# Configuring Distributed Cloud Firewall
> This section describes the Distributed Cloud Firewall (DCF) functional area of Aviatrix CoPilot.
Aviatrix CoPilot.
## DCF Constraints
* For any VNets that have Security Group Orchestration applied, and that are
  included in a rule that is not enforced, the application security group (ASG)
  in the network security group (NSG) rule remains associated with the VM even
  though the NSG rule using the ASG is not present.
* Logging can consume a large amount of disk space. You can
  [manage disk space settings](https://docs.aviatrix.com/docs/enterprise/10.0/guides/controlplane/disk-management.md#monitor-data-disk-volume-utilization)
  and
  [retention settings](https://docs.aviatrix.com/docs/enterprise/10.0/guides/controlplane/disk-management.md#data-retention)
  . You can also configure how long to keep your [Distributed Cloud Firewall
  logs](https://legacy.docs.aviatrix.com/documentation/latest/security/dcf-log-files.html?expand=true).
* A SmartGroup traffic flow can belong to more than one rule. If this occurs,
  the priority of the rule determines the action that is taken first.
* DCF rules with WebGroups ([Layer 7 (L7)](https://docs.aviatrix.com/docs/enterprise/10.0/reference/general/general-glossary.md)) do not support
  asymmetric traffic.
* If there are cases where egress and east-west traffic DCF rules may overlap,
  [Layer 4 (L4)](https://docs.aviatrix.com/docs/enterprise/10.0/reference/general/general-glossary.md)
  rules should have a higher priority than L7 (WebGroups-based) rules.
* DCF on Edge does not support
  [hostname filtering](https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/components/dcf/hostname-smartgroups-about.md)
  , L7 filtering,
  [SNI-based filtering](https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/components/dcf/webgroups-about.md)
  , or DNS reachability. If you want to filter traffic for DCF on Edge, you must
  use SmartGroups or the Domain feature of WebGroups.
* After you disable Source NAT or delete a DCF rule with
  [Local Egress](https://docs.aviatrix.com/docs/enterprise/10.0/guides/security/egress/egress-enabling-local.md)
  enabled, the gateway does not clean up the associated local egress routing
  state. This residual state does not affect traffic as long as no Local Egress
  rule applies to the gateway. However, if a Local Egress rule applies to a
  Spoke gateway that does not have Source NAT enabled, or that is running a
  gateway image earlier than Controller 10.1, traffic that matches the rule is
  blackholed instead of falling back to centralized routing. A bell notification
  and log trace are generated so that you can identify and correct the gateway
  configuration.
## Distributed Cloud Firewall Prerequisites
Before applying Distributed Cloud Firewall (DCF):
* [Enable the DCF feature](#enabling-the-distributed-cloud-firewall-feature).
* Ensure that DCF is
  [enforced on your cloud accounts and/or Edge](https://docs.aviatrix.com/docs/enterprise/10.0/guides/security/dcf/dcf-settings.md)
  . You will be able to create DCF rules for non-enforced clouds, but they will
  not be applied to the gateways in those clouds until those clouds are
  enforced.
* Your version of CoPilot must be 2.0 or greater.
* Your version of Aviatrix Controller must be 6.7 or greater.
* Gateways must have their image updated to version 6.7 or greater.
* Network reachability should be configured between the VPCs that contain
  applications that require connectivity. You configure network reachability
  using
  [Connected Transit/MCNS](https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/components/connectivity/activemesh-about.md)
* Enable SNAT on the Spoke gateways enforcing Egress filtering.
* If you plan to use Cloud Tags in your SmartGroups, Cloud resources must be
  tagged appropriately.
* Create the following groups, if you want to use them in your Distributed Cloud
  Firewall configuration:
  * [SmartGroups](https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/components/dcf/smartgroups-about.md)
  * [WebGroups](https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/components/dcf/webgroups-about.md)
    > [!NOTE]
    > If you select a WebGroup when creating a rule, the Destination Group must
    > be 'Public Internet'. Any Spoke gateways that are part of the Source Group
    > must contain a VPC/VNet Resource Type that has Local Egress enabled (Spoke
    > gateway).
