# Performance Improvement with Gateway Scaling
> The Gateway Scaling tabs are marked as Legacy if you configured any Scaling policies prior to CoPilot 4.15. As soon as all policies are removed from the Cloud Fabric > Scaling > Policies tab, all the Legacy Gateway Scaling tabs are removed.
## About Gateway Scaling
removed.
Aviatrix recommends using the [Auto
Right-Sizing feature](https://docs.aviatrix.com/docs/enterprise/10.1/concepts-architectures/architecture/sizing/auto-right-sizing-about.md), unless you need to schedule gateway sizing or want to
add new gateway instances when scaling up.
The gateway scaling feature helps ensure that appropriate sizing is applied to
VPCs/VNets on AWS and Azure Spoke gateways. This can reduce CSP costs, improve
performance and mitigate packet loss. You can apply manual, automatic, or
scheduled scaling to your selected VPCs/VNets.
Manual scaling occurs when the metrics in your trigger conditions are met for a
configured time period. A recommendation to scale up (increase the gateway size
or add gateway instances) or scale down (decrease the gateway size or remove
gateway instances) is then generated that you can choose to apply. With manual
scaling you can scale a VPC/VNet up and down one time.
When the instance size changes, it changes for all gateways in that VPC/VNet.
Automatic scaling occurs when the (combination of) metrics are outside the ideal
operating range for a set time period, and a gateway scaling event has not
occurred in the duration specified by the cool-down period. Gateways in the
selected VPCs/VNets are added or removed automatically.
Scheduled scaling (adding and removing a gateway instance) occurs during a
configured time period. You should only select this option if you can regularly
predict traffic and resource consumption within regularly scheduled hours.
> [!NOTE]
> VPCs/VNets cannot have both automatic and scheduled scaling applied.
> [!NOTE]
> Each VPC/VNet can only scale one gateway at a time. Multiple VPC/VNets can
> scale gateways at the same time.
> [!NOTE]
> You can only scale down gateways created with auto or scheduled scaling.
> Gateways created using different methods, such as Terraform or CoPilot, cannot
> be removed via this scaling feature.
### Before You Begin
* For gateway scaling features, the user account you have designated as your [CoPilot service
  account](https://docs.aviatrix.com/docs/enterprise/10.1/reference/controlplane/copilot-user-account-administration.md) must have a minimum of all\_write permissions.
* (optional) Configure at least one [email address](https://docs.aviatrix.com/docs/enterprise/10.1/reference/ui/monitor/notifications.md) or [webhook](https://docs.aviatrix.com/docs/enterprise/10.1/reference/ui/monitor/notifications.md) in CoPilot under Monitor >
  Notifications > Recipients. This email address or webhook is where
  recommendations are sent when a manual scaling policy is triggered.
* The Aviatrix Controller must be upgraded to version 7.0 to support the
  creation of new instances using gateway scaling.
* Any AWS/Azure Spoke gateways that you want to use in gateway scaling cannot
  have HPE, BGP, NAT, DNAT, SNAT, FQDN gateways, or Site2Cloud enabled.
* Remember that not all regions support all gateway (instance) sizes. Before
  adding or removing gateway instances (manual scaling), you should determine
  what increased or decreased instance size best suits the requirements of your
  network infrastructure.
* (automatic scaling) Make note of your base (starting) number of gateways.
  Gateways will not be scaled down if the base (starting) number of gateways has
  already been reached.
## Creating a Policy
The Policies tab is marked as Legacy if you configured Gateway Scaling policies
prior to CoPilot 4.15. If you did not configure any Gateway Scaling policies
prior to CoPilot 4.15, this tab is not displayed.
In CoPilot under Cloud Fabric > Scaling > Policies, you create policies that
monitor VPCs/VNets to determine when to generate a recommendation or when
gateway scaling should occur.
If network architecture is changed after a policy is created (for example, High
Performance Encryption is enabled on a VPC that is included in a policy), the
scaling event related to the policy may fail. If an error occurs during policy
creation or execution you should first check for any network architecture
changes.
On this tab you can:
* Create policies
* Edit policies
* Filter policies
* Download the contents of the tab as a CSV
* Delete policies: click the trash can icon (you are asked to confirm the
  deletion)
* View events for selected automatic policies
* View events or show recommendations for selected manual policies
Policies are never invalidated.
![scaling policy tab](https://mintcdn.com/aviatrix-14b37c43/SLQZZmwp9yQQEWL0/images/reference/gateways/scaling-policy-tab.png?fit=max\&auto=format\&n=SLQZZmwp9yQQEWL0\&q=85\&s=5c63829e3984b6d66391a0fbe39d6718)
### Viewing Policy Details
When you click a policy name on the Scaling > Policies tab details are displayed
for that policy:
* VPCs/VNets in the policy
* If it is a manual, automatic, or scheduled scaling policy
* The metrics in the trigger conditions or the ideal operating range
* **Evaluation Period** - The duration of time (in minutes) where CoPilot
  evaluates the average of the metric(s) specified to trigger the action.
