# Installing Edge OS and Onboarding Dell Hardware
> To deploy an Aviatrix Edge Transit or Spoke Gateway, you must first procure and onboard your edge device onto the Aviatrix Edge Platform.
This following topics provide the prerequisite and deployment steps to install
Aviatrix Edge OS and onboard Dell hardware onto the Aviatrix Edge Platform.
<Tabs>
  <Tab title="Onboarding Dell Hardware">
    <a id="edge-device-prerequisites" />
    This topic provides the instructions to install Edge OS and onboard edge device.
    ## Prerequisites
    The prerequisites to install Edge OS and onboard edge device.
    ### 1. Procure the Edge Device
    If you do not already have your edge device, you need to evaluate the hardware
    that you require for your edge computing and procure the hardware. Contact your
    Aviatrix account manager for the hardware you may require.
    For a list of Aviatrix supported hardware, see <a href={"/docs/enterprise/" +
      "10.1" + "/reference/gateways/edge/edge-hardware-specs"}>Supported Edge
    Hardware for the Aviatrix Edge Platform</a>.
    ### 2. Obtain the Device Serial Number
    Obtain the Serial Number of your edge device. To onboard and register the edge
    device with the Aviatrix Edge platform, you will be required to provide the
    device Serial Number.
    The device Serial Number can be found from the iDRAC. Login to the iDRAC. On the
    Dashboard, look for *System Information/Service Tag*:
    <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-idrac-serial-number.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=c89927685357ccb114c127805fa3a010" alt="edge-idrac-serial-number" width="785" height="472" data-path="images/guides/connectivity/edge/edge-idrac-serial-number.png" />
    ### 3. You must have Aviatrix Controller and CoPilot deployed.
    ### 4. Set Up the Aviatrix Edge Platform Accout
    To onboard and register the edge device onto the platform, you will need to
    create an Aviatrix Edge Platform Account.
    To set up the account, see <a href={"/docs/enterprise/" + "10.1" +
      "/guides/connectivity/edge/edge-platform-account"}>Setting up Accounts for Edge
    Platforms</a>.
    ### 5. Set Up Proxy Profile
    If you are using a Proxy setup, you can configure a proxy profile and associate
    the profile with the edge device. To create a proxy profile, see <a href={"/docs/enterprise/" + "10.1" +
      "/guides/connectivity/edge/edge-proxy-profile"}>Using a Proxy Profile on the
    Edge Device</a>.
    ### 6. Obtain iDRAC, MGMT, WAN, LAN IP Address/Mask, and ASN and LAN Router Details
    1. To Configure iDRAC, iDRAC port requires IPv4 address, its subnet and gateway
       IP information. Refer to
       [Integrated Dell Remote Access Controller 9 User's Guide](https://www.dell.com/support/manuals/en-us/idrac9-lifecycle-controller-v4.x-series/idrac9_4.00.00.00_ug_new/setting-up-idrac-ip-address?guid=guid-23b48a9f-7afe-42e0-8398-ad3bedb82226\&lang=en-us).
    2. MGMT interface is used to establish connectivity to AEP backend. MGMT
       interface can either get DHCP IP address from customer network or can be
       statically configured. MGMT requires IPv4 network, mask and gateway.
    <Note>
      When using static IP on MGMT port, an image file is requried to be downloaded
      from CoPilot and loaded onto the device. Steps are documented in the [Using
      iDRAC Remote Console and ISO](#using-idrac-remote-console-and-iso) and
      [USB](#usb) tabs.
    </Note>
    3. LAN port is used by Edge gateway for connectivity to datacenter on-premises
       devices. The Edge gateway LAN interface requires IPv4 address, subnet length
       and gateway IP (which is the downstream datacenter on-premises router).
    4. WAN port is used by Edge gateway to connect to upstream network over which
       connectivity to Transit in cloud is established. WAN interface on Edge
       gateway requires IPv4 address, subnet length and gateway IP (which is the
    ### 7. Provide Network Access
    The Management Port needs internet access to communicate with the Aviatrix
    Platform.
