# Networks with Overlapping CIDRs Scenarios
> This document describes a few scenarios of overlapping networking CIDRs and their solutions. The solution uses the Mapped option of the Aviatrix Site2Cloud feature when building IPsec tunnels.
<a href={"/docs/enterprise/" + "10.1" + "/guides/connectivity/vpn/s2c-configuration-workflow"}>Site2Cloud</a>
Using Mapped Site2Cloud provides the advantage of not having to configure
individual SNAT/DNAT rules, as all virtual and physical network addresses are
1-1 translated.
This document does not go into specifics of the actual configurations. For this
information, see
<a href={"/docs/enterprise/" + "10.1" + "/guides/connectivity/vpn/overlapping-networks-mapped-ipsec"}>Configuring Overlapping Networks with Network Mapped IPsec</a>
## Scenario 1: On-prem Overlaps with Spoke in Aviatrix Transit Deployment
In this scenario, the Aviatrix Transit solution is deployed, and a resource on
the on-prem site overlaps with a Spoke CIDR it needs to communicate with, as
shown in the diagram below.
<img src="https://mintcdn.com/aviatrix-14b37c43/Gre8pdluiL7JmlpL/images/guides/connectivity/vpn/overlap-onprem-aviatrix-transit.png?fit=max&auto=format&n=Gre8pdluiL7JmlpL&q=85&s=6d60353f14196c1ba795447614d37b3f" alt="Overlap On-Prem Aviatrix Transit" width="1546" height="1076" data-path="images/guides/connectivity/vpn/overlap-onprem-aviatrix-transit.png" />
This scenario is made possible by the *Forward Traffic to Transit Gateway*
option that you can enable after configuring your Site2Cloud connection. See
[Forwarding Traffic to Transit Gateway](https://legacy.docs.aviatrix.com/documentation/latest/network/externaldevice-settings.html#forward-traffic-transit)
for more information.
<a id="scenario4-multisites-overlap-transit-deployment" />
## Scenario 2: Multi-Sites Overlap in Aviatrix Transit Deployment
This scenario extends the previous solution to include multi-sites, as shown in
the diagram below.
Spoke 2 in this scenario is a landing Spoke. When the Site2Cloud Forwarding
option referenced above is enabled, NAT occurs on the landing Spoke and ensures
that bidirectional traffic flow is possible between on-prem routers and local
Spoke and Transit gateways.
Either side can now initiate traffic (locally or remotely), as per what you
configured in your Site2Cloud connection. If you select only one of these, you
cannot initiate from the other direction and NAT translation will not occur.
Enabling the
[Auto Advertise Spoke Site2Cloud CIDRs](https://legacy.docs.aviatrix.com/documentation/latest/network/spoke-gateway-route-settings.html?expand=true#auto-advertise-cidrs)
option (select a Spoke Gateway and select this option from the Settings tab) in
this scenario ensures that the other Spokes in the scenario are aware of the
virtual CIDRs on which the landing Spoke is going to perform NAT (Spoke 2).
If you select this Auto Advertise option ensure that you do not advertise more
than the CSP-allowed limit of routes per route table. For example, for AWS the
routes per route table limit is described
[here](https://docs.aws.amazon.com/vpc/latest/userguide/amazon-vpc-limits.html).
## Scenario 3: On-prem Overlaps with Spoke VPC/VNet in TGW Deployment
In this scenario, on-prem site-1 overlaps with Spoke-1 VPC/VNet CIDR. They are
both 172.32.0.0/16 and want to communicate with each other. The solution is to
deploy an Aviatrix Gateway in Spoke-2 VPC/VNet and build an IPsec tunnel between
Spoke-2 gateway and the on-prem. In the deployment, both Spoke-1 and Spoke-2 are
attached to TGW and are in the same Network Domain.
The diagram shown below illustrates how to use Spoke VPC Advertised Routes to
build a more complex network. You can launch an Aviatrix Gateway in Spoke-1
directly and build the IPsec tunnel.
<Tip>
  VPC Spoke-1 is for illustration purposes. The destination network that overlaps with the on-prem site may be an on-prem network that connects with AWS TGW via AWS Direct Connect or VPN. Similarly, the on-prem network could be a VPC/VNet in the cloud.
</Tip>
<img src="https://mintcdn.com/aviatrix-14b37c43/Gre8pdluiL7JmlpL/images/guides/connectivity/vpn/overlap-onprem-tgw.png?fit=max&auto=format&n=Gre8pdluiL7JmlpL&q=85&s=1df6883afff3817e1c2ff69752ee9f43" alt="Overlap On-Prem TGW" width="1518" height="1078" data-path="images/guides/connectivity/vpn/overlap-onprem-tgw.png" />
Following are the steps to set up the above networks.