* **Cool Down Period** - (Automatic scaling only) The number of minutes that
  must elapse between consecutive gateway scaling events. Even if the monitored
  VPCs/VNets fall outside the ideal operating range for the specified Evaluation
  Period, gateway scaling will not occur again until after the Cool Down Period
  has elapsed.
* Who receives alerts/emails related to the execution of the policy (if
  configured)
* The time period, start and end date, and performance metrics for the selected
  time period. Metrics for manual scaling polices are shown individually. You
  can select which VPC/VNet to view metrics for.
* Events related to the executed policy
### Creating a Manual Scaling Policy
On the Cloud Fabric > Scaling > Policies tab, click **+Policy**. The Create New
Scaling Policy dialog displays.
![400](https://mintcdn.com/aviatrix-14b37c43/SLQZZmwp9yQQEWL0/images/reference/gateways/scaling-create-manual.png?fit=max\&auto=format\&n=SLQZZmwp9yQQEWL0\&q=85\&s=cf1518487ca18d69160aa9a93706dbe6)
After selecting **Manual Scaling**, configure the following:
| Field | Description |
| **Name** | Enter a name for the scaling policy that clearly describes what the policy will do. |
| **Manual Scaling VPC/VNets** | Select Spoke VPC/VNets, Transit VPC/VNets or SNAT Enabled VPC/VNets. |
| **Monitor VPC/VNets** | Enter the name of the VPC/VNet, which displays the matching VPC/VNets that can be assigned to the policy. Click **Select All** to select all matching VPCs/VNets and assign them to the policy. Or, select the checkbox next to specific VPC/VNets to include them. SNAT enabled VPC/VNets that also have BGP or egress enabled will not be available in the Monitor VPC/VNets field. |
| **Trigger Conditions** | Select **Matches all conditions (AND)** or **Matches any condition (OR)** to determine if all conditions must be met, or if only one of the conditions must be met. The metric chosen must have an average greater than or less than the chosen threshold limit, relative to the Evaluation Period. In either case these conditions must be sustained for the configured Evaluation Period to generate manual scaling recommendations. You can enter a maximum of five trigger conditions, or five groups that each contain a maximum of five trigger conditions. See the "Creating a Manual Scaling Policy" document for the list of system and metric trigger conditions. |
| **Evaluation Period** | Enter the duration of time (in minutes) where CoPilot evaluates the average of the metric(s) specified to trigger the action of recommending gateway scaling. |
| **Recommendation Operation** | Select the scaling operation to perform, which is dictated by the VPC/VNet type (Spoke or Transit). In Spoke VPC/VNets you can increase/decrease instance sizes (scale up/down) or add/remove gateway instances (scale out/in). In Transit VPC/VNets and SNAT Enabled VPC/VNets you can only increase/decrease instance sizes (scale up/down). For more details, see "Recommendation Operation Details" in the "Creating a Manual Policy" document. |
| **Send Notifications To** | Select the email address where the notification is sent when the trigger conditions are met. If this field is left blank, you will not receive alerts. After you receive your notification email, go to the Scaling > Recommendations tab to execute the recommendation. |
Click **Save** to save the policy and begin monitoring the selected VPCs/VNets.
#### Available System and Network Trigger Conditions
**System**:
* CPU Used (%)
* Memory Used
* Memory Used (%)
**Network**:
* Transmitted Rate
* Received Rate
* Total Rate
* Packets Transmitted Rate
* Packet Received Rate
* Total Rate (in packets)
* Bandwidth Ingress Limit Exceeded Rate
* Bandwidth Egress Limit Exceeded Rate
* PPS Limit Exceeded Rate
* Conntrack Limit Exceeded Rate
* Packet Drop Rate
* Packet Drop Rate (%)
#### Recommendation Operation Details
When scaling up/out, the current gateway size is increased for as long as the
trigger conditions are met, or a gateway instance is added. If you are adding a
gateway instance, an instance is added to an empty subnet.
When scaling down/in, the current gateway size is decreased for as long as the
trigger conditions are met, or a gateway instance is removed.
Prior to version 7.0 gateways in a single VPC/VNet are scaled to use the same
instance size.
Once the VPC/VNet recommendation has been created, and the scaling action has
completed, the VPC/VNet will be removed from the policy.
Once a recommendation has been accepted, the gateway will not scale (up/down or
in/out) until another manual policy has been configured, and another
recommendation has been generated.