    Ensure your firewalls allow access to the IP addresses in the *Aviatrix Edge
    Platform access (Edge Gateway deployed on hardware form factors which are
    Aviatrix managed)* table at
    [Aviatrix Products: Required Access for External Sites](https://aviatrix.zendesk.com/hc/en-us/articles/4417312119437-Aviatrix-Products-Required-Access-for-External-Sites)
    on the Aviatrix Customer Support website.
    <a id="edge-os-install" />
    ## Edge OS Installation and Device Onboarding
    The Aviatrix Edge OS can be installed on the Dell hardware using Dell Remote
    Access Controller (iDRAC) and ISO, or using USB.
    Before you install the Edge OS, you need to enable the required BIOS settings on
    the Dell hardware. See <a href={"/docs/enterprise/" + "10.1" +
      "/reference/gateways/edge/edge-device-bios-config"}>Dell PowerEdge BIOS
    Configuration</a>.
    If you prefer to install Edge OS using iDRAC and ISO, follow the instruction in
    [Using iDRAC Remote Console and ISO](#using-idrac-remote-console-and-iso).
    If you prefer to use a USB installer to install Aviatrix Edge OS, follow the
    instructions in [USB](#usb).
  </Tab>
  <Tab title="Using iDRAC Remote Console and ISO">
    This topic provides instructions for installing Aviatrix Edge OS on Dell
    hardware by using iDRAC remote console and ISO.
    <Tip>
      These instructions require that a Dell iDRAC license is applied on the Dell
      server, which would allow the operator to access the server's remote virtual
      console and load virtual media. The license is typically applied at factory by
      Dell, please choose enterprise iDRAC as described in Dell tech specs for
      Aviatrix Edge.
    </Tip>
    <Note>
      This document does not cover user management for Dell iDRAC. You are
      responsible to configure user access on the Dell server. You will need an
      admin user or one with equivalent access to install Aviatrix Edge OS on the
      server.
    </Note>
    ## 1. Prerequisites
    Before you start to onboard and install the Edge OS on the edge device, make
    sure these [prerequisite steps](#edge-device-prerequisites) (in the **Onboarding
    Dell Hardware** tab) are completed.
    ## 2. Onboard Edge Device onto Aviatrix Edge Platform
    1. In Aviatrix CoPilot, go to **Cloud Fabric** > **Hybrid Cloud** >
       **Devices** tab.
    2. Click **Onboard Device**, then provide the following information.
       | Field                | Description        |
       | Name                 | A name to identify the edge device.        |
       | Platform             | The Aviatrix Edge Platform Account where to onboard the device.        |
       | Device Configuration | Dell HW with single ethernet controller for Edge Spoke Gateway, select **DELL Poweredge 1x E810**. Dell HW with two ethernet controllers for Edge Spoke or Transit Gateway, select **DELL Poweredge 2x E810**. |
       | Serial Number        | The serial number of the edge device.        |
    3. Expand **Device Interface Configuration** and configure the device's
       **Function MGMT** (Management) interface.
       1. If you plan to use DHCP for the device Management interface, turn **DHCP**
          toggle to **On**.
       2. If you plan to configure a Static IP address for the device Management
          interface, leave **DHCP** toggle to **Off**.
       3. If **DHCP** is **Off**, enter the Static IP address for the Management
          interface.
          | Interface CIDR | The Static IP address of the Management interface. |
          | Gateway IP     | The Management Default Gateway IP address.         |
          | Primary DNS    | The primary DNS server IP address.                 |
          | Secondary DNS  | (Optional) The secondary DNS server IP address.    |
       4. If you are using a proxy server to route internet traffic, from the
          **Proxy Profile** dropdown menu, select the proxy profile to upload to the
          edge device (see <a href={"/docs/enterprise/" + "10.1" +
          the Edge Device</a>).
    4. Under **Advanced**, specify the Edge Management CIDR that will be used on the
       Edge gateway interface. If a CIDR is not specified, the system auto assigns
       10.100.101.0/24 CIDR range and assigns 10.100.101.2 IP address on the
       interface.
