# Deploy an Edge Spoke Gateway on Megaport Virtual Edge
> This document provides instructions to deploy a primary Edge Spoke Gateway on Megaport Virtual Edge (MVE).
This document provides instructions to deploy a primary Edge Spoke Gateway on <a href={"/docs/enterprise/" + "10.1" +
"/concepts-architectures/components/connectivity/edge-megaport#edge-megaport-platform"}>Megaport
Virtual Edge (MVE)</a>.
For an overview of Aviatrix Edge, see <a href={"/docs/enterprise/" +
"10.1" +
"/concepts-architectures/components/edge-gateways/edge-overview"}>About Aviatrix
Hybrid Cloud Edge</a>.
## Topology
The design below shows a high-level hybrid cloud solution with Aviatrix Edge
leveraging Megaport fabric.
<img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-megaport-topology.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=5a47fef508538626fecca2a97908bb0b" alt="Edge Megaport Topology" width="709" height="445" data-path="images/guides/connectivity/edge/edge-megaport-topology.png" />
## Prerequisites
Before you deploy an Edge Spoke Gateway on the Megaport platform, ensure the <a href={"/docs/enterprise/" + "10.1" +
"/reference/gateways/edge/edge-spoke-transit-planning#megaport"}>prerequisite
steps</a> are complete.
## Deploy the Primary Edge Spoke Gateway (Megaport)
To create and deploy the primary Edge Spoke Gateway in Megaport Virtual Edge
(MVE), perform these steps.
1. [Create the Primary Edge Spoke Gateway ZTP Cloud-Init File (Megaport)](https://legacy.docs.aviatrix.com/documentation/latest/network/edge-spoke-create-megaport.html).
2. [Deploy the Edge Spoke Gateway in MVE using the cloud-init ZTP file](https://legacy.docs.aviatrix.com/documentation/latest/network/edge-vm-create-megaport.html).
3. [Verify the Edge Spoke Gateway creation](https://legacy.docs.aviatrix.com/documentation/latest/network/edge-create-verify.html).
## Next Steps
* For high availability (HA) and redundancy, you can create and deploy HA Edge
  Spoke Gateway. See <a href={"/docs/enterprise/" + "10.1" +
  "/concepts-architectures/architecture/connectivity/edge-spoke-ha"}>Deploy a HA
  Edge Spoke Gateway (Megaport)</a>.
  Spoke Gateway to multiple Aviatrix gateways. See <a href={"/docs/enterprise/" + "10.1" +
  "/guides/connectivity/edge/edge-spoke-attachments"}>Edge Gateway
  Attachments</a>.
* For remote site connectivity, you can connect the Edge Spoke Gateway to remote
  devices. See <a href={"/docs/enterprise/" + "10.1" +
  "/guides/connectivity/edge/edge-s2c-workflow"}>Edge Gateway External
  Connection</a>.