#### Implementing Recommendations
The Recommendations tabs is marked as Legacy if you configured Gateway Scaling
policies prior to CoPilot 4.15. If you did not configure any Gateway Scaling
policies prior to CoPilot 4.15, this tab is not displayed.
After receiving a notification email indicating that trigger conditions have
been met and sustained for the configured Evaluation Period (if you entered this
information when creating the policy), you can choose to implement the manual
scaling recommendation. A recommendation is generated per VPC/VNet rather than
per policy.
On the Cloud Fabric > Scaling > Recommendations tab, you can choose to scale up
or down (Transit VPCs), or up/down in/out (Spoke VPCs) depending on the
Operation you selected when creating the related policy. After the
recommendation has executed it is removed from the Recommendations list and is
displayed as an event on the Scaling > Events tab.
![scaling recommendation](https://mintcdn.com/aviatrix-14b37c43/SLQZZmwp9yQQEWL0/images/reference/gateways/scaling-recommendation.png?fit=max\&auto=format\&n=SLQZZmwp9yQQEWL0\&q=85\&s=050fa9b6e9802d4dbf1c4627125f55ef)
Clicking a recommendation in the Time field for a policy on the Recommendation
tab shows the policy details and the performance of the metrics that have been
triggered over the selected time period. After viewing this historical detail
you can decide if you want to apply the recommendation.
A recommendation is not valid when it falls outside of the triggered conditions.
A recommendation can become valid again if it once again falls in the triggered
conditional range, and there is at least one VPC remaining in the manual policy.
If the VPC is removed from the policy it will not trigger again.
To implement a recommendation:
1. Click **Scale Up**, **Scale Down**, or **Scale In** next to a recommendation
   in the list.
2. If you scale up or down by increasing or decreasing current gateway size:
   * Select the new instance size.
   ![scaling manual instance size](https://mintcdn.com/aviatrix-14b37c43/SLQZZmwp9yQQEWL0/images/reference/gateways/scaling-manual-instance-size.png?fit=max\&auto=format\&n=SLQZZmwp9yQQEWL0\&q=85\&s=40524c09e90c8f062c054971021fbed6)
   * Acknowledge that this operation could cause a brief network downtime.
   * Click **Begin Scaling**.
3. If you scale in or out by adding or removing instances:
   **Scale Up:**
   * Click **+Instance**.
   * Select an available subnet.
   * Select an existing IP, or allocate a new IP to the instance.
   ![scaling instance](https://mintcdn.com/aviatrix-14b37c43/SLQZZmwp9yQQEWL0/images/reference/gateways/scaling-instance.png?fit=max\&auto=format\&n=SLQZZmwp9yQQEWL0\&q=85\&s=093ba4b44eda668dcb6f4137a49cfc02)
   **Scale Down:**
   * Click the Delete icon next to the instance to delete (at least one row must
     remain).
> [!NOTE]
> You cannot add an instance if no subnet is available in that VPC/VNet.
After scaling has occurred:
* a message displays on the Scaling > Recommendations tab indicating this, and
  that the VPC/VNet that triggered the recommendation has been removed from the
  policy.
* The related recommendation is removed from the Recommendations list.
* An event is generated and added to the Events page.
Scaling operations run one at a time per policy. Multiple policies can run at
the same time.
### Creating an Automatic Scaling Policy
When you apply automatic scaling, gateways are added and removed to handle
system load.
If system load is within the ideal operating range, the number of gateways will
not change. If system load is lower than the ideal operating range, scaling down
will only commence if the number of existing gateways is greater than your base
(starting) number of gateways. If your base (starting) number of gateways has
already been reached, no action is taken.
Aviatrix recommends applying one automatic scaling policy per VPC/VNet.
> [!NOTE]
To create an automatic scaling policy:
![640](https://mintcdn.com/aviatrix-14b37c43/SLQZZmwp9yQQEWL0/images/reference/gateways/scaling-create-auto.png?fit=max\&auto=format\&n=SLQZZmwp9yQQEWL0\&q=85\&s=eb7eb3287bd48c95612c87f5fbead1f7)
After selecting **Automatic Scaling**, configure the following:
| **Name** | Enter a name for the policy that clearly describes what the policy will do. |
| **Monitor VPC/VNets** | Select the VPCs/VNets to monitor. |
| **Ideal Operating Range** | Select **Matches all conditions (AND)** if all conditions must be met or **Matches any condition (OR)** if only one of the conditions must be met. You can enter a maximum of one condition per metric. Available metrics are CPU Used (%) and Memory Used (%). For example, if you have just the CPU Used (%) metric in your policy and the percentage range is from 20-80%, automatic scaling is not triggered until conditions fall outside of this ideal operating range (for example, 90%). Automatic scaling metrics are always percentages. |
| **Evaluation Period** | Enter the number of minutes during which CoPilot evaluates the average of the metric(s) specified to trigger automatic scaling. When the average metric conditions are outside the ideal operating range, automatic scaling occurs (addition or removal of gateways). Each metric and its operation (AND/OR) is taken into account when determining when automatic scaling will occur. |
| **Send Notifications To** | Select the email address/webhook where the notification is sent when gateway scaling has occurred. If this field is left blank you will not receive alerts. |
| **Cool Down Period** | Enter the number of minutes that must elapse between consecutive gateway scaling events. Even if the monitored VPCs/VNets fall outside the ideal operating range for the specified Evaluation Period, gateway scaling will not occur again until after the Cool Down Period has elapsed. |
Click **Save**.
