used to configure
and manage polices. These policies can be applied to one or more Security
Gateways.
Install the SmartConsole and log in with the Gaia Portal username, password and
IP Address of the Check Point Gateway.
![400](https://mintcdn.com/aviatrix-14b37c43/-mwrdwN2SbwuEu52/images/reference/security/firenet/smart-console-login-aws.png?fit=max\&auto=format\&n=-mwrdwN2SbwuEu52\&q=85\&s=0d17070cd2df5c3bfc2a6f8e4e900f23)
Execute the "Get Interfaces With Topology" function to sync up the settings that
we have configured via the Gaia Portal.
![smartconsole\_gateway\_login\_aws](https://mintcdn.com/aviatrix-14b37c43/-mwrdwN2SbwuEu52/images/reference/security/firenet/smartconsole-gateway-login-aws.png?fit=max\&auto=format\&n=-mwrdwN2SbwuEu52\&q=85\&s=b35ee64e6125fb8bc57d468196dcf366)
1. Select **Gateways & Servers** on the left.
2. Double-click on the Check Point Firewall.
3. Select **Network Management** on the left.
4. Click **Get Interfaces** to expand options.
5. Click **Get Interfaces With Topology**.
6. Click **Yes**.
![v2\_CheckPoint\_SmartConsole\_syncup\_01](https://mintcdn.com/aviatrix-14b37c43/HMh-g4DI2V-ei5Vm/images/reference/security/firenet/checkpoint-smartconsole-syncup-one.png?fit=max\&auto=format\&n=HMh-g4DI2V-ei5Vm\&q=85\&s=bd259fce696f0b5d5dff7d2ef0dd7406)
Review the Get Topology Results which should match to the settings that we have
configured via Gaia Portal.
![v2\_CheckPoint\_SmartConsole\_syncup\_02](https://mintcdn.com/aviatrix-14b37c43/HMh-g4DI2V-ei5Vm/images/reference/security/firenet/checkpoint-smartconsole-syncup-two.png?fit=max\&auto=format\&n=HMh-g4DI2V-ei5Vm\&q=85\&s=0149acb615514d1afe1eee181e4fb2d1)
7. Click **Accept**.
Go to Security Policies > Access Control > Policy and click **Install Policy**
and then **Install** to commit the settings.
![install\_policy\_aws](https://mintcdn.com/aviatrix-14b37c43/-mwrdwN2SbwuEu52/images/reference/security/firenet/install-policy-aws.png?fit=max\&auto=format\&n=-mwrdwN2SbwuEu52\&q=85\&s=ee5d9401883a9adf82fcd8a7e96b6bad)
## Configuring the Basic Traffic Policy to Allow Traffic VPC-to-VPC
In this step, you will configure a basic traffic security policy that allows
traffic to pass through the firewall.
In the Check Point UI, from Security Policies > Access Control > Policy,
configure a policy by either modifying the default Cleanup rule or adding a new
rule above the default rule.
| Field | Value |
| Name | Configure any name for this policy (i.e. allow-all) |
| Source | Any |
| Destination | Any |
| VPN | Any |
| Service & Applications | Any |
| Action | Accept |
| Track | Log |
![v2\_CheckPoint\_policy\_vpc\_to\_vpc](https://mintcdn.com/aviatrix-14b37c43/HMh-g4DI2V-ei5Vm/images/reference/security/firenet/checkpoint-policy-vpc-aws.png?fit=max\&auto=format\&n=HMh-g4DI2V-ei5Vm\&q=85\&s=11a07be0f066adc045ab4d7c2174820e)
Click **Install Policy** and then **Install** to commit the settings.
![v2\_CheckPoint\_policy\_vpc\_to\_vpc\_install](https://mintcdn.com/aviatrix-14b37c43/HMh-g4DI2V-ei5Vm/images/reference/security/firenet/checkpoint-policy-vpc-install.png?fit=max\&auto=format\&n=HMh-g4DI2V-ei5Vm\&q=85\&s=969d9595c5a1fbe4fe063962527f1cba)
## (Optional) Configuring the Basic Traffic Policy to Allow Traffic VPC to Internet
Internet traffic to pass through the firewall. Given that Aviatrix Gateways will
only forward traffic from the TGW to the LAN port of the firewall, we can just
set our policy condition to match any packet that is going into the LAN
interface and out of the WAN interface.
You must enable the **Egress inspection** feature on FireNet if it is not
already enabled. To enable it:
1. In Aviatrix CoPilot, navigate to Security > FireNet > FireNet Gateways on the
   left navigation menu.
