# AZ Affinity and Symmetric Routing Architecture
> How Aviatrix combines AZ-aware nexthop selection with per-spoke symmetric routing to cut cross-AZ costs and enable east-west inspection in AWS.
## Overview
In an Aviatrix ActiveMesh fabric, every healthy gateway instance in a spoke or
transit gateway group is an equally eligible next hop, regardless of which
Availability Zone (AZ) it runs in. In AWS, that design has two costs: AWS bills
for every crossing of an AZ boundary, and each crossing adds latency that
compounds across a multi-hop inspection path such as
spoke-transit-firewall-spoke. It also blocks east-west Layer 7 inspection
features, which require the forward and return leg of a flow to traverse the
same gateway pair. AZ affinity and per-spoke-group symmetric routing solve both
problems together: AZ affinity biases next-hop selection toward the local AZ to
reduce cross-AZ charges and latency, and symmetric routing pins a spoke subnet's
forward and return traffic to a single spoke gateway instance so that a stateful
inspection function running on that spoke gateway sees a complete view of every
flow. Use this architecture when you run Aviatrix spokes and transits in AWS
across multiple Availability Zones and need to control cross-AZ cost or latency,
or to enable east-west inspection.
<Note>
  In Controller 10.1, AZ affinity and symmetric routing are supported for AWS
  only, and are not supported on spokes or transits attached to FireNet.
</Note>
## Architecture Diagram
The diagram below shows the topology this architecture assumes: one spoke
gateway instance and one transit gateway instance per Availability Zone, with AZ
affinity biasing the spoke-to-transit and transit-to-spoke paths toward the
local AZ, and symmetric routing pinning a spoke subnet's traffic to a single
owning gateway instance for both directions.
<img src="https://mintcdn.com/aviatrix-14b37c43/0cJ6mdcM_TcZxo37/images/concepts-architectures/architecture/connectivity/az-affinity-symmetric-routing.svg?fit=max&auto=format&n=0cJ6mdcM_TcZxo37&q=85&s=d235650db788402cb49d4c4b437440f9" alt="Spoke and transit gateway instances deployed across two Availability Zones, showing the same-AZ next hop preferred between each spoke and transit instance and the cross-AZ next hop used only as a fallback" width="1100" height="780" data-path="images/concepts-architectures/architecture/connectivity/az-affinity-symmetric-routing.svg" />
Each spoke subnet is "owned" by exactly one gateway instance for both outbound
and inbound traffic. Traffic from a spoke instance to the transit group prefers
the transit instance in the same AZ; traffic back from the transit group to the
spoke prefers the owning instance's AZ. Either direction falls back to a healthy
instance in the other AZ when no same-AZ instance is available. AZ affinity
never reduces availability: it only changes which healthy instance is preferred.
## Design Principles
### AZ-Local Preference, Not AZ-Only Enforcement
AZ affinity biases next-hop selection toward the same-AZ gateway instance rather
than restricting traffic to that AZ. When the local-AZ instance is unavailable,
routing falls back to a healthy instance in another AZ, so the cost and latency
optimization never comes at the expense of high availability.
### Deterministic Flow Symmetry Over Load Distribution
Per-spoke-group symmetric routing assigns each subnet's outbound and inbound
traffic to a single, consistent gateway instance instead of distributing it
across the whole gateway group. This sacrifices some load-spreading in exchange
for the connection-state guarantee that stateful east-west inspection depends
on.
### Cloud-Native Enforcement
The architecture uses the standard AWS per-subnet route table association and
gateway route-metric mechanisms already available in the platform. It does not
introduce new infrastructure, so enabling it does not require new components or
a different deployment topology.
### Attachment-Scoped, Opt-In Control
AZ affinity is enabled independently on each spoke-to-transit or
transit-to-transit attachment rather than globally. You can adopt it selectively
on the attachments where cost, latency, or inspection consistency matters most,
and leave others on default ActiveMesh behavior.
## Components
This architecture combines the following Aviatrix components:
* <a href={"/docs/enterprise/" + "10.1" + "/concepts-architectures/components/connectivity/activemesh-about"}>ActiveMesh</a>
  : the next-hop selection and packet-forwarding engine that AZ affinity extends
  with an AZ-local preference tier.
* <a href={"/docs/enterprise/" + "10.1" + "/reference/ui/cloud-fabric/gateways"}>Spoke and Transit Gateways</a>
  : the gateway instances between which AZ affinity and symmetric routing
  operate. The toggle is configured on the spoke-transit or transit-transit
  attachment.
* <a href={"/docs/enterprise/" + "10.1" + "/concepts-architectures/components/dcf/webgroups-about"}>WebGroups</a>
  : a Distributed Cloud Firewall policy construct whose east-west enforcement
  depends on symmetric routing for a consistent, bidirectional view of each
  flow.
* <a href={"/docs/enterprise/" + "10.1" + "/guides/security/dcf/ips"}>
    East-West IDS/IPS
  </a>
  : intrusion detection and prevention for east-west traffic. Like WebGroups
  enforcement, it requires symmetric routing to track connection state
  correctly.
