# Deploy an Edge Transit Gateway on Megaport Virtual Edge
> This document provides instructions to deploy a primary Edge Transit Gateway on Megaport Virtual Edge (MVE).
For an overview of Aviatrix Edge, see [About Aviatrix
Hybrid Cloud Edge](https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/components/edge-gateways/edge-overview.md).
## Topology
![eat-equinix-megaport-topology.png](https://mintcdn.com/aviatrix-14b37c43/DtLW-mqMRi95qZN9/images/guides/connectivity/edge/eat-equinix-megaport-topology.png?fit=max\&auto=format\&n=DtLW-mqMRi95qZN9\&q=85\&s=3f95f255590679c73d4d52de762cfbe7)
## Prerequisites
Before you deploy an Edge Transit Gateway on the Megaport platform, ensure the
[prerequisite steps](https://docs.aviatrix.com/docs/enterprise/10.0/reference/gateways/edge/edge-spoke-transit-planning.md#megaport)
are complete.
## Deploy the Primary Edge Transit Gateway (Megaport)
To create and deploy the primary Edge Transit Gateway in Megaport Virtual Edge
(MVE), first you need to generate the cloud-init file in CoPilot, then deploy
the Edge gateway in MVE using the cloud-init file:
1. [Create the Primary Edge Transit Gateway cloud-init ZTP file](https://legacy.docs.aviatrix.com/documentation/latest/network/edge-transit-create-megaport.html).
2. [Deploy the Edge Transit Gateway in MVE using the cloud-init ZTP file](https://legacy.docs.aviatrix.com/documentation/latest/network/edge-vm-create-megaport.html).
3. [Verify the Edge Transit Gateway creation](https://legacy.docs.aviatrix.com/documentation/latest/network/edge-gateway-verify.html).
## Next Steps
* For high availability (HA) and redundancy, you can create and deploy HA Edge
  Transit Gateway. See
  [Deploy a HA Edge Transit Gateway (Megaport)](https://legacy.docs.aviatrix.com/documentation/latest/network/edge-transit-ha-create-megaport.html).
  Transit Gateway to multiple Aviatrix gateways. See [Edge Gateway
  Attachments](https://docs.aviatrix.com/docs/enterprise/10.0/guides/connectivity/gateways/edge-gateway-attachments.md).
* For remote site connectivity, you can connect the Edge Transit Gateway to
  remote devices. See [Edge Gateway External Connection](https://docs.aviatrix.com/docs/enterprise/10.0/guides/connectivity/gateways/edge-s2c.md).
