# Customized SNAT and DNAT on Edge
> The Aviatrix Hybrid Cloud Edge solution supports customized SNAT and DNAT for the use case where the cloud service provider (CSP) network CIDR overlaps with the on-premises network CIDR. The customized SNAT and DNAT apply to HPE-enabled and HPE-disabled Edge Spoke gateways.
* Single IP and Customized SNAT on Edge Spoke Gateway - For network traffic
  initiated from the edge location towards the CSP.
* DNAT on Edge Spoke Gateway - For network traffic initiated from the edge
  location towards Transit Gateway in cloud or CSP.
<Note>
  Customized SNAT on Edge Spoke Gateway is not supported when VLAN segmentation
  is also configured in the same network domain.
</Note>
This diagram shows overlapping CSP and on-premises network CIDRs.
<img src="https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-snat-dnat.png?fit=max&auto=format&n=8iF92JcVck-Y3RaJ&q=85&s=2d0902413cc8a64e1796a0a622d65bed" alt="Diagram showing overlapping CSP and on-premises network CIDRs with SNAT and DNAT on Edge" width="425" height="598" data-path="images/concepts-architectures/architecture/connectivity/edge-snat-dnat.png" />
In this example, to resolve the overlapping CIDR issue, you would perform these
steps:
1. Create a mapping of the Real CIDR to Virtual CIDR for both the cloud
   instances and on-premises hosts or workloads. For example:
| **Network**      | **Real CIDR** | **Virtual CIDR** |
| Cloud workload   | 10.3.0.86/32  | 10.203.0.86/32   |
| On-prem workload | 10.3.0.85/32  | 10.103.0.85/32   |
2. Configure DNAT on Edge Spoke Gateway for traffic initiated from on-premises
   to cloud.
   a. In Aviatrix CoPilot, go to **Cloud Fabric > Hybrid Cloud > Edge Gateways**
   tab. b. Click **Spoke Gateways** c. Select the Edge Spoke Gateway for which
   you want to enable DNAT. d. In the Edge Spoke Gateway's **Settings** tab,
   expand the **Network Address Translation (NAT)** section. e. Set the
   **Destination NAT** toggle to **On**. f. In **Destination NAT**, from the
   **Instance** dropdown menu, select the Edge Spoke Gateway. g. Click **+
   Rule** and provide the following information.
| **Field**  | **Description**        |
| Instance   | From the dropdown list, select the Edge Gateway instance.                                           |
| Src CIDR   | Enter 10.3.0.85/32.        |
| Dst CIDR   | Enter 10.203.0.86/32 (the virtual IP of the cloud instance).                                        |
| Connection | From the dropdown list, select the connection which reflects the connection to the Transit Gateway. |
| Mark       | (Optional) Enter a unique value. Value should be between 65535 - 99999.                             |
| DNAT IP    | Enter 10.3.0.86 (cloud instance).        |
3. Configure a Manual BGP Advertised CIDR List to advertise the DNAT virtual IP
   from the Edge Spoke Gateway to on-premises via BGP. a. In the Edge Spoke
   Gateway's **Settings** tab, expand the **Border Gateway Protocol (BGP)**
   section. b. In **Manual BGP Advertised CIDR List**, enter the following
   information.
| Advertised CIDRs (Per Gateway)    | Leave this blank.                                                      |
| Connection                        | From the dropdown menu, select the connection to the on-prem BGP peer. |
| Advertised CIDRs (Per Connection) | Enter 10.203.0.86/32 (the virtual IP of the cloud instance)            |
4. Configure SNAT on the Edge Spoke Gateway for traffic initiated from cloud to
   on-premises. a. In the Edge Gateway's **Settings** tab, expand the **Network
   Address Translation (NAT) section**. b. Click the **Source NAT** switch to
   **On**, then click **Customized SNAT**. c. From the **Instance** dropdown
   menu, select the Edge Spoke Gateway. d. Click **+ Rule** and provide the
| Connection | Select the output connection where the rule will apply.                                                       |
| Mark       | Enter the value that was defined in the DNAT settings.<br /><br />Specifies a TCP session where rule applies. |
| SNAT IP    | Enter 10.103.0.85 (virtual IP of the on-prem host).                                                           |