## Traffic Flows
### Spoke to Transit (Outbound)
A workload in a spoke subnet sends traffic toward the transit gateway group. The
spoke gateway instance handling that subnet prefers a transit gateway instance
in its own Availability Zone. If no healthy instance is available in the same
AZ, it falls back to a healthy instance in another AZ.
### Transit to Spoke (Return)
Return traffic from the transit group back to the spoke prefers the spoke
gateway instance that owns the destination subnet, in the same Availability Zone
as that instance. If no same-AZ transit instance is available, traffic is
load-balanced across the remaining healthy instances.
### Transit to Transit (Peered Domains)
When two transit gateway groups are peered (for example, across regions or
Aviatrix domains), AZ affinity applies the same same-AZ preference to traffic
crossing that peering. This applies independently of whether AZ affinity is also
enabled on the spoke attachments behind either transit.
### Symmetric Routing Pins the Subnet's Owner
Independently of AZ affinity, per-spoke-group symmetric routing associates each
spoke subnet's route table with a single gateway instance. That instance handles
both the outbound leg and the inbound leg of every flow originating from or
destined to that subnet, so a stateful inspection function on the spoke gateway
always sees both directions of the flow.
## Variants and Trade-offs
| Decision                     | Option A                                          | Option B                                        | When to choose B        |
| AZ affinity on an attachment | Disabled (default ActiveMesh behavior)            | Enabled                                         | Traffic on that attachment crosses AZ boundaries often enough that transfer cost or latency matters, or the attachment carries traffic that requires east-west inspection |
| Scope of enablement          | Enable on every attachment                        | Enable per attachment selectively               | Only some attachments (for example, the ones carrying inspected traffic) need the cost, latency, or symmetry benefit                                                      |
| Gateway topology             | One gateway instance per AZ per group (supported) | More than one gateway instance per AZ per group | Not applicable: this topology is not supported by AZ affinity or symmetric routing in Controller 10.1        |
<Note>
  Enabling AZ affinity limits Equal-Cost Multi-Path (ECMP) load-sharing across
  all gateway instances in the group, because traffic is biased toward a single
  same-AZ instance instead of being spread across every healthy instance. This
  can reduce aggregate bandwidth across the group. Weigh this against the
  cross-AZ cost and latency reduction before enabling AZ affinity on a
  high-throughput attachment.
</Note>
## Sizing and Scale Considerations
AZ affinity and symmetric routing do not introduce scale limits beyond the
existing per-attachment and per-route-table limits of the underlying platform.
The one structural constraint is topological, not numeric: the model supports at
most one gateway instance per Availability Zone in a given spoke or transit
gateway group. Deployments using one gateway instance per Availability Zone do
not need to resize or restructure their gateway groups to adopt AZ affinity or
symmetric routing.
CoPilot includes built-in capability audits for both AZ affinity and symmetric
routing. Each audit checks whether a spoke's VPC route tables and subnets are
structured correctly for the corresponding feature, and reports any
configuration gaps before you enable it in production.
## Security Considerations
Symmetric routing is a prerequisite for any east-west Layer 7 inspection feature
that depends on connection state, including east-west IDS/IPS and
WebGroups-based policies. It guarantees flow-level symmetry at the spoke gateway
only: the same spoke gateway instance always sees both the forward and return
leg of a given flow. It does not guarantee that the same transit gateway
instance is used in both directions. If symmetric routing is not enabled on a
spoke's transit attachment, ActiveMesh can resolve the forward and return legs
of the same flow to different spoke gateway instances. When that happens,
neither instance sees the complete flow, and a stateful inspection function
running on the spoke gateway loses visibility into part of the connection.
Traffic that is expected to be inspected can pass with incomplete coverage.
AZ affinity itself is a routing cost and latency optimization and has no direct
security property. Because it changes which gateway instance a flow's traffic is
likely to traverse, review any per-gateway logging, monitoring, or compliance
controls to confirm they account for AZ-local traffic patterns once AZ affinity
is enabled.
## Limitations
* AWS only. AZ affinity and symmetric routing are supported for AWS spokes and
  transits in Controller 10.1. AZ affinity is primarily an AWS cost
  optimization; symmetric routing's underlying design is cloud-agnostic, but
  only AWS is supported in this release. Other cloud providers are not covered
  by this architecture.
* High Performance Encryption required. Both gateways in the attachment or
  peering must have High Performance Encryption enabled to use AZ affinity.
* Not supported with FireNet. AZ affinity and symmetric routing are not
  supported on spokes or transits attached to FireNet in Controller 10.1.
* One gateway instance per AZ per group. The model assumes exactly one gateway
  instance per Availability Zone in a spoke or transit gateway group. Topologies
  with more than one instance per AZ per group are not supported.
## Related Resources
  : configure the AZ affinity toggle on a spoke-transit or transit-transit
  attachment.
    East-West IDS/IPS
  </a>
  : configuration guide for the inspection feature that requires symmetric
  routing.