  * [ExternalGroups](https://docs.aviatrix.com/docs/enterprise/10.0/reference/externalgroup-about.md)
### Intrusion Detection
If you plan to enable Intrusion Detection in a Distributed Cloud Firewall
policy, remember:
* IDS cannot be applied to east-west traffic if HA VPC/VNets are being used.
* IDS can work with HA for egress traffic.
## Distributed Cloud Firewall Setup and Default Action Rule
Distributed Cloud Firewall (DCF) enforces zero trust access control between
groups of resources in your network. This document focuses on enabling the DCF
feature and configuring the Default Action Rule, which controls traffic handling
in the absence of explicit rules.
> [!NOTE]
> If you configured the ThreatIQ and/or Geoblocking features prior to Controller
> version 7.2.4820, in 7.2.4820 you automatically receive a free Distributed
> Cloud Firewall (DCF) license. If you did not configure the ThreatIQ and/or
> Geoblocking features prior to Controller version 7.2.4820, you are expected to
> purchase a DCF license. This will include the ExternalGroup feature (replaces
> the ThreatIQ and Geoblocking features).
### Enabling the Distributed Cloud Firewall Feature
Enabling the Distributed Cloud Firewall feature allows you to create and manage
rules, rulesets, and policies to enforce zero trust principles.
> [!NOTE]
> If you enabled Distributed Cloud Firewall in a previous Controller version,
> you do not need to enable it again.
To enable the Distributed Cloud Firewall (DCF) feature, if it is not enabled
already:
1. Go to the Security > Distributed Cloud Firewall > Policies tab.
2. Click **Begin Using Distributed Cloud Firewall**.
3. Click **Begin** again to confirm the action and enable the feature.
### Default Action Rule for Distributed Cloud Firewall
> [!NOTE]
> Starting with Controller version 8.1, the Default Action Rule is automatically
> created when DCF is enabled. Legacy rules such as Greenfield and
> DefaultDenyAll are no longer generated; the Default Action Rule replaces their
> function. The Default Action Rule cannot be deleted. When you upgrade to
> Controller 8.1 or earlier, the existing DefaultDenyAll rule is converted to a
> non-system rule, which you can delete. If you use Controller 8.0 or earlier,
> both a [Greenfield Rule and a DefaultDenyAll
> rule](#greenfield-rule-and-defaultdenyall-rule) are deleted.
After enabling the Distributed Cloud Firewall feature, a Default Action Rule is
created. This is a system rule used to enforce
[zero trust principles](https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/components/dcf/dcf-zero-trust.md)
by controlling how traffic is handled in the absence of explicit rules. This
rule must be set to Deny after it is created, to ensure that traffic is not
permitted by default. The action of the Default Action Rule is enforced globally
and is evaluated after all user-defined and system-defined rules/rulesets.
> [!NOTE]
> You may see the Manage Rules Better with Rulesets splash screen when you first
> access the Policies tab. If so, click **Acknowledge** to continue.
#### New DCF Users
1. On the Security > Distributed Cloud Firewall > Policies tab, click **Begin
2. You may have to click **Begin** again to confirm the action. This Default
   Action Rule is then created on the Policies tab in the User Ruleset (formerly
   the V1 Policy List ruleset).
![60%](https://mintcdn.com/aviatrix-14b37c43/qERZ79zkW46BYFbv/images/reference/dcf/greenfield-default-action.png?fit=max\&auto=format\&n=qERZ79zkW46BYFbv\&q=85\&s=8bdedca2a89d059e7deebdda037ab65d)
3. Change the action of the Default Action Rule to **Deny**. This is mandatory.
4. Continue with creating DCF rulesets and rules.
#### Existing DCF Users
   **Acknowledge** on the splash screen that informs you about the Default
   Action Rule.
2. The Default Action Rule is displayed on the Policies tab in the V1 Policy
   List ruleset. The Default Action Rule replaces the pre-existing
   DefaultDenyAll rule, if you used the DCF feature prior to Controller 8.1. You
   can delete the old DefaultDenyAll rule if it exists.
