# Distributed Cloud Firewall Supported Capabilities
> Since Controller Version 6.8, DCF has been supported in AWS, AWS GovCloud, Azure, Azure Government, and GCP.
## Ranges
| Capability | 6.8 | 6.9 | 7.0 | 7.1 | 7.2 | 8.0 | 8.1 | 8.2 | 9.0 | 10.0 |
| Number of SmartGroups | 500 | 500 | 500 | 500 | 1,200 | 1,200 | 1,200 | 1,200 | 1,200 | 1,200 |
| Number of Domains per WebGroup | | | | 3,000 | 3,000 | 3,000 | 3,000 | 3,000 | 3,000 | 3,000 |
| Number of CIDRs per Group | 3,000 | 3,000 | 3,000 | 3,000 | 10,000 | 10,000 | 10,000 | 10,000 | 10,000 | 10,000 |
| Total Number of CIDRs | | | 10,000 | 10,000 | 300,000 | 300,000 | 300,000 | 300,000 | 300,000 | 300,000 |
| Number of DCF Rules | 2,000 | 2,000 | 2,000 | 2,000 | 5,000 | 5,000 | 5,000 | 5,000 | 5,000 | 5,000 |
## Supported Features
The following are supported on AWS, Azure and GCP unless otherwise noted.
* PV = feature is in
  [Preview](https://docs.aviatrix.com/docs/enterprise/10.0/reference/feature-modes/index.md#preview-features)
* EA = feature is in
  [Early Access](https://docs.aviatrix.com/docs/enterprise/10.0/reference/feature-modes/index.md#early-access-ea-features)
* GA = feature is
  [Generally Available](https://docs.aviatrix.com/docs/enterprise/10.0/reference/feature-modes/index.md#general-availability-ga-features)
* If a cell is blank the feature was not supported in that release.
| Feature | 6.8 | 6.9 | 7.0 | 7.1 | 7.2 | 8.0 | 8.1 | 8.2 | 9.0 |
| DCF on Edge Spoke (L4) | | | | | | | PV | PV | PV |
| DCF on Edge Spoke (L7) | | | | | | | | | PV |
| DCF on Edge Transit S2C (L4) | | | | | | | PV | PV | PV |
| DCF on Serverless | | | | | | | | | EA (AWS) |
| **DCF Rules** | | | | | | | | | |
| Layer 4 Rules | | GA | GA | GA | GA | GA | GA | | |
| Rules with Domain (SNI) WebGroups | | | PV | GA | GA | GA | GA | | |
| Rules with URL WebGroups | | | PV | PV | PV | PV | PV | PV | GA |
| Rules with ExternalGroups (formerly GeoGroups and ThreatGroups) | | | | | GA | GA | GA | | |
| DCF on Public Subnet Filtering Gateways | | | | | PV | PV | GA (AWS) | | |
| DCF on Site2Cloud (L4 only on Transit) | | | | | PV | PV | GA (AWS/AWS Gov Cloud/Azure/Azure Gov) PV (GCP/OCI) | GA (AWS/AWS Gov Cloud/Azure/Azure Gov) PV (GCP/OCI) | |
| DCF on Transit Egress | | | | | | | PV | PV | GA |
| [Security Group Orchestration](https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/components/dcf/security-group-orchestration.md) (not supported on GCP) | | | PV (Azure) | PV (Azure, AWS) | PV (AWS) GA (Azure) | PV (AWS) GA (Azure) | PV (AWS) GA (Azure) | PV (AWS) GA (Azure) | PV (AWS) GA (Azure) |
| [DCF Rulesets](https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/components/dcf/dcf-rulesets-about.md) | | | | | | GA | GA | | |
| **Deep Packet Inspection** | | | | | | | | | |
| Transparent TLS Decryption | | | | PV | PV | PV | PV | PV | GA |
| Suricata IDS (Egress only) | | | | PV | PV | PV | PV | PV | GA |
| Suricata IPS (Egress Only) | | | | | | | | PV | GA |
| **Advanced Features** | | | | | | | | | |
| IPS Custom Signatures/Feed | | | | | | | | PV | GA |
| Import Decryption Certificate | | | PV | PV | PV | PV | PV | PV | GA |
| **Logging** | | | | | | | | | |
| Layer 4 logging (+Domain) | | | GA | GA | GA | GA | GA | | |
| IDS/IPS logging | | | PV | PV | PV | PV | PV | PV | GA |
| Log export via Syslog | | | GA | GA | GA | GA | GA | | |
| **Asset Groups/SmartGroups** | | | | | | | | | |
| SmartGroups (VM/VPC/Subnet) | | GA | GA | GA | GA | GA | GA | | |
| DNS Hostname SmartGroups | | | | | PV | PV | GA | | |
| Kubernetes SmartGroups (Workloads and Nodes) | | | | | | | PV | PV | PV |
| Domain WebGroups | | | PV | GA | GA | GA | GA | | |
| SNI Verification (valid with WebGroups) | | | | | | PV | PV | PV | GA |
| ExternalGroups (includes Threat Feeds and Countries) | | | | | PV | PV | GA | | |
| SmartGroups (S2C) | | | | | GA | GA | GA | | |
| [SaaS-Based Services](https://docs.aviatrix.com/docs/enterprise/10.0/reference/externalgroup-about.md) (Azure and GitHub) | | | | | | PV | Azure (GA) GitHub (PV) | Azure (GA) GitHub (PV) | Azure (GA) GitHub (GA) |
## Additional Capabilities
* Overlapping IPs have been supported since Controller Version 7.0. Distributed
  Cloud Firewall (DCF) understands any defined SNAT/DNAT rules and updates the
  address for each gateway, enforcing the DCF rules.
* DCF auto-prunes all rules and pushes only related rules to specific gateways.
* SmartGroups dynamically change the resources inside the groups by tracking EC2
  changes (AWS, Azure, GCP).
> [!NOTE]
> Shared VPC instance tags are not supported in GCP-based SmartGroups.
* Log Export to Splunk HTTP Event Collector
