# Edge Transit Gateway External Connection
> Many enterprises today use cloud adjacent and on-premises data center locations for connecting various remote sites and partners. The ability to seamlessly build a secure network fabric to cloud and remote sites and deploy segmentation controls to meet agility and business zero trust...
controls to meet agility and business zero trust architecture is increasingly
vital for customers with workloads that span multiple locations.
## What is Edge Transit Gateway External Connection?
Aviatrix Edge Transit Gateway external connection site-to-cloud (S2C) allows
enterprises to build secure connectivity across non-CSP locations and build
networks that address segmentation and IP address overlapping for M\&A
deployments. You can leverage Edge Transit Gateway external connection to land
VPN connections from on-premises, datacenters (DCs), and network provider
locations, such as Equinix and Megaport, in a simple and secure way to protect
workload following Zero Trust Network Access (ZTNA) principles.
Aviatrix Edge Transit Gateway external connection (S2C) provides these key
benefits:
* **Simplified Deployment**: Build secure tunnels seamlessly from any
  on-premises, datacenter, and network provider locations such as Equinix and
  Megaport.
* **Scalability**: Single Edge Transit Gateway can support multiple external
  connections.
* **Security**: Build segmentation for tunnels to protect and secure hybrid and
  partner connectivity.
* **Automated Network Address Translation (NAT)**: Simplifies NAT policy
  configuration, making it easier to manage overlapping IP addresses improving
  network integration and communication.
* **Overlapping IPs**: Solves IP address overlapping challenges with NAT on Edge
  Transit Gateway tunnels. This helps with M\&A onboarding and rapid time to
  value all while securing the networks.
* **On-Premises Device Compatibility**: The solution seamlessly interoperates
  with various on-premises devices, supporting different encryption algorithms
  and configurations, especialy beneficial for SaaS providers connecting with
  diverse customer equipment.
* **High Availability and Redundancy**: Support for dynamically rerouting
  traffic to backup gateways if the primary tunnel experiences downtime.
* **Visibility and Troubleshooting**: Aviatrix provides detailed insights and
  diagnostic tools, aiding in effective troubleshooting and network management.
## How does Edge Transit Gateway External Connection work?
Aviatrix's Edge Transit Gateway establishes encrypted connections to partner,
remote sites, and external networks, facilitating secure data transfer over the
internet or over private networks.
The Edge Transit Gateway supports BGP over IPsec, BGP over GRE, and BGP over LAN
connections. It runs a BGP session to an external device, such as a remote
router or firewall to dynamically exchange routes. The remote endpoints can be
active-mesh or standalone devices. The gateway uses the tunneling protocol to
build a tunnel to the external device for packet forwarding.
## How do you create Edge Transit Gateway External Connection?
Aviatrix Edge Transit Gateway external connection (S2C) can be created in:
* Appliance form factor on the Aviatrix Edge Platform (AEP)
* Equinix
* Megaport
For more information, see <a href={"/docs/enterprise/" + "10.1" +
"/guides/connectivity/edge/edge-s2c-workflow"}>Edge Transit Gateway External
Connection Workflow</a>.
## Design Examples
**Connect remote sites and on-premises datacenter to cloud**
The following architecture shows Edge Transit Gateway external connection (S2C)
to connect remote offices and on-premises datacenter to cloud workloads.
<img src="https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-transit-s2c1.png?fit=max&auto=format&n=8iF92JcVck-Y3RaJ&q=85&s=1434951e35939e5b91636d27fc450b5d" alt="Edge Transit Gateway external connection connecting remote offices and on-premises datacenter to cloud workloads" width="942" height="582" data-path="images/concepts-architectures/architecture/connectivity/edge-transit-s2c1.png" />
**Edge Transit Gateway External Connection in Megaport**
The following diagram shows Edge Transit Gateway external connection (S2C) to
connect a customer network at DC or in another MVE to cloud.
<img src="https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-transit-s2c2.png?fit=max&auto=format&n=8iF92JcVck-Y3RaJ&q=85&s=50a574b16338c1998d311b287c4fbcf2" alt="Edge Transit Gateway external connection in Megaport connecting customer network to cloud" width="534" height="258" data-path="images/concepts-architectures/architecture/connectivity/edge-transit-s2c2.png" />
The diagram shows:
* Edge Transit Gateway external IPsec connection to a remote customer network.
* Edge Transit Gateway external IPsec connection to SDWAN.
**Edge Transit Gateway External Connection for Peering Between Edges**
The following diagram shows two Transit Edge Gateways deployed in two Megaport
locations to peer between edges.
<img src="https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-transit-s2c3.png?fit=max&auto=format&n=8iF92JcVck-Y3RaJ&q=85&s=9a5af6331ebfab7484cbe1c4ce1be41b" alt="Two Transit Edge Gateways deployed in Megaport locations peering between edges" width="578" height="314" data-path="images/concepts-architectures/architecture/connectivity/edge-transit-s2c3.png" />
The diagram shows:
* Edge Transit Gateway external connection to another MVE via SDWAN device.
* Edge Transit Gateway could also have an external connection to a remote
  network over internet.
Edge Transit Gateway external connection (S2C) simplifies building end-to-end
secure network and enables setting up segmentation for different connections for
Zero Trust Network Access (ZTNA).