![Default Action Rule](https://mintcdn.com/aviatrix-14b37c43/qERZ79zkW46BYFbv/images/reference/dcf/brownfield-default-rule.png?fit=max\&auto=format\&n=qERZ79zkW46BYFbv\&q=85\&s=cf8ed9dc37d3dabeab3691ed7024aa90)
4. You can delete the pre-existing Greenfield-Rule if it exists, assuming that
   you have reviewed traffic patterns first.
#### Modifying the Default Action Rule
You can do the following to the Default Action Rule:
* Change the action from Permit to Deny
* Change the name of the rule
* Enable logging
### Greenfield Rule and DefaultDenyAll Rule
In Controller 8.0 and lower, the placeholder Greenfield Rule prevents traffic
from being dropped before you start configuring the rest of your rules. After
you create additional rules you can move the Greenfield Rule where needed in
your rule priority list. You can edit or delete the Greenfield Rule later, if
desired.
> [!NOTE]
> The Greenfield Rule is only enforced on gateways, and not on Security Groups
> in the cloud.
By default (if you selected the recommended **Permit All Traffic** option), the
Greenfield Rule has the following attributes:
* Source/Destination Groups: Anywhere (0.0.0.0/0)
* Protocol: Any
* Action: Permit
* Logging: On
The DefaultDenyAll Rule blocks traffic to any CIDR covered in Distributed Cloud
Firewall rules. This rule is not editable.
### DCF-Related Features
If the Distributed Cloud Firewall feature is enabled, these features are
available:
* Enforcement on PSF Gateways
* Enforcement on External Connections
* Enforcement on Transit Egress
You must enable these features from the Security > Distributed Cloud Firewall >
Settings tab. With these features, you can enforce
[DCF on PSF Gateways](https://docs.aviatrix.com/docs/enterprise/10.0/reference/dcf/dcf-psf.md)
[External Connections](https://docs.aviatrix.com/docs/enterprise/10.0/guides/security/dcf/dcf-settings.md#enforcement-on-external-connections)
, or
[Transit Egress gateways](https://docs.aviatrix.com/docs/enterprise/10.0/reference/dcf/dcf-transit-egress.md)
* [DCF on Kubernetes Clusters](https://docs.aviatrix.com/docs/enterprise/10.0/guides/security/dcf/dcf-kubernetes.md)
  from the Feature Previews list. To use this feature, you must enable it from
  the
  [Discovery of Kubernetes Resources](https://docs.aviatrix.com/docs/enterprise/10.0/guides/security/dcf/kubernetes-resource-discovery.md)
  card on the Groups > Settings tab.
## Creating Groups for Distributed Cloud Firewall
### SmartGroups
A Distributed Cloud Firewall (DCF) SmartGroup contains one or more filters to
identify cloud endpoints that map to an app domain. A filter specifies resource
matching criteria. Matching criteria could be a cloud tag; a resource attribute
(such as account name or region); a list of IP prefixes; or a Site2Cloud
external connection. All conditions within the filter must be satisfied to be
matched. A tag or resource attribute-based filter must be associated with a
resource type (VPC/VNet, subnet, or VM).
[Creating SmartGroups](https://docs.aviatrix.com/docs/enterprise/10.0/reference/ui/groups/index.md#create-smartgroup)
### WebGroups
A DCF WebGroup contains one or more domain names or URLs that assists in
filtering (and providing security to) Internet-bound traffic.
[Creating WebGroups](https://docs.aviatrix.com/docs/enterprise/10.0/reference/ui/groups/index.md#create-web-group)
### ExternalGroups
An ExternalGroup can contain countries, threat feeds, and SaaS-based services
(Azure and GitHub).
[Managing the Relationship Between Feeds and ExternalGroups](https://docs.aviatrix.com/docs/enterprise/10.0/reference/ui/groups/index.md#create-external-group)
## Creating Distributed Cloud Firewall Rules
After [creating your groups](#creating-groups-for-distributed-cloud-firewall),
you create Distributed Cloud Firewall (DCF) rules within one of the
system-defined rulesets to define the access control to apply on the traffic
between those groups.
