# Kubernetes Onboarding Prerequisites
> Single canonical prerequisites for onboarding any Kubernetes cluster (EKS, AKS, GKE, or self-managed) to the Aviatrix Controller for Distributed Cloud Firewall.
Read this page once before onboarding any Kubernetes cluster. The cloud-specific
onboarding pages link back to anchors here rather than restating the
requirements.
## Platform requirements
Confirm the following before onboarding any cluster:
* The
  [Distributed Cloud Firewall feature](https://docs.aviatrix.com/docs/enterprise/10.1/guides/security/dcf/dcf-enable-feature.md)
  is enabled.
* [Discovery of Kubernetes Resources](https://docs.aviatrix.com/docs/enterprise/10.1/guides/security/dcf/kubernetes-resource-discovery.md)
  is enabled under **Groups > Settings**.
* The Kubernetes API server is reachable from the Aviatrix Controller. The most
  common case is a public API endpoint with the Controller's IP allowlisted;
  private clusters require a private network path. See
  [Onboarding Private Kubernetes Clusters](https://docs.aviatrix.com/docs/enterprise/10.1/guides/security/dcf/private-kubernetes-cluster-onboard.md)
* SNAT is disabled on worker nodes. See
  [Disable SNAT for Kubernetes Workloads](https://docs.aviatrix.com/docs/enterprise/10.1/reference/dcf/kubernetes-snat.md)
  for EKS / AKS / GKE instructions.
* The cluster uses flat networking (the default for EKS, AKS, and GKE). Overlay
  networks are supported but only for Service-typed SmartGroups used as the
  destination of DCF rules. See
  [Services, Load Balancing, and Networking](https://kubernetes.io/docs/concepts/services-networking/)
  for background.
## Cloud account discovery permissions
The Aviatrix Controller's cloud account must include the permissions below for
the relevant provider so the controller can discover clusters in the cloud
account.
> [tab] AWS (EKS)
> * `eks:ListClusters`
> * `eks:DescribeCluster`
> * `elasticloadbalancing:DescribeLoadBalancers` (already present in the base set)
> * `elasticloadbalancing:DescribeTags` (already present in the base set)
> For step-by-step IAM setup, see
> [Onboard EKS Clusters](https://docs.aviatrix.com/docs/enterprise/10.1/guides/security/dcf/kubernetes-onboard-eks.md)
> [tab] Azure (AKS)
> **For cluster discovery**
> * `Microsoft.ResourceGraph/resources/read`
> * `Microsoft.ContainerService/managedClusters/read`
> **For onboarding using the Cloud Account (CSP credentials) with Entra ID**
> No additional permissions beyond cluster discovery — the Controller requests its
> own short-lived OAuth2 token instead of retrieving a kubeconfig.
> **For onboarding using the Cloud Account (CSP credentials) with local accounts**
> * `Microsoft.ContainerService/managedClusters/listClusterUserCredential/action`
> > [!NOTE]
> > Starting in Controller 10.1, onboarding via the Cloud Account (Path A)
> > supports Microsoft Entra ID authentication in addition to local accounts. A
> > cluster with Entra ID as its only authentication method cannot use the local
> > accounts option — the Aviatrix Controller does not execute external auth
> > binaries, and the kubeconfig returned by `listClusterUserCredential` for an
> > Entra ID-only cluster relies on `exec` plugins. Use the Entra ID option
> > instead. See&#x20;
> > [Apply Azure RBAC](https://docs.aviatrix.com/docs/enterprise/10.1/guides/platform-administration/account-azure.md)
> [tab] Google Cloud (GKE)
> * `container.clusters.get`
> * `container.clusters.list`
> In-cluster access (namespaces, services, pods, nodes, endpointslices) is granted
> via GCP IAM-to-Kubernetes-RBAC mapping plus the Aviatrix helm chart. See
> [Onboard GKE Clusters](https://docs.aviatrix.com/docs/enterprise/10.1/guides/security/dcf/kubernetes-onboard-gke.md)
## Kubernetes RBAC
The Aviatrix Controller authenticates to your cluster's Kubernetes API and reads
namespaces, services, pods, nodes, and endpoint slices. Permissions are granted
by a single ClusterRole, `avx-controller`, installed by the
[Aviatrix k8s-firewall helm chart](https://github.com/AviatrixSystems/k8s-firewall-charts).
