# Using a Proxy Profile on the Edge Device
> The edge devices supported on the Aviatrix Edge Platform requires egress over the public internet to communicate with the Aviatrix Platform. If internet traffic is routed through a proxy server, you can configure a proxy profile and associate the profile with the edge device.
## Creating a Proxy Profile
To configure a proxy profile, follow these steps.
1. In Aviatrix CoPilot, go to **Cloud Fabric > Hybrid Cloud > Devices** tab.
2. Click **Proxy Profiles**.
3. In Proxy Profiles, click **+ Proxy Profile**, then provide the following
   information.
| **Field** | **Description** |
| Name | A name for the proxy profile. |
| Transparent Mode | If you use a Transparent proxy server, set Transparent Mode toggle to **On**. A Proxy CA Certificate is required when Transparent Mode is On. |
| Proxy Server IP | The IP address of the Proxy server. |
| Port | The port number used for the Proxy server. |
| Proxy CA Certificate | The certificate authority (CA) certificate to use on the edge device. The Proxy CA certificate must be in Privacy Enhanced Mail (PEM) file format. |
4. Click **Save**.
You can now use the proxy profile to configure the Management interface of the
edge device when you onboard the device.
## Modifying or Deleting a Proxy Profile
> [!NOTE]
> If a proxy profile is associated with an edge device, modifying the proxy file
> may result in communication disruptions with the Aviatrix platform.
To modify a proxy profile:
3. In the table, locate the proxy profile you want to edit and click the
   **Edit** icon on the right.
4. Make any changes needed.
5. Click **Save**.
To delete a proxy profile:
3. In the table, locate the proxy profile you want to delete and click the
   **Delete** icon on the right.
   > [!NOTE]
   > The Delete icon is disabled if a proxy profile is associated with any edge
   > device. You must first remove the proxy profile association for the edge
   > devices.
4. To confirm the deletion, click **Delete**.
## Removing a Proxy Profile Association for an Edge Device
To remove a proxy profile association for an edge device:
2. In the table, locate the edge device and click the **Edit** icon on the
   right.
3. Delete the proxy profile associated with the MGMT interface.
4. Click **Save**.
