# Gateway Keepalive
> The keepalive speed is a global configuration that applies to all Aviatrix gateways. Aviatrix gateways send periodic keepalive messages to the Aviatrix Controller that enables the Controller to determine when a gateway's state changes to monitor when a gateway is down.
<a id="start-help-keepalive" />
The following table shows how frequently gateways send keepalive messages and
how often the Controller processes these messages.
| Speed  | Gateway sends keepalive | Down detection  |
| Fast   | every 2 seconds         | every 7 seconds |
| Medium | every 12 seconds        | every 1 minute  |
| Slow   | every 1 minute          | every 5 minutes |
By default, the keepalive speed is set to **Medium**.
A gateway is considered to be in the **UP** state if the Controller receives at
least 2 (out of a possible 5) messages from that gateway between two consecutive
health checks. For example:
When set to **Fast**, the gateway down detection time is between 7 seconds and
14 seconds.
When set to **Medium**, the gateway down detection time is between 1 minute to 2
minutes.
<a id="end-help-keepalive" />
## Changing Gateway Keepalive Setting
To change the keepalive speed:
1. In Aviatrix CoPilot, go to **Settings > Configuration > General** tab.
2. In the **General** tab, expand the **Advanced** section.
3. Under **Advanced** section, in **Gateway to Controller Communication**, from
   the **Keep-Alive Speed** dropdown menu, select the speed.
4. Click **Save**.