Aviatrix recommends installing the helm chart on every onboarded cluster. It is
the canonical packaging of the Aviatrix CRDs and the `avx-controller`
ClusterRole and ClusterRoleBinding, and it stays aligned with the controller
version. If Helm is not available in your environment, you can render the same
objects with
`helm template k8s-firewall k8s-firewall/k8s-firewall | kubectl apply -f -` and
apply them yourself.
### What the ClusterRole grants
| Permission | Resources | Used for |
| Read | `namespaces`, `services`, `pods`, `nodes`, `endpointslices` | SmartGroup discovery (always required) |
| Read/write | `networking.aviatrix.com/*` | In-cluster `FirewallPolicy` / `WebgroupPolicy` CRDs |
| Create/patch | `events` | Controller status events |
The helm chart installs this ClusterRole regardless of whether you use CRD-based
DCF policy — there is no separate discovery-only manifest. If you cannot use the
helm chart (for example, a custom self-managed cluster without helm), see the
equivalent manifest on the
[Onboard Self-Managed or Custom Clusters](https://docs.aviatrix.com/docs/enterprise/10.1/guides/security/dcf/kubernetes-onboard-custom.md)
page.
CRD-based policy requires the `k8s_dcf_policies` feature flag to be enabled by
Aviatrix. See
[Distributed Cloud Firewall for Kubernetes](https://docs.aviatrix.com/docs/enterprise/10.1/guides/security/dcf/dcf-kubernetes.md)
## Kubeconfig requirements
When onboarding via the kubeconfig path (an alternative to CSP credentials,
supported on every provider), the kubeconfig must:
* Use inline credential data — `certificate-authority-data`, `token`, or
  `client-certificate-data` (base64-encoded). The Controller does not read files
  from the local filesystem.
* Use static credentials. `exec` plugins (such as `aws eks get-token` or AAD
  auth) are not supported.
* Contain a single cluster, user, and context.
* Be sufficient to read namespaces, services, pods, nodes, and endpointslices.
  For CRD-based DCF policy, also read/write `networking.aviatrix.com/*`.
For a worked example see
## Limitations
* Automatic onboarding via the **Kubernetes Clusters** tab supports only
  publicly available clusters. Private clusters are onboarded after establishing
  connectivity. See
* A cluster that does not meet the prerequisites above appears greyed out in the
  SmartGroup creation dialog.
## Next Steps
* [Onboard EKS Clusters](https://docs.aviatrix.com/docs/enterprise/10.1/guides/security/dcf/kubernetes-onboard-eks.md)
* [Onboard AKS Clusters](https://docs.aviatrix.com/docs/enterprise/10.1/guides/security/dcf/kubernetes-onboard-aks.md)
* [Onboard GKE Clusters](https://docs.aviatrix.com/docs/enterprise/10.1/guides/security/dcf/kubernetes-onboard-gke.md)
* [Onboard Self-Managed or Custom Clusters](https://docs.aviatrix.com/docs/enterprise/10.1/guides/security/dcf/kubernetes-onboard-custom.md)
## Related Topics
* [Aviatrix Kubernetes Firewall](https://docs.aviatrix.com/docs/enterprise/10.1/concepts-architectures/components/dcf/kubernetes-overview.md)
* [Distributed Cloud Firewall for Kubernetes](https://docs.aviatrix.com/docs/enterprise/10.1/guides/security/dcf/dcf-kubernetes.md)
* [Disable SNAT for Kubernetes Workloads](https://docs.aviatrix.com/docs/enterprise/10.1/reference/dcf/kubernetes-snat.md)