2. Click the Edit icon ![edit icon](https://mintcdn.com/aviatrix-14b37c43/-mwrdwN2SbwuEu52/images/reference/security/firenet/edit-icon.png?fit=max\&auto=format\&n=-mwrdwN2SbwuEu52\&q=85\&s=a4211445d52df244d56b4df393a0d9c3) next
   to a FireNet Gateway.
3. Scroll down to the Egress toggle switch and turn it **On**.
4. Click **Save**.
5. Verify the Egress status on the FireNet Gateways tab.
In the Check Point Firewall SmartConsole, navigate to the Gateways & Servers
page and then double-click on the gateway to enable NAT function as per the
following screenshot.
1. Click **NAT**.
2. Select the **Hide internal networks behind the Gateway's external IP**
   checkbox.
3. Click **OK**.
4. Click **Install Policy**.
![v2\_CheckPoint\_policy\_vpc\_to\_internet\_nat\_enabled](https://mintcdn.com/aviatrix-14b37c43/HMh-g4DI2V-ei5Vm/images/reference/security/firenet/checkpoint-policy-nat-enabled.png?fit=max\&auto=format\&n=HMh-g4DI2V-ei5Vm\&q=85\&s=29292029c39e27ae3100a2205ac22f69)
The NAT function needs to be enabled on the Check Point FW interface eth0 for
this VPC to Internet policy. Refer to
[Check Point's NAT instruction](https://sc1.checkpoint.com/documents/R80.40/WebAdminGuides/EN/CP_R80.40_Firewall_AdminGuide/Topics-FWG/Working-with-Hide-NAT.htm)
for details.
(Optional) If you have the default "Cleanup rule", navigate to Security
Policies > Access Control > Policy and inject a new rule for Internet Policy on
top of the default Cleanup rule.
| Field | Value |
| Name | Configure any name for this policy (i.e. Internet-Policy) |
| Source | Any |
| Destination | Select the object with All\_internet |
| VPN | Any |
| Action | Accept |
| Track | Log |
![cp\_policy\_vpc\_to\_internet\_aws](https://mintcdn.com/aviatrix-14b37c43/-mwrdwN2SbwuEu52/images/reference/security/firenet/cp-policy-internet-aws.png?fit=max\&auto=format\&n=-mwrdwN2SbwuEu52\&q=85\&s=48302c3f52ea3189d42d696fe23c7e55)
After validating that your traffic is being routed through your firewall
instances, you can customize the security policy to your requirements.
## Validate Check Point in AWS firewall Instance
Now your firewall instance is configured and ready to receive packets. The next
step is to validate your configurations and polices using FlightPath and
Diagnostic Tools (ping, traceroute, etc.).
## Viewing Traffic Log for Check Point in AWS/Azure
You can view if traffic is forwarded to the firewall instance by logging in to
the Check Point Firewall SmartConsole and navigating to the Logs & Monitor page.
### Verifying VPC-to-VPC traffic
Launch one instance in PROD Spoke VPC and another in DEV Spoke VPC. Start
pinging packets from a instance in DEV Spoke VPC to the private IP of another
instance in PROD Spoke VPC. The ICMP traffic should go through and be inspected
in the firewall.
![v2\_CheckPoint\_view\_traffic\_log\_vpc\_to\_vpc](https://mintcdn.com/aviatrix-14b37c43/-mwrdwN2SbwuEu52/images/reference/security/firenet/checkpoint-vpc-aws.png?fit=max\&auto=format\&n=-mwrdwN2SbwuEu52\&q=85\&s=99fd9834b6d020df2057cc72c85704cb)
### (Optional) Verifying VPC to Internet traffic
To verify VPC to internet traffic for your Check Point in AWS firewall, launch a
private instance in the Spoke VPC (i.e. PROD Spoke VPC) and start pinging
packets from the private instance towards Internet (e.g 8.8.8.8) to verify the
egress function. The ICMP traffic should go through, and be inspected on the
firewall.
![v2\_CheckPoint\_view\_traffic\_log\_vpc\_to\_internet](https://mintcdn.com/aviatrix-14b37c43/HMh-g4DI2V-ei5Vm/images/reference/security/firenet/checkpoint-internet-aws.png?fit=max\&auto=format\&n=HMh-g4DI2V-ei5Vm\&q=85\&s=ee891adbdeb7b5c45e111d66f4db9851)