    <Tip>
      If the auto assigned CIDR is used, ensure that this range does not overlap
      with any other network.
    </Tip>
    <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-onboard-mgmt-static-ip.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=b85eb6621f239c60be5cfca359539acd" alt="edge-onboard-mgmt-static-ip.png" width="670" height="690" data-path="images/guides/connectivity/edge/edge-onboard-mgmt-static-ip.png" />
    5. Save the configuration.
       * When DHCP is selected for MGMT interface, click **Save**.
       * When Static IP is selected for MGMT interface, from the **Save and Download
         Config** drop-down menu, click **Save**.
    This will download a **bootstrap-config.img** file (for example,
    3QDDWX3-bootstrap-config.img). Your device will show up as **Provisioned** in
    Copilot.
    <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-onboard-device-provisioned.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=72ca87d0d33af4fad40cb9d964df68f8" alt="edge-onboard-device-provisioned.png" width="3088" height="444" data-path="images/guides/connectivity/edge/edge-onboard-device-provisioned.png" />
    6. If you need to change the management interface's configurations (from DHCP to
       Static or vice versa), you can click Edit icon and update the configuration.
       Save the changes you made to the device.
    <a id="install-os-idrac" />
    ## 3. Install Aviatrix Edge OS on the Edge Device
    Install Aviatrix Edge OS on the edge device.
    1. Obtain the latest **iso** file published by Aviatrix from the
       [Aviatrix Support site](https://support.aviatrix.com/downloads).
    2. Download the latest, **production** Aviatrix Edge OS **.iso** file to a
       jumphost which is in the same network as the Dell server. The jumphost
       enables a fast upload of the ISO file to the server as compared to getting it
       over the internet. If the server has fast internet access, you can mount the
       ISO file from your laptop.
    <Tip>
      If the ISO file is fetched over the internet and if the download speed is
      poor, it may increase the overall installation time. It is recommended that
      the file be downloaded to a laptop/jumphost in the same network as the server.
    </Tip>
    3. From the jumphost, login to the Dell server's iDRAC UI.
           <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-idrac-ui.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=07971f7ef74c2e4171cea7af867d6590" alt="edge-idrac-ui.png" width="3536" height="2074" data-path="images/guides/connectivity/edge/edge-idrac-ui.png" />
    4. Open the Virtual Console to the server. On the Virtual Console window, click
       **Virtual Media** > **Connect Virtual Media** > **Connect Virtual
       Media**. Virtual Media should show up as connected.
           <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-idrac-virtual-console1.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=051525faac53f76c0cc28539b79aee7e" alt="edge-idrac-virtual-console1.png" width="1602" height="1390" data-path="images/guides/connectivity/edge/edge-idrac-virtual-console1.png" />
    5. Under **Map CD/DVD**, choose the Edge OS ISO file and click **Map Device**.
       Under **Map Removable Disk**, select the **bootstrap-config.img** file and
       again click **Map Device**. The removable disk is a virtual USB.
    <Note>
      If you selected DHCP for the device's management interface, you do not need to
      map a file to the removable disk. You only need the Edge OS ISO file.
    </Note>
    Your virtual media dialog box should look like this:
    <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-idrac-virtual-console2.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=2d56ed18e0b7cf2005dc190eb87fe6d9" alt="edge-idrac-virtual-console2.png" width="1604" height="1366" data-path="images/guides/connectivity/edge/edge-idrac-virtual-console2.png" />
    Close this dialog box.
    6. From the Virtual Console, click **Boot** and under **Boot Controls**, and
       select **Virtual CD/DVD/ISO**. A dialog box will open, asking you to confirm
       the boot action. Click **Yes**.
           <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-idrac-virtual-console3.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=e13ac040221a08a065d20bcb00064fc2" alt="edge-idrac-virtual-console3.png" width="2850" height="1430" data-path="images/guides/connectivity/edge/edge-idrac-virtual-console3.png" />
    7. From the Virtual Console, click **Power** and select the **Reset System (warm
       boot)** option. This will start the installation of Aviatrix Edge OS (AEP
       EvE) on the server.