After automatic scaling is performed on a VPC/VNet that VPC/VNet is removed from
the policy.
Only a gateway that has been added using automatic scaling can be removed using
automatic scaling. User-created gateways are not removed by automatic scaling.
If two metrics configured in your automatic scaling policy give contradictory
recommendations, the policy defaults to scaling **Up or Out** - in other words,
increasing gateway number or size. For example, if the CPU Used metric states
that the scaling event should scale out, but the Memory Use metric stated that
the policy should scale in, the policy defaults to scaling out.
### Creating a Scheduled Scaling Policy
You can create a scheduled scaling policy to add a gateway instance during a
scheduled time period, and remove it when the scheduled time period ends. The
gateway instance is created in the first available empty subnet. Gateways can
only be removed if they were previously added using gateway scaling.
> [!NOTE]
> [!NOTE]
> Scheduled scaling occurs in the local time zone in which the browser is
> deployed. For example, if the scheduled scaling event is set to begin at 9 am,
> it begins at 9 am according to the local browser time zone.
![500](https://mintcdn.com/aviatrix-14b37c43/SLQZZmwp9yQQEWL0/images/reference/gateways/scaling-create-scheduled.png?fit=max\&auto=format\&n=SLQZZmwp9yQQEWL0\&q=85\&s=438cc950777fcb034f06320592fcdad4)
After selecting **Scheduled Scaling**, configure the following:
| **Scheduled VPC/VNets** | Select the VPCs/VNets on which to apply the policy. You can type a string in this field to display the matching VPCs/VNets. You can then click **Select All** to select the matching VPCs/VNets. |
| **Scaling Schedule** | Select a time to begin scaling out, and a time to begin scaling in. |
| **On** | Select the days when this scheduled scaling will be performed. |
| **Send Notifications To** | Select the email address/webhook which should receive the notification when the scaling begins and ends. If this field is left blank you will not receive alerts. |
Click **Save**.
Select **Scheduled Scaling**.
Under Scaling Schedule, select a time to begin scaling out, and a time to begin
scaling in.
In the **Send Notifications To** field, select the **email address** or
**webhook** which should receive the notification when the scaling begins and
ends.
### Deleting a Policy
To delete a policy, navigate to the Cloud Fabric > Scaling > Policies tab and
click the delete icon next to the policy. You see a warning when attempting to
delete a policy.
When you delete a policy:
* Existing recommendations for that policy become invalid (manual scaling).
* If a scaling event is occurring related to that policy, it will complete.
* Gateways added with manual scaling can be deleted like a regular gateway.
* Any gateways created with auto scaling will scale down automatically. A
  gateway can only be scaled down automatically if it was created with auto
  scaling.
### Viewing the Events Tab
The Events tab is marked as Legacy if you configured Gateway Scaling policies
The Events tab lists when auto or manual scaling events occurred, and if the
action related to the event succeeded or failed.
![gateway scaling events](https://mintcdn.com/aviatrix-14b37c43/qERZ79zkW46BYFbv/images/reference/gateways/gateway-scaling-events.png?fit=max\&auto=format\&n=qERZ79zkW46BYFbv\&q=85\&s=f1a13528bab9e28392def15d2e2f9921)
The Events tab shows the following information:
* Time of the event
* Policy name
* VPC/VNet name
* Trigger Conditions (Evaluation Period)
* Gateway Instances
* Event name
Clicking an event time in the list shows Trigger Condition details and if the
policy type is Manual or Automatic.
![gateway scaling events details](https://mintcdn.com/aviatrix-14b37c43/qERZ79zkW46BYFbv/images/reference/gateways/gateway-scaling-events-details.png?fit=max\&auto=format\&n=qERZ79zkW46BYFbv\&q=85\&s=2693796b0324573a1959edafdeb471a1)
