# Edge Spoke Gateway Horizontal Scaling
> This document provides a brief overview of Aviatrix Edge Spoke Gateway horizontal scaling.
horizontal scaling.
> [!NOTE]
> Edge Spoke Gateway horizontal scaling is supported only with the latest
> version of the Aviatrix Controller.
Edge Spoke Gateway horizontal scaling provides you the flexibility to add or
remove gateways to plan for capacity during peak times to ensure high
availability and improve and maintain network stability and performance.
Horizontal scaling requires all Edge Spoke Gateways in an
[edge site](https://legacy.docs.aviatrix.com/documentation/latest/network/edge-spoke-settings.html)
to be deployed in *active-active* mode. A maximum of eight Edge Spoke Gateway
instances are supported per site.
Edge Spoke Gateways can be scaled horizontally and peered to the Transit Gateway
or Edge Transit Gateways across single or multiple clouds and regions. The Edge
Spoke Gateways connects to the Transit Gateways and Edge Transit Gateways with
active peering connections. Network traffic between the Transit Gateways and
Edge Spoke Gateways or between Edge Transit Gateways and Edge Spoke Gateways is
load balanced and forwarded across all active peering connections by using Equal
Cost Multi Path (ECMP) routing.
The following figure shows multiple Edge Spoke Gateways deployed in the same
edge site for horizontal scaling with multiple active-active high availability
connections for multicloud to edge connectivity.
![Diagram showing Edge Spoke Gateway horizontal scaling with multicloud to edge connectivity](https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-horizontal-scale.png?fit=max\&auto=format\&n=8iF92JcVck-Y3RaJ\&q=85\&s=d28496a6a9c4b3af0d1349cf2987d1ba)
The following example shows an Edge configuration in CoPilot for horizontal
scaling with Edge Spoke Gateway instances for the same edge site in
*active-active high availability mode*.
![Edge configuration in CoPilot showing horizontal scaling with Edge Spoke Gateway instances in active-active high availability mode](https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-ha.png?fit=max\&auto=format\&n=8iF92JcVck-Y3RaJ\&q=85\&s=af0ac788efd6b946f39aa091d111f5d2)
When a high availability mode is not selected, Edge Spoke Gateways deployed in
the same edge site default to active-active mode.
scaling with Edge Spoke Gateway instances in *active-active* mode (no HA) for
the same edge site.
![Edge configuration in CoPilot showing horizontal scaling with Edge Spoke Gateway instances in active-active mode without HA](https://mintcdn.com/aviatrix-14b37c43/8iF92JcVck-Y3RaJ/images/concepts-architectures/architecture/connectivity/edge-spoke-scaling-no-ha.png?fit=max\&auto=format\&n=8iF92JcVck-Y3RaJ\&q=85\&s=85d9c37681f06579236a31e98fadbfa4)
For more information about creating HA Edge Gateways, see [About
Creating Highly Available Edge Gateways](https://docs.aviatrix.com/docs/enterprise/10.0/concepts-architectures/architecture/connectivity/edge-spoke-ha.md).
