# Automate Security Operations Through Policy as Code
> How Aviatrix lets security teams manage policy as code and query operations in natural language, covering the business case and key components.
Ticket-driven security cannot keep pace with infrastructure that teams deploy
through pipelines. Aviatrix lets you manage policy as code, record who changed
what, and answer operational questions through an AI assistant, so security
operations scale with the estate instead of with headcount.
## Business Challenge
When a firewall change needs a ticket, security becomes the bottleneck and teams
route around it. When many teams edit one policy, changes collide and no one can
say who changed a rule or why. Analysts also spend time translating a question
such as "which workloads can reach this database?" into console clicks and
exports.
## The Business Case for Security Automation
### Risk Mitigation
* **Reviewed changes.** Teams review, test, and approve rule changes in a
  pipeline before they reach production.
* **An audit trail.** You can see who changed which policy object and when.
* **Unsafe rules rejected.** Admission policy engines can block a Kubernetes
  rule that is too broad before it takes effect.
* **Evidence for change control.** An auditor can follow a change from request
  to rollout.
### Operational Efficiency
* **Safe delegation.** Multiple teams manage their own policy sections without
  overwriting each other.
* **Policy next to the workload.** Application teams declare egress rules
  alongside their deployments instead of filing a ticket.
* **Faster answers.** Engineers and agents query Aviatrix data through the
  Aviatrix MCP server instead of navigating the console.
### Strategic Value
* **Repeatable onboarding.** New accounts, clusters, and teams adopt policy
  through the same pipelines and Terraform modules, so growth does not add a
  ticket queue for the security team.
* **Fewer workarounds.** Teams that can change policy through their pipeline do
  not route around security.
## How Aviatrix Addresses Operational Scale
Teams write policy through Terraform or Kubernetes resources, the Controller
distributes it, and audit, visibility, and AI-assisted questions come back out.
![Security operations automation architecture: Terraform with multiwriter policy and Kubernetes custom resources in GitOps write policy to the Aviatrix Controller, which distributes Distributed Cloud Firewall rules to gateways, records a policy audit trail, and exposes topology and flows in CoPilot, which an AI assistant can query, mostly read-only, through the Aviatrix MCP server.](https://mintcdn.com/aviatrix-14b37c43/fGohijthCmM99wVL/images/solutions/security-automation/security-automation-architecture.png?fit=max\&auto=format\&n=fGohijthCmM99wVL\&q=85\&s=a92a251fff4244f0b08f5c9fcd2dc7f6)
*Terraform and Kubernetes resources write policy, and audit, CoPilot, and MCP
return the results.*
### Manage Policy With Terraform
The Aviatrix Terraform provider manages SmartGroups, WebGroups, and Distributed
Cloud Firewall (DCF) rules. Multiwriter policy lets several Terraform
configurations or teams own separate policy groups in the same ruleset, so a
platform team and an application team can each manage their part.
### Use GitOps for Kubernetes
The `FirewallPolicy` and `WebgroupPolicy` custom resources let application teams
declare egress policy next to their workloads. Kubernetes RBAC, Git review, and
admission policy engines control and validate those changes.
### Audit Every Change
DCF policy audit records changes to policy objects and shows what changed. You
can use it to review rollouts or demonstrate change control.
### Ask Questions With MCP
The Aviatrix MCP server for enterprise fabrics gives an MCP-capable assistant
access to Aviatrix Controller and CoPilot information, so you can ask about
topology, policy, and status in natural language. Almost all of its tools are
read-only, and the few that change state need write permission. A separate MCP
server serves Aviatrix documentation to your assistant.
## Key Components
> [card] [Terraform Provider](https://docs.aviatrix.com/docs/enterprise/10.0/reference/terraform/provider.md)
> Declares SmartGroups, WebGroups, and DCF rules as code.
> [card] [Multiwriter Policy](https://docs.aviatrix.com/docs/enterprise/10.0/guides/security/dcf/multiwriter-policy-terraform.md)
> Lets several teams own separate sections of DCF policy.
> [card] [CoPilot](https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/components/controlplane/copilot-overview.md)
> Shows topology, flow visibility, and the audit view of policy changes.
> [card] [MCP for Enterprise Fabrics](https://docs.aviatrix.com/docs/enterprise/10.0/solutions/ai-agent-integrations/mcp-for-enterprise-fabrics.md)
> Gives natural-language access to Aviatrix Controller and CoPilot data.
## Related Documentation
Use these documents to plan and implement security automation.
### Configuration Guides
* [Multiwriter Policy With Terraform](https://docs.aviatrix.com/docs/enterprise/10.0/guides/security/dcf/multiwriter-policy-terraform.md)
  — split policy ownership across teams.
* [DCF Policy Audit](https://docs.aviatrix.com/docs/enterprise/10.0/guides/security/dcf/policy-audit.md)
  — review the history of policy changes.
* [MCP for Enterprise Fabrics](https://docs.aviatrix.com/docs/enterprise/10.0/solutions/ai-agent-integrations/mcp-for-enterprise-fabrics.md)
  — connect an assistant to your Controller and CoPilot. Confirm the tools
  available for your Controller version before you rely on them in a runbook.
* [MCP for Aviatrix Docs](https://docs.aviatrix.com/docs/enterprise/10.0/solutions/ai-agent-integrations/mcp-for-docs.md)
  — give your assistant access to Aviatrix documentation.
### Reference
* [Terraform Provider](https://docs.aviatrix.com/docs/enterprise/10.0/reference/terraform/provider.md)
  — resources and data sources.
* [Kubernetes CRD Reference](https://docs.aviatrix.com/docs/enterprise/10.0/reference/dcf/kubernetes-crd-reference.md)
  — fields, RBAC, and GitOps guidance.
* [MCP Suggested Use Cases](https://docs.aviatrix.com/docs/enterprise/10.0/solutions/ai-agent-integrations/mcp-suggested-use-cases.md)
  — example prompts for operations and troubleshooting.