    <Warning>Do not close the Virtual console window.</Warning>
    <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-idrac-virtual-console4.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=7a90aec3e7e4333f783d60eb434bb886" alt="edge-idrac-virtual-console4.png" width="3574" height="2234" data-path="images/guides/connectivity/edge/edge-idrac-virtual-console4.png" />
    <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-idrac-virtual-console5.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=cf15ade9463606e314a98575f3eca39d" alt="edge-idrac-virtual-console5.png" width="3584" height="2240" data-path="images/guides/connectivity/edge/edge-idrac-virtual-console5.png" />
    8. If you have SSH access to the iDRAC, you can SSH to it and type **console
       com2**. This will connect you to the serial console of the server and you
       will see the Aviatrix Edge OS (AEP EvE) installation logs.
           <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-idrac-install-log1.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=bfcd9cb67483ff025acbbed0db62c8dc" alt="edge-idrac-install-log1.png" width="1738" height="1280" data-path="images/guides/connectivity/edge/edge-idrac-install-log1.png" />
    9. The installation typically takes 10 to 15 minutes. It may vary depending on
       where the ISO file is being uploaded to the server via the Virtual Console.
    Once the installation is complete, the server will automatically power down.
    This can also be confirmed from the EvE installation logs in the serial console.
    <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-idrac-install-log2.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=856d37db74c8e1d860e4943e624e860a" alt="edge-idrac-install-log2.png" width="1742" height="756" data-path="images/guides/connectivity/edge/edge-idrac-install-log2.png" />
    <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-idrac-power-off.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=1017f8d9da9b6991548b3c22f9cdf305" alt="edge-idrac-power-off.png" width="3302" height="2238" data-path="images/guides/connectivity/edge/edge-idrac-power-off.png" />
    10. From the Virtual Console, go to **Virtual Media** and under **Map CD/DVD**,
        click **Un-Map Device**. Confirm the un-map action by clicking **Yes**. This
        will remove the ISO file from the Virtual Console.
    If you had mapped a **bootstrap-config.img** file to the removable disk/virtual
    USB, keep it as is. We will configure the server's management interface with the
    static IP information in this virtual USB.
    <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-idrac-virtual-console6.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=346a88e761dab87d808e776d3870fea5" alt="edge-idrac-virtual-console6.png" width="1602" height="1372" data-path="images/guides/connectivity/edge/edge-idrac-virtual-console6.png" />
    Click **Close** to save the changes.
    11. From the Virtual Console, go to **Power**. You will see only one option this
        time, **Power On System**. Confirm the power action by clicking on **Yes**.
            <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-idrac-power-on1.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=e3da90cb647e645a94fe3ebb479beedd" alt="edge-idrac-power-on1.png" width="2916" height="614" data-path="images/guides/connectivity/edge/edge-idrac-power-on1.png" />
    12. Allow the server to power on. It will boot AEP EvE.
            <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-idrac-power-on2.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=c410aca24c91107be864b0c57cc4024d" alt="edge-idrac-power-on2.png" width="2778" height="1288" data-path="images/guides/connectivity/edge/edge-idrac-power-on2.png" />
    13. If you have access to the server's serial console, you will see the boot
        logs. Aviatrix Edge OS will read the static IP configuration from the
        virtual USB and configure it on the server. The server will dial out to AEP
        (controller.edge.aviatrix.com) and connect to it. Look for logs (the actual
        log text may vary) with these entries:
    * **PASS: port eth0 fully connected to EV controller
      controller.edge.aviatrix.com**
    * **1 out of 4 ports specified to have EV controller connectivity passed test**
    <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-idrac-boot-log1.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=e8571f5526f57c9439678a0cf4eac479" alt="edge-idrac-boot-log1.png" width="1296" height="416" data-path="images/guides/connectivity/edge/edge-idrac-boot-log1.png" />
    <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-idrac-boot-log2.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=d402c6f4c8ef080041bec201680c1106" alt="edge-idrac-boot-log2.png" width="1360" height="1000" data-path="images/guides/connectivity/edge/edge-idrac-boot-log2.png" />
    14. The Dell device will show up as **Connected** in **Copilot (go to Cloud
        Fabric** > **Hybrid Cloud** > **Devices)** and can now be used to
        launch an Edge gateway. For details on how to launch an Edge Transit or Edge
        Spoke Gateway, see
        [Hybrid Cloud Connectivity](https://legacy.docs.aviatrix.com/documentation/latest/network/edge-connectivity.html).