If your SmartGroups contain Spoke Gateways, ensure that those Spoke Gateways
have
[Egress enabled](https://docs.aviatrix.com/docs/enterprise/10.0/guides/security/egress/egress-enabling-local.md)
If you have upgraded to Controller 8.0, you can use the **Policies** tab to
create and manage DCF rulesets.
![microseg policies](https://mintcdn.com/aviatrix-14b37c43/qERZ79zkW46BYFbv/images/reference/dcf/microseg-policies.png?fit=max\&auto=format\&n=qERZ79zkW46BYFbv\&q=85\&s=245a87e6456154c21d28d4344e0ce099)
For example, in the
[workload isolation use case](https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/components/dcf/smartgroup-use-cases.md)
, all traffic (e.g., ports and protocols) between the ShoppingCart application
and the Product Logging app must be blocked (Denied). You can decide which
policies to enforce, and if you want to log the actions related to a rule. These
rules are enforced (if enabled) on your Spoke gateways, and are executed against
the Spoke gateways in the order that they are shown in the rule list.
Creating a rule for the workload isolation use case would resemble the
following:
* Source Group: Shopping Cart application
* Destination Group: Product Logging app
* Action: Deny
* Protocol: Any
* Ports: 0-65535 (Any)
* Logging: Off
* Enforcement: On
1. In CoPilot, go to Security > Distributed Cloud Firewall > Policies.
2. Select a ruleset from the Ruleset list.
3. Click **+ Rule**. The Create Rule dialog displays.
![40%](https://mintcdn.com/aviatrix-14b37c43/qERZ79zkW46BYFbv/images/reference/dcf/dcf-create-rule2.png?fit=max\&auto=format\&n=qERZ79zkW46BYFbv\&q=85\&s=5c6863d54e6af6ac24971e241cbb28ae)
4. Use the
   [Distributed Cloud Firewall Field Reference](https://legacy.docs.aviatrix.com/documentation/latest/security/dcf-rule-dialog-reference.html)
   to create your rule.
If the Rule Behavior Action is Deny, the **SNI Verification** toggle is not
displayed.
The **SNI Verification** feature is only available with Controller 8.0.
### Tips for Rule Creation
* Always specify the port and protocol for HTTP/TLS or non-HTTP/TLS when the
  domain names overlap.
* Or, you can prioritize HTTP/TLS rules in the DCF Rules list (but this means
  that non-TLS/HTTP traffic will always be pulled through the web proxy).
* Save any changes on the Policies tab (changes to logging or enforcement)
  before switching to another ruleset.
* When configuring TLS Decryption in DCF, note that while the configuration is
  applied per rule, its operation is global. Once a connection is decrypted to
  check a URL filter, it remains decrypted even if it does not match that rule's
  filter. The connection may match a later rule without decryption requirements,
  but it will already be decrypted due to the earlier rule. Therefore, carefully
  consider the placement of rules requiring decryption.
### Viewing DCF Rule Details
You can click a DCF rule on the Security > Distributed Cloud Firewall > Policies
tab to view its configuration details, source and destination entities, and
statistics in the right-hand pane.
![dcf rule details](https://mintcdn.com/aviatrix-14b37c43/qERZ79zkW46BYFbv/images/reference/dcf/dcf-rule-details.png?fit=max\&auto=format\&n=qERZ79zkW46BYFbv\&q=85\&s=364522215ab324715577e75265553fe1)
The Groups tab in the details pane shows the Source Entities, Destination
Entities, and WebGroups used in the rule. The Statistics tab shows the number of
hits for the rule, and the last time it was hit.
## Related Topics
* [Disabling the Distributed Cloud Firewall Feature](https://docs.aviatrix.com/docs/enterprise/10.0/guides/security/dcf/dcf-disable-feature.md)
* [Editing a Distributed Cloud Firewall Rule](https://legacy.docs.aviatrix.com/documentation/latest/security/dcf-rule-edit.html)
* [Deleting a Distributed Cloud Firewall Rule](https://legacy.docs.aviatrix.com/documentation/latest/security/dcf-rule-delete.html)
* [DCF Actions](https://docs.aviatrix.com/docs/enterprise/10.0/reference/ui/security/distributed-cloud-firewall.md#manage-policy-enforcement-and-logging)