1. <a href={"/docs/enterprise/" + "10.1" + "/reference/ui/networking/connectivity#edit-aws-tgw"}>Attach VPC/VNet Spoke-2 to TGW</a>
2. <a href={"/docs/enterprise/" + "10.1" + "/reference/ui/cloud-fabric/gateways#view-spoke-gateways"}>Launch Aviatrix gateway in Spoke-2</a>
   . You can add an instance when creating the Spoke Gateway if you want to use
   HA.
3. Create a
   [Static Route-Based (Mapped) connection](https://legacy.docs.aviatrix.com/documentation/latest/network/external-connection-create-static-route-based-mapped.html)
   from Spoke-2 to Site-1 using these values:
| Parameter               | Value          |
| Local Subnet (real)     | 172.32.0.0/16  |
| Local Subnet (virtual)  | 192.168.0.0/16 |
| Remote Subnet (real)    | 172.32.0.0/16  |
| Remote Subnet (virtual) | 100.100.0.0/16 |
4. Configure the on-premises site-1 IPsec. Key parameters are:
   * Local Subnet: 172.32.0.0/16
   * Remote Subnet: 192.168.0.0/16
   You can
   [download the configuration from step 4](https://legacy.docs.aviatrix.com/documentation/latest/network/external-connection-download-configuration.html)
   to use in the on-prem configuration.
5. Check the tunnel status at Diagnostics > Cloud Routes > External Connections.
6. Advertise 100.100.0.0/16 to TGW from Spoke-2 VPC/VNet:
   1. On the Networking > Connectivity > AWS TGW tab, click the name of your AWS
      TGW.
   2. Click the Attachments sub-tab and then click VPC.
   3. Attach the Spoke VPC you created in Step 2 above and ensure that the
      Customize Spoke VPC Routes field contains 172.34.0.0/100, 100.100.0.0/16
      (where 172.34.0.0/16 is the Spoke-2 VPC/VNet CIDR and 100.100.0.0/16 is
      the virtual network CIDR of on-prem site-1).
7. Test connectivity. From on-prem site-1 to ping an instance in Spoke-1 using
   the Spoke-1 virtual network CIDR with the real host portion of its IP
   address. For example, if the instance in Spoke-1 is 172.32.10.15, then site-1
   should ping 192.168.10.15.
## Scenario 4: Multi-Sites Overlap in TGW Deployment
Scenario 1 can be extended to on-prem multi sites that have overlapping or
identical network addresses, as shown in the diagram below.
<img src="https://mintcdn.com/aviatrix-14b37c43/Gre8pdluiL7JmlpL/images/guides/connectivity/vpn/overlap-multi-onprem-tgw.png?fit=max&auto=format&n=Gre8pdluiL7JmlpL&q=85&s=a376e64fba1415e4c486dd3fc9a5bc40" alt="Overlap Multi On-Prem TGW" width="1464" height="1092" data-path="images/guides/connectivity/vpn/overlap-multi-onprem-tgw.png" />
   HA.
3. Create a
   from Spoke2 to Site-1 using these values:
| Parameter               | Value          |
4. Create an on-premises site-1 to Spoke-2 Gateway IPsec connection with an
   on-premises router or firewall:
   * Route Based VPN
6. Create a
   from Spoke-2 to Site-2 using these values:
| Parameter               | Value          |
| Remote Subnet (virtual) | 100.200.0.0/16 |
7. Create an on-prem site-2 to Spoke-2 gateway IPsec connection with an on-prem
   router or firewall. Key parameters:
   * Route Based VPN
8. Advertise 100.100.0.0/16 100.200.0.0/16 to TGW from Spoke-2 VPC/VNet:
      TGW.
   2. Click the Attachments sub-tab and then click *VPC*.
   3. Attach the Spoke-2 VPC if it is not attached already.
   4. Ensure that the Customize Spoke VPC Routes field contains 172.34.0.0/100,
      100.100.0.0/16, 100.200.0.0/16 (where 172.34.0.0/16 is Spoke-2 VPC/VNet
      CIDR; 100.100.0.0/16 is the virtual network CIDR of on-prem site-1; and
      100.200.0.0/16 is the virtual network CIDR of on-prem site-2).
9. Test connectivity for on-prem site-1 by pinging an instance in Spoke-1 using
10. Test connectivity for on-prem site-2 by pinging an instance in Spoke-1 using
    site-2 should ping 192.168.10.15.
## Solving Overlapping IP Addresses
Real-world use cases sometimes require a combination of
and other features, such as
[SNAT](https://legacy.docs.aviatrix.com/documentation/latest/network/snat-dnat-settings.html)
and
[DNAT](https://legacy.docs.aviatrix.com/documentation/latest/network/snat-dnat-settings.html).
To learn more, see
[Configuring Overlapping Networks with Customized SNAT and DNAT](https://legacy.docs.aviatrix.com/documentation/latest/network/s2c-overlapping-ip.html).