            <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-device-connected.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=954ef3364f1e3cfd85ff9b0717389666" alt="edge-device-connected.png" width="3582" height="806" data-path="images/guides/connectivity/edge/edge-device-connected.png" />
    15. Return to the Virtual Console, go to **Virtual Media** > **Disconnect
        Virtual Media**. Click **Yes**. This will unmap and disconnect all virtual
        media files. Close the virtual media box. You can now also close the Virtual
        Console.
    AEP EvE installation is complete and it will persist across server reboots.
  </Tab>
  <Tab title="USB">
    This topic provides instructions for installing the Aviatrix Edge OS on Dell
    hardware using USB.
    If you use iDRAC with virtual media to install Edge OS, we recommend using the
    remote console to configure a static IP on the device. See the
    [Using iDRAC Remote Console and ISO](#using-idrac-remote-console-and-iso) tab.
    ## 1. Prerequisites
    * Before you start to onboard and install the Edge OS on the edge device, make
      **Onboarding Dell Hardware** tab) are completed.
    * Download and install a software on your laptop which you can use to Flash an
      OS to a USB drive or SD card, like
      [balenaEtcher - Flash OS images to SD cards & USB drives](https://etcher.balena.io/).
    ## 2. Prepare a USB Installer with Aviatrix Edge OS
    Prepare a USB installer with Aviatrix Edge OS.
    1. Download the latest Aviatrix Edge OS from
       [Aviatrix Support](https://support.aviatrix.com/downloads).
    2. Connect a USB drive to a laptop.
    3. Open Balena Etcher
       1. Select the Aviatrix Edge OS image
       2. Select the USB drive
       3. Flash
    The USB installer is ready to use.
    ## 3. Onboard Edge Device onto Aviatrix Edge Platform
    Onboard the edge device onto the Aviatrix Edge Platform.
       **Devices** tab.
          toggle to **On**.
          interface.
       4. If you are using a proxy server to route internet traffic, from **Proxy
          Profile** dropdown menu, select the profile to upload to the edge device.
       interface.
    <Tip>
    </Tip>
    Copilot.
    6. Connect a USB drive to your laptop.
    <Tip>
      This USB drive should be different from the one which was Flashed with the
      Aviatrix Edge OS image.
    </Tip>
    7. Open Balena Etcher.
       1. Select the device's **bootstrap-config.img** image file.
       2. Select the USB drive.
       3. Flash
    ## 4. Installing Aviatrix Edge OS with a USB Installer
    Install Aviatrix Edge OS on the edge Device using the USB installer.
    <Note>
      This procedure is based on Aviatrix OS installer on a USB drive. When we have
      iDRAC license to enable virtual media functions, we can use an ISO installer
      file over a network (see the **Using iDRAC Remote Console and ISO** tab).
    </Note>
    1. Connect VGA/serial and keyboard to Dell server, and power it on.
    2. From the Dell server's VGA/serial console, from **iDRAC Settings** >
       **Network** to setup iDRAC with Static IP address or desired IP address
       settings, apply the new settings and then reboot the system.
           <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-usb-idrac-settings.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=5347e8f4a48d97a90133fe52a7c04e7e" alt="edge-usb-idrac-settings.png" width="1138" height="856" data-path="images/guides/connectivity/edge/edge-usb-idrac-settings.png" />
    3. Identify the Dell server's face panel with dual USB ports and plug in
       Aviatrix OS installer USB disk to the USB port labeled with **SS**; then
       browse to iDRAC's IP address to login to the iDRAC UI with default
       credentials, which can be found from the Dell service tag label.
    <Tip>Do not reset the root password when prompted to do so.</Tip>
    <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-usb-idrac-login.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=e21055d3fceec02b57976b706db720a6" alt="edge-usb-idrac-login.png" width="2578" height="1500" data-path="images/guides/connectivity/edge/edge-usb-idrac-login.png" />
    4. After you login to iDRAC UI, go to **IDRAC Settings** > **Users** add a
       default login user account.
           <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-usb-idrac-user-settings.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=c08ec1e7fd9aec3303f680ac724f3afc" alt="edge-usb-idrac-user-settings.png" width="1914" height="574" data-path="images/guides/connectivity/edge/edge-usb-idrac-user-settings.png" />
    5. From iDRAC9 UI **Configuration** > **BIOS Settings**, follow Aviatrix's
       recommended BIOS configuration in <a href={"/docs/enterprise/" +
       "10.1" + "/reference/gateways/edge/edge-device-bios-config"}>Dell
       PowerEdge BIOS Configuration</a>.
    Apply BIOS setting changes, go to the bottom of the page and click **Apply AND
    Reboot** and **OK**.
    <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-usb-bios-config.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=6c2435a71875cb6ce59a35e1abb5cc4f" alt="edge-usb-bios-config.png" width="3414" height="1756" data-path="images/guides/connectivity/edge/edge-usb-bios-config.png" />
    6. Go to **Maintenance** > **Job Queue**, you can see current Job queue and
       task status.
           <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-usb-idrac-maintenance.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=b9406ce02c7dc5345ea2b15055d1be2c" alt="edge-usb-idrac-maintenance.png" width="3438" height="868" data-path="images/guides/connectivity/edge/edge-usb-idrac-maintenance.png" />
    7. Login to iDRAC9 console using SSH.
    ```bash theme={null}
    ssh admin@idrac9_mgmt_ip
    and issue the following command to enter Eve device console:
    console com2
    <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-usb-idrac-ssh-console.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=cd5b581bbd701731f7e3b17b86413c0c" alt="edge-usb-idrac-ssh-console.png" width="1022" height="304" data-path="images/guides/connectivity/edge/edge-usb-idrac-ssh-console.png" />
    Wait 5 to 10 minutes until the installation is done and you should see the log
    below log from iDRAC9 console.
    <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-usb-idrac-install-log.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=4feb4e2cc95cf41b9f539576b93d4c76" alt="edge-usb-idrac-install-log.png" width="1556" height="384" data-path="images/guides/connectivity/edge/edge-usb-idrac-install-log.png" />
    8. Detach the USB installer from the Dell R450 and power it on from
       **Configuration** > **Power Management**, from **Power Control** dropdown,
       choose **Power On System** and click **Apply**.
           <img src="https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/edge-usb-idrac-power-on.png?fit=max&auto=format&n=DtLW-mqMRi95qZN9&q=85&s=8cdf9048b1b3ae746a12c7552d800fe4" alt="edge-usb-idrac-power-on.png" width="2210" height="740" data-path="images/guides/connectivity/edge/edge-usb-idrac-power-on.png" />
    Wait 5 to 10 minutes while Aviatrix OS boots up.
    9. The device will power off once the installation is done. At this stage,
       connect the USB drive which has the static IP information to the device and
       power on the device. Aviatrix Edge OS will read the static IP information
       from the USB and configure the device. To view the configuration logs, you
       can SSH to the device and connect to the serial console.
    <Note>
      If you power on the device without inserting the USB drive which has the
      static IP information, you can do it at a later time. Connect the USB to the
      device and reset the system (warm boot). Aviatrix Edge OS will read the
      information from the USB and configure the device.
    </Note>
    10. After the static IP is configured, the device should be able to dial out to
        AEP (controller.edge.aviatrix.com) and register with the service. The device
        should show up as **Connected** in CoPilot and can now be used to launch an
        Edge gateway. For details on how to launch an Edge Transit or Edge Spoke
        Gateway, see
  </Tab>
</Tabs>
